Python Version conflict? -- Is "correctly installed".
Are you in testing or unstable? Pyhton 3.11 has not yet reached to Stable. Do you have all packages up to date? There seems to be new versions for Kajongg
and python-zope-interface
in testing and unstable branches
Edit:
Looking a little bit more in depth, it seems that Kajongg is not ready for Zope-interface
version 6. implements
was dropped from this module in that version. And Kajongg tries to import implements
just to verify that zope-interface
module is installed (it doesn’t use it directly)
So the solution is to try to warn the application developers about this and wait for a modified version of the app.
