KDE black screen with cursor after suspend
After suspend my couple of weeks old Manjaro KDE install resumes to a black screen with the cursor. I'm using dual monitors, other specs are listed in the inxi output below.
How to reproduce:
  1. Go to sleep either with:
    • launch menu 'Sleep' entry
    • systemctl suspend
    • dbus: "qdbus --system org.freedesktop.login1 /org/freedesktop/login1 org.freedesktop.login1.Manager.Suspend true"
  2. Wake from sleep.
Only way to recover has been to press CTRL+ALT+BACKSPACE, after which the login screen finally loads.
Trying to login via TTY (ctrl+alt+2) and restarting plasmashell or replacing kwin_x11 both fail. The error I get by trying to restart plasmashell is:
qt.qpa.xcb: could not connect to display
qt.qpa.plugin: Could not load the Qt platform plugin "xcb" in "" even though it was found.
This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Available platform plugins are: wayland-org.kde.kwin.qpa, eglfs, linuxfb, minimal, minimalegl, offscreen, vnc, xcb.
Plasma theme is currently Breeze Dark, it was Breeze Transparent Dark for a time and changing back to regular Dark hasn't helped.
Here's my inxi -Fxzc0 output:
 henri@henri-amd  ~  inxi -Fxzc0
System:    Host: henri-amd Kernel: 5.2.10-1-MANJARO x86_64 bits: 64 compiler: gcc v: 9.1.0 Desktop: KDE Plasma 5.16.4
           Distro: Manjaro Linux
Machine:   Type: Desktop Mobo: ASUSTeK model: ROG STRIX X570-E GAMING v: Rev X.0x serial: <filter> UEFI: American Megatrends
           v: 1005 date: 08/01/2019
CPU:       Topology: 12-Core model: AMD Ryzen 9 3900X bits: 64 type: MT MCP arch: Zen L2 cache: 6144 KiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 182139
           Speed: 3532 MHz min/max: 2200/3800 MHz Core speeds (MHz): 1: 3933 2: 2053 3: 2792 4: 2793 5: 4072 6: 1915 7: 2030
           8: 2794 9: 2793 10: 1863 11: 2196 12: 2196 13: 2044 14: 2195 15: 1863 16: 2794 17: 2794 18: 2794 19: 2795 20: 1862
           21: 2196 22: 2195 23: 2196 24: 1862
Graphics:  Device-1: NVIDIA GP102 [GeForce GTX 1080 Ti] vendor: ASUSTeK driver: nvidia v: 430.40 bus ID: 0b:00.0
           Display: x11 server: X.Org 1.20.5 driver: nvidia resolution: 2560x1440~60Hz, 3840x2160~60Hz
           OpenGL: renderer: GeForce GTX 1080 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 430.40 direct render: Yes
Audio:     Device-1: Creative Labs Sound Core3D [Sound Blaster Recon3D / Z-Series] driver: snd_hda_intel v: kernel
           bus ID: 04:00.0
           Device-2: NVIDIA GP102 HDMI Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel bus ID: 0b:00.1
           Device-3: Advanced Micro Devices [AMD] Starship/Matisse HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
           bus ID: 0d:00.4
           Sound Server: ALSA v: k5.2.10-1-MANJARO
Network:   Device-1: Intel driver: iwlwifi v: kernel port: N/A bus ID: 05:00.0
           IF: wlp5s0 state: down mac: <filter>
           Device-2: Realtek vendor: ASUSTeK driver: N/A port: e000 bus ID: 06:00.0
           Device-3: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: 5.6.0-k port: d000 bus ID: 07:00.0
           IF: enp7s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Drives:    Local Storage: total: 2.73 TiB used: 929.65 GiB (33.3%)
           ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO Plus 1TB size: 931.51 GiB
           ID-2: /dev/sda vendor: Samsung model: SSD 850 EVO 500GB size: 465.76 GiB
           ID-3: /dev/sdb vendor: Samsung model: SSD 860 EVO 1TB size: 931.51 GiB
           ID-4: /dev/sdc vendor: Samsung model: SSD 850 EVO 500GB size: 465.76 GiB
Partition: ID-1: / size: 483.34 GiB used: 21.57 GiB (4.5%) fs: ext4 dev: /dev/nvme0n1p5
Sensors:   System Temperatures: cpu: 58.6 C mobo: N/A gpu: nvidia temp: 55 C
           Fan Speeds (RPM): cpu: 0 gpu: nvidia fan: 0%
Info:      Processes: 437 Uptime: 2h 20m Memory: 31.39 GiB used: 2.79 GiB (8.9%) Init: systemd Compilers: gcc: 9.1.0
           Shell: zsh v: 5.7.1 inxi: 3.0.36
Here's the tail of dmesg output:
[ 1002.111639] PM: suspend entry (deep)
[ 1002.119374] Filesystems sync: 0.007 seconds
[ 1002.897831] Freezing user space processes ... (elapsed 0.001 seconds) done.
[ 1002.899573] OOM killer disabled.
[ 1002.899573] Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
[ 1002.900767] printk: Suspending console(s) (use no_console_suspend to debug)
[ 1002.926727] sd 1:0:0:0: [sda] Synchronizing SCSI cache
[ 1002.929844] sd 1:0:0:0: [sda] Stopping disk
[ 1002.929891] sd 3:0:0:0: [sdb] Synchronizing SCSI cache
[ 1002.929959] sd 8:0:0:0: [sdc] Synchronizing SCSI cache
[ 1002.932605] sd 8:0:0:0: [sdc] Stopping disk
[ 1002.932783] sd 3:0:0:0: [sdb] Stopping disk
[ 1002.973064] WARNING: CPU: 20 PID: 4426 at kernel/irq/chip.c:210 irq_startup+0xe3/0xf0
[ 1002.973065] Modules linked in: cmac edac_mce_amd fuse rfcomm bnep btusb btrtl btbcm btintel bluetooth mousedev joydev input_leds ecdh_generic ecc snd_hda_codec_hdmi arc4 squashfs loop nls_iso8859_1 nls_cp437 vfat fat iwlmvm kvm mac80211 irqbypass iwlwifi snd_hda_codec_realtek snd_hda_codec_generic crct10dif_pclmul eeepc_wmi snd_hda_codec_ca0132 asus_wmi crc32_pclmul ledtrig_audio wmi_bmof sparse_keymap mxm_wmi ghash_clmulni_intel cfg80211 uinput snd_hda_intel nvidia_drm(POE) nvidia_modeset(POE) snd_hda_codec drm_kms_helper snd_hda_core igb aesni_intel snd_hwdep snd_pcm snd_timer aes_x86_64 crypto_simd sp5100_tco ccp snd cryptd i2c_piix4 pcspkr k10temp i2c_algo_bit glue_helper rng_core soundcore rfkill dca drm agpgart syscopyarea wmi sysfillrect sysimgblt pinctrl_amd evdev fb_sys_fops mac_hid pcc_cpufreq acpi_cpufreq nvidia(POE) ipmi_devintf ipmi_msghandler crypto_user ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 hid_generic usbhid hid sd_mod ahci libahci libata xhci_pci
[ 1002.973105]  crc32c_intel scsi_mod xhci_hcd
[ 1002.973109] CPU: 20 PID: 4426 Comm: kworker/u64:34 Tainted: P           OE     5.2.10-1-MANJARO #1
[ 1002.973110] Hardware name: System manufacturer System Product Name/ROG STRIX X570-E GAMING, BIOS 1005 08/01/2019
[ 1002.973113] Workqueue: events_unbound async_run_entry_fn
[ 1002.973115] RIP: 0010:irq_startup+0xe3/0xf0
[ 1002.973117] Code: e8 d2 41 00 00 85 c0 0f 85 76 0a 00 00 4c 89 e7 31 d2 4c 89 ee e8 dd cb ff ff 48 89 ef e8 b5 fe ff ff 41 89 c4 e9 4f ff ff ff <0f> 0b eb b2 66 0f 1f 84 00 00 00 00 00 0f 1f 44 00 00 55 48 89 fd
[ 1002.973118] RSP: 0018:ffffbc6bcded7c50 EFLAGS: 00010002
[ 1002.973120] RAX: 0000000000000140 RBX: 0000000000000001 RCX: 0000000000000140
[ 1002.973121] RDX: 0000000000000000 RSI: ffffffffae941ec0 RDI: ffff9d8f35761018
[ 1002.973122] RBP: ffff9d8f35761000 R08: 0000000000000000 R09: 0000000000000004
[ 1002.973122] R10: 0000000000000000 R11: ffffffffae851708 R12: 0000000000000001
[ 1002.973123] R13: ffff9d8f35761018 R14: 0000000000000000 R15: ffff9d8f3a3a0000
[ 1002.973124] FS:  0000000000000000(0000) GS:ffff9d8f3ed00000(0000) knlGS:0000000000000000
[ 1002.973125] CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 1002.973126] CR2: 00000000022ceef6 CR3: 000000075306c000 CR4: 0000000000340ee0
[ 1002.973127] Call Trace:
[ 1002.973132]  enable_irq+0x53/0xa0
[ 1002.973136]  nvme_poll_irqdisable+0x20c/0x280
[ 1002.973138]  __nvme_disable_io_queues+0x19d/0x1d0
[ 1002.973140]  ? nvme_del_queue_end+0x20/0x20
[ 1002.973143]  nvme_dev_disable+0x15c/0x210
[ 1002.973145]  nvme_suspend+0x13/0x20
[ 1002.973148]  pci_pm_suspend+0x72/0x130
[ 1002.973150]  ? pci_pm_freeze+0xd0/0xd0
[ 1002.973153]  dpm_run_callback+0x4f/0x180
[ 1002.973156]  __device_suspend+0x121/0x4e0
[ 1002.973158]  async_suspend+0x1b/0x90
[ 1002.973160]  async_run_entry_fn+0x37/0x140
[ 1002.973162]  process_one_work+0x1d1/0x3e0
[ 1002.973165]  worker_thread+0x4a/0x3d0
[ 1002.973167]  kthread+0xfb/0x130
[ 1002.973169]  ? process_one_work+0x3e0/0x3e0
[ 1002.973171]  ? kthread_park+0x80/0x80
[ 1002.973174]  ret_from_fork+0x22/0x40
[ 1002.973176] ---[ end trace 4eb7b668064ddf9e ]---
[ 1003.630125] ACPI: EC: interrupt blocked
[ 1003.696893] ACPI: Preparing to enter system sleep state S3
[ 1004.230340] ACPI: EC: event blocked
[ 1004.230341] ACPI: EC: EC stopped
[ 1004.230342] PM: Saving platform NVS memory
[ 1004.230352] Disabling non-boot CPUs ...
[ 1004.231131] IRQ 146: no longer affine to CPU1
[ 1004.232165] smpboot: CPU 1 is now offline
[ 1004.233764] IRQ 147: no longer affine to CPU2
[ 1004.234790] smpboot: CPU 2 is now offline
[ 1004.236082] IRQ 148: no longer affine to CPU3
[ 1004.237234] smpboot: CPU 3 is now offline
[ 1004.239525] IRQ 149: no longer affine to CPU4
[ 1004.240631] smpboot: CPU 4 is now offline
[ 1004.242473] IRQ 150: no longer affine to CPU5
[ 1004.243569] smpboot: CPU 5 is now offline
[ 1004.245432] IRQ 151: no longer affine to CPU6
[ 1004.246500] smpboot: CPU 6 is now offline
[ 1004.247638] IRQ 152: no longer affine to CPU7
[ 1004.248655] smpboot: CPU 7 is now offline
[ 1004.249933] IRQ 153: no longer affine to CPU8
[ 1004.250954] smpboot: CPU 8 is now offline
[ 1004.252178] IRQ 154: no longer affine to CPU9
[ 1004.253244] smpboot: CPU 9 is now offline
[ 1004.254300] IRQ 155: no longer affine to CPU10
[ 1004.255314] smpboot: CPU 10 is now offline
[ 1004.257539] smpboot: CPU 11 is now offline
[ 1004.259984] smpboot: CPU 12 is now offline
[ 1004.260801] Spectre V2 : Update user space SMT mitigation: STIBP off
[ 1004.262252] smpboot: CPU 13 is now offline
[ 1004.264454] smpboot: CPU 14 is now offline
[ 1004.266655] smpboot: CPU 15 is now offline
[ 1004.269096] smpboot: CPU 16 is now offline
[ 1004.271273] smpboot: CPU 17 is now offline
[ 1004.273479] smpboot: CPU 18 is now offline
[ 1004.275552] smpboot: CPU 19 is now offline
[ 1004.277578] smpboot: CPU 20 is now offline
[ 1004.279669] smpboot: CPU 21 is now offline
[ 1004.281605] smpboot: CPU 22 is now offline
[ 1004.283752] smpboot: CPU 23 is now offline
[ 1004.284827] ACPI: Low-level resume complete
[ 1004.284858] ACPI: EC: EC started
[ 1004.284858] PM: Restoring platform NVS memory
[ 1004.284997] LVT offset 0 assigned for vector 0x400
[ 1004.285392] Enabling non-boot CPUs ...
