Hello,
Just updated and I have some errors and a core dump. How can I resolve this ??
$ inxi -Fazy
Kernel: 6.0.11-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-6.0-x86_64
root=UUID=e2c0e7c8-7b62-446c-8a8f-3636efd65ef0 rw apparmor=1
security=apparmor udev.log_priority=3 acpi_backlight=video ibt=off
Desktop: Xfce v: 4.16.1 tk: Gtk v: 3.24.34 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: LENOVO product: 82RF v: Legion 5 Pro 16IAH7H
serial: Chassis: type: 10 v: Legion 5 Pro 16IAH7H
serial:
Mobo: LENOVO model: LNVNB161216 v: NO DPK serial:
UEFI: LENOVO v: J2CN40WW date: 04/15/2022
ID-1: BAT0 charge: 78.4 Wh (97.0%) condition: 80.8/80.0 Wh (101.0%)
volts: 17.0 min: 15.4 model: Sunwoda L21D4PC1 type: Li-poly serial:
status: discharging cycles: 9
Info: model: 12th Gen Intel Core i9-12900H bits: 64 type: MST AMCP
arch: Alder Lake gen: core 12 level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 3
microcode: 0x424
Topology: cpus: 1x cores: 14 mt: 6 tpc: 2 st: 8 threads: 20 smt: enabled
cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32 KiB, 8x64 KiB
L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 2900 min/max: 400/4900:5000:3800 scaling:
driver: intel_pstate governor: performance cores: 1: 2900 2: 2900 3: 2900
4: 2900 5: 2900 6: 2900 7: 2900 8: 2900 9: 2900 10: 2900 11: 2900 12: 2900
13: 2900 14: 2900 15: 2900 16: 2900 17: 2900 18: 2900 19: 2900 20: 2900
bogomips: 116780
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Device-1: Intel Alder Lake-P Integrated Graphics vendor: Lenovo driver: i915
v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+ ports:
active: eDP-1 empty: DP-1,DP-2 bus-ID: 00:02.0 chip-ID: 8086:46a6
class-ID: 0300
Device-2: NVIDIA GA104M [Geforce RTX 3070 Ti Laptop GPU] vendor: Lenovo
driver: nvidia v: 525.60.11 alternate: nouveau,nvidia_drm non-free: 520.xx+
status: current (as of 2022-10) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 8
link-max: lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:24e0 class-ID: 0300
Device-3: Chicony Integrated Camera type: USB driver: uvcvideo
bus-ID: 3-6:4 chip-ID: 04f2:b67d class-ID: 0e02
Display: x11 server: X.Org v: 21.1.4 compositor: xfwm v: 4.16.1 driver: X:
loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa dri: iris
gpu: i915 display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 2560x1600 s-dpi: 96 s-size: 677x423mm (26.65x16.65")
s-diag: 798mm (31.43")
Monitor-1: eDP-1 model: BOE Display 0x0a1f built: 2021 res: 2560x1600
hz: 60 dpi: 189 gamma: 1.2 size: 344x215mm (13.54x8.46") diag: 406mm (16")
ratio: 16:10 modes: 2560x1600
API: OpenGL v: 4.6 Mesa 22.2.4 renderer: Mesa Intel Graphics (ADL GT2)
direct render: Yes
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_tgl
bus-ID: 00:1f.3 chip-ID: 8086:51c8 class-ID: 0403
Device-2: NVIDIA GA104 High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 8
link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:228b class-ID: 0403
Sound API: ALSA v: k6.0.11-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.61 running: no
Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:51f0 class-ID: 0280
