Just January (2017) Screenshots
screenshots
#145
You can install "xdgurl"
then if you are using themes and icons from “opendesktop.org” you can opt to hit the install button available. it installs into the home sub-folder… i use this option at times
#146
A few more from my rotation, then I promise I’ll stop…
#147
Which music player is that in 2nd screenshot at right hand side??
#148
Im gonna nudge in here for kouros…
its “Lollypop”
[You will be forgiven for not realizing it was actually printed in view in the scrot :stuck_out_tongue: ]
#149
Yep…:slight_smile:
#150
please explain, what is all this goodness?
#151
i haven’t seen Skeletor in years, he looks great!
#152
very sick… damn… i really like what you got going there.
enlightenment has always looked clunky to me. this has made me take a second look. is it tedious to configure/customize?
#153
Please @minjaro it might be easier if you posted one comment and utilized the username call with the ‘@’ symbol to separate your responses [just less to scroll, single comment, tidier] .
Like
@minjaro
I do enjoy your enthusiasm
But, @kouros17 is going to get a response too :wink:
#154
I did see that in my defense.
Just didn’t realize it :smiley:
#155
the parts not listed in neofetch are mousepad (the text editor on the left), thunar (top right), termite displaying the aforementioned neofetch and ncmpcpp both inside tmux (bottom left).
the bar is polybar.
the top screenshot is rofi
#156
Playing around in Virtualbox… learning how to setup a netinstall manjaro openbox.
Modified the lightdm-gtk greeter somewhat, would like to find out how to change the login box to transparent or a different shape.
Openbox goodness…
#157
You made an interesting point there, Chrys. It’s been placed on the backburner for further slow-cooked processing. :wink:
#158
I don’t think of customizing Enlightenment as tedious - just a bit of fun because it is easy. With everything comes a learning curve and I would say try it if you are curious.
Regards
#159
Transparency needs compositor. Like compton or xcompmgr. You can try adding their commands to xinitrc, no guarantees it will work though. Lightdm isn’t a window manager.
You can however try other lightdm greeters
yaourt -Ss lightdm greeter
Take your pick. Try webkit greeters. Some are cute, some are hideous, some have transparency, some don’t work at all.
These are available in repository, so more likely to work. It appears some haven’t been updated since 2013-14. Maybe stay clear of those
community/lightdm-webkit-greeter 0.1.2-6
    A lightweight display manager
community/lightdm-webkit-theme-bevel 20130623-1
    A minimal theme for the LightDM Webkit greeter
community/lightdm-webkit-theme-manjaro-light 20140511-1
    A simple webkit theme for Manjaro Linux
community/lightdm-webkit2-greeter-manjaro 1.3.0-1
    A webkit2 greeter for LightDM build for Manjaro
community/lightdm-webkit2-greeter-manjaro-dark 1.3.0-1 [installed]
    A webkit2 greeter for LightDM build for Manjaro Dark version
Good luck.
#160
I wouldn’t say i’m on the Dark side of the Force but quite close :smile: but minimalisticly !
#161
Thanks badbodh. I am using compton but within the openbox wm autostart file and getting transparency on the desktop fine. What i wanted to know is how or is there a way to change the style of the lightdm greeter, like i was able to move the login box and add a background picture, leave out the the user picture on the login box but i cant figure out one would change the greeters style, is there some sort of stylesheet that controls the look?
#162
My desktop KDE Plasma 5.8.5 ;). The Dock is “Latte-Dock” and colors applied are “Brown Steel”.
#163
Xfce, nothing new.
#164
Great picture, shame you chose the wrong DE.
Sorry, but I love KDE, for many years already, and for me there is no other DE than KDE. All others are dull.
But again, great picture.
