Hello ARM community.
Small update this time around, nothing major!
Some highlights:
- Some of our kernels got updated
- KDE Plasma is now updated to 5.23.2
- Added some packages for our PinePhone Pro support
- Thunderbird got a new point release with 91.2.1
- Lots of Mobile specific packages got updated
- Many python packages got updated
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
- Install
waydroid-image
and all it’s dependencies. - Run
pkexec setup-waydroid
. - You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker linux-rpi4 xf86-video-fbturbo-git
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64 #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2 #disable cause kodi uses more
dtoverlay=rpivid-v4l2
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Older notifications
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt
Arch Linux - News: Sorting out old password hashes
The ghostpcl
and ghostxps
requires manual intervention (if you have these installed):
The nss
package requires manual intervention:
The packages hplip
and firewalld
Package Changes
(Tue Oct 26 22:48:07 CEST 2021)
- arm-testing community aarch64: 183 new and 183 removed package(s)
- arm-testing core aarch64: 16 new and 13 removed package(s)
- arm-testing extra aarch64: 192 new and 186 removed package(s)
- arm-testing kde-unstable aarch64: 78 new and 78 removed package(s)
:: Different overlay package(s) in repository community aarch64
PACKAGE 2021-10-21 2021-10-26
calls 41.0+52+g43fb850-1 41.0+71+g94d730c-1
chatty 0.4.0+223+g58d96fb-1 0.4.0+244+g4674c9c-1
element-desktop 1.9.2-1 1.9.3-1
element-web 1.9.2-1 1.9.3-1
firmware-raspberrypi 6-1.9 6-2
gnome-calendar-mobile 41.0-1 41.0-2
gnome-control-center-mobile 40.1-1 41.0-4
inxi 3.3.07.1-1 3.3.08.1-1
mmsd-tng 1.4+3+gc162b5d-1 1.5-1
phoc 0.8.0+91+g75900fe-1 0.8.0+95+g9dd5d11-1
phosh0.13.1+113+gc910e1d-10.13.1+127+g37a7ec0-1
phosh-antispam 1.1+1+g62220f3-12.0beta+10+g78b5cfb-1
pinephone-post-install 20211017-1 20211025-1
pinephonepro-post-install 20211021-1 20211022-2
powersupply 0.4.0-1 0.5.0-1
vvmd 0.5-1 0.6-1
bigscreen-post-install - 20211026-7
wlrootsqt - 1.0.0alpha1-1
:: Different sync package(s) in repository community aarch64
adios2 2.7.1-1 2.7.1-2
adrdox 2.5.0-2 2.5.0-3
amule 1:2.3.3-2 1:2.3.3-3
android-tools 31.0.2-1 31.0.3-1
b3sum 1.0.0-2 1.1.0-1
benchmark 1.5.6-1 1.6.0-1
birdfont 2.29.5-1 2.29.6-1
bleachbit 4.4.0-1 4.4.1-1
bmake 20210314-1 20211001-1
bpftrace 0.13.0-1 0.14.0-1