[ 1004.285425] x86: Booting SMP configuration:
[ 1004.285426] smpboot: Booting Node 0 Processor 1 APIC 0x2
[ 1004.285532] microcode: CPU1: patch_level=0x08701013
[ 1004.288160] CPU1 is up
[ 1004.288172] smpboot: Booting Node 0 Processor 2 APIC 0x4
[ 1004.288280] microcode: CPU2: patch_level=0x08701013
[ 1004.290617] CPU2 is up
[ 1004.290626] smpboot: Booting Node 0 Processor 3 APIC 0x8
[ 1004.290768] microcode: CPU3: patch_level=0x08701013
[ 1004.293181] CPU3 is up
[ 1004.293196] smpboot: Booting Node 0 Processor 4 APIC 0xa
[ 1004.293326] microcode: CPU4: patch_level=0x08701013
[ 1004.295697] CPU4 is up
[ 1004.295711] smpboot: Booting Node 0 Processor 5 APIC 0xc
[ 1004.295839] microcode: CPU5: patch_level=0x08701013
[ 1004.298212] CPU5 is up
[ 1004.298226] smpboot: Booting Node 0 Processor 6 APIC 0x10
[ 1004.298360] microcode: CPU6: patch_level=0x08701013
[ 1004.300805] CPU6 is up
[ 1004.300819] smpboot: Booting Node 0 Processor 7 APIC 0x12
[ 1004.300950] microcode: CPU7: patch_level=0x08701013
[ 1004.303354] CPU7 is up
[ 1004.303368] smpboot: Booting Node 0 Processor 8 APIC 0x14
[ 1004.303497] microcode: CPU8: patch_level=0x08701013
[ 1004.305905] CPU8 is up
[ 1004.305918] smpboot: Booting Node 0 Processor 9 APIC 0x18
[ 1004.306049] microcode: CPU9: patch_level=0x08701013
[ 1004.308541] CPU9 is up
[ 1004.308556] smpboot: Booting Node 0 Processor 10 APIC 0x1a
[ 1004.308687] microcode: CPU10: patch_level=0x08701013
[ 1004.311120] CPU10 is up
[ 1004.311134] smpboot: Booting Node 0 Processor 11 APIC 0x1c
[ 1004.311263] microcode: CPU11: patch_level=0x08701013
[ 1004.313706] CPU11 is up
[ 1004.313721] smpboot: Booting Node 0 Processor 12 APIC 0x1
[ 1004.313857] microcode: CPU12: patch_level=0x08701013
[ 1004.316931] Spectre V2 : Update user space SMT mitigation: STIBP always-on
[ 1004.316950] CPU12 is up
[ 1004.316976] smpboot: Booting Node 0 Processor 13 APIC 0x3
[ 1004.317084] microcode: CPU13: patch_level=0x08701013
[ 1004.319545] CPU13 is up
[ 1004.319560] smpboot: Booting Node 0 Processor 14 APIC 0x5
[ 1004.319666] microcode: CPU14: patch_level=0x08701013
[ 1004.322137] CPU14 is up
[ 1004.322149] smpboot: Booting Node 0 Processor 15 APIC 0x9
[ 1004.322277] microcode: CPU15: patch_level=0x08701013
[ 1004.324774] CPU15 is up
[ 1004.324788] smpboot: Booting Node 0 Processor 16 APIC 0xb
[ 1004.324927] microcode: CPU16: patch_level=0x08701013
[ 1004.327425] CPU16 is up
[ 1004.327441] smpboot: Booting Node 0 Processor 17 APIC 0xd
[ 1004.327584] microcode: CPU17: patch_level=0x08701013
[ 1004.330105] CPU17 is up
[ 1004.330124] smpboot: Booting Node 0 Processor 18 APIC 0x11
[ 1004.330254] microcode: CPU18: patch_level=0x08701013
[ 1004.332807] CPU18 is up
[ 1004.332823] smpboot: Booting Node 0 Processor 19 APIC 0x13
[ 1004.332959] microcode: CPU19: patch_level=0x08701013
[ 1004.335501] CPU19 is up
[ 1004.335516] smpboot: Booting Node 0 Processor 20 APIC 0x15
[ 1004.335654] microcode: CPU20: patch_level=0x08701013
[ 1004.338227] CPU20 is up
[ 1004.338242] smpboot: Booting Node 0 Processor 21 APIC 0x19
[ 1004.338371] microcode: CPU21: patch_level=0x08701013
[ 1004.340966] CPU21 is up
[ 1004.340981] smpboot: Booting Node 0 Processor 22 APIC 0x1b
[ 1004.341127] microcode: CPU22: patch_level=0x08701013
[ 1004.343722] CPU22 is up
[ 1004.343736] smpboot: Booting Node 0 Processor 23 APIC 0x1d
[ 1004.343878] microcode: CPU23: patch_level=0x08701013
[ 1004.346502] CPU23 is up
[ 1004.347796] ACPI: Waking up from system sleep state S3
[ 1004.348535] ACPI: EC: interrupt unblocked
[ 1004.370681] snd_hda_intel 0000:0b:00.1: spurious response 0x0:0x0, last cmd=0x6f2f03
[ 1004.370682] snd_hda_intel 0000:0b:00.1: spurious response 0x0:0x0, last cmd=0x6f2f03
[ 1004.370683] snd_hda_intel 0000:0b:00.1: spurious response 0x0:0x0, last cmd=0x6f2f03
[ 1004.370685] snd_hda_intel 0000:0b:00.1: spurious response 0x0:0x0, last cmd=0x6f2f03
[ 1004.370688] snd_hda_codec_hdmi hdaudioC1D0: HDMI: invalid ELD data byte 3
[ 1004.416558] ACPI: EC: event unblocked
[ 1004.416637] sd 3:0:0:0: [sdb] Starting disk
[ 1004.416638] sd 8:0:0:0: [sdc] Starting disk
[ 1004.416640] sd 1:0:0:0: [sda] Starting disk
[ 1004.427646] iwlwifi 0000:05:00.0: Applying debug destination EXTERNAL_DRAM
[ 1004.525545] snd_hda_intel 0000:04:00.0: Direct firmware load for ctefx-desktop.bin failed with error -2
[ 1004.575457] iwlwifi 0000:05:00.0: FW already configured (0) - re-configuring
[ 1004.627830] nvme nvme0: Shutdown timeout set to 8 seconds
[ 1004.658433] nvme nvme0: 32/0/0 default/read/poll queues
[ 1004.731609] ata11: SATA link down (SStatus 0 SControl 300)
[ 1004.731937] ata10: SATA link down (SStatus 0 SControl 300)
[ 1004.887366] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1004.887601] ata2.00: supports DRM functions and may not be fully accessible
[ 1004.888515] ata2.00: NCQ Send/Recv Log not supported
[ 1004.889619] ata2.00: supports DRM functions and may not be fully accessible
[ 1004.889950] ata2.00: NCQ Send/Recv Log not supported
[ 1004.891113] ata9: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1004.891114] ata4: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1004.891126] ata2.00: configured for UDMA/133
[ 1004.891349] ata9.00: supports DRM functions and may not be fully accessible
[ 1004.891446] ata4.00: supports DRM functions and may not be fully accessible
[ 1004.892087] ata9.00: disabling queued TRIM support
[ 1004.893668] ata9.00: supports DRM functions and may not be fully accessible
[ 1004.894161] ata9.00: disabling queued TRIM support
[ 1004.894861] ata4.00: supports DRM functions and may not be fully accessible
[ 1004.895441] ata9.00: configured for UDMA/133
[ 1004.897546] ata4.00: configured for UDMA/133
[ 1004.907981] ata4.00: Enabling discard_zeroes_data
[ 1005.114335] snd_hda_codec_ca0132 hdaudioC0D1: ca0132 DSP downloaded and running
[ 1007.131638] OOM killer enabled.
[ 1007.131639] Restarting tasks ... done.
[ 1007.133397] PM: suspend exit
[ 1019.055758] fbcon: Taking over console
[ 1019.055927] Console: switching to colour frame buffer device 128x48
[ 1029.074555] igb 0000:07:00.0 enp7s0: igb: enp7s0 NIC Link is Up 100 Mbps Full Duplex, Flow Control: RX
[ 1029.074804] IPv6: ADDRCONF(NETDEV_CHANGE): enp7s0: link becomes ready
[ 1045.784001] check: Corrupted low memory at 00000000d1669006 (2aa8 phys) = 00550000
[ 1045.784004] check: Corrupted low memory at 0000000033ad02f9 (5550 phys) = f00000000000
[ 1045.784011] ------------[ cut here ]------------
[ 1045.784011] Memory corruption detected in low memory
[ 1045.784017] WARNING: CPU: 0 PID: 4537 at arch/x86/kernel/check.c:161 check_corruption+0xcd/0xd1
[ 1045.784018] Modules linked in: cmac edac_mce_amd fuse rfcomm bnep btusb btrtl btbcm btintel bluetooth mousedev joydev input_leds ecdh_generic ecc snd_hda_codec_hdmi arc4 squashfs loop nls_iso8859_1 nls_cp437 vfat fat iwlmvm kvm mac80211 irqbypass iwlwifi snd_hda_codec_realtek snd_hda_codec_generic crct10dif_pclmul eeepc_wmi snd_hda_codec_ca0132 asus_wmi crc32_pclmul ledtrig_audio wmi_bmof sparse_keymap mxm_wmi ghash_clmulni_intel cfg80211 uinput snd_hda_intel nvidia_drm(POE) nvidia_modeset(POE) snd_hda_codec drm_kms_helper snd_hda_core igb aesni_intel snd_hwdep snd_pcm snd_timer aes_x86_64 crypto_simd sp5100_tco ccp snd cryptd i2c_piix4 pcspkr k10temp i2c_algo_bit glue_helper rng_core soundcore rfkill dca drm agpgart syscopyarea wmi sysfillrect sysimgblt pinctrl_amd evdev fb_sys_fops mac_hid pcc_cpufreq acpi_cpufreq nvidia(POE) ipmi_devintf ipmi_msghandler crypto_user ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 hid_generic usbhid hid sd_mod ahci libahci libata xhci_pci
[ 1045.784050]  crc32c_intel scsi_mod xhci_hcd
[ 1045.784053] CPU: 0 PID: 4537 Comm: kworker/0:3 Tainted: P        W  OE     5.2.10-1-MANJARO #1
[ 1045.784054] Hardware name: System manufacturer System Product Name/ROG STRIX X570-E GAMING, BIOS 1005 08/01/2019
[ 1045.784056] Workqueue: events check_corruption
[ 1045.784057] RIP: 0010:check_corruption+0xcd/0xd1
[ 1045.784058] Code: 41 5c bf 40 01 00 00 41 5d e9 9f c7 03 00 80 3d 17 8a 2a 01 00 75 c7 48 c7 c7 90 d1 6b ae c6 05 07 8a 2a 01 01 e8 22 f9 01 00 <0f> 0b eb b0 48 c7 c7 18 d1 6b ae e8 71 bb 08 00 48 8b 35 bc 40 2d
[ 1045.784059] RSP: 0018:ffffbc6bcc657e58 EFLAGS: 00010282
[ 1045.784060] RAX: 0000000000000000 RBX: ffff9d8740010000 RCX: 0000000000000000
[ 1045.784060] RDX: 0000000000000007 RSI: 0000000000000082 RDI: 00000000ffffffff
[ 1045.784061] RBP: 0000000000000001 R08: 00000000000005ae R09: 0000000000000001
[ 1045.784061] R10: 0000000000000000 R11: 0000000000000001 R12: ffff9d8740010000
[ 1045.784062] R13: 0000000080000000 R14: 0000000000000000 R15: 0ffff9d8f3e82f70
[ 1045.784063] FS:  0000000000000000(0000) GS:ffff9d8f3e800000(0000) knlGS:0000000000000000
[ 1045.784064] CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 1045.784064] CR2: 00007f837d6f5270 CR3: 00000007ba8a6000 CR4: 0000000000340ef0
[ 1045.784065] Call Trace:
[ 1045.784069]  process_one_work+0x1d1/0x3e0
[ 1045.784071]  worker_thread+0x4a/0x3d0
[ 1045.784073]  kthread+0xfb/0x130
[ 1045.784074]  ? process_one_work+0x3e0/0x3e0
[ 1045.784075]  ? kthread_park+0x80/0x80
[ 1045.784077]  ret_from_fork+0x22/0x40
[ 1045.784079] ---[ end trace 4eb7b668064ddf9f ]---
here's the tail of journalctl output:
elo 28 23:09:43 henri-amd org_kde_powerdevil[1546]: powerdevil: Suspend session triggered with QMap(("Explicit", QVariant(bool, true))("Type", QVariant(uint, 1)))
elo 28 23:09:43 henri-amd org_kde_powerdevil[1546]: powerdevil: Suspend session triggered with QMap(("Explicit", QVariant(bool, true))("SkipFade", QVariant(bool, true))("Type", QVariant(uint, 1)))
elo 28 23:09:43 henri-amd org_kde_powerdevil[1546]: powerdevil: Starting Login1 suspend job
elo 28 23:09:43 henri-amd org_kde_powerdevil[1546]: powerdevil: Pausing all media players before sleep
elo 28 23:09:43 henri-amd ksmserver[1253]: lock called
elo 28 23:09:43 henri-amd kdeinit5[1234]: bluedevil: About to suspend
elo 28 23:09:43 henri-amd NetworkManager[810]: <info>  [1567022983.4493] manager: sleep: sleep requested (sleeping: no  enabled: yes)
elo 28 23:09:43 henri-amd NetworkManager[810]: <info>  [1567022983.4494] device (p2p-dev-wlp5s0): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
elo 28 23:09:43 henri-amd NetworkManager[810]: <info>  [1567022983.4498] manager: NetworkManager state is now ASLEEP
elo 28 23:09:43 henri-amd ksmserver[1253]: Lock window Id:  18874375
elo 28 23:09:43 henri-amd ksmserver[1253]: CreateNotify: 18874375
elo 28 23:09:43 henri-amd ksmserver[1253]: CreateNotify: 18874377
elo 28 23:09:43 henri-amd ksmserver[1253]: CreateNotify: 125829124
elo 28 23:09:43 henri-amd kscreenlocker_greet[4140]: Qt: Session management error: networkIdsList argument is NULL
elo 28 23:09:43 henri-amd ksmserver[1253]: CreateNotify: 125829127
elo 28 23:09:43 henri-amd ksmserver[1253]: CreateNotify: 125829131
elo 28 23:09:43 henri-amd ksmserver[1253]: CreateNotify: 125829133
elo 28 23:09:43 henri-amd kscreenlocker_greet[4140]: kf5.kpackage: No metadata file in the package, expected it at: "/usr/share/wallpapers/Breath/contents/images/"
elo 28 23:09:43 henri-amd kscreenlocker_greet[4140]: file:///usr/share/plasma/wallpapers/org.kde.image/contents/ui/main.qml:71:9: Unable to assign [undefined] to QStringList
elo 28 23:09:43 henri-amd ksmserver[1253]: CreateNotify: 125829135
elo 28 23:09:43 henri-amd ksmserver[1253]: CreateNotify: 125829137
elo 28 23:09:43 henri-amd ksmserver[1253]: MapNotify: 125829135
elo 28 23:09:43 henri-amd ksmserver[1253]: CreateNotify: 125829139
elo 28 23:09:43 henri-amd ksmserver[1253]: MapNotify: 125829139
elo 28 23:09:43 henri-amd ksmserver[1253]: CreateNotify: 125829142
elo 28 23:09:43 henri-amd ksmserver[1253]: CreateNotify: 125829145
elo 28 23:09:44 henri-amd ksmserver[1253]: MapNotify: 18874375
elo 28 23:09:44 henri-amd systemd[1]: Starting TLP suspend/resume...
elo 28 23:09:44 henri-amd kscreenlocker_greet[4140]: UdevQt: unable to create udev monitor connection
elo 28 23:09:44 henri-amd ksmserver[1253]: CreateNotify: 125829148
elo 28 23:09:44 henri-amd systemd[1]: Started TLP suspend/resume.
elo 28 23:09:44 henri-amd systemd[1]: Reached target Sleep.
elo 28 23:09:44 henri-amd systemd[1]: Starting Suspend...
elo 28 23:09:44 henri-amd systemd-sleep[4382]: Suspending system...
elo 28 23:09:44 henri-amd kernel: PM: suspend entry (deep)
elo 28 23:09:44 henri-amd kscreenlocker_greet[4140]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
elo 28 23:09:44 henri-amd kernel: Filesystems sync: 0.007 seconds
elo 28 23:09:44 henri-amd kscreenlocker_greet[4140]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/SessionManagementScreen.qml:64:5: Unable to assign [undefined] to int
elo 28 23:09:44 henri-amd kscreenlocker_greet[4140]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/ActionButton.qml:33:5: Unable to assign [undefined] to int
elo 28 23:09:44 henri-amd kscreenlocker_greet[4140]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/KeyboardLayoutButton.qml:29:5: Unable to assign [undefined] to int
elo 28 23:09:44 henri-amd kscreenlocker_greet[4140]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/Battery.qml:48:9: Unable to assign [undefined] to double
elo 28 23:09:54 henri-amd kernel: Freezing user space processes ... (elapsed 0.001 seconds) done.
elo 28 23:09:54 henri-amd kernel: OOM killer disabled.
