Ich versuche ein AppImage auszuführen. Aber es passiert nichts. Im terminal sehe ich lediglich:
[ck@ck-n650du Downloads]$ ./Blockpad-1.8.1.3890-x86_64.AppImage
fuse: memory allocation failed
squashfuse 0.5.2 (c) 2012 Dave Vasilevsky
Usage: squashfuse [options] ARCHIVE MOUNTPOINT
(null) options:
-o offset=N offset N bytes into ARCHIVE to mount
-o subdir=PATH mount subdirectory PATH of ARCHIVE
-o notify_pipe=PATH named pipe that will receive 's' (success)
or 'f' (failure) when the mountpoint is ready
-o timeout=N idle N seconds for automatic unmount
-o uid=N set file owner to uid N
-o gid=N set file group to gid N
FUSE options:
-h --help print help
-V --version print version
-d -o debug enable debug output (implies -f)
-f foreground operation
-s disable multi-threaded operation
-o clone_fd use separate fuse device fd for each thread
(may improve performance)
-o max_idle_threads the maximum number of idle worker threads
allowed (default: -1)
-o max_threads the maximum number of worker threads
allowed (default: 10)
(null) options:
FUSE options:
(null) options:
FUSE options:
Can't open squashfs image: Bad address
Cannot mount AppImage, please check your FUSE setup.
You might still be able to extract the contents of this AppImage
if you run it with the --appimage-extract option.
See https://github.com/AppImage/AppImageKit/wiki/FUSE
for more information
execv error: No such file or directory