btop 1.0.18-1 1.0.19-1
calibre 5.29.0-1 5.30.0-1
cargo-c 0.9.4-1 0.9.5-1
cargo-udeps 0.1.23-1 0.1.24-1
criu 3.16-1 3.16.1-1
crystal 1.2.0-1 1.2.1-1
d-containers 0.8.0-4 0.8.0-5
d-mir-core 1.1.14-4 1.1.14-7
d-stdx-allocator 3.0.2-16 3.0.2-17
dns-lexicon 3.8.0-1 3.8.1-1
docker 1:20.10.9-1 1:20.10.10-1
dunst 1.7.0-1 1.7.0-3
facter 3.14.19-1 3.14.20-2
fceux 2.4.0-1 2.5.0-1
filezilla 3.56.0-1 3.56.1-1
freerdp 2:2.4.0-2 2:2.4.1-1
fscrypt 0.3.0-1 0.3.1-1
gir-to-d 0.22.0-2 0.22.0-5
git-cliff 0.4.0-1 0.4.2-1
gitea 1.15.4-1 1.15.5-1
glances 3.2.2-1 3.2.3-1
global 6.6.7-1 6.6.7-2
go 2:1.17.1-1 2:1.17.2-1
go-yq 4.13.4-1 4.13.5-1
goreleaser 0.182.1-1 0.183.0-1
grpc 1.41.0-1 1.41.1-1
grpc-cli 1.41.0-1 1.41.1-1
gtkd 3.9.0-13 3.9.0-16
guake 3.8.0-1 3.8.1-1
himalaya 0.5.0-1 0.5.1-1
ibus-m17n 1.4.7-1 1.4.8-1
interception-dual-function-keys 1.4.0-1 1.4.0-2
interception-tools 0.6.7-1 0.6.7-2
jami-daemon 20211004-1 20211004-3
jitterentropy 3.3.0-1 3.3.1-1
jupyter-nbclassic 0.3.2-1 0.3.3-1
kodi-platform 20190726.809c5e9-31 20190726.809c5e9-32
latte-dock 0.10.2-1 0.10.3-1
lazygit 0.29-1 0.30.1-1
ldc 2:1.27.1-1 3:1.28.0-1
libavif 0.9.2-1 0.9.3-1
libfilezilla 0.34.1-1 0.34.2-1
libhx 3.26-1 4.2-1
liblphobos 2:1.27.1-1 3:1.28.0-1
libquicktime 1.2.4-24 1.2.4-25
libtg_owt 0.git7.575fb17-1 0.git7.575fb17-2
libyuv r2212+dfaf7534-2 r2266+eb6e7bb6-1.1
lutris 0.5.8.4-1 0.5.9.1-1
lxc 1:4.0.11-1 1:4.0.11-2
lxcfs 4.0.9-1 4.0.11-1
marked 3.0.4-1 3.0.5-1
matrix-synapse 1.44.0-2 1.45.1-1
mediastreamer 5.0.36-1 5.0.36-2
meilisearch 0.22.0-1 0.23.1-1
menyoki 1.5.3-1 1.5.5-1
miniserve 0.17.0-1 0.18.0-1
motion 4.3.2-1 4.4.0-1
msgpack-cxx 4.0.2-1 4.0.3-1
neomutt 20211015-1 20211022-2
nuitka 0.6.16.4-2 0.6.17.4-1
opencolorio 2.1.0-1 -
pari 2.13.2-1 2.13.3-1
perl-gtk3-imageview 9-1 10-1
php-grpc 1.41.0-1 1.41.1-1
php7-grpc 1.41.0-1 1.41.1-1
plasma5-applets-window-buttons 0.9.0-3 0.10.0-1
powerdns 4.5.1-1 4.5.1-3
pulumi 3.15.0-1 3.16.0-1
py3status 3.39-1 3.39-2
pyright 1.1.180-1 1.1.181-1
python-astroid 2.8.3-1 2.8.4-1
python-autobahn 21.3.1-1 21.3.1-2
python-awesomeversion 21.8.1-1 21.10.0-1
python-canonicaljson 1.4.0-3 1.5.0-1
python-cfn-lint 0.54.2-1 0.54.3-1
python-cymem 2.0.5-1.1 2.0.6-1
python-django-environ 0.8.0-1 0.8.1-1
python-frozendict 1:2.0.6-1 1:2.0.7-1
python-grpcio 1.41.0-1 1.41.1-1
python-identify 2.3.0-1 2.3.1-1
python-moto 2.2.9-1 2.2.10-1
python-oslo-concurrency 4.4.1-1 4.5.0-1
python-oslo-log 4.6.0-1 4.6.1-1
python-param 1.11.1-1 1.12.0-1
python-phonenumbers 8.12.34-1 8.12.35-1