elo 28 23:09:54 henri-amd kernel: Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
elo 28 23:09:54 henri-amd kernel: printk: Suspending console(s) (use no_console_suspend to debug)
elo 28 23:09:54 henri-amd kernel: sd 1:0:0:0: [sda] Synchronizing SCSI cache
elo 28 23:09:54 henri-amd kernel: sd 1:0:0:0: [sda] Stopping disk
elo 28 23:09:54 henri-amd kernel: sd 3:0:0:0: [sdb] Synchronizing SCSI cache
elo 28 23:09:54 henri-amd kernel: sd 8:0:0:0: [sdc] Synchronizing SCSI cache
elo 28 23:09:54 henri-amd kernel: sd 8:0:0:0: [sdc] Stopping disk
elo 28 23:09:54 henri-amd kernel: sd 3:0:0:0: [sdb] Stopping disk
elo 28 23:09:54 henri-amd kernel: WARNING: CPU: 20 PID: 4426 at kernel/irq/chip.c:210 irq_startup+0xe3/0xf0
elo 28 23:09:54 henri-amd kernel: Modules linked in: cmac edac_mce_amd fuse rfcomm bnep btusb btrtl btbcm btintel bluetooth mousedev joydev input_leds ecdh_generic ecc snd_hda_codec_hdmi arc4 squashfs loop nls_iso8859_1 nls_cp437 vfat fat iwlmvm kvm mac80211 irqbypass iwlwifi snd_hda_codec_realtek snd_hda_codec_generic crct10dif_pclmul eeepc_wmi snd_hda_codec_ca0132 asus_wmi crc32_pclmul ledtrig_audio wmi_bmof sparse_keymap mxm_wmi ghash_clmulni_intel cfg80211 uinput snd_hda_intel nvidia_drm(POE) nvidia_modeset(POE) snd_hda_codec drm_kms_helper snd_hda_core igb aesni_intel snd_hwdep snd_pcm snd_timer aes_x86_64 crypto_simd sp5100_tco ccp snd cryptd i2c_piix4 pcspkr k10temp i2c_algo_bit glue_helper rng_core soundcore rfkill dca drm agpgart syscopyarea wmi sysfillrect sysimgblt pinctrl_amd evdev fb_sys_fops mac_hid pcc_cpufreq acpi_cpufreq nvidia(POE) ipmi_devintf ipmi_msghandler crypto_user ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 hid_generic usbhid hid sd_mod ahci libahci libata xhci_pci
elo 28 23:09:54 henri-amd kernel:  crc32c_intel scsi_mod xhci_hcd
elo 28 23:09:54 henri-amd kernel: CPU: 20 PID: 4426 Comm: kworker/u64:34 Tainted: P           OE     5.2.10-1-MANJARO #1
elo 28 23:09:54 henri-amd kernel: Hardware name: System manufacturer System Product Name/ROG STRIX X570-E GAMING, BIOS 1005 08/01/2019
elo 28 23:09:54 henri-amd kernel: Workqueue: events_unbound async_run_entry_fn
elo 28 23:09:54 henri-amd kernel: RIP: 0010:irq_startup+0xe3/0xf0
elo 28 23:09:54 henri-amd kernel: Code: e8 d2 41 00 00 85 c0 0f 85 76 0a 00 00 4c 89 e7 31 d2 4c 89 ee e8 dd cb ff ff 48 89 ef e8 b5 fe ff ff 41 89 c4 e9 4f ff ff ff <0f> 0b eb b2 66 0f 1f 84 00 00 00 00 00 0f 1f 44 00 00 55 48 89 fd
elo 28 23:09:54 henri-amd kernel: RSP: 0018:ffffbc6bcded7c50 EFLAGS: 00010002
elo 28 23:09:54 henri-amd kernel: RAX: 0000000000000140 RBX: 0000000000000001 RCX: 0000000000000140
elo 28 23:09:54 henri-amd kernel: RDX: 0000000000000000 RSI: ffffffffae941ec0 RDI: ffff9d8f35761018
elo 28 23:09:54 henri-amd kernel: RBP: ffff9d8f35761000 R08: 0000000000000000 R09: 0000000000000004
elo 28 23:09:54 henri-amd kernel: R10: 0000000000000000 R11: ffffffffae851708 R12: 0000000000000001
elo 28 23:09:54 henri-amd kernel: R13: ffff9d8f35761018 R14: 0000000000000000 R15: ffff9d8f3a3a0000
elo 28 23:09:54 henri-amd kernel: FS:  0000000000000000(0000) GS:ffff9d8f3ed00000(0000) knlGS:0000000000000000
elo 28 23:09:54 henri-amd kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
elo 28 23:09:54 henri-amd kernel: CR2: 00000000022ceef6 CR3: 000000075306c000 CR4: 0000000000340ee0
elo 28 23:09:54 henri-amd kernel: Call Trace:
elo 28 23:09:54 henri-amd kernel:  enable_irq+0x53/0xa0
elo 28 23:09:54 henri-amd kernel:  nvme_poll_irqdisable+0x20c/0x280
elo 28 23:09:54 henri-amd kernel:  __nvme_disable_io_queues+0x19d/0x1d0
elo 28 23:09:54 henri-amd kernel:  ? nvme_del_queue_end+0x20/0x20
elo 28 23:09:54 henri-amd kernel:  nvme_dev_disable+0x15c/0x210
elo 28 23:09:54 henri-amd kernel:  nvme_suspend+0x13/0x20
elo 28 23:09:54 henri-amd kernel:  pci_pm_suspend+0x72/0x130
elo 28 23:09:54 henri-amd kernel:  ? pci_pm_freeze+0xd0/0xd0
elo 28 23:09:54 henri-amd kernel:  dpm_run_callback+0x4f/0x180
elo 28 23:09:54 henri-amd kernel:  __device_suspend+0x121/0x4e0
elo 28 23:09:54 henri-amd kernel:  async_suspend+0x1b/0x90
elo 28 23:09:54 henri-amd kernel:  async_run_entry_fn+0x37/0x140
elo 28 23:09:54 henri-amd kernel:  process_one_work+0x1d1/0x3e0
elo 28 23:09:54 henri-amd kernel:  worker_thread+0x4a/0x3d0
elo 28 23:09:54 henri-amd kernel:  kthread+0xfb/0x130
elo 28 23:09:54 henri-amd kernel:  ? process_one_work+0x3e0/0x3e0
elo 28 23:09:54 henri-amd kernel:  ? kthread_park+0x80/0x80
elo 28 23:09:54 henri-amd kernel:  ret_from_fork+0x22/0x40
elo 28 23:09:54 henri-amd kernel: ---[ end trace 4eb7b668064ddf9e ]---
elo 28 23:09:54 henri-amd kernel: ACPI: EC: interrupt blocked
elo 28 23:09:54 henri-amd kernel: ACPI: Preparing to enter system sleep state S3
elo 28 23:09:54 henri-amd kernel: ACPI: EC: event blocked
elo 28 23:09:54 henri-amd kernel: ACPI: EC: EC stopped
elo 28 23:09:54 henri-amd kernel: PM: Saving platform NVS memory
elo 28 23:09:54 henri-amd kernel: Disabling non-boot CPUs ...
elo 28 23:09:54 henri-amd kernel: IRQ 146: no longer affine to CPU1
elo 28 23:09:54 henri-amd kernel: smpboot: CPU 1 is now offline
elo 28 23:09:54 henri-amd kernel: IRQ 147: no longer affine to CPU2
elo 28 23:09:54 henri-amd kernel: smpboot: CPU 2 is now offline
elo 28 23:09:54 henri-amd kernel: IRQ 148: no longer affine to CPU3
elo 28 23:09:54 henri-amd kernel: smpboot: CPU 3 is now offline
elo 28 23:09:54 henri-amd kernel: IRQ 149: no longer affine to CPU4
elo 28 23:09:54 henri-amd kernel: smpboot: CPU 4 is now offline
elo 28 23:09:54 henri-amd kernel: IRQ 150: no longer affine to CPU5
elo 28 23:09:54 henri-amd kernel: smpboot: CPU 5 is now offline
elo 28 23:09:54 henri-amd kernel: IRQ 151: no longer affine to CPU6
elo 28 23:09:54 henri-amd kernel: smpboot: CPU 6 is now offline
elo 28 23:09:54 henri-amd kernel: IRQ 152: no longer affine to CPU7
elo 28 23:09:54 henri-amd kernel: smpboot: CPU 7 is now offline
elo 28 23:09:54 henri-amd kernel: IRQ 153: no longer affine to CPU8
elo 28 23:09:54 henri-amd kernel: smpboot: CPU 8 is now offline
elo 28 23:09:54 henri-amd kernel: IRQ 154: no longer affine to CPU9
elo 28 23:09:54 henri-amd kernel: smpboot: CPU 9 is now offline
elo 28 23:09:54 henri-amd kernel: IRQ 155: no longer affine to CPU10
elo 28 23:09:54 henri-amd kernel: smpboot: CPU 10 is now offline
elo 28 23:09:54 henri-amd kernel: smpboot: CPU 11 is now offline
elo 28 23:09:54 henri-amd kernel: smpboot: CPU 12 is now offline
elo 28 23:09:54 henri-amd kernel: Spectre V2 : Update user space SMT mitigation: STIBP off
elo 28 23:09:54 henri-amd kernel: smpboot: CPU 13 is now offline
elo 28 23:09:54 henri-amd kernel: smpboot: CPU 14 is now offline
elo 28 23:09:54 henri-amd kernel: smpboot: CPU 15 is now offline
elo 28 23:09:54 henri-amd kernel: smpboot: CPU 16 is now offline
elo 28 23:09:54 henri-amd kernel: smpboot: CPU 17 is now offline
elo 28 23:09:54 henri-amd kernel: smpboot: CPU 18 is now offline
elo 28 23:09:54 henri-amd kernel: smpboot: CPU 19 is now offline
elo 28 23:09:54 henri-amd kernel: smpboot: CPU 20 is now offline
elo 28 23:09:54 henri-amd kernel: smpboot: CPU 21 is now offline
elo 28 23:09:54 henri-amd kernel: smpboot: CPU 22 is now offline
elo 28 23:09:54 henri-amd kernel: smpboot: CPU 23 is now offline
elo 28 23:09:54 henri-amd kernel: ACPI: Low-level resume complete
elo 28 23:09:54 henri-amd kernel: ACPI: EC: EC started
elo 28 23:09:54 henri-amd kernel: PM: Restoring platform NVS memory
elo 28 23:09:54 henri-amd kernel: LVT offset 0 assigned for vector 0x400
elo 28 23:09:54 henri-amd kernel: Enabling non-boot CPUs ...
elo 28 23:09:54 henri-amd kernel: x86: Booting SMP configuration:
elo 28 23:09:54 henri-amd kernel: smpboot: Booting Node 0 Processor 1 APIC 0x2
elo 28 23:09:54 henri-amd kernel: microcode: CPU1: patch_level=0x08701013
elo 28 23:09:54 henri-amd kernel: CPU1 is up
elo 28 23:09:54 henri-amd kernel: smpboot: Booting Node 0 Processor 2 APIC 0x4
elo 28 23:09:54 henri-amd kernel: microcode: CPU2: patch_level=0x08701013
elo 28 23:09:54 henri-amd kernel: CPU2 is up
elo 28 23:09:54 henri-amd kernel: smpboot: Booting Node 0 Processor 3 APIC 0x8
elo 28 23:09:54 henri-amd kernel: microcode: CPU3: patch_level=0x08701013
elo 28 23:09:54 henri-amd kernel: CPU3 is up
elo 28 23:09:54 henri-amd kernel: smpboot: Booting Node 0 Processor 4 APIC 0xa
elo 28 23:09:54 henri-amd kernel: microcode: CPU4: patch_level=0x08701013
elo 28 23:09:54 henri-amd kernel: CPU4 is up
elo 28 23:09:54 henri-amd kernel: smpboot: Booting Node 0 Processor 5 APIC 0xc
elo 28 23:09:54 henri-amd kernel: microcode: CPU5: patch_level=0x08701013
elo 28 23:09:54 henri-amd kernel: CPU5 is up
elo 28 23:09:54 henri-amd kernel: smpboot: Booting Node 0 Processor 6 APIC 0x10
elo 28 23:09:54 henri-amd kernel: microcode: CPU6: patch_level=0x08701013
elo 28 23:09:54 henri-amd kernel: CPU6 is up
elo 28 23:09:54 henri-amd kernel: smpboot: Booting Node 0 Processor 7 APIC 0x12
elo 28 23:09:54 henri-amd kernel: microcode: CPU7: patch_level=0x08701013
elo 28 23:09:54 henri-amd kernel: CPU7 is up
elo 28 23:09:54 henri-amd kernel: smpboot: Booting Node 0 Processor 8 APIC 0x14
elo 28 23:09:54 henri-amd kernel: microcode: CPU8: patch_level=0x08701013
elo 28 23:09:54 henri-amd kernel: CPU8 is up
elo 28 23:09:54 henri-amd kernel: smpboot: Booting Node 0 Processor 9 APIC 0x18
elo 28 23:09:54 henri-amd kernel: microcode: CPU9: patch_level=0x08701013
elo 28 23:09:54 henri-amd kernel: CPU9 is up
elo 28 23:09:54 henri-amd kernel: smpboot: Booting Node 0 Processor 10 APIC 0x1a
elo 28 23:09:54 henri-amd kernel: microcode: CPU10: patch_level=0x08701013
elo 28 23:09:54 henri-amd kernel: CPU10 is up
elo 28 23:09:54 henri-amd kernel: smpboot: Booting Node 0 Processor 11 APIC 0x1c
elo 28 23:09:54 henri-amd kernel: microcode: CPU11: patch_level=0x08701013
elo 28 23:09:54 henri-amd kernel: CPU11 is up
elo 28 23:09:54 henri-amd kernel: smpboot: Booting Node 0 Processor 12 APIC 0x1
elo 28 23:09:54 henri-amd kernel: microcode: CPU12: patch_level=0x08701013
elo 28 23:09:54 henri-amd kernel: Spectre V2 : Update user space SMT mitigation: STIBP always-on
elo 28 23:09:54 henri-amd kernel: CPU12 is up
elo 28 23:09:54 henri-amd kernel: smpboot: Booting Node 0 Processor 13 APIC 0x3
elo 28 23:09:54 henri-amd kernel: microcode: CPU13: patch_level=0x08701013
elo 28 23:09:54 henri-amd kernel: CPU13 is up
elo 28 23:09:54 henri-amd kernel: smpboot: Booting Node 0 Processor 14 APIC 0x5
elo 28 23:09:54 henri-amd kernel: microcode: CPU14: patch_level=0x08701013
elo 28 23:09:54 henri-amd kernel: CPU14 is up
elo 28 23:09:54 henri-amd kernel: smpboot: Booting Node 0 Processor 15 APIC 0x9
elo 28 23:09:54 henri-amd kernel: microcode: CPU15: patch_level=0x08701013
elo 28 23:09:54 henri-amd kernel: CPU15 is up
elo 28 23:09:54 henri-amd kernel: smpboot: Booting Node 0 Processor 16 APIC 0xb
elo 28 23:09:54 henri-amd kernel: microcode: CPU16: patch_level=0x08701013
elo 28 23:09:54 henri-amd kernel: CPU16 is up
elo 28 23:09:54 henri-amd kernel: smpboot: Booting Node 0 Processor 17 APIC 0xd
elo 28 23:09:54 henri-amd kernel: microcode: CPU17: patch_level=0x08701013
elo 28 23:09:54 henri-amd kernel: CPU17 is up
elo 28 23:09:54 henri-amd kernel: smpboot: Booting Node 0 Processor 18 APIC 0x11
elo 28 23:09:54 henri-amd kernel: microcode: CPU18: patch_level=0x08701013
elo 28 23:09:54 henri-amd kernel: CPU18 is up
elo 28 23:09:54 henri-amd kernel: smpboot: Booting Node 0 Processor 19 APIC 0x13
elo 28 23:09:54 henri-amd kernel: microcode: CPU19: patch_level=0x08701013
elo 28 23:09:54 henri-amd kernel: CPU19 is up
elo 28 23:09:54 henri-amd kernel: smpboot: Booting Node 0 Processor 20 APIC 0x15
elo 28 23:09:54 henri-amd kernel: microcode: CPU20: patch_level=0x08701013
elo 28 23:09:54 henri-amd kernel: CPU20 is up
elo 28 23:09:54 henri-amd kernel: smpboot: Booting Node 0 Processor 21 APIC 0x19
elo 28 23:09:54 henri-amd kernel: microcode: CPU21: patch_level=0x08701013
elo 28 23:09:54 henri-amd kernel: CPU21 is up
elo 28 23:09:54 henri-amd kernel: smpboot: Booting Node 0 Processor 22 APIC 0x1b
elo 28 23:09:54 henri-amd kernel: microcode: CPU22: patch_level=0x08701013
elo 28 23:09:54 henri-amd kernel: CPU22 is up
elo 28 23:09:54 henri-amd kernel: smpboot: Booting Node 0 Processor 23 APIC 0x1d
elo 28 23:09:54 henri-amd kernel: microcode: CPU23: patch_level=0x08701013
elo 28 23:09:54 henri-amd kernel: CPU23 is up
elo 28 23:09:54 henri-amd kernel: ACPI: Waking up from system sleep state S3
elo 28 23:09:54 henri-amd kernel: ACPI: EC: interrupt unblocked
elo 28 23:09:54 henri-amd kernel: snd_hda_intel 0000:0b:00.1: spurious response 0x0:0x0, last cmd=0x6f2f03
elo 28 23:09:54 henri-amd kernel: snd_hda_codec_hdmi hdaudioC1D0: HDMI: invalid ELD data byte 3
elo 28 23:09:54 henri-amd kernel: ACPI: EC: event unblocked
elo 28 23:09:54 henri-amd kernel: sd 3:0:0:0: [sdb] Starting disk
elo 28 23:09:54 henri-amd kernel: sd 8:0:0:0: [sdc] Starting disk
elo 28 23:09:54 henri-amd kernel: sd 1:0:0:0: [sda] Starting disk
elo 28 23:09:54 henri-amd kernel: iwlwifi 0000:05:00.0: Applying debug destination EXTERNAL_DRAM
elo 28 23:09:54 henri-amd kernel: snd_hda_intel 0000:04:00.0: Direct firmware load for ctefx-desktop.bin failed with error -2
elo 28 23:09:54 henri-amd kernel: iwlwifi 0000:05:00.0: FW already configured (0) - re-configuring
elo 28 23:09:54 henri-amd kernel: nvme nvme0: Shutdown timeout set to 8 seconds
elo 28 23:09:54 henri-amd kernel: nvme nvme0: 32/0/0 default/read/poll queues
elo 28 23:09:54 henri-amd kernel: ata11: SATA link down (SStatus 0 SControl 300)
elo 28 23:09:54 henri-amd kernel: ata10: SATA link down (SStatus 0 SControl 300)
elo 28 23:09:54 henri-amd kernel: ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
elo 28 23:09:54 henri-amd kernel: ata2.00: supports DRM functions and may not be fully accessible
elo 28 23:09:54 henri-amd kernel: ata2.00: NCQ Send/Recv Log not supported
elo 28 23:09:54 henri-amd kernel: ata9: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
elo 28 23:09:54 henri-amd kernel: ata4: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
elo 28 23:09:54 henri-amd kernel: ata2.00: configured for UDMA/133
elo 28 23:09:54 henri-amd kernel: ata9.00: supports DRM functions and may not be fully accessible
elo 28 23:09:54 henri-amd kernel: ata4.00: supports DRM functions and may not be fully accessible
elo 28 23:09:54 henri-amd kernel: ata9.00: disabling queued TRIM support
elo 28 23:09:54 henri-amd kernel: ata9.00: configured for UDMA/133
elo 28 23:09:54 henri-amd kernel: ata4.00: configured for UDMA/133
elo 28 23:09:54 henri-amd kernel: ata4.00: Enabling discard_zeroes_data
elo 28 23:09:54 henri-amd kernel: snd_hda_codec_ca0132 hdaudioC0D1: ca0132 DSP downloaded and running
elo 28 23:09:54 henri-amd kernel: OOM killer enabled.