IF: wlp0s20f3 state: up mac:
vendor: Lenovo driver: r8169 v: kernel pcie: speed: Unknown lanes: 63
link-max: gen: 6 speed: 64 GT/s port: 3000 bus-ID: 34:00.0
IF: enp52s0 state: down mac:
Device-1: Intel type: USB driver: btusb v: 0.8 bus-ID: 3-10:6
chip-ID: 8087:0033 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
Local Storage: total: 983.06 GiB used: 14.78 GiB (1.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVL21T0HCLR-00BL2
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 type: SSD serial: rev: CL1QGXA7 temp: 36.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Kingston
model: DataTraveler 3.0 size: 29.2 GiB block-size: physical: 512 B
logical: 512 B type: N/A serial: rev: PMAP scheme: MBR
ID-1: / raw-size: 42 GiB size: 41.04 GiB (97.72%) used: 14.24 GiB (34.7%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
used: 4.4 MiB (0.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 903.4 GiB size: 888.14 GiB (98.31%)
used: 548.1 MiB (0.1%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
ID-1: swap-1 type: partition size: 7.97 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p4 maj-min: 259:4
System Temperatures: cpu: 33.0 C mobo: N/A
Processes: 343 Uptime: 20m wakeups: 1 Memory: 31.08 GiB used: 1.55 GiB (5.0%)
Init: systemd v: 251 default: graphical tool: systemctl Compilers:
gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman pkgs: 1112 libs: 320
tools: pamac,paru pm: flatpak pkgs: 0 Shell: Bash v: 5.1.16
running-in: xfce4-terminal inxi: 3.3.23
$ sudo journalctl -p 3 -xb
Dec 06 18:06:34 legion kernel: pci 0000:00:07.0: DPC: RP PIO log size 0 is invalid
Dec 06 18:06:35 legion kernel:
Dec 06 18:06:39 legion kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
Dec 06 18:06:41 legion bluetoothd[1352]: src/plugin.c:plugin_init() Failed to init vcp plugin
Dec 06 18:06:41 legion bluetoothd[1352]: src/plugin.c:plugin_init() Failed to init mcp plugin
Dec 06 18:06:41 legion bluetoothd[1352]: src/plugin.c:plugin_init() Failed to init bap plugin
Dec 06 18:06:41 legion bluetoothd[1352]: Failed to set mode: Failed (0x03)
Dec 06 18:06:41 legion systemd-coredump[1298]: [🡕] Process 912 (Xorg) of user 0 dumped core.
Module linux-vdso.so.1 with build-id 347c2dae0c6fde546a9f67972c3e1272119739b6
Module libgobject-2.0.so.0 with build-id fed1527402a76901bdf714318a10e982570e3a69
Module libgudev-1.0.so.0 with build-id 460465b63a086d945124662363191903c0002793
Module libwacom.so.9 with build-id e0305944ffbc4bc72839093bcad8800af06968ed
Module libevdev.so.2 with build-id 9ded5f5a6c45f3b30cf380d8a505e90b5f85f164
Module libmtdev.so.1 with build-id 862cf8d5b0a0dd4d4d225e17f54be93ab9c3b34e
Module libinput.so.10 with build-id c64ddd0d240274932700727a693a6b9d15bea585
Module libinput_drv.so with build-id cf829f2000cbe7c7b226d0bc4c8188ab0fa99b62
Module libnvidia-glcore.so.525.60.11 with build-id a9e9acc90cc4626db579f8bf84a4f91574f6b04f
Module libnvidia-tls.so.525.60.11 with build-id a820b303cb808da40698ea7c7bb5faf0f513e260
Module libglxserver_nvidia.so with build-id 7b92afe16f5158562a3f87cb3a660012084c4cf0