python-pyls-black 0.4.6-1 -
python-pymongo 3.12.0-1 3.12.1-1
python-pymupdf 1.19.0-1 1.19.1-1
python-pytz 2021.1-1 2021.3-1
python-tokenize-rt 4.1.0-2 4.2.1-1
python-tzdata 2021.4-1 2021.5-1
python-uproot-methods 0.10.0-1 0.10.1-1
python2-gudev 147.2-8 -
python2-pytz 2021.1-1 2021.3-1
qutebrowser 2.3.1-1 2.4.0-1
r10k 3.11.0-2 3.13.0-1
repo 2.17-1 2.17.2-1
ruby-jwt 2.2.3-1 2.3.0-1
ruby-molinillo 0.7.0-3 0.8.0-1
ruby-puppet_metadata 1.1.1-1 1.2.0-1
rust-analyzer 20211018-1 20211025-1
sbctl 0.6-1 0.7-1
seatd 0.6.2-1 0.6.3-1
shutter 0.99-1 0.99.1-1
sigil 1.7.0-1 1.8.0-1
skaffold 1.32.0-1 1.33.1-1
sn0int 0.21.2-1 0.23.0-1
spirv-headers1.5.4.raytracing.fixed-11.5.4.r106+ge71fedd-2
stylelint 13.13.1-1 14.0.0-1
stylelint-config-recommended 5.0.0-1 6.0.0-1
stylelint-config-standard 22.0.0-1 23.0.0-1
supercollider 3.12.1-1 3.12.1-3
syncthing 1.18.2-1 1.18.3-1
syncthing-relaysrv 1.18.2-1 1.18.3-1
terragrunt 0.35.3-1 0.35.4-1
texstudio 4.0.1-1 4.0.2-1
tilix 1.9.4-4 1.9.4-5
toxcore 1:0.2.12-2 1:0.2.12-3
toxic 0.11.1-1 0.11.1-2
translate-toolkit 3.3.6-1 3.4.1-1
ts-node 10.3.0-1 10.3.1-1
ttc-iosevka 10.3.3-1 10.3.4-1
ttc-iosevka-aile 10.3.3-1 10.3.4-1
ttc-iosevka-curly 10.3.3-1 10.3.4-1
ttc-iosevka-curly-slab 10.3.3-1 10.3.4-1
ttc-iosevka-etoile 10.3.3-1 10.3.4-1
ttc-iosevka-slab 10.3.3-1 10.3.4-1
ttc-iosevka-ss01 10.3.3-1 10.3.4-1
ttc-iosevka-ss02 10.3.3-1 10.3.4-1
ttc-iosevka-ss03 10.3.3-1 10.3.4-1
ttc-iosevka-ss04 10.3.3-1 10.3.4-1
ttc-iosevka-ss05 10.3.3-1 10.3.4-1
ttc-iosevka-ss06 10.3.3-1 10.3.4-1
ttc-iosevka-ss07 10.3.3-1 10.3.4-1
ttc-iosevka-ss08 10.3.3-1 10.3.4-1
ttc-iosevka-ss09 10.3.3-1 10.3.4-1
ttc-iosevka-ss10 10.3.3-1 10.3.4-1
ttc-iosevka-ss11 10.3.3-1 10.3.4-1
ttc-iosevka-ss12 10.3.3-1 10.3.4-1
ttc-iosevka-ss13 10.3.3-1 10.3.4-1
ttc-iosevka-ss14 10.3.3-1 10.3.4-1
ttc-iosevka-ss15 10.3.3-1 10.3.4-1
ttc-iosevka-ss16 10.3.3-1 10.3.4-1
ttc-iosevka-ss17 10.3.3-1 10.3.4-1
ttc-iosevka-ss18 10.3.3-1 10.3.4-1
uutils-coreutils 0.0.7-2 0.0.8-1
v2ray-geoip 202110140026-1 202110210032-1
vcsh 2.0.2-1 2.0.3-1
vim-himalaya 0.5.0-1 0.5.1-1
wireplumber 0.4.3-1 -
wireplumber-docs 0.4.3-1 -
wmfocus 1.2.0-1 1.3.0-1
xdg-desktop-portal-wlr 0.4.0-2 0.4.0-3
xdotool 3.20210903.1-1 3.20211022.1-1
xine-lib 1.2.11-5 1.2.11-6
xplr 0.15.0-1 0.15.2-1
yaml-cpp 0.6.3-2 0.7.0-2
cargo-feature - 0.5.5-1
dpdk - 21.08-1
python-mistune1 - 0.8.4-1
:: Different overlay package(s) in repository core aarch64
linux 5.14.14-1 5.14.14-2
linux-headers 5.14.14-1 5.14.14-2