elo 28 23:09:54 henri-amd kernel: Restarting tasks ... done.
elo 28 23:09:54 henri-amd kernel: PM: suspend exit
elo 28 23:09:54 henri-amd systemd-sleep[4382]: System resumed.
elo 28 23:09:54 henri-amd wpa_supplicant[879]: wlp5s0: CTRL-EVENT-REGDOM-CHANGE init=DRIVER type=WORLD
elo 28 23:09:54 henri-amd systemd[1]: systemd-suspend.service: Succeeded.
elo 28 23:09:54 henri-amd systemd[1]: Started Suspend.
elo 28 23:09:54 henri-amd systemd[1]: Stopped target Sleep.
elo 28 23:09:54 henri-amd systemd[1]: Reached target Suspend.
elo 28 23:09:54 henri-amd systemd-logind[808]: Operation 'sleep' finished.
elo 28 23:09:54 henri-amd systemd[1]: Stopping TLP suspend/resume...
elo 28 23:09:54 henri-amd systemd[1]: Stopped target Suspend.
elo 28 23:09:54 henri-amd NetworkManager[810]: <info>  [1567022994.4523] manager: sleep: wake requested (sleeping: yes  enabled: yes)
elo 28 23:09:54 henri-amd NetworkManager[810]: <info>  [1567022994.4524] device (enp7s0): state change: activated -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
elo 28 23:09:54 henri-amd NetworkManager[810]: <info>  [1567022994.4525] dhcp4 (enp7s0): canceled DHCP transaction
elo 28 23:09:54 henri-amd NetworkManager[810]: <info>  [1567022994.4525] dhcp4 (enp7s0): state changed bound -> done
elo 28 23:09:54 henri-amd avahi-daemon[805]: Withdrawing address record for 192.168.1.207 on enp7s0.
elo 28 23:09:54 henri-amd avahi-daemon[805]: Leaving mDNS multicast group on interface enp7s0.IPv4 with address 192.168.1.207.
elo 28 23:09:54 henri-amd avahi-daemon[805]: Interface enp7s0.IPv4 no longer relevant for mDNS.
elo 28 23:09:54 henri-amd avahi-daemon[805]: Withdrawing address record for fe80::cb98:bb2c:922f:89b5 on enp7s0.
elo 28 23:09:54 henri-amd avahi-daemon[805]: Leaving mDNS multicast group on interface enp7s0.IPv6 with address fe80::cb98:bb2c:922f:89b5.
elo 28 23:09:54 henri-amd avahi-daemon[805]: Interface enp7s0.IPv6 no longer relevant for mDNS.
elo 28 23:09:54 henri-amd NetworkManager[810]: <info>  [1567022994.4567] manager: NetworkManager state is now CONNECTED_GLOBAL
elo 28 23:09:54 henri-amd NetworkManager[810]: <info>  [1567022994.4860] manager: NetworkManager state is now DISCONNECTED
elo 28 23:09:54 henri-amd NetworkManager[810]: <info>  [1567022994.4869] device (wlp5s0): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
elo 28 23:09:54 henri-amd NetworkManager[810]: <info>  [1567022994.4875] device (wlp5s0): set-hw-addr: reset MAC address to 3C:F0:11:D9:D1:22 (unmanage)
elo 28 23:09:54 henri-amd dbus-daemon[809]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.2' (uid=0 pid=810 comm="/usr/bin/NetworkManager --no-daemon " label="unconfined")
elo 28 23:09:54 henri-amd NetworkManager[810]: <info>  [1567022994.4890] device (enp7s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'managed')
elo 28 23:09:54 henri-amd systemd[1]: Starting Network Manager Script Dispatcher Service...
elo 28 23:09:54 henri-amd dbus-daemon[809]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
elo 28 23:09:54 henri-amd systemd[1]: Started Network Manager Script Dispatcher Service.
elo 28 23:09:54 henri-amd rtkit-daemon[1315]: Supervising 16 threads of 7 processes of 1 users.
elo 28 23:09:54 henri-amd rtkit-daemon[1315]: Successfully made thread 4590 of process 1308 owned by '1000' RT at priority 5.
elo 28 23:09:54 henri-amd rtkit-daemon[1315]: Supervising 17 threads of 7 processes of 1 users.
elo 28 23:09:54 henri-amd NetworkManager[810]: <info>  [1567022994.5137] device (wlp5s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'managed')
elo 28 23:09:54 henri-amd NetworkManager[810]: <info>  [1567022994.5147] device (p2p-dev-wlp5s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'managed')
elo 28 23:09:54 henri-amd wpa_supplicant[879]: nl80211: deinit ifname=p2p-dev-wlp5s0 disabled_11b_rates=0
elo 28 23:09:54 henri-amd systemd[1]: tlp-sleep.service: Succeeded.
elo 28 23:09:54 henri-amd systemd[1]: Stopped TLP suspend/resume.
elo 28 23:09:54 henri-amd wpa_supplicant[879]: nl80211: deinit ifname=wlp5s0 disabled_11b_rates=0
elo 28 23:09:54 henri-amd NetworkManager[810]: <info>  [1567022994.8049] sup-iface[0x564270033220,wlp5s0]: supports 5 scan SSIDs
elo 28 23:09:54 henri-amd NetworkManager[810]: <info>  [1567022994.8056] device (wlp5s0): supplicant interface state: starting -> ready
elo 28 23:09:54 henri-amd NetworkManager[810]: <info>  [1567022994.8057] device (p2p-dev-wlp5s0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
elo 28 23:09:54 henri-amd NetworkManager[810]: <info>  [1567022994.8060] device (wlp5s0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
elo 28 23:09:55 henri-amd ksmserver[1253]: CreateNotify: 125829151
elo 28 23:09:55 henri-amd org_kde_powerdevil[1546]: powerdevil: ACTIVE SESSION PATH CHANGED: "/org/freedesktop/login1/session/_31"
elo 28 23:09:55 henri-amd org_kde_powerdevil[1546]: powerdevil: Current session is now active
elo 28 23:09:55 henri-amd ksmserver[1253]: CreateNotify: 132120580
elo 28 23:09:55 henri-amd ksmserver[1253]: CreateNotify: 130023428
elo 28 23:09:55 henri-amd kscreenlocker_greet[4140]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/UserDelegate.qml:41:5: Unable to assign [undefined] to int
elo 28 23:09:55 henri-amd kdeinit5[1234]: bluedevil: About to resume
elo 28 23:09:55 henri-amd kcminit[4799]: Initializing  "kcm_mouse" :  "kcminit_mouse"
elo 28 23:09:55 henri-amd kcminit[4796]: Initializing  "kcm_mouse" :  "kcminit_mouse"
elo 28 23:09:55 henri-amd ksmserver[1253]: CreateNotify: 134217732
elo 28 23:09:55 henri-amd ksmserver[1253]: CreateNotify: 127926276
elo 28 23:09:55 henri-amd ksmserver[1253]: CreateNotify: 132120581
elo 28 23:09:55 henri-amd ksmserver[1253]: CreateNotify: 130023429
elo 28 23:09:55 henri-amd kcminit[4807]: Initializing  "kcm_mouse" :  "kcminit_mouse"
elo 28 23:09:55 henri-amd kcminit[4806]: Initializing  "kcm_mouse" :  "kcminit_mouse"
elo 28 23:09:55 henri-amd ksmserver[1253]: CreateNotify: 134217733
elo 28 23:09:55 henri-amd ksmserver[1253]: CreateNotify: 127926277
elo 28 23:09:55 henri-amd kwin_x11[1273]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 23833, resource id: 132120580, major code: 18 (ChangeProperty), minor code: 0
elo 28 23:09:55 henri-amd kwin_x11[1273]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 23837, resource id: 130023428, major code: 18 (ChangeProperty), minor code: 0
elo 28 23:09:55 henri-amd kwin_x11[1273]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 23841, resource id: 134217732, major code: 18 (ChangeProperty), minor code: 0
elo 28 23:09:55 henri-amd kwin_x11[1273]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 23845, resource id: 127926276, major code: 18 (ChangeProperty), minor code: 0
elo 28 23:09:55 henri-amd kwin_x11[1273]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 23849, resource id: 132120581, major code: 18 (ChangeProperty), minor code: 0
elo 28 23:09:55 henri-amd kwin_x11[1273]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 23853, resource id: 130023429, major code: 18 (ChangeProperty), minor code: 0
elo 28 23:09:55 henri-amd kwin_x11[1273]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 23857, resource id: 134217733, major code: 18 (ChangeProperty), minor code: 0
elo 28 23:09:55 henri-amd kwin_x11[1273]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 23861, resource id: 127926277, major code: 18 (ChangeProperty), minor code: 0
elo 28 23:09:55 henri-amd ksmserver[1253]: UnmapNotify: 41943113
elo 28 23:09:55 henri-amd ksmserver[1253]: UnmapNotify: 41943114
elo 28 23:09:55 henri-amd ksmserver[1253]: UnmapNotify: 41943115
elo 28 23:09:55 henri-amd ksmserver[1253]: UnmapNotify: 41943116
elo 28 23:09:55 henri-amd ksmserver[1253]: UnmapNotify: 485
elo 28 23:09:55 henri-amd ksmserver[1253]: Unknown toplevel for MapNotify
elo 28 23:09:55 henri-amd ksmserver[1253]: Unknown toplevel for DestroyNotify
elo 28 23:09:55 henri-amd ksmserver[1253]: CreateNotify: 485
elo 28 23:09:55 henri-amd ksmserver[1253]: MapNotify: 485
elo 28 23:09:55 henri-amd kwin_x11[1273]: BlurConfig::instance called after the first use - ignoring
elo 28 23:09:55 henri-amd kwin_x11[1273]: DesktopGridConfig::instance called after the first use - ignoring
elo 28 23:09:55 henri-amd kwin_x11[1273]: KscreenConfig::instance called after the first use - ignoring
elo 28 23:09:55 henri-amd kwin_x11[1273]: PresentWindowsConfig::instance called after the first use - ignoring
elo 28 23:09:55 henri-amd ksmserver[1253]: CreateNotify: 41965426
elo 28 23:09:55 henri-amd ksmserver[1253]: MapNotify: 41965426
elo 28 23:09:55 henri-amd ksmserver[1253]: CreateNotify: 41965427
elo 28 23:09:55 henri-amd ksmserver[1253]: MapNotify: 41965427
elo 28 23:09:55 henri-amd ksmserver[1253]: CreateNotify: 41965428
elo 28 23:09:55 henri-amd ksmserver[1253]: MapNotify: 41965428
elo 28 23:09:55 henri-amd ksmserver[1253]: CreateNotify: 41965429
elo 28 23:09:55 henri-amd ksmserver[1253]: MapNotify: 41965429
elo 28 23:09:55 henri-amd kwin_x11[1273]: SlideConfig::instance called after the first use - ignoring
elo 28 23:09:55 henri-amd kwin_x11[1273]: SlidingPopupsConfig::instance called after the first use - ignoring
elo 28 23:09:55 henri-amd kwin_x11[1273]: ZoomConfig::instance called after the first use - ignoring
elo 28 23:09:55 henri-amd ksmserver[1253]: CreateNotify: 41965431
elo 28 23:09:56 henri-amd ModemManager[807]: <info>  Couldn't check support for device '/sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:04.0/0000:05:00.0': not supported by any plugin
elo 28 23:09:56 henri-amd ModemManager[807]: <info>  Couldn't check support for device '/sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:06.0/0000:07:00.0': not supported by any plugin
elo 28 23:10:03 henri-amd org_kde_powerdevil[1546]: powerdevil: Scheduling inhibition from ":1.12" "My SDL application" with cookie 40 and reason "Playing a game"
elo 28 23:10:03 henri-amd org_kde_powerdevil[1546]: powerdevil: Releasing inhibition with cookie  40
elo 28 23:10:03 henri-amd org_kde_powerdevil[1546]: powerdevil: It was only scheduled for inhibition but not enforced yet, just discarding it
elo 28 23:10:04 henri-amd systemd[1]: NetworkManager-dispatcher.service: Succeeded.
elo 28 23:10:06 henri-amd systemd[1]: Started Getty on tty2.
elo 28 23:10:06 henri-amd rtkit-daemon[1315]: Supervising 16 threads of 7 processes of 1 users.
elo 28 23:10:06 henri-amd rtkit-daemon[1315]: Successfully made thread 4819 of process 1308 owned by '1000' RT at priority 5.
elo 28 23:10:06 henri-amd rtkit-daemon[1315]: Supervising 17 threads of 7 processes of 1 users.
elo 28 23:10:06 henri-amd kernel: fbcon: Taking over console
elo 28 23:10:06 henri-amd kernel: Console: switching to colour frame buffer device 128x48
elo 28 23:10:06 henri-amd org_kde_powerdevil[1546]: powerdevil: ACTIVE SESSION PATH CHANGED: "/"
elo 28 23:10:06 henri-amd org_kde_powerdevil[1546]: powerdevil: Switched to inactive session - leaving unchanged
elo 28 23:10:09 henri-amd login[4818]: pam_unix(login:session): session opened for user henri by LOGIN(uid=0)
elo 28 23:10:09 henri-amd systemd-logind[808]: New session 3 of user henri.
elo 28 23:10:09 henri-amd systemd[1]: Started Session 3 of user henri.