Module libxcb-sync.so.1 with build-id de15064c5b1223f9c3d94d5b5e59c0e148e5a0c5
Module libxcb-present.so.0 with build-id 29d01b0e5a22d67e950f9088e18ebf3706a79fc3
Module libxcb-xfixes.so.0 with build-id f26021303f6d30c734aeb5f2fc49373df523863f
Module libxcb-dri2.so.0 with build-id d3b3a7718cac8f1d7eb19926ec4ae059a2b6ed75
Module libX11-xcb.so.1 with build-id 0c964dfdb76868a6f06183ced0c61514b1aea487
Module libEGL_mesa.so.0 with build-id 9c1eaa9f909b5a8d74ab460e71daab7fb02cfab7
Module libnvidia-egl-gbm.so.1 with build-id 1f14517fa9fd345aa89bd27bb435d0379b5e0f65
Module libnvidia-eglcore.so.525.60.11 with build-id d902de6bb70b4c8a903dd73ad8ef8b5e35888abf
Module libwayland-client.so.0 with build-id 72faeb674e37b695629833a5646eb8f757b95985
Module libnvidia-egl-wayland.so.1 with build-id 6928bea1d3616e10d20adabbffa557155ec8e88a
Module libnvidia-glsi.so.525.60.11 with build-id 3cc23c48f0ca0bbbcb31b65fa8291aca9aa86180
Module libpthread.so.0 with build-id 3954d7fd57fa4db438d0ccdd8e2c6f7cc97c2e46
Module libEGL_nvidia.so.0 with build-id 303ae16b9756fd4879354dc49f46ecd08c9f6be6
Module libEGL.so.1 with build-id 14389538015bb4a3a44e794e2466e31bf0834209
Module libicudata.so.72 with build-id a133b365160fc45e002163e5435f3029f4254cfa
Module libicuuc.so.72 with build-id 16a6ce3029f13a2ab5b96414d3c9369311d3ae42
Module libxml2.so.2 with build-id 171e32069b76d4cfedbfdf97f2087807948a9b3d
Module libncursesw.so.6 with build-id b9917757481e6fa6097e2a1f31f5bb5eaf138c4e
Module libedit.so.0 with build-id 7238f531cc2c5f25b845ee0a04b02377ba2eb483
Module libstdc++.so.6 with build-id 735a3d0cc7699fd69337361cba4aedb644b2a7ed
Module libxcb-dri3.so.0 with build-id 683071cc6aaad8250612c1ed904a55c92d0ba120
Module libdrm_nouveau.so.2 with build-id d828ce5d18dfdb45b34dbb56870527e4017a54b8
Module libdrm_amdgpu.so.1 with build-id 2919fffd12ed21cc45716c153ccd296f4224a574
Module libelf.so.1 with build-id 6b7711c74229c8c16197f4df2f640a8ed5bedfdf
Module libdrm_radeon.so.1 with build-id 849129d9e4fd828c9256c0b5be107f3043f1d716
Module libsensors.so.5 with build-id f9c765e839cb1e84bf0020a153710aeffc2b2844
Module libLLVM-14.so with build-id ccb44cf9eb629e6b18536a6f6ee82e72fee5a728
Module iris_dri.so with build-id b52fd63bb08850badbd6f5fe59fe19b42d070fea
Module libglapi.so.0 with build-id 81b9c39841c5ac0321e6a7a16062876725cedbb4
Module libepoxy.so.0 with build-id edc178a150c4255d124e1e1ecbdbecebd1a388cd
Module libglamoregl.so with build-id d1fbcfb0727a53cc05c81a288ca38e9e224d6f99
Module libwfb.so with build-id d2133897168704b54c415745ca88d9b145cd4942
Module libdl.so.2 with build-id 414d1d630bc04818a150b9c73e4493f3395e8869
Module librt.so.1 with build-id ce8e0934f83057f038b5a06eb70082bef142d2f0
Module nvidia_drv.so with build-id 2166d21cafcc524c2830a2da8e70745f21cfa2a7
Module libffi.so.8 with build-id 5c6b22b6624dd486a0783dfe74fee085b626b573
Module libexpat.so.1 with build-id a98bfab551dfa3df6889c33d5fd2ccfa6d505608
Module libwayland-server.so.0 with build-id 1a07d2c4b6e9caafeaca9ee92ee77c983472874e
Module libgbm.so.1 with build-id a1f00acf391e32dd33637e16c05fbc708e0b7d84
Module modesetting_drv.so with build-id 75d16c62ac83c0a7fdb8c7fd1b65537baad78597