linux-pinephone 5.14.14-1 5.14.14-2
linux-pinephone-headers 5.14.14-1 5.14.14-2
linux-rc 5.15.rc6-2 5.15.rc7-2
linux-rc-headers 5.15.rc6-2 5.15.rc7-2
linux-rpi4 5.10.74-1 5.10.75-1
linux-rpi4-headers 5.10.74-1 5.10.75-1
linux-rpi4-mainline 5.14.13-1 5.14.14-2
linux-rpi4-mainline-headers 5.14.13-1 5.14.14-2
raspberrypi-bootloader 20211019-1 20211025-1
raspberrypi-bootloader-x 20211019-1 20211025-1
linux-pinephonepro - 5.14.14-1
linux-pinephonepro-headers - 5.14.14-1
uboot-pinephonepro - 2021.10-1
:: Different sync package(s) in repository core aarch64
gdbm 1.21-1 1.22-1
:: Different overlay package(s) in repository extra aarch64
mesa-git22.0.0_devel.146279.d31ca63527e-122.0.0_devel.146490.c2d522b07f9-1
pamac-cli 10.2.2-5 10.2.2-6
pamac-gnome-integration 10.2.2-5 10.2.2-6
pamac-gtk 10.2.2-5 10.2.2-6
plasma-mobile-nm 5.23.1-1 5.23.2-1
plasma-nano 5.23.1-1 5.23.2-1
plasma-phone-components 5.23.1-1 5.23.2-1
qqc2-breeze-style 5.23.1-1 5.23.2-1
gst-plugins-base - 1.18.5-1.1
gst-plugins-base-libs - 1.18.5-1.1
:: Different sync package(s) in repository extra aarch64
alsa-card-profiles 1:0.3.38-1 1:0.3.39-1
avidemux-cli 2.7.8-2 2.7.8-3
avidemux-qt 2.7.8-2 2.7.8-3
bluedevil 1:5.23.1-1 1:5.23.2-1
botan 2.18.1-1 2.18.2-1
breeze 5.23.1-1 5.23.2-1
breeze-grub 5.23.1-1 5.23.2-1
breeze-gtk 5.23.1-1 5.23.2-1
c-ares 1.17.2-1 1.18.0-1
discover 5.23.1-1 5.23.2-1
drkonqi 5.23.1-1 5.23.2-1
exiv2 0.27.4-2 0.27.5-1
ffmpeg 2:4.4-4 2:4.4-5
gd 2.3.3-2 2.3.3-3
gi-docgen 2021.7-1 2021.8-1
graphviz 2.49.2-1 2.49.3-1
grilo 0.3.13-1 0.3.14-1
grilo-plugins 1:0.3.13-2 1:0.3.14-1
gst-plugin-gtk 1.18.5-1 1.18.5-2
gst-plugin-pipewire 1:0.3.38-1 1:0.3.39-1
gst-plugin-qmlgl 1.18.5-1 1.18.5-2
gst-plugins-good 1.18.5-1 1.18.5-2
gst-plugins-ugly 1.18.5-1 1.18.5-2
gtk31:3.24.30+62+g8d04980f38-21:3.24.30+90+g20be04f7ac-1
gtk3-demos1:3.24.30+62+g8d04980f38-21:3.24.30+90+g20be04f7ac-1
gtk3-docs1:3.24.30+62+g8d04980f38-21:3.24.30+90+g20be04f7ac-1
imagemagick 7.1.0.10-1 7.1.0.11-1
imagemagick-doc 7.1.0.10-1 7.1.0.11-1
jdk8-openjdk 8.u292-1 8.u292-1.1
jre8-openjdk 8.u292-1 8.u292-1.1
jre8-openjdk-headless 8.u292-1 8.u292-1.1
kactivitymanagerd 5.23.1-1 5.23.2-1
kde-cli-tools 5.23.1-1 5.23.2-1
kde-gtk-config 5.23.1-1 5.23.2-1
kdecoration 5.23.1-1 5.23.2-1
kdeplasma-addons 5.23.1-1 5.23.2-1
kgamma5 5.23.1-1 5.23.2-1
khotkeys 5.23.1-1 5.23.2-1
kimageformats 5.87.0-1 5.87.0-2
kinfocenter 5.23.1-1 5.23.2-1
kmenuedit 5.23.1-1 5.23.2-1
krita 4.4.8-2 4.4.8-3
kscreen 5.23.1-1 5.23.2-1