elo 28 23:10:09 henri-amd login[4818]: LOGIN ON tty2 BY henri
elo 28 23:10:09 henri-amd org_kde_powerdevil[1546]: powerdevil: ACTIVE SESSION PATH CHANGED: "/org/freedesktop/login1/session/_33"
elo 28 23:10:09 henri-amd org_kde_powerdevil[1546]: powerdevil: Current session is now inactive
elo 28 23:10:09 henri-amd org_kde_powerdevil[1546]: powerdevil: Enforcing inhibition from ":1.12" "My SDL application" with cookie 40 and reason "Playing a game"
elo 28 23:10:09 henri-amd org_kde_powerdevil[1546]: powerdevil: By the time we wanted to enforce the inhibition it was already gone; discarding it
elo 28 23:10:09 henri-amd rtkit-daemon[1315]: Supervising 16 threads of 7 processes of 1 users.
elo 28 23:10:09 henri-amd rtkit-daemon[1315]: Successfully made thread 4855 of process 1308 owned by '1000' RT at priority 5.
elo 28 23:10:09 henri-amd rtkit-daemon[1315]: Supervising 17 threads of 7 processes of 1 users.
elo 28 23:10:16 henri-amd NetworkManager[810]: <info>  [1567023016.3805] device (enp7s0): carrier: link connected
elo 28 23:10:16 henri-amd NetworkManager[810]: <info>  [1567023016.3806] device (enp7s0): state change: unavailable -> disconnected (reason 'carrier-changed', sys-iface-state: 'managed')
elo 28 23:10:16 henri-amd NetworkManager[810]: <info>  [1567023016.3816] policy: auto-activating connection 'Wired connection 1' (2befcc01-a604-371d-a46b-0b5f6889e1ee)
elo 28 23:10:16 henri-amd NetworkManager[810]: <info>  [1567023016.3821] device (enp7s0): Activation: starting connection 'Wired connection 1' (2befcc01-a604-371d-a46b-0b5f6889e1ee)
elo 28 23:10:16 henri-amd NetworkManager[810]: <info>  [1567023016.3822] device (enp7s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
elo 28 23:10:16 henri-amd kernel: igb 0000:07:00.0 enp7s0: igb: enp7s0 NIC Link is Up 100 Mbps Full Duplex, Flow Control: RX
elo 28 23:10:16 henri-amd kernel: IPv6: ADDRCONF(NETDEV_CHANGE): enp7s0: link becomes ready
elo 28 23:10:16 henri-amd NetworkManager[810]: <info>  [1567023016.3825] manager: NetworkManager state is now CONNECTING
elo 28 23:10:16 henri-amd NetworkManager[810]: <info>  [1567023016.3827] device (enp7s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
elo 28 23:10:16 henri-amd NetworkManager[810]: <info>  [1567023016.3833] device (enp7s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
elo 28 23:10:16 henri-amd NetworkManager[810]: <info>  [1567023016.3835] dhcp4 (enp7s0): activation: beginning transaction (timeout in 45 seconds)
elo 28 23:10:16 henri-amd avahi-daemon[805]: Joining mDNS multicast group on interface enp7s0.IPv6 with address fe80::cb98:bb2c:922f:89b5.
elo 28 23:10:16 henri-amd avahi-daemon[805]: New relevant interface enp7s0.IPv6 for mDNS.
elo 28 23:10:16 henri-amd avahi-daemon[805]: Registering new address record for fe80::cb98:bb2c:922f:89b5 on enp7s0.*.
elo 28 23:10:16 henri-amd kdeinit5[1234]: plasma-nm: Unhandled active connection state change:  1
elo 28 23:10:18 henri-amd dbus-daemon[809]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.2' (uid=0 pid=810 comm="/usr/bin/NetworkManager --no-daemon " label="unconfined")
elo 28 23:10:18 henri-amd systemd[1]: Starting Network Manager Script Dispatcher Service...
elo 28 23:10:18 henri-amd dbus-daemon[809]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
elo 28 23:10:18 henri-amd systemd[1]: Started Network Manager Script Dispatcher Service.
elo 28 23:10:20 henri-amd ksmserver[1253]: CreateNotify: 127926276
elo 28 23:10:22 henri-amd NetworkManager[810]: <info>  [1567023022.0359] dhcp4 (enp7s0): state changed unknown -> bound
elo 28 23:10:22 henri-amd avahi-daemon[805]: Joining mDNS multicast group on interface enp7s0.IPv4 with address 192.168.1.207.
elo 28 23:10:22 henri-amd avahi-daemon[805]: New relevant interface enp7s0.IPv4 for mDNS.
elo 28 23:10:22 henri-amd avahi-daemon[805]: Registering new address record for 192.168.1.207 on enp7s0.IPv4.
elo 28 23:10:22 henri-amd NetworkManager[810]: <info>  [1567023022.0369] device (enp7s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
elo 28 23:10:22 henri-amd NetworkManager[810]: <info>  [1567023022.0392] device (enp7s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
elo 28 23:10:22 henri-amd NetworkManager[810]: <info>  [1567023022.0395] device (enp7s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
elo 28 23:10:22 henri-amd NetworkManager[810]: <info>  [1567023022.0399] manager: NetworkManager state is now CONNECTED_LOCAL
elo 28 23:10:22 henri-amd NetworkManager[810]: <info>  [1567023022.0408] manager: NetworkManager state is now CONNECTED_SITE
elo 28 23:10:22 henri-amd NetworkManager[810]: <info>  [1567023022.0409] policy: set 'Wired connection 1' (enp7s0) as default for IPv4 routing and DNS
elo 28 23:10:22 henri-amd NetworkManager[810]: <info>  [1567023022.0442] device (enp7s0): Activation: successful, device activated.
Any help trying to get this sorted out would be greatly appreciated!
And here's the Xorg.0.log:
[     3.738] (--) Log file renamed from "/var/log/Xorg.pid-1161.log" to "/var/log/Xorg.0.log"
[     3.739]
X.Org X Server 1.20.5
[     3.739] Build Operating System: Linux Arch Linux
[     3.739] Current Operating System: Linux henri-amd 5.2.10-1-MANJARO #1 SMP PREEMPT Sun Aug 25 16:12:12 UTC 2019 x86_64
[     3.739] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.2-x86_64 root=UUID=445dc905-7d08-4da5-91c9-aaf0327a09e5 rw quiet apparmor=1 security=apparmor udev.log_priority=3 audit=0
[     3.739] Build Date: 14 August 2019  10:50:56PM
[     3.739]
[     3.739] Current version of pixman: 0.38.4
[     3.739] 	Before reporting problems, check http://wiki.x.org
[     3.739] Markers: (--) probed, (**) from config file, (==) default setting,
[     3.739] (==) Log file: "/var/log/Xorg.0.log", Time: Wed Aug 28 22:53:06 2019
[     3.740] (==) Using config directory: "/etc/X11/xorg.conf.d"
[     3.740] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[     3.740] (==) ServerLayout "Layout0"
[     3.740] (**) |-->Screen "Screen0" (0)
[     3.740] (**) |   |-->Monitor "Monitor0"
[     3.741] (**) |   |-->Device "Device0"
[     3.741] (**) |-->Input Device "Keyboard0"
[     3.741] (**) |-->Input Device "Mouse0"
[     3.741] (==) Automatically adding devices
[     3.741] (==) Automatically enabling devices
[     3.741] (==) Automatically adding GPU devices
[     3.741] (==) Automatically binding GPU devices
[     3.741] (==) Max clients allowed: 256, resource mask: 0x1fffff
[     3.742] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[     3.742] 	Entry deleted from font path.
[     3.742] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[     3.742] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi".
[     3.742] 	(Run 'mkfontdir' on "/usr/share/fonts/100dpi").
[     3.742] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi".
[     3.742] 	(Run 'mkfontdir' on "/usr/share/fonts/75dpi").
[     3.742] (==) FontPath set to:
	/usr/share/fonts/misc,
	/usr/share/fonts/TTF
[     3.742] (==) ModulePath set to "/usr/lib/xorg/modules"
[     3.742] (**) Extension "COMPOSITE" is enabled
[     3.742] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[     3.742] (WW) Disabling Keyboard0
[     3.742] (WW) Disabling Mouse0
[     3.742] (II) Module ABI versions:
[     3.742] 	X.Org ANSI C Emulation: 0.4
[     3.742] 	X.Org Video Driver: 24.0
[     3.742] 	X.Org XInput driver : 24.1
[     3.742] 	X.Org Server Extension : 10.0
[     3.743] (++) using VT number 1
[     3.743] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[     3.743] (II) xfree86: Adding drm device (/dev/dri/card0)
[     3.744] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[     3.744] (**) OutputClass "nvidia" setting /dev/dri/card0 as PrimaryGPU
[     3.745] (--) PCI:*(11@0:0:0) 10de:1b06:1043:85e4 rev 161, Mem @ 0xf6000000/16777216, 0xe0000000/268435456, 0xf0000000/33554432, I/O @ 0x0000f000/128, BIOS @ 0x????????/524288
[     3.745] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[     3.745] (II) LoadModule: "glx"
[     3.745] (II) Loading /usr/lib/nvidia/xorg/libglx.so
[     3.757] (II) Module glx: vendor="NVIDIA Corporation"
[     3.757] 	compiled for 1.6.99.901, module version = 1.0.0
[     3.757] 	Module class: X.Org Server Extension
[     3.757] (II) NVIDIA GLX Module  430.40  Sun Jul 21 05:00:26 CDT 2019
[     3.757] (II) LoadModule: "nvidia"
[     3.757] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[     3.759] (II) Module nvidia: vendor="NVIDIA Corporation"
[     3.759] 	compiled for 1.6.99.901, module version = 1.0.0
[     3.759] 	Module class: X.Org Video Driver
[     3.759] (II) NVIDIA dlloader X Driver  430.40  Sun Jul 21 05:01:54 CDT 2019
[     3.759] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[     3.760] (II) Loading sub module "fb"
[     3.760] (II) LoadModule: "fb"
[     3.760] (II) Loading /usr/lib/xorg/modules/libfb.so
[     3.760] (II) Module fb: vendor="X.Org Foundation"
[     3.760] 	compiled for 1.20.5, module version = 1.0.0
[     3.760] 	ABI class: X.Org ANSI C Emulation, version 0.4
[     3.760] (II) Loading sub module "wfb"
[     3.760] (II) LoadModule: "wfb"
[     3.760] (II) Loading /usr/lib/xorg/modules/libwfb.so
[     3.761] (II) Module wfb: vendor="X.Org Foundation"
[     3.761] 	compiled for 1.20.5, module version = 1.0.0
[     3.761] 	ABI class: X.Org ANSI C Emulation, version 0.4
[     3.761] (II) Loading sub module "ramdac"
[     3.761] (II) LoadModule: "ramdac"
[     3.761] (II) Module "ramdac" already built-in
[     3.770] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[     3.770] (==) NVIDIA(0): RGB weight 888
[     3.770] (==) NVIDIA(0): Default visual is TrueColor
[     3.770] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[     3.770] (II) Applying OutputClass "nvidia" options to /dev/dri/card0
[     3.770] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[     3.770] (**) NVIDIA(0): Enabling 2D acceleration
[     4.589] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:11:0:0
[     4.589] (--) NVIDIA(0):     DFP-0
[     4.589] (--) NVIDIA(0):     DFP-1
[     4.589] (--) NVIDIA(0):     DFP-2
[     4.589] (--) NVIDIA(0):     DFP-3
[     4.589] (--) NVIDIA(0):     DFP-4
[     4.589] (--) NVIDIA(0):     DFP-5 (boot)
[     4.589] (--) NVIDIA(0):     DFP-6
[     4.590] (II) NVIDIA(0): NVIDIA GPU GeForce GTX 1080 Ti (GP102-A) at PCI:11:0:0
[     4.590] (II) NVIDIA(0):     (GPU-0)
[     4.590] (--) NVIDIA(0): Memory: 11534336 kBytes
[     4.590] (--) NVIDIA(0): VideoBIOS: 86.02.39.00.23
[     4.590] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[     4.590] (--) NVIDIA(GPU-0): DFP-0: disconnected
[     4.590] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[     4.590] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[     4.590] (--) NVIDIA(GPU-0): DFP-1: disconnected
[     4.590] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[     4.590] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[     4.590] (--) NVIDIA(GPU-0): DFP-2: disconnected
[     4.590] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[     4.590] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[     4.590] (--) NVIDIA(GPU-0): DELL U2515H (DFP-3): connected
[     4.590] (--) NVIDIA(GPU-0): DELL U2515H (DFP-3): Internal DisplayPort
[     4.590] (--) NVIDIA(GPU-0): DELL U2515H (DFP-3): 1440.0 MHz maximum pixel clock
[     4.593] (--) NVIDIA(GPU-0): DFP-4: disconnected
[     4.593] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[     4.593] (--) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
[     4.735] (--) NVIDIA(GPU-0): Acer XB271HK (DFP-5): connected
[     4.735] (--) NVIDIA(GPU-0): Acer XB271HK (DFP-5): Internal DisplayPort
[     4.735] (--) NVIDIA(GPU-0): Acer XB271HK (DFP-5): 1440.0 MHz maximum pixel clock
[     4.737] (--) NVIDIA(GPU-0): DFP-6: disconnected
[     4.737] (--) NVIDIA(GPU-0): DFP-6: Internal TMDS
[     4.737] (--) NVIDIA(GPU-0): DFP-6: 165.0 MHz maximum pixel clock
[     4.741] (==) NVIDIA(0):
[     4.741] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[     4.741] (==) NVIDIA(0):     will be used as the requested mode.
[     4.741] (II) NVIDIA(0): Validated MetaModes:
[     4.741] (II) NVIDIA(0):     "DFP-5:nvidia-auto-select,DFP-3:nvidia-auto-select"
[     4.741] (II) NVIDIA(0): Virtual screen size determined to be 6400 x 2160
[     4.744] (--) NVIDIA(0): DPI set to (162, 161); computed from "UseEdidDpi" X config
[     4.744] (--) NVIDIA(0):     option
[     4.744] (II) NVIDIA: Using 24576.00 MB of virtual memory for indirect memory
[     4.744] (II) NVIDIA:     access.
[     4.746] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[     4.746] (II) NVIDIA(0):     may not be running or the "AcpidSocketPath" X
[     4.746] (II) NVIDIA(0):     configuration option may not be set correctly.  When the
[     4.746] (II) NVIDIA(0):     ACPI event daemon is available, the NVIDIA X driver will
[     4.746] (II) NVIDIA(0):     try to use it to receive ACPI event notifications.  For
[     4.746] (II) NVIDIA(0):     details, please see the "ConnectToAcpid" and
[     4.746] (II) NVIDIA(0):     "AcpidSocketPath" X configuration options in Appendix B: X
[     4.746] (II) NVIDIA(0):     Config Options in the README.
[     4.764] (II) NVIDIA(0): Setting mode "DFP-5:nvidia-auto-select,DFP-3:nvidia-auto-select"
[     4.866] (==) NVIDIA(0): Disabling shared memory pixmaps
[     4.866] (==) NVIDIA(0): Backing store enabled
[     4.866] (==) NVIDIA(0): Silken mouse disabled
[     4.866] (**) NVIDIA(0): DPMS enabled
[     4.866] (WW) NVIDIA(0): Option "PrimaryGPU" is not used
[     4.866] (WW) NVIDIA(0): Option "NoLogo" is not used
[     4.866] (II) Loading sub module "dri2"
[     4.866] (II) LoadModule: "dri2"
[     4.866] (II) Module "dri2" already built-in
[     4.866] (II) NVIDIA(0): [DRI2] Setup complete
[     4.866] (II) NVIDIA(0): [DRI2]   VDPAU driver: nvidia
[     4.866] (II) Initializing extension Generic Event Extension
[     4.866] (II) Initializing extension SHAPE
[     4.866] (II) Initializing extension MIT-SHM
[     4.867] (II) Initializing extension XInputExtension
[     4.867] (II) Initializing extension XTEST
[     4.867] (II) Initializing extension BIG-REQUESTS
[     4.867] (II) Initializing extension SYNC
[     4.867] (II) Initializing extension XKEYBOARD
[     4.867] (II) Initializing extension XC-MISC
[     4.867] (II) Initializing extension SECURITY
[     4.867] (II) Initializing extension XFIXES
[     4.867] (II) Initializing extension RENDER
[     4.867] (II) Initializing extension RANDR
[     4.867] (II) Initializing extension COMPOSITE
[     4.867] (II) Initializing extension DAMAGE
[     4.867] (II) Initializing extension MIT-SCREEN-SAVER
[     4.867] (II) Initializing extension DOUBLE-BUFFER
[     4.867] (II) Initializing extension RECORD
[     4.867] (II) Initializing extension DPMS
[     4.867] (II) Initializing extension Present
[     4.868] (II) Initializing extension DRI3
[     4.868] (II) Initializing extension X-Resource
[     4.868] (II) Initializing extension XVideo
[     4.868] (II) Initializing extension XVideo-MotionCompensation
[     4.868] (II) Initializing extension GLX
[     4.868] (II) Indirect GLX disabled.