Module libxcb.so.1 with build-id f91cf228ed88bb657ff0eac72aa1b9eb1d9610c9
Module libX11.so.6 with build-id 3a3128cd603a4018c9df0e5f40cdde3bf1fd613e
Module libGLX.so.0 with build-id d2c37fb8ec3bc53c67c013b0c6ac63ec086c8883
Module libGLdispatch.so.0 with build-id 7879a881271650eff97c35aff7a8674859c5ae94
Module libGL.so.1 with build-id 6f65953140bc8a2aba47c9d492658dc61891393e
Module libglx.so with build-id cdac1c71de6833198b0863c5623454872e21d2b6
Module libpcre2-8.so.0 with build-id 917fc43d2c9f8539a3e324555c6c73886e8000a8
Module libbrotlicommon.so.1 with build-id c02b3da37cb4c613d7ee0212bbd5a589f00f6180
Module libglib-2.0.so.0 with build-id 74ed0d152046ff91cc5dfd7020fcc2f1d9f689e5
Module libgraphite2.so.3 with build-id ce58945ebb55b86d3a4e717b6eae29efc4720d8e
Module libresolv.so.2 with build-id 2e70cfe9f2972fb13487eeefcb10e4afafed6157
Module libkeyutils.so.1 with build-id ac405ddd17be10ce538da3211415ee50c8f8df79
Module libkrb5support.so.0 with build-id a5f810b57abf4afb41b94bee230a97851d06a279
Module libcom_err.so.2 with build-id 3360a28740ffbbd5a5c0c21d09072445908707e5
Module libk5crypto.so.3 with build-id ab0df0423a058a79962a54ffa8eb7ae47445f91a
Module libkrb5.so.3 with build-id a4e376ba5c58c292059c674e6837811fe3df83ab
Module libgpg-error.so.0 with build-id 3252cd345720e102cc148a683a5dc7c9d88671ea
Module libbrotlidec.so.1 with build-id 14ed71411788cf2c17d8d72c3a7594627f498e40
Module libharfbuzz.so.0 with build-id 181bbb0db2bce74b6bd5ed66ee7dcbed96323d8b
Module libpng16.so.16 with build-id e3d7975e42ac42676559de7aca491d6189fbb1d1
Module libbz2.so.1.0 with build-id d56120069b422b43ed82347d3589494c22cfb509
Module libgssapi_krb5.so.2 with build-id 38e063da079423ae8073326b5c3368b1277acb6d
Module libgcc_s.so.1 with build-id 85db482c4585a328d95ec41124337a967bb24d8f
Module liblz4.so.1 with build-id 84ea95d811dad359e94e100ebe6a746294ffe8a7
Module libzstd.so.1 with build-id ab54c2881f53ab314e134f3e08c76d504376dd5d
Module liblzma.so.5 with build-id 3771167d412c5eb6e309e353c5559ebabee05484
Module libgcrypt.so.20 with build-id 7707a20ebd73a7b5aee84ccdae6e1d7c12f2260b
Module libcap.so.2 with build-id 9b38b08de708f439a9d0a4f8b9914151bc8d4b50
Module libfreetype.so.6 with build-id f89dd5502e75aca28fb5c3ccd0dbd26fe822bfef
Module libfontenc.so.1 with build-id f7a7d3e170f0e46c3579cfb769a5fdf8515f31c1
Module libz.so.1 with build-id 1a4313716f6a80dced5f29f2b35272d06c2d2ce5
Module ld-linux-x86-64.so.2 with build-id 22bd7a2c03d8cfc05ef7092bfae5932223189bc1
Module libc.so.6 with build-id 1e94beb079e278ac4f2c8bce1f53091548ea1584
Module libxcvt.so.0 with build-id 8d2dc49487938c2b11d2831de4b044ef39b31e17
Module libtirpc.so.3 with build-id e1da084293b75c21947e43717fff7ebb91b279da
Module libdrm.so.2 with build-id 9a69d336dca7033fe0df95977c79e6a67e4e51c7
Module libudev.so.1 with build-id 817401b9b452ca6689f50bafeab2db7288536a5e
Module libdbus-1.so.3 with build-id 6d6e4846c8e56903b4fe7d992ae6bb30c8a20a9c
Module libunwind.so.8 with build-id e2dc74d90076f9f9888c8763c64f0cd1bcad3943
Module libsystemd.so.0 with build-id 1c1489e575197ffbf417c79f926e572421f3692f