kscreenlocker 5.23.1-1 5.23.2-1
ksshaskpass 5.23.1-1 5.23.2-1
ksystemstats 5.23.1-1 5.23.2-1
kwallet-pam 5.23.1-1 5.23.2-1
kwayland-integration 5.23.1-1 5.23.2-1
kwayland-server 5.23.1-1 5.23.2-1
kwin 5.23.1-1 5.23.2-1
kwrited 5.23.1-1 5.23.2-1
layer-shell-qt 5.23.1-1 5.23.2-1
libcaca 0.99.beta19-5 0.99.beta20-1
libinput 1.19.1-1 1.19.2-1
libkscreen 5.23.1-1 5.23.2-1
libksysguard 5.23.1-1 5.23.2-1
libsoup 2.74.0-3 2.74.1-1
libsoup3 3.0.1-1 3.0.2-1
libupnp 1.14.12-1 1.14.12-2
libvpx 1.10.0-1 1.11.0-1
libwpe 1.10.1-1 1.12.0-1
mencoder 38322-1 38322-2
meson 0.59.2-1 0.60.0-1
milou 5.23.1-1 5.23.2-1
mpd 0.23.1-1 0.23.2-1
mpg123 1.29.1-1 1.29.2-1
mplayer 38322-1 38322-2
opencolorio1 1.1.1-3 -
openjdk8-src 8.u292-1 8.u292-1.1
oxygen 5.23.1-1 5.23.2-1
pipewire-alsa 1:0.3.38-1 1:0.3.39-1
pipewire-docs 1:0.3.38-1 1:0.3.39-1
pipewire-jack 1:0.3.38-1 1:0.3.39-1
pipewire-media-session 1:0.3.38-1 1:0.4.0-1
pipewire-pulse 1:0.3.38-1 1:0.3.39-1
pipewire-zeroconf 1:0.3.38-1 1:0.3.39-1
plasma-browser-integration 5.23.1-1 5.23.2-1
plasma-desktop 5.23.1-1 5.23.2-1
plasma-disks 5.23.1-1 5.23.2-1
plasma-firewall 5.23.1-1 5.23.2-1
plasma-integration 5.23.1-1 5.23.2-1
plasma-nm 5.23.1-1 5.23.2-1
plasma-pa 5.23.1-1 5.23.2-1
plasma-sdk 5.23.1-1 5.23.2-1
plasma-systemmonitor 5.23.1-1 5.23.2-1
plasma-thunderbolt 5.23.1-1 5.23.2-1
plasma-vault 5.23.1-1 5.23.2-1
plasma-wayland-session 5.23.1-1 5.23.2-1
plasma-workspace 5.23.1-1 5.23.2-1
plasma-workspace-wallpapers 5.23.1-1 5.23.2-1
polkit-kde-agent 5.23.1-1 5.23.2-1
powerdevil 5.23.1-1 5.23.2-1
qt5-base 5.15.2+kde+r251-1 5.15.2+kde+r254-1
qt5-webengine 5.15.6-4 5.15.6-5
qt5-xcb-private-headers 5.15.2+kde+r251-1 5.15.2+kde+r254-1
qt6-webengine 6.2.0-1 6.2.0-2
qtcreator 5.0.2-1 5.0.2-4
rubygems 3.2.21-1 3.2.29-1
rust 1:1.55.0-1 1:1.56.0-1
rust-docs 1:1.55.0-1 1:1.56.0-1
sddm-kcm 5.23.1-1 5.23.2-1
systemsettings 5.23.1-1 5.23.2-1
thunderbird 91.2.0-2.1 91.2.1-1
thunderbird-i18n-af 91.2.0-2.1 91.2.1-1
thunderbird-i18n-ar 91.2.0-2.1 91.2.1-1
thunderbird-i18n-ast 91.2.0-2.1 91.2.1-1
thunderbird-i18n-be 91.2.0-2.1 91.2.1-1
thunderbird-i18n-bg 91.2.0-2.1 91.2.1-1
thunderbird-i18n-br 91.2.0-2.1 91.2.1-1
thunderbird-i18n-ca 91.2.0-2.1 91.2.1-1
thunderbird-i18n-cak 91.2.0-2.1 91.2.1-1
thunderbird-i18n-cs 91.2.0-2.1 91.2.1-1
thunderbird-i18n-cy 91.2.0-2.1 91.2.1-1
thunderbird-i18n-da 91.2.0-2.1 91.2.1-1
thunderbird-i18n-de 91.2.0-2.1 91.2.1-1
thunderbird-i18n-dsb 91.2.0-2.1 91.2.1-1
thunderbird-i18n-el 91.2.0-2.1 91.2.1-1
thunderbird-i18n-en-gb 91.2.0-2.1 91.2.1-1
thunderbird-i18n-en-us 91.2.0-2.1 91.2.1-1
thunderbird-i18n-es-ar 91.2.0-2.1 91.2.1-1
thunderbird-i18n-es-es 91.2.0-2.1 91.2.1-1
thunderbird-i18n-et 91.2.0-2.1 91.2.1-1
thunderbird-i18n-eu 91.2.0-2.1 91.2.1-1
thunderbird-i18n-fi 91.2.0-2.1 91.2.1-1
thunderbird-i18n-fr 91.2.0-2.1 91.2.1-1
thunderbird-i18n-fy-nl 91.2.0-2.1 91.2.1-1
thunderbird-i18n-ga-ie 91.2.0-2.1 91.2.1-1
thunderbird-i18n-gd 91.2.0-2.1 91.2.1-1
thunderbird-i18n-gl 91.2.0-2.1 91.2.1-1
thunderbird-i18n-he 91.2.0-2.1 91.2.1-1
thunderbird-i18n-hr 91.2.0-2.1 91.2.1-1
thunderbird-i18n-hsb 91.2.0-2.1 91.2.1-1
thunderbird-i18n-hu 91.2.0-2.1 91.2.1-1
thunderbird-i18n-hy-am 91.2.0-2.1 91.2.1-1
thunderbird-i18n-id 91.2.0-2.1 91.2.1-1
thunderbird-i18n-is 91.2.0-2.1 91.2.1-1
thunderbird-i18n-it 91.2.0-2.1 91.2.1-1
thunderbird-i18n-ja 91.2.0-2.1 91.2.1-1
thunderbird-i18n-ka 91.2.0-2.1 91.2.1-1
thunderbird-i18n-kab 91.2.0-2.1 91.2.1-1
thunderbird-i18n-kk 91.2.0-2.1 91.2.1-1
thunderbird-i18n-ko 91.2.0-2.1 91.2.1-1
thunderbird-i18n-lt 91.2.0-2.1 91.2.1-1
thunderbird-i18n-ms 91.2.0-2.1 91.2.1-1
thunderbird-i18n-nb-no 91.2.0-2.1 91.2.1-1
thunderbird-i18n-nl 91.2.0-2.1 91.2.1-1
thunderbird-i18n-nn-no 91.2.0-2.1 91.2.1-1
thunderbird-i18n-pa-in 91.2.0-2.1 91.2.1-1
thunderbird-i18n-pl 91.2.0-2.1 91.2.1-1
thunderbird-i18n-pt-br 91.2.0-2.1 91.2.1-1
thunderbird-i18n-pt-pt 91.2.0-2.1 91.2.1-1
thunderbird-i18n-rm 91.2.0-2.1 91.2.1-1
thunderbird-i18n-ro 91.2.0-2.1 91.2.1-1
thunderbird-i18n-ru 91.2.0-2.1 91.2.1-1
thunderbird-i18n-sk 91.2.0-2.1 91.2.1-1
thunderbird-i18n-sl 91.2.0-2.1 91.2.1-1
thunderbird-i18n-sq 91.2.0-2.1 91.2.1-1
thunderbird-i18n-sr 91.2.0-2.1 91.2.1-1
thunderbird-i18n-sv-se 91.2.0-2.1 91.2.1-1
thunderbird-i18n-th 91.2.0-2.1 91.2.1-1
thunderbird-i18n-tr 91.2.0-2.1 91.2.1-1
thunderbird-i18n-uk 91.2.0-2.1 91.2.1-1
thunderbird-i18n-uz 91.2.0-2.1 91.2.1-1
thunderbird-i18n-vi 91.2.0-2.1 91.2.1-1
thunderbird-i18n-zh-cn 91.2.0-2.1 91.2.1-1
thunderbird-i18n-zh-tw 91.2.0-2.1 91.2.1-1
vlc 3.0.16-3 3.0.16-4
webkit2gtk 2.32.4-1 2.34.1-1
wpebackend-fdo 1.10.0-1 1.12.0-1
wpewebkit 2.32.4-1 2.34.1-1
x2643:0.161.r3039.544c61f-13:0.163.r3060.5db6aa6-1
xdg-desktop-portal-kde 5.23.1-1 5.23.2-1
zabbix-agent 5.4.4-1 5.4.5-1
zabbix-agent2 5.4.4-1 5.4.5-1
zabbix-frontend-php 5.4.4-1 5.4.5-1
zabbix-proxy 5.4.4-1 5.4.5-1
zabbix-server 5.4.4-1 5.4.5-1
opencolorio - 2.1.0-2
pipewire-media-session-docs - 1:0.4.0-1
pipewire-v4l2 - 1:0.3.39-1
wireplumber - 0.4.4-4