[     4.868] (II) Initializing extension XFree86-VidModeExtension
[     4.868] (II) Initializing extension XFree86-DGA
[     4.868] (II) Initializing extension XFree86-DRI
[     4.868] (II) Initializing extension DRI2
[     4.868] (II) Initializing extension NV-GLX
[     4.868] (II) Initializing extension NV-CONTROL
[     4.868] (II) Initializing extension XINERAMA
[     4.905] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[     4.905] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[     4.905] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[     4.905] (**) Power Button: Applying InputClass "system-keyboard"
[     4.905] (**) Power Button: Applying InputClass "Keyboard Defaults"
[     4.905] (II) LoadModule: "libinput"
[     4.905] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[     4.907] (II) Module libinput: vendor="X.Org Foundation"
[     4.907] 	compiled for 1.20.5, module version = 0.29.0
[     4.907] 	Module class: X.Org XInput Driver
[     4.907] 	ABI class: X.Org XInput driver, version 24.1
[     4.907] (II) Using input driver 'libinput' for 'Power Button'
[     4.907] (**) Power Button: always reports core events
[     4.907] (**) Option "Device" "/dev/input/event1"
[     4.907] (**) Option "_source" "server/udev"
[     4.911] (II) event1  - Power Button: is tagged by udev as: Keyboard
[     4.911] (II) event1  - Power Button: device is a keyboard
[     4.911] (II) event1  - Power Button: device removed
[     4.943] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[     4.943] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[     4.943] (**) Option "xkb_model" "pc105"
[     4.943] (**) Option "xkb_layout" "fi"
[     4.943] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[     4.962] (II) event1  - Power Button: is tagged by udev as: Keyboard
[     4.962] (II) event1  - Power Button: device is a keyboard
[     4.963] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[     4.963] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[     4.963] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[     4.963] (**) Power Button: Applying InputClass "system-keyboard"
[     4.963] (**) Power Button: Applying InputClass "Keyboard Defaults"
[     4.963] (II) Using input driver 'libinput' for 'Power Button'
[     4.963] (**) Power Button: always reports core events
[     4.963] (**) Option "Device" "/dev/input/event0"
[     4.963] (**) Option "_source" "server/udev"
[     4.963] (II) event0  - Power Button: is tagged by udev as: Keyboard
[     4.963] (II) event0  - Power Button: device is a keyboard
[     4.963] (II) event0  - Power Button: device removed
[     4.996] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[     4.996] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[     4.996] (**) Option "xkb_model" "pc105"
[     4.996] (**) Option "xkb_layout" "fi"
[     4.996] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[     4.997] (II) event0  - Power Button: is tagged by udev as: Keyboard
[     4.997] (II) event0  - Power Button: device is a keyboard
[     4.998] (II) config/udev: Adding input device HDA Creative Mic (/dev/input/event23)
[     4.998] (II) No input driver specified, ignoring this device.
[     4.998] (II) This device may have been added with another device file.
[     4.998] (II) config/udev: Adding input device HDA Creative Line Out Surround (/dev/input/event24)
[     4.998] (II) config/udev: Adding input device HDA Creative Line Out CLFE (/dev/input/event25)
[     4.999] (II) config/udev: Adding input device HDA Creative Front Headphone (/dev/input/event26)
[     4.999] (II) No input driver specified, ignoring this device.
[     4.999] (II) This device may have been added with another device file.
[     4.999] (II) config/udev: Adding input device E-Signal USB Gaming Keyboard (/dev/input/event2)
[     4.999] (**) E-Signal USB Gaming Keyboard: Applying InputClass "evdev keyboard catchall"
[     5.000] (**) E-Signal USB Gaming Keyboard: Applying InputClass "libinput keyboard catchall"
[     5.000] (**) E-Signal USB Gaming Keyboard: Applying InputClass "system-keyboard"
[     5.000] (**) E-Signal USB Gaming Keyboard: Applying InputClass "Keyboard Defaults"
[     5.000] (II) Using input driver 'libinput' for 'E-Signal USB Gaming Keyboard'
[     5.000] (**) E-Signal USB Gaming Keyboard: always reports core events
[     5.000] (**) Option "Device" "/dev/input/event2"
[     5.000] (**) Option "_source" "server/udev"
[     5.001] (II) event2  - E-Signal USB Gaming Keyboard: is tagged by udev as: Keyboard
[     5.001] (II) event2  - E-Signal USB Gaming Keyboard: device is a keyboard
[     5.001] (II) event2  - E-Signal USB Gaming Keyboard: device removed
[     5.036] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:08:00.1/usb1/1-3/1-3:1.0/0003:04D9:A002.0002/input/input2/event2"
[     5.036] (II) XINPUT: Adding extended input device "E-Signal USB Gaming Keyboard" (type: KEYBOARD, id 8)
[     5.036] (**) Option "xkb_model" "pc105"
[     5.036] (**) Option "xkb_layout" "fi"
[     5.036] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[     5.037] (II) event2  - E-Signal USB Gaming Keyboard: is tagged by udev as: Keyboard
[     5.037] (II) event2  - E-Signal USB Gaming Keyboard: device is a keyboard
[     5.038] (II) config/udev: Adding input device E-Signal USB Gaming Keyboard Mouse (/dev/input/event3)
[     5.038] (**) E-Signal USB Gaming Keyboard Mouse: Applying InputClass "evdev pointer catchall"
[     5.038] (**) E-Signal USB Gaming Keyboard Mouse: Applying InputClass "libinput pointer catchall"
[     5.038] (II) Using input driver 'libinput' for 'E-Signal USB Gaming Keyboard Mouse'
[     5.038] (**) E-Signal USB Gaming Keyboard Mouse: always reports core events
[     5.038] (**) Option "Device" "/dev/input/event3"
[     5.038] (**) Option "_source" "server/udev"
[     5.039] (II) event3  - E-Signal USB Gaming Keyboard Mouse: is tagged by udev as: Mouse
[     5.039] (II) event3  - E-Signal USB Gaming Keyboard Mouse: device is a pointer
[     5.039] (II) event3  - E-Signal USB Gaming Keyboard Mouse: device removed
[     5.090] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:08:00.1/usb1/1-3/1-3:1.1/0003:04D9:A002.0003/input/input3/event3"
[     5.090] (II) XINPUT: Adding extended input device "E-Signal USB Gaming Keyboard Mouse" (type: MOUSE, id 9)
[     5.090] (**) Option "AccelerationScheme" "none"
[     5.090] (**) E-Signal USB Gaming Keyboard Mouse: (accel) selected scheme none/0
[     5.090] (**) E-Signal USB Gaming Keyboard Mouse: (accel) acceleration factor: 2.000
[     5.090] (**) E-Signal USB Gaming Keyboard Mouse: (accel) acceleration threshold: 4
[     5.091] (II) event3  - E-Signal USB Gaming Keyboard Mouse: is tagged by udev as: Mouse
[     5.091] (II) event3  - E-Signal USB Gaming Keyboard Mouse: device is a pointer
[     5.091] (II) config/udev: Adding input device E-Signal USB Gaming Keyboard Mouse (/dev/input/mouse0)
[     5.091] (II) No input driver specified, ignoring this device.
[     5.091] (II) This device may have been added with another device file.
[     5.092] (II) config/udev: Adding input device E-Signal USB Gaming Keyboard System Control (/dev/input/event4)
[     5.092] (**) E-Signal USB Gaming Keyboard System Control: Applying InputClass "evdev keyboard catchall"
[     5.092] (**) E-Signal USB Gaming Keyboard System Control: Applying InputClass "libinput keyboard catchall"
[     5.092] (**) E-Signal USB Gaming Keyboard System Control: Applying InputClass "system-keyboard"
[     5.092] (**) E-Signal USB Gaming Keyboard System Control: Applying InputClass "Keyboard Defaults"
[     5.092] (II) Using input driver 'libinput' for 'E-Signal USB Gaming Keyboard System Control'
[     5.092] (**) E-Signal USB Gaming Keyboard System Control: always reports core events
[     5.092] (**) Option "Device" "/dev/input/event4"
[     5.092] (**) Option "_source" "server/udev"
[     5.093] (II) event4  - E-Signal USB Gaming Keyboard System Control: is tagged by udev as: Keyboard
[     5.093] (II) event4  - E-Signal USB Gaming Keyboard System Control: device is a keyboard
[     5.093] (II) event4  - E-Signal USB Gaming Keyboard System Control: device removed
[     5.130] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:08:00.1/usb1/1-3/1-3:1.1/0003:04D9:A002.0003/input/input4/event4"
[     5.130] (II) XINPUT: Adding extended input device "E-Signal USB Gaming Keyboard System Control" (type: KEYBOARD, id 10)
[     5.130] (**) Option "xkb_model" "pc105"
[     5.130] (**) Option "xkb_layout" "fi"
[     5.130] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[     5.131] (II) event4  - E-Signal USB Gaming Keyboard System Control: is tagged by udev as: Keyboard
[     5.131] (II) event4  - E-Signal USB Gaming Keyboard System Control: device is a keyboard
[     5.131] (II) config/udev: Adding input device E-Signal USB Gaming Keyboard Consumer Control (/dev/input/event5)
[     5.131] (**) E-Signal USB Gaming Keyboard Consumer Control: Applying InputClass "evdev keyboard catchall"
[     5.131] (**) E-Signal USB Gaming Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[     5.131] (**) E-Signal USB Gaming Keyboard Consumer Control: Applying InputClass "system-keyboard"
[     5.131] (**) E-Signal USB Gaming Keyboard Consumer Control: Applying InputClass "Keyboard Defaults"
[     5.131] (II) Using input driver 'libinput' for 'E-Signal USB Gaming Keyboard Consumer Control'
[     5.131] (**) E-Signal USB Gaming Keyboard Consumer Control: always reports core events
[     5.131] (**) Option "Device" "/dev/input/event5"
[     5.131] (**) Option "_source" "server/udev"
[     5.133] (II) event5  - E-Signal USB Gaming Keyboard Consumer Control: is tagged by udev as: Keyboard
[     5.133] (II) event5  - E-Signal USB Gaming Keyboard Consumer Control: device is a keyboard
[     5.133] (II) event5  - E-Signal USB Gaming Keyboard Consumer Control: device removed
[     5.156] (II) libinput: E-Signal USB Gaming Keyboard Consumer Control: needs a virtual subdevice
[     5.156] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:08:00.1/usb1/1-3/1-3:1.1/0003:04D9:A002.0003/input/input5/event5"
[     5.156] (II) XINPUT: Adding extended input device "E-Signal USB Gaming Keyboard Consumer Control" (type: MOUSE, id 11)
[     5.156] (**) Option "AccelerationScheme" "none"
[     5.156] (**) E-Signal USB Gaming Keyboard Consumer Control: (accel) selected scheme none/0
[     5.156] (**) E-Signal USB Gaming Keyboard Consumer Control: (accel) acceleration factor: 2.000
[     5.156] (**) E-Signal USB Gaming Keyboard Consumer Control: (accel) acceleration threshold: 4
[     5.158] (II) event5  - E-Signal USB Gaming Keyboard Consumer Control: is tagged by udev as: Keyboard
[     5.158] (II) event5  - E-Signal USB Gaming Keyboard Consumer Control: device is a keyboard
[     5.158] (II) config/udev: Adding input device Logitech Gaming Mouse G502 (/dev/input/event7)
[     5.158] (**) Logitech Gaming Mouse G502: Applying InputClass "evdev pointer catchall"
[     5.158] (**) Logitech Gaming Mouse G502: Applying InputClass "libinput pointer catchall"
[     5.158] (II) Using input driver 'libinput' for 'Logitech Gaming Mouse G502'
[     5.158] (**) Logitech Gaming Mouse G502: always reports core events
[     5.158] (**) Option "Device" "/dev/input/event7"
[     5.158] (**) Option "_source" "server/udev"
[     5.214] (II) event7  - Logitech Gaming Mouse G502: is tagged by udev as: Mouse
[     5.214] (II) event7  - Logitech Gaming Mouse G502: device set to 2400 DPI
[     5.214] (II) event7  - Logitech Gaming Mouse G502: device is a pointer
[     5.214] (II) event7  - Logitech Gaming Mouse G502: device removed
[     5.277] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:08:00.1/usb1/1-4/1-4:1.0/0003:046D:C332.0006/input/input8/event7"
[     5.277] (II) XINPUT: Adding extended input device "Logitech Gaming Mouse G502" (type: MOUSE, id 12)
[     5.277] (**) Option "AccelerationScheme" "none"
[     5.277] (**) Logitech Gaming Mouse G502: (accel) selected scheme none/0
[     5.277] (**) Logitech Gaming Mouse G502: (accel) acceleration factor: 2.000
[     5.277] (**) Logitech Gaming Mouse G502: (accel) acceleration threshold: 4
[     5.334] (II) event7  - Logitech Gaming Mouse G502: is tagged by udev as: Mouse
[     5.334] (II) event7  - Logitech Gaming Mouse G502: device set to 2400 DPI
[     5.334] (II) event7  - Logitech Gaming Mouse G502: device is a pointer
[     5.335] (II) config/udev: Adding input device Logitech Gaming Mouse G502 (/dev/input/mouse1)
[     5.335] (II) No input driver specified, ignoring this device.
[     5.335] (II) This device may have been added with another device file.
[     5.336] (II) config/udev: Adding input device Logitech Gaming Mouse G502 Consumer Control (/dev/input/event10)
[     5.336] (**) Logitech Gaming Mouse G502 Consumer Control: Applying InputClass "evdev keyboard catchall"
[     5.336] (**) Logitech Gaming Mouse G502 Consumer Control: Applying InputClass "libinput keyboard catchall"
[     5.336] (**) Logitech Gaming Mouse G502 Consumer Control: Applying InputClass "system-keyboard"
[     5.336] (**) Logitech Gaming Mouse G502 Consumer Control: Applying InputClass "Keyboard Defaults"
[     5.336] (II) Using input driver 'libinput' for 'Logitech Gaming Mouse G502 Consumer Control'
[     5.336] (**) Logitech Gaming Mouse G502 Consumer Control: always reports core events
[     5.336] (**) Option "Device" "/dev/input/event10"
[     5.336] (**) Option "_source" "server/udev"
[     5.337] (II) event10 - Logitech Gaming Mouse G502 Consumer Control: is tagged by udev as: Keyboard
[     5.337] (II) event10 - Logitech Gaming Mouse G502 Consumer Control: device is a keyboard
[     5.337] (II) event10 - Logitech Gaming Mouse G502 Consumer Control: device removed
[     5.370] (II) libinput: Logitech Gaming Mouse G502 Consumer Control: needs a virtual subdevice
[     5.370] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:08:00.1/usb1/1-4/1-4:1.1/0003:046D:C332.0007/input/input10/event10"
[     5.370] (II) XINPUT: Adding extended input device "Logitech Gaming Mouse G502 Consumer Control" (type: MOUSE, id 13)
[     5.370] (**) Option "AccelerationScheme" "none"
[     5.370] (**) Logitech Gaming Mouse G502 Consumer Control: (accel) selected scheme none/0
[     5.370] (**) Logitech Gaming Mouse G502 Consumer Control: (accel) acceleration factor: 2.000
[     5.370] (**) Logitech Gaming Mouse G502 Consumer Control: (accel) acceleration threshold: 4
[     5.371] (II) event10 - Logitech Gaming Mouse G502 Consumer Control: is tagged by udev as: Keyboard
[     5.371] (II) event10 - Logitech Gaming Mouse G502 Consumer Control: device is a keyboard
[     5.371] (II) config/udev: Adding input device Logitech Gaming Mouse G502 System Control (/dev/input/event12)
[     5.371] (**) Logitech Gaming Mouse G502 System Control: Applying InputClass "evdev keyboard catchall"
[     5.371] (**) Logitech Gaming Mouse G502 System Control: Applying InputClass "libinput keyboard catchall"
[     5.371] (**) Logitech Gaming Mouse G502 System Control: Applying InputClass "system-keyboard"
[     5.371] (**) Logitech Gaming Mouse G502 System Control: Applying InputClass "Keyboard Defaults"
[     5.371] (II) Using input driver 'libinput' for 'Logitech Gaming Mouse G502 System Control'
[     5.371] (**) Logitech Gaming Mouse G502 System Control: always reports core events
[     5.371] (**) Option "Device" "/dev/input/event12"
[     5.371] (**) Option "_source" "server/udev"
[     5.372] (II) event12 - Logitech Gaming Mouse G502 System Control: is tagged by udev as: Keyboard
[     5.372] (II) event12 - Logitech Gaming Mouse G502 System Control: device is a keyboard
[     5.372] (II) event12 - Logitech Gaming Mouse G502 System Control: device removed
[     5.396] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:08:00.1/usb1/1-4/1-4:1.1/0003:046D:C332.0007/input/input11/event12"
[     5.396] (II) XINPUT: Adding extended input device "Logitech Gaming Mouse G502 System Control" (type: KEYBOARD, id 14)
[     5.396] (**) Option "xkb_model" "pc105"
[     5.396] (**) Option "xkb_layout" "fi"
[     5.396] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[     5.397] (II) event12 - Logitech Gaming Mouse G502 System Control: is tagged by udev as: Keyboard
[     5.398] (II) event12 - Logitech Gaming Mouse G502 System Control: device is a keyboard
[     5.398] (II) config/udev: Adding input device Logitech Gaming Mouse G502 Keyboard (/dev/input/event8)
[     5.398] (**) Logitech Gaming Mouse G502 Keyboard: Applying InputClass "evdev keyboard catchall"
[     5.398] (**) Logitech Gaming Mouse G502 Keyboard: Applying InputClass "libinput keyboard catchall"
[     5.398] (**) Logitech Gaming Mouse G502 Keyboard: Applying InputClass "system-keyboard"
[     5.398] (**) Logitech Gaming Mouse G502 Keyboard: Applying InputClass "Keyboard Defaults"
[     5.398] (II) Using input driver 'libinput' for 'Logitech Gaming Mouse G502 Keyboard'
[     5.398] (**) Logitech Gaming Mouse G502 Keyboard: always reports core events
[     5.398] (**) Option "Device" "/dev/input/event8"
[     5.398] (**) Option "_source" "server/udev"
[     5.399] (II) event8  - Logitech Gaming Mouse G502 Keyboard: is tagged by udev as: Keyboard
[     5.399] (II) event8  - Logitech Gaming Mouse G502 Keyboard: device is a keyboard
[     5.399] (II) event8  - Logitech Gaming Mouse G502 Keyboard: device removed
[     5.423] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:08:00.1/usb1/1-4/1-4:1.1/0003:046D:C332.0007/input/input9/event8"
[     5.423] (II) XINPUT: Adding extended input device "Logitech Gaming Mouse G502 Keyboard" (type: KEYBOARD, id 15)
[     5.423] (**) Option "xkb_model" "pc105"
[     5.423] (**) Option "xkb_layout" "fi"
[     5.423] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[     5.425] (II) event8  - Logitech Gaming Mouse G502 Keyboard: is tagged by udev as: Keyboard
[     5.425] (II) event8  - Logitech Gaming Mouse G502 Keyboard: device is a keyboard
[     5.425] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event19)
[     5.425] (II) No input driver specified, ignoring this device.
[     5.425] (II) This device may have been added with another device file.
[     5.425] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event20)
[     5.426] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event21)
[     5.426] (II) No input driver specified, ignoring this device.
[     5.426] (II) This device may have been added with another device file.
[     5.426] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event22)
[     5.426] (II) config/udev: Adding input device HD-Audio Generic Front Mic (/dev/input/event11)
[     5.426] (II) config/udev: Adding input device HD-Audio Generic Rear Mic (/dev/input/event13)
[     5.426] (II) config/udev: Adding input device HD-Audio Generic Line (/dev/input/event14)
[     5.427] (II) No input driver specified, ignoring this device.
[     5.427] (II) This device may have been added with another device file.
[     5.427] (II) config/udev: Adding input device HD-Audio Generic Line Out Front (/dev/input/event15)
[     5.427] (II) config/udev: Adding input device HD-Audio Generic Line Out Surround (/dev/input/event16)
[     5.427] (II) config/udev: Adding input device HD-Audio Generic Line Out CLFE (/dev/input/event17)
[     5.427] (II) config/udev: Adding input device HD-Audio Generic Front Headphone (/dev/input/event18)
[     5.428] (II) No input driver specified, ignoring this device.
[     5.428] (II) This device may have been added with another device file.
[     5.428] (II) config/udev: Adding input device Eee PC WMI hotkeys (/dev/input/event9)
[     5.428] (**) Eee PC WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[     5.428] (**) Eee PC WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[     5.428] (**) Eee PC WMI hotkeys: Applying InputClass "system-keyboard"
[     5.428] (**) Eee PC WMI hotkeys: Applying InputClass "Keyboard Defaults"
[     5.428] (II) Using input driver 'libinput' for 'Eee PC WMI hotkeys'
[     5.428] (**) Eee PC WMI hotkeys: always reports core events
[     5.428] (**) Option "Device" "/dev/input/event9"
[     5.428] (**) Option "_source" "server/udev"
[     5.429] (II) event9  - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[     5.429] (II) event9  - Eee PC WMI hotkeys: device is a keyboard
[     5.429] (II) event9  - Eee PC WMI hotkeys: device removed
[     5.490] (**) Option "config_info" "udev:/sys/devices/platform/eeepc-wmi/input/input14/event9"
[     5.490] (II) XINPUT: Adding extended input device "Eee PC WMI hotkeys" (type: KEYBOARD, id 16)
[     5.490] (**) Option "xkb_model" "pc105"
[     5.490] (**) Option "xkb_layout" "fi"
[     5.490] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[     5.491] (II) event9  - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[     5.491] (II) event9  - Eee PC WMI hotkeys: device is a keyboard
[     5.492] (II) config/udev: Adding input device PC Speaker (/dev/input/event6)
[     5.492] (II) No input driver specified, ignoring this device.
[     5.492] (II) This device may have been added with another device file.
[     5.495] (**) E-Signal USB Gaming Keyboard Consumer Control: Applying InputClass "evdev keyboard catchall"
[     5.495] (**) E-Signal USB Gaming Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[     5.495] (**) E-Signal USB Gaming Keyboard Consumer Control: Applying InputClass "system-keyboard"
[     5.495] (**) E-Signal USB Gaming Keyboard Consumer Control: Applying InputClass "Keyboard Defaults"
[     5.495] (II) Using input driver 'libinput' for 'E-Signal USB Gaming Keyboard Consumer Control'
[     5.495] (**) E-Signal USB Gaming Keyboard Consumer Control: always reports core events
[     5.495] (**) Option "Device" "/dev/input/event5"
[     5.495] (**) Option "_source" "_driver/libinput"
[     5.495] (II) libinput: E-Signal USB Gaming Keyboard Consumer Control: is a virtual subdevice
[     5.495] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:08:00.1/usb1/1-3/1-3:1.1/0003:04D9:A002.0003/input/input5/event5"
[     5.496] (II) XINPUT: Adding extended input device "E-Signal USB Gaming Keyboard Consumer Control" (type: KEYBOARD, id 17)
[     5.496] (**) Option "xkb_model" "pc105"
[     5.496] (**) Option "xkb_layout" "fi"
[     5.496] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[     5.496] (**) Logitech Gaming Mouse G502 Consumer Control: Applying InputClass "evdev keyboard catchall"
[     5.496] (**) Logitech Gaming Mouse G502 Consumer Control: Applying InputClass "libinput keyboard catchall"
[     5.496] (**) Logitech Gaming Mouse G502 Consumer Control: Applying InputClass "system-keyboard"
[     5.496] (**) Logitech Gaming Mouse G502 Consumer Control: Applying InputClass "Keyboard Defaults"
[     5.496] (II) Using input driver 'libinput' for 'Logitech Gaming Mouse G502 Consumer Control'
[     5.496] (**) Logitech Gaming Mouse G502 Consumer Control: always reports core events
[     5.496] (**) Option "Device" "/dev/input/event10"
[     5.496] (**) Option "_source" "_driver/libinput"
[     5.496] (II) libinput: Logitech Gaming Mouse G502 Consumer Control: is a virtual subdevice
[     5.496] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:08:00.1/usb1/1-4/1-4:1.1/0003:046D:C332.0007/input/input10/event10"
[     5.496] (II) XINPUT: Adding extended input device "Logitech Gaming Mouse G502 Consumer Control" (type: KEYBOARD, id 18)
[     5.497] (--) NVIDIA(GPU-0): DELL U2515H (DFP-3): connected
[     5.497] (--) NVIDIA(GPU-0): DELL U2515H (DFP-3): Internal DisplayPort
[     5.497] (--) NVIDIA(GPU-0): DELL U2515H (DFP-3): 1440.0 MHz maximum pixel clock
[     5.497] (--) NVIDIA(GPU-0): Acer XB271HK (DFP-5): connected
[     5.497] (--) NVIDIA(GPU-0): Acer XB271HK (DFP-5): Internal DisplayPort
[     5.497] (--) NVIDIA(GPU-0): Acer XB271HK (DFP-5): 1440.0 MHz maximum pixel clock
[     5.497] (II) config/udev: Adding input device HDA Creative Line Out Surround (/dev/input/event24)
[     5.497] (II) No input driver specified, ignoring this device.
[     5.497] (II) This device may have been added with another device file.
[     5.498] (II) config/udev: Adding input device HDA Creative Line Out CLFE (/dev/input/event25)
[     5.498] (II) No input driver specified, ignoring this device.
[     5.498] (II) This device may have been added with another device file.
[     5.498] (II) config/udev: Adding input device HDA Creative Mic (/dev/input/event23)
[     5.498] (II) config/udev: Adding input device HDA Creative Front Headphone (/dev/input/event26)
[     5.501] (EE) Failed to open authorization file "/var/run/sddm/{76e43839-a4f6-46d2-9be1-63f08659532c}": No such file or directory
[     6.666] (--) NVIDIA(GPU-0): DFP-0: disconnected
[     6.666] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[     6.666] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[     6.666] (--) NVIDIA(GPU-0): DFP-1: disconnected
[     6.666] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[     6.666] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[     6.666] (--) NVIDIA(GPU-0): DFP-2: disconnected
[     6.666] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[     6.666] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[     6.667] (--) NVIDIA(GPU-0): DELL U2515H (DFP-3): connected
[     6.667] (--) NVIDIA(GPU-0): DELL U2515H (DFP-3): Internal DisplayPort
[     6.667] (--) NVIDIA(GPU-0): DELL U2515H (DFP-3): 1440.0 MHz maximum pixel clock
[     6.669] (--) NVIDIA(GPU-0): DFP-4: disconnected
[     6.669] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[     6.669] (--) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
[     6.669] (--) NVIDIA(GPU-0): Acer XB271HK (DFP-5): connected
[     6.669] (--) NVIDIA(GPU-0): Acer XB271HK (DFP-5): Internal DisplayPort
[     6.669] (--) NVIDIA(GPU-0): Acer XB271HK (DFP-5): 1440.0 MHz maximum pixel clock
[     6.671] (--) NVIDIA(GPU-0): DFP-6: disconnected
[     6.671] (--) NVIDIA(GPU-0): DFP-6: Internal TMDS
[     6.671] (--) NVIDIA(GPU-0): DFP-6: 165.0 MHz maximum pixel clock
[     6.676] (--) NVIDIA(GPU-0): DFP-0: disconnected
[     6.676] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[     6.676] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[     6.676] (--) NVIDIA(GPU-0): DFP-1: disconnected
[     6.676] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[     6.676] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[     6.676] (--) NVIDIA(GPU-0): DFP-2: disconnected
[     6.676] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[     6.676] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[     6.676] (--) NVIDIA(GPU-0): DELL U2515H (DFP-3): connected
[     6.676] (--) NVIDIA(GPU-0): DELL U2515H (DFP-3): Internal DisplayPort
[     6.676] (--) NVIDIA(GPU-0): DELL U2515H (DFP-3): 1440.0 MHz maximum pixel clock
[     6.678] (--) NVIDIA(GPU-0): DFP-4: disconnected
[     6.678] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[     6.678] (--) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
[     6.679] (--) NVIDIA(GPU-0): Acer XB271HK (DFP-5): connected
[     6.679] (--) NVIDIA(GPU-0): Acer XB271HK (DFP-5): Internal DisplayPort
[     6.679] (--) NVIDIA(GPU-0): Acer XB271HK (DFP-5): 1440.0 MHz maximum pixel clock
[     6.681] (--) NVIDIA(GPU-0): DFP-6: disconnected
[     6.681] (--) NVIDIA(GPU-0): DFP-6: Internal TMDS
[     6.681] (--) NVIDIA(GPU-0): DFP-6: 165.0 MHz maximum pixel clock
[     6.845] (II) NVIDIA(0): Setting mode "DP-2: nvidia-auto-select @3840x2160 +0+0 {ViewPortIn=3840x2160, ViewPortOut=3840x2160+0+0}, DP-0: nvidia-auto-select @1440x2560 +3839+0 {ViewPortIn=1440x2560, ViewPortOut=2560x1440+0+0, Rotation=270}"
[     7.041] (II) NVIDIA(0): Setting mode "DP-2: nvidia-auto-select @3840x2160 +0+199 {ViewPortIn=3840x2160, ViewPortOut=3840x2160+0+0}, DP-0: nvidia-auto-select @1440x2560 +3839+0 {ViewPortIn=1440x2560, ViewPortOut=2560x1440+0+0, Rotation=270}"
[    11.024] (--) NVIDIA(GPU-0): DFP-0: disconnected
[    11.024] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[    11.024] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[    11.024] (--) NVIDIA(GPU-0): DFP-1: disconnected
[    11.024] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[    11.024] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[    11.024] (--) NVIDIA(GPU-0): DFP-2: disconnected
[    11.024] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[    11.024] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[    11.025] (--) NVIDIA(GPU-0): DELL U2515H (DFP-3): connected
[    11.025] (--) NVIDIA(GPU-0): DELL U2515H (DFP-3): Internal DisplayPort
[    11.025] (--) NVIDIA(GPU-0): DELL U2515H (DFP-3): 1440.0 MHz maximum pixel clock
[    11.027] (--) NVIDIA(GPU-0): DFP-4: disconnected
[    11.027] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[    11.027] (--) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
[    11.027] (--) NVIDIA(GPU-0): Acer XB271HK (DFP-5): connected
[    11.027] (--) NVIDIA(GPU-0): Acer XB271HK (DFP-5): Internal DisplayPort
[    11.027] (--) NVIDIA(GPU-0): Acer XB271HK (DFP-5): 1440.0 MHz maximum pixel clock
[    11.029] (--) NVIDIA(GPU-0): DFP-6: disconnected
[    11.029] (--) NVIDIA(GPU-0): DFP-6: Internal TMDS
[    11.029] (--) NVIDIA(GPU-0): DFP-6: 165.0 MHz maximum pixel clock
[    16.524] (--) NVIDIA(GPU-0): DFP-0: disconnected
[    16.524] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[    16.524] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[    16.524] (--) NVIDIA(GPU-0): DFP-1: disconnected
[    16.524] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[    16.524] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[    16.524] (--) NVIDIA(GPU-0): DFP-2: disconnected
[    16.524] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[    16.524] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[    16.525] (--) NVIDIA(GPU-0): DELL U2515H (DFP-3): connected
[    16.525] (--) NVIDIA(GPU-0): DELL U2515H (DFP-3): Internal DisplayPort
[    16.525] (--) NVIDIA(GPU-0): DELL U2515H (DFP-3): 1440.0 MHz maximum pixel clock
[    16.527] (--) NVIDIA(GPU-0): DFP-4: disconnected
[    16.527] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[    16.527] (--) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
[    16.528] (--) NVIDIA(GPU-0): Acer XB271HK (DFP-5): connected
[    16.528] (--) NVIDIA(GPU-0): Acer XB271HK (DFP-5): Internal DisplayPort
[    16.528] (--) NVIDIA(GPU-0): Acer XB271HK (DFP-5): 1440.0 MHz maximum pixel clock
[    16.529] (--) NVIDIA(GPU-0): DFP-6: disconnected
[    16.529] (--) NVIDIA(GPU-0): DFP-6: Internal TMDS
[    16.529] (--) NVIDIA(GPU-0): DFP-6: 165.0 MHz maximum pixel clock
[    28.813] (EE) client bug: timer event7 debounce short: offset negative (-2ms)
[   942.836] (EE) client bug: timer event7 debounce short: offset negative (-1ms)
[  1002.176] (II) event1  - Power Button: device removed
[  1002.223] (II) event0  - Power Button: device removed
[  1002.261] (II) event2  - E-Signal USB Gaming Keyboard: device removed
[  1002.290] (II) event3  - E-Signal USB Gaming Keyboard Mouse: device removed
[  1002.357] (II) event4  - E-Signal USB Gaming Keyboard System Control: device removed
[  1002.396] (II) event7  - Logitech Gaming Mouse G502: device removed
[  1002.464] (II) event12 - Logitech Gaming Mouse G502 System Control: device removed
[  1002.490] (II) event8  - Logitech Gaming Mouse G502 Keyboard: device removed
[  1002.516] (II) event9  - Eee PC WMI hotkeys: device removed
[  1002.570] (II) event5  - E-Signal USB Gaming Keyboard Consumer Control: device removed
[  1002.610] (II) event10 - Logitech Gaming Mouse G502 Consumer Control: device removed
[  1007.271] (--) NVIDIA(GPU-0): DFP-0: disconnected
[  1007.271] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[  1007.271] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[  1007.271] (--) NVIDIA(GPU-0): DFP-1: disconnected
[  1007.271] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[  1007.271] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[  1007.271] (--) NVIDIA(GPU-0): DFP-2: disconnected
[  1007.271] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[  1007.271] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[  1007.271] (--) NVIDIA(GPU-0): DELL U2515H (DFP-3): connected
[  1007.271] (--) NVIDIA(GPU-0): DELL U2515H (DFP-3): Internal DisplayPort
[  1007.271] (--) NVIDIA(GPU-0): DELL U2515H (DFP-3): 1440.0 MHz maximum pixel clock
[  1007.273] (--) NVIDIA(GPU-0): DFP-4: disconnected
[  1007.273] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[  1007.273] (--) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
[  1007.274] (--) NVIDIA(GPU-0): Acer XB271HK (DFP-5): connected
[  1007.274] (--) NVIDIA(GPU-0): Acer XB271HK (DFP-5): Internal DisplayPort
[  1007.274] (--) NVIDIA(GPU-0): Acer XB271HK (DFP-5): 1440.0 MHz maximum pixel clock
[  1007.275] (--) NVIDIA(GPU-0): DFP-6: disconnected
[  1007.275] (--) NVIDIA(GPU-0): DFP-6: Internal TMDS
[  1007.275] (--) NVIDIA(GPU-0): DFP-6: 165.0 MHz maximum pixel clock
[  1007.290] (II) NVIDIA(0): Setting mode "DP-2: nvidia-auto-select @3840x2160 +0+199 {ViewPortIn=3840x2160, ViewPortOut=3840x2160+0+0}, DP-0: nvidia-auto-select @1440x2560 +3839+0 {ViewPortIn=1440x2560, ViewPortOut=2560x1440+0+0, Rotation=270}"
[  1007.414] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[  1007.414] (II) NVIDIA(0):     may not be running or the "AcpidSocketPath" X
[  1007.414] (II) NVIDIA(0):     configuration option may not be set correctly.  When the
[  1007.414] (II) NVIDIA(0):     ACPI event daemon is available, the NVIDIA X driver will
[  1007.414] (II) NVIDIA(0):     try to use it to receive ACPI event notifications.  For
[  1007.414] (II) NVIDIA(0):     details, please see the "ConnectToAcpid" and
[  1007.414] (II) NVIDIA(0):     "AcpidSocketPath" X configuration options in Appendix B: X
[  1007.414] (II) NVIDIA(0):     Config Options in the README.
[  1007.487] (II) event1  - Power Button: is tagged by udev as: Keyboard
[  1007.487] (II) event1  - Power Button: device is a keyboard
[  1007.487] (II) event0  - Power Button: is tagged by udev as: Keyboard
[  1007.487] (II) event0  - Power Button: device is a keyboard
[  1007.488] (II) event2  - E-Signal USB Gaming Keyboard: is tagged by udev as: Keyboard
[  1007.488] (II) event2  - E-Signal USB Gaming Keyboard: device is a keyboard
[  1007.489] (II) event3  - E-Signal USB Gaming Keyboard Mouse: is tagged by udev as: Mouse
[  1007.490] (II) event3  - E-Signal USB Gaming Keyboard Mouse: device is a pointer
[  1007.491] (II) event4  - E-Signal USB Gaming Keyboard System Control: is tagged by udev as: Keyboard
[  1007.491] (II) event4  - E-Signal USB Gaming Keyboard System Control: device is a keyboard
[  1007.492] (II) event5  - E-Signal USB Gaming Keyboard Consumer Control: is tagged by udev as: Keyboard
[  1007.492] (II) event5  - E-Signal USB Gaming Keyboard Consumer Control: device is a keyboard
[  1007.547] (II) event7  - Logitech Gaming Mouse G502: is tagged by udev as: Mouse
[  1007.547] (II) event7  - Logitech Gaming Mouse G502: device set to 2400 DPI
[  1007.547] (II) event7  - Logitech Gaming Mouse G502: device is a pointer
[  1007.548] (II) event10 - Logitech Gaming Mouse G502 Consumer Control: is tagged by udev as: Keyboard
[  1007.548] (II) event10 - Logitech Gaming Mouse G502 Consumer Control: device is a keyboard
[  1007.549] (II) event12 - Logitech Gaming Mouse G502 System Control: is tagged by udev as: Keyboard
[  1007.549] (II) event12 - Logitech Gaming Mouse G502 System Control: device is a keyboard
[  1007.550] (II) event8  - Logitech Gaming Mouse G502 Keyboard: is tagged by udev as: Keyboard
[  1007.550] (II) event8  - Logitech Gaming Mouse G502 Keyboard: device is a keyboard
[  1007.551] (II) event9  - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[  1007.551] (II) event9  - Eee PC WMI hotkeys: device is a keyboard
[  1018.358] (II) event1  - Power Button: device removed
[  1018.384] (II) event0  - Power Button: device removed
[  1018.424] (II) event2  - E-Signal USB Gaming Keyboard: device removed
[  1018.450] (II) event3  - E-Signal USB Gaming Keyboard Mouse: device removed
[  1018.503] (II) event4  - E-Signal USB Gaming Keyboard System Control: device removed
[  1018.544] (II) event7  - Logitech Gaming Mouse G502: device removed
[  1018.610] (II) event12 - Logitech Gaming Mouse G502 System Control: device removed
[  1018.650] (II) event8  - Logitech Gaming Mouse G502 Keyboard: device removed
[  1018.690] (II) event9  - Eee PC WMI hotkeys: device removed
[  1018.743] (II) event5  - E-Signal USB Gaming Keyboard Consumer Control: device removed
[  1018.770] (II) event10 - Logitech Gaming Mouse G502 Consumer Control: device removed
Add to /etc/X11/mhwd.d/nvidia.conf this line:
Option "ConnectToAcpid" "Off"
to the Section "Device" so that acpi thing doesn't show up/interfere ...
I see no reason why there would be an issue for resuming from suspend. Maybe you need a fixed config as i mentioned here (for different issue)
I'm on KDE and i had no problems with GTX 650 nor with the GTX 960 and fixed config for each.
Maybe you can try to enable haveged service.
systemctl enable haveged --now
Another thing you could try, is to follow the systemd service ... See some examples here:
Thanks for having a look! Here's my /etc/X11/mhwd.d/nvidia.conf after I added the option:
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig:  version 430.40
Section "ServerLayout"
    Identifier     "Layout0"
    Screen      0  "Screen0"
    InputDevice    "Keyboard0" "CoreKeyboard"
    InputDevice    "Mouse0" "CorePointer"
EndSection
Section "Files"
EndSection
Section "InputDevice"
    # generated from default
    Identifier     "Mouse0"
    Driver         "mouse"
    Option         "Protocol" "auto"
    Option         "Device" "/dev/psaux"
    Option         "Emulate3Buttons" "no"
    Option         "ZAxisMapping" "4 5"
EndSection
    Identifier     "Keyboard0"
    Driver         "kbd"
EndSection
Section "Monitor"
    Identifier     "Monitor0"
    VendorName     "Unknown"
    ModelName      "Unknown"
    Option         "DPMS"
EndSection
Section "Device"
    Identifier     "Device0"
    Driver         "nvidia"
    VendorName     "NVIDIA Corporation"
        Option "NoLogo" "1"
EndSection
Section "Screen"
    Identifier     "Screen0"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
    SubSection     "Display"
        Depth       24
    EndSubSection
EndSection
Section "Extensions"
    Option         "COMPOSITE" "Enable"
EndSection
Section "InputClass"
    Identifier          "Keyboard Defaults"
    MatchIsKeyboard        "yes"
    Option              "XkbOptions" "terminate:ctrl_alt_bksp"
EndSection
Do you see anything that should be updated/fixed?
I ran into the haveged service suggestion and I have enabled it without results.
Thanks for the suggestion on the plasma restart service, I'll look into it.
Looks ok to me, as a slight modification of the default one.
Personally i prefer to use also the entry:
Section "ServerFlags"
    Option "IndirectGLX" "On"
EndSection
right between the Section "Extensions" and Section "InputClass" ... i always add more to my config than default, especially for my KDE installs. (old habit).
Look also at the Compositor settings, and make sure is set to be enabled at startup and be on OpenGL 3.1 (might not be related).
That might be the only one that will sure make a difference if nothing else worked.
Thanks. I changed the OpenGL version to 3.1 in the compositor settings but it didn't help either. It was set to enabled at startup and the black screen issue has never come up after a reboot or cold boot.
You might want to disable TLP (or uninstall it temporarily), to exclude it from the possible reasons. Or maybe try to configure it properly.
One at a time, though... :wink:
It looks like that disabling TLP was the solution for now! I did add a script that disables bluetooth during suspend since it was preventing the suspension properly staying in sleep but I don't think it was a part of the solution since manually disabling bluetooth service didn't help.
Can you tell me how to configure TLP properly or what to read to be able to do it?
Thank you so much!
https://linrunner.de/en/tlp/docs/tlp-troubleshooting.html
[HowTo] Power savings setup| 20180403
I suggest installing this package: tlpui
A GTK-UI to change TLP configuration files easily
Hey! Thought you've gone missing.
Could this manjaro's BSOD (black screen of death) {courtesy of openminded} be due to the boot_indeterminate or boot_success thingy in grubenv? I 've gone through (back then) the workings of /etc/grub.d/xxx_xx
and I think there is a delay (30 secs, 60secs, 2 mins?) whenever there's a boot failure previously.
I don't know coding, you do. Also, my manjaro's grub quite messed up at the moment, with vanilla-grub, clear-grub, upstream-grub, fedora-grub and ubuntu-grub. But mainly, I cannot get my manjaro to bork up, not easy to get any linux borked up. And boot failure?! Can you look into the workings and let me know? There are other posts elsewhere too on this BSOD. Thanks.
ps: I don't hibernate. My swap's smaller than my ram (not used for hibernation).
Maybe, but this can very well come from the code, not grub.d files.
No, I won't. It's not me who messed with a highly critical system part source code. Ask those who did.
I do, but I can easily come back from a failure, which has not happened for years.
It doesn't always matter for hibernation. With about 4GB swap you can usually/normally hibernate, even with more RAM than that.
I now have grub-vanilla and will keep it, until grub becomes... grub again.
Messing with grub code is completely out of sense IMHO, when there are no bugs.
And forcing a not tested enough grub on ALL Manjaro users, cannot be more intimidating. Stubbornness has become a badge. Wow! Let's celebrate!
The codes in 10_linux, etc...
But never mind since you are on grub-vanilla, you can't check it out that there are lines in there (fedora-grub) that use boot_indeterminate and boot-success.
I'm not going to talk about hibernation, swap here. Not relevant. Just asking if you hibernate, does it hang. Again you can't test. You don't have fedora-grub.
And if you have 'ubuntu-grub' (used in Manjaro 2.0.4-6), and again you don't have, there's
GRUB_HIDDEN_TIMEOUT to make grub menu hidden.
But that's deprecated . Guess what replaces it?
GRUB_TIMEOUT_STYLE !! :rofl:
Never mind. Looks like we're both wasting our time.
If it was only grub.d files code (Bash), we can read easily. But "they" have been altering source code of the program (C something), which is hard to read (for me).
Forget it...
Thanks a lot for your help.
Are there any downsides to just leaving TLP to disabled state?
TLP is controlling power management/consumption for your system's hardware.
For a desktop consumption may not be so important, but disks (not SSD) may have more wear than needed.
Usually you can blacklist, or configure PM template/model for each set of devices, so you may find a working scenario for your system, if you configure TLP properly. It needs reading and testing from your side. When you find some spare time :wink:
Disabling TLP didn't work for me. Thinkpad X1 Extreme with 1 external monitor via Thinkpad USB-C Dock station.
Any suggestions on what logs I need to upload?
Part of inxi -Fxzc0
System:    Host: *** Kernel: 5.2.21-1-MANJARO x86_64 bits: 64 compiler: gcc v: 9.2.0 Desktop: KDE Plasma 5.16.5
           Distro: Manjaro Linux
Machine:   Type: Laptop System: LENOVO product: 20MF000BUS v: ThinkPad X1 Extreme serial: <filter>
           Mobo: LENOVO model: 20MF000BUS v: *** WIN serial: <filter> UEFI: LENOVO v: N2EET42W (1.24 ) date: 08/06/2019
CPU:       Topology: 6-Core model: Intel Core i7-8750H bits: 64 type: MT MCP arch: Kaby Lake rev: A L2 cache: 9216 KiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 53004
           Speed: 800 MHz min/max: 800/4100 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800 8: 800
           9: 800 10: 800 11: 801 12: 800
Graphics:  Device-1: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile] vendor: Lenovo driver: nvidia v: 418.88 bus ID: 01:00.0
           Display: x11 server: X.Org 1.20.5 driver: nvidia resolution: 3840x2160~60Hz, 1920x1080~60Hz
           OpenGL: renderer: GeForce GTX 1050 Ti with Max-Q Design/PCIe/SSE2 v: 4.6.0 NVIDIA 418.88 direct render: Yes
Info:      Processes: 291 Uptime: 32m Memory: 15.19 GiB used: 4.42 GiB (29.1%) Init: systemd Compilers: gcc: 9.2.0 Shell: bash
           v: 5.0.11 inxi: 3.0.36
Some dmesg:
[    8.829480] ucsi_acpi USBC000:00: PPM NOT RESPONDING
[    8.829483] ucsi_acpi USBC000:00: con1: failed to register alternate modes
[    9.490075] typec_displayport port0-partner.0: failed to enter mode
[  902.062825] nvidia-modeset: WARNING: GPU:0: CMN (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[  150.173040] thinkpad_acpi: unhandled HKEY event 0x6031
I'm also experiencing similar issue. See here for more details: Manjaro KDE + NVIDIA proprietary driver got blank screen after wake up