Module libxshmfence.so.1 with build-id 132b07a9077d5068fc07934d2a447b03c35a5f55
Module libXfont2.so.2 with build-id 668e8978278a4a193f23a62834f6f63ab6ea8387
Module libXdmcp.so.6 with build-id b7297dfce6c9cf4f69330f47605623a2043c990e
Module libXau.so.6 with build-id c7b63a96648d44c9628dfba0cc48fb7c3e45f2b4
Module libnettle.so.8 with build-id 6a26cbe6819abc8c57668f80ca8c8160fd85e29e
Module libpciaccess.so.0 with build-id 10faaf8c3a53bce001fa0f95c6a5c91dfc769dff
Module libm.so.6 with build-id 2c8ff1d29b255da5b7371efd5caf57444d622838
Module libpixman-1.so.0 with build-id 52e6f12fd7fd7332f0c98fb5982716b3432e3df6
Module Xorg with build-id 7eb3c71a79d1a4df8409b669e6a13b49335c1078
Stack trace of thread 912:
#0 0x00007f7f627a364c n/a (libc.so.6 + 0x8864c)
#1 0x00007f7f62753958 raise (libc.so.6 + 0x38958)
#2 0x00007f7f6273d53d abort (libc.so.6 + 0x2253d)
#3 0x000055ece65d4910 OsAbort (Xorg + 0x157910)
#4 0x000055ece65d62b3 FatalError (Xorg + 0x1592b3)
#5 0x000055ece65dbc4c n/a (Xorg + 0x15ec4c)
#6 0x00007f7f62753a00 n/a (libc.so.6 + 0x38a00)
#7 0x000055ece653a03a RRTellChanged (Xorg + 0xbd03a)
#8 0x000055ece663084f n/a (Xorg + 0x1b384f)
#9 0x000055ece6656db6 n/a (Xorg + 0x1d9db6)
#10 0x000055ece6656ea8 n/a (Xorg + 0x1d9ea8)
#11 0x000055ece65d4552 n/a (Xorg + 0x157552)
#12 0x000055ece65cf493 WaitForSomething (Xorg + 0x152493)
#13 0x000055ece64bb526 n/a (Xorg + 0x3e526)
#14 0x00007f7f6273e290 n/a (libc.so.6 + 0x23290)
#15 0x00007f7f6273e34a __libc_start_main (libc.so.6 + 0x2334a)
#16 0x000055ece64bc4b5 _start (Xorg + 0x3f4b5)
Stack trace of thread 1137:
#0 0x00007f7f6279e4b6 n/a (libc.so.6 + 0x834b6)
#1 0x00007f7f627a0cd0 pthread_cond_wait (libc.so.6 + 0x85cd0)
#2 0x00007f7f5f50799e n/a (iris_dri.so + 0x10799e)
#3 0x00007f7f5f4baf8c n/a (iris_dri.so + 0xbaf8c)
#4 0x00007f7f5f5078cc n/a (iris_dri.so + 0x1078cc)
#5 0x00007f7f627a18fd n/a (libc.so.6 + 0x868fd)
#6 0x00007f7f62823a60 n/a (libc.so.6 + 0x108a60)
Stack trace of thread 1022:
Stack trace of thread 1136:
Stack trace of thread 1029:
Stack trace of thread 1030:
Stack trace of thread 1027:
Stack trace of thread 1135:
Stack trace of thread 1032:
Stack trace of thread 1134:
Stack trace of thread 1140:
Stack trace of thread 1020:
Stack trace of thread 1146:
Stack trace of thread 1138:
Stack trace of thread 1144:
Stack trace of thread 1139:
Stack trace of thread 1148:
Stack trace of thread 1145:
Stack trace of thread 1151:
#0 0x00007f7f62823096 epoll_wait (libc.so.6 + 0x108096)
#1 0x000055ece65d450b n/a (Xorg + 0x15750b)
#2 0x000055ece65d04a9 n/a (Xorg + 0x1534a9)
#3 0x00007f7f627a18fd n/a (libc.so.6 + 0x868fd)
#4 0x00007f7f62823a60 n/a (libc.so.6 + 0x108a60)
Stack trace of thread 1018:
Stack trace of thread 1147:
Stack trace of thread 1142:
Stack trace of thread 1021:
Stack trace of thread 1023:
Stack trace of thread 1133:
Stack trace of thread 1033:
Stack trace of thread 1143:
Stack trace of thread 1025:
Stack trace of thread 1013:
Stack trace of thread 1017:
Stack trace of thread 1132:
Stack trace of thread 1024:
Stack trace of thread 1141:
Stack trace of thread 1019:
Stack trace of thread 1031:
