I’m having a small but annoying issue with KDE Network Manager on my old laptop, when I’m connected to my home network KDE Network Manager keeps giving me an exclamation mark over the Wi-Fi icon prompting that there’s an issue, only thing is that there are no issues, and I’'m connected to the Wi-Fi network just fine, however it will say the following;
Wi-Fi: Connected to <network_name> (log in required)
I have no captive portals for my network or any kind of special requirements to login, its just enter the password for the BSSID of my network and you’re done. but here it’s trying to prompt me for a Captive Portal Login for no explicit reason, I did go to Settings > Notifications and turned off Captive Portal Notifications but this message/warning still doesn’t go away. This issue has only just recently started popping up, and its pretty annoying.
It will even show me a popup notification saying Click here to login
taking me to the KDE Captive Portal page → networkcheck.kde.org and it says OK on the page. How can I disable this Captive Portal notification completely? Because clearly turning off the notification in settings didn’t do anything, or at the very least is there a hidden setting somewhere to tell the network manager that this connection doesn’t require captive portal to login?