wireplumber-docs - 0.4.4-4
:: Different overlay package(s) in repository kde-unstable aarch64
akonadi21.08.2.r12631.g93214347f-121.08.2.r12634.g1d99b853e-1
akonadi-contacts21.08.2.r3073.g280e389c-121.08.2.r3074.gbcb55478-1
attica5.87.0.r842.gba026a4-15.87.0.r843.gf534cb6-1
baloo5.87.0.r3013.gcbf8efe8-15.87.0.r3014.ga9af0cc4-1
breeze5.23.1.r2289.g7f9f732a-15.23.1.r2291.g945ba0cc-1
breeze-icons5.87.0.r1812.gc0a4f65e-15.87.0.r1814.gd9a5af79-1
discover5.23.1.r8385.g198dde85-15.23.1.r8387.g5b06bc12-1
disman5.22.4.r1811.gca36775-15.23.1.r1811.gca36775-1
dolphin21.08.2.r6722.g73082d2e4-121.08.2.r6724.gb497dc9cb-1
elisa21.08.2.r2784.gce301cbc-121.08.2.r2785.gbc32cc3e-1
eventviews21.08.2.r54.gc767443-121.08.2.r55.g78c9be3-1
extra-cmake-modules5.87.0.r3380.ge62246c-15.87.0.r3381.g0516940-1
itinerary21.08.2.r1499.g0e0021b-121.08.2.r1503.geecb99e-1
kate21.08.2.r18413.ga92f86c43-121.08.2.r18416.g002c13208-1
kbounce21.08.2.r813.g94de5c1-121.08.2.r814.g527484a-1
kcontacts1:5.87.0.r3271.g2b9ece91-11:5.87.0.r3281.g9ee9adb6-1
kcoreaddons5.87.0.r1321.gb1c0b041-15.87.0.r1327.g54f3d649-1
kde-telephony-meta21.08.2.r431.gf42ca1b-121.08.2.r431.gfd18389-1
kdeclarative5.87.0.r931.gc661dcf-15.87.0.r932.g9c2702e-1
kdelibs4support5.87.0.r1044.g60f08c91-15.87.0.r1045.g0fb8e0b5-1
kdenlive21.08.2.r15115.g996dad59b-121.08.2.r15118.gb9900ba7c-1
kdepim-runtime21.08.2.r15342.g775ba9e93-121.08.2.r15343.gf67fd89c3-1
kdeplasma-addons5.23.1.r8595.g921202841-15.23.1.r8596.gc9f4dabfd-1
kdiamond21.08.2.r677.g9946e96-121.08.2.r678.g91fc7e2-1
kdisplay5.22.4.r1456.gc03ddcb-15.23.1.r1456.gc03ddcb-1
kfilemetadata5.87.0.r817.g6dfcd50-15.87.0.r818.gdd28fac-1
kglobalaccel5.87.0.r476.g40c9eb0-15.87.0.r477.g6ac1330-1
khealthcertificate r85.98d610a-1 r88.a3147ee-1
kholidays1:5.87.0.r973.gbd84d74-11:5.87.0.r974.g4088594-1
kinfocenter5.23.1.r1971.gc3cb026-15.23.1.r1972.gaadcb0e-1
kio5.87.0.r5050.g8e87461c-15.87.0.r5064.gfa2d8f9d-1
kio-extras21.08.2.r7161.gd6e40ca9-121.08.2.r7162.g2fd29ed7-1
kirigami25.87.0.r2929.gfc817a5c-15.87.0.r2934.g8ba168cf-1
kmail21.08.2.r26038.gfdb3df4e4-121.08.2.r26039.g449f9a3ff-1
knewstuff5.87.0.r1228.g6979bf80-15.87.0.r1229.g199d74c3-1
konsole21.08.2.r7986.gca7842a6-121.08.2.r7993.gbdf48484-1
kontact21.08.2.r5392.ga0977199-121.08.2.r5410.gf13991ae-1
kontrast21.08.2.r184.g31f3975-121.08.2.r185.g87b7f26-1
konversation21.08.2.r9000.g7d8174ca-121.08.2.r9001.gce902d45-1
kopeninghours21.08.2.r274.g6c8e88d-121.08.2.r275.g0d02b17-1
korganizer21.08.2.r11535.gb9d383288-121.08.2.r11537.g290671352-1
kparts5.87.0.r536.geb7a0a3-15.87.0.r539.g003a6f7-1
kpublictransport21.08.2.r1915.g4ccb9ee3-121.08.2.r1919.g94bda46c-1
kservice5.87.0.r955.g5e1cfd1-15.87.0.r956.ge5c14a6-1
ksudoku21.08.2.r1064.g39527e7-121.08.2.r1065.g906bc99-1
ktexteditor5.87.0.r2962.ga9606626-15.87.0.r2966.g2ad0032f-1
kwave21.08.2.r3748.gb07b5249-121.08.2.r3750.gad7e0654-1
kwayland-server5.23.1.r1402.g173c0b0-15.23.1.r1404.g53b453d-1
kwin5.23.1.r20180.gc7c63ba26-15.23.1.r20192.g839293f98-1
kwinft5.22.4.r19523.g84fcc28d3-15.23.1.r19542.g293ace855-1
kwrite21.08.2.r18413.ga92f86c43-121.08.2.r18416.g002c13208-1
libakonadi21.08.2.r12631.g93214347f-121.08.2.r12634.g1d99b853e-1
libkgapi21.08.2.r1305.g6d6dfc5-121.08.2.r1307.g2b9b254-1
neochat r1917.g65cc3928-1 r1926.gf2cf82ee-1
okular21.08.2.r9509.gd61a7ddf1-121.08.2.r9511.g810e9db2b-1
oxygen5.23.1.r4434.g1d771cca-15.23.1.r4435.g0bb26020-1
parley21.08.2.r4464.g015a76e0-121.08.2.r4465.geb0eeec8-1
plasma-browser-integration5.23.1.r1286.g8b49cef7-15.23.1.r1290.g4a41e90b-1
plasma-desktop5.23.1.r8709.g1d0ec8b23-15.23.1.r8716.g5902959b2-1
plasma-disks5.23.1.r238.g77533da-15.23.1.r239.g9cfd8d3-1
plasma-firewall5.23.1.r531.gb17aa4a-15.23.1.r532.gbe64b8e-1
plasma-nm5.23.1.r3117.g7166eb4c-15.23.1.r3118.g6dab6159-1
plasma-phone-components5.23.1.r1509.gd7b72904-15.23.1.r1510.gb091ce2a-1
plasma-settings 21.08.r31.g8908df7-1 21.08.r32.g71a9339-1
plasma-systemmonitor5.23.1.r505.g4ff4dca-15.23.1.r507.g40619c2-1
plasma-wayland-protocols1.4.0.r1038.g070ea05-11.4.0.r1039.ga463349-1
polkit-kde-agent5.23.1.r507.g3f64adb-15.23.1.r508.gb1fdc29-1
powerdevil5.23.1.r2488.g983f8609-15.23.1.r2489.gcb23bfc6-1
print-manager21.08.2.r1062.g5ae8470-121.08.2.r1063.g017ecea-1
purpose5.87.0.r902.g216ecc5-15.87.0.r905.ge798226-1
rocs21.08.2.r3044.gf0400004-121.08.2.r3046.g3f99c211-1
sddm0.19.0.r84.gc7e8a9f-10.19.0.r91.ge83ced0-1
sonnet5.87.0.r643.g9359ac5-15.87.0.r644.ga01fc66-1
spacebar 21.08.r8.g0e6f86f-1 21.08.r9.gbfd039d-1
spectacle21.08.2.r1185.g3c91729-121.08.2.r1188.g5347492-1
syntax-highlighting5.87.0.r1727.g6de91621-15.87.0.r1728.g9722ec1b-1
systemsettings5.23.1.r2550.gc815c7a9-15.23.1.r2552.g9c14abc7-1
wrapland5.22.4.r1644.g2c19a619-15.23.1.r1644.g2c19a619-1
- Run this command to switch branch:
sudo pacman-mirrors -aS testing && sudo pacman -Syyu
. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself.(Please post your solution)
- Yes i am currently experiencing an issue due to the update. (Please post about it)
0 voters
