Hello, the nvidia-drm module is literally missing. Please help.
$ sudo journalctl -p 3 -xb
Aug 12 17:45:34 HELLRIDER systemd-modules-load[218]: Failed to find module 'nvidia-drm'
$ inxi -SGazy
Kernel: 5.10.56-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/vmlinuz-5.10-x86_64
root=UUID=22ad1895-9134-4c0c-91c8-e5e48d526261 rw quiet
resume=UUID=8d2b2432-28a4-4a0a-9378-689e7e1a1499 udev.log_priority=3
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7
Device-1: Intel Core Processor Integrated Graphics vendor: ASUSTeK
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:0046 class-ID: 0300
Device-2: NVIDIA GT216M [GeForce GT 325M] vendor: ASUSTeK driver: nvidia
v: 340.108 alternate: nouveau bus-ID: 01:00.0 chip-ID: 10de:0a35
class-ID: 0300
Device-3: IMC Networks 2M Integrated Webcam type: USB driver: uvcvideo
bus-ID: 1-1.2:3 chip-ID: 13d3:5122 class-ID: 0e02
Display: x11 server: X.Org 1.20.13 compositor: xfwm4 v: 4.16.1 driver:
loaded: modesetting,nvidia display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 423x238mm (16.7x9.4")
s-diag: 485mm (19.1")
Monitor-1: LVDS-1-1 res: 1600x900 hz: 60 dpi: 106
size: 382x215mm (15.0x8.5") diag: 438mm (17.3")
OpenGL: renderer: GeForce GT 325M/PCIe/SSE2 v: 3.3.0 NVIDIA 340.108
direct render: Yes
$ lsmod | rg nvidia
nvidia 10604544 43
drm 569344 7 drm_kms_helper,nvidia,i915
agpgart 53248 4 intel_agp,intel_gtt,nvidia,drm
$ fd 'nvidia-drm' /
/usr/share/X11/xorg.conf.d/10-nvidia-drm-outputclass.conf
/var/tmp/pamac-build-goran/nvidia-340xx-utils/nvidia-drm-outputclass.conf
/etc/modprobe.d/nvidia-drm.conf
I did this tutorial.
Prepare your system for building drivers
you may want to install development tools: sudo pacman -S git base-devel
then you may want to install your proper kernel headers: sudo pacman -S $(mhwd-kernel -li | grep '*' | cut -d ' ' -f5 | awk '{print $0,"-headers"}' | sed s'/ //'g)
340xx (dkms 5.4 - 5.10)
You need to get the sources first:
git clone https://gitlab.manjaro.org/packages/extra/nvidia-340xx-utils.git
git clone https://gitlab.manjaro.org/packages/multilib/lib32-nvidia-340xx-utils…
First uninstalled everything and installed from AUR all for nvidia-340xx and the dkms - rebooted and nothing.
Then uninstalled again and followed the tutorial - rebooted and again nothing.
Is the module in some of the packages and how can I extract it ??
Thanks…
Hello @GokuSan
Check this folder:
find /usr/lib/modules/$(uname -r)/extramodules/ -name "nvidia*"
and please post this content:
cat /etc/modprobe.d/nvidia-drm.conf
However… I would rather say it is nvidia_drm
and not nvidia-drm
Hi
$ find /usr/lib/modules/$(uname -r)/extramodules/ -name "nvidia* # its empty.
However if I check manually
$ la /usr/lib/modules/5.10.56-1-MANJARO/extramodules/
. .. version # Only this file is present.
$ cat /etc/modprobe.d/nvidia-drm.conf
options nvidia_drm modeset=1
For example
modinfo nvidia_drm
will show you the path… if not there try nvidia
$ modinfo nvidia_drm
modinfo: ERROR: Module nvidia_drm not found.
$ modinfo nvidia
filename: /lib/modules/5.10.56-1-MANJARO/kernel/drivers/video/nvidia.ko.xz
Nvidia and nvidia-uvm exist.
$ fd 'nvidia-uvm' /
/usr/lib/modules/5.4.138-1-MANJARO/kernel/drivers/video/nvidia-uvm.ko.xz
/usr/lib/modules/5.10.56-1-MANJARO/kernel/drivers/video/nvidia-uvm.ko.xz
/var/lib/dkms/nvidia/340.108/5.10.56-1-MANJARO/x86_64/module/nvidia-uvm.ko.xz
/var/lib/dkms/nvidia/340.108/5.4.138-1-MANJARO/x86_64/module/nvidia-uvm.ko.xz
@megavolt I just recompiled the driver through dkms. This is the short output of the log
$ vim /var/lib/dkms/nvidia/340.108/5.10.56-1-MANJARO/x86_64/log/make.log
DKMS make.log for nvidia-340.108 for kernel 5.10.56-1-MANJARO (x86_64)
Thu 12 Aug 20:54:01 CEST 2021
NVIDIA: calling KBUILD...
make[1]: Entering directory '/usr/lib/modules/5.10.56-1-MANJARO/build'
test -e include/generated/autoconf.h -a -e include/config/auto.conf || ( \
echo >&2; \
echo >&2 " ERROR: Kernel configuration is invalid."; \
echo >&2 " include/generated/autoconf.h or include/config/auto.conf are missing.";\
echo >&2 " Run 'make oldconfig && make prepare' on kernel src to fix it."; \
echo >&2 ; \
/bin/false)
Can this help you, help me
Colud this be the culprit for me not having the nvidia-drm module ??
I searched a bit… could it not be the simple fact that v340.108 just don’t have nvidia_drm
? nvidia_drm
was at that time not there as I remember… Maybe I am wrong.
If I search it:
KMS site:https://download.nvidia.com/XFree86/Linux-x86_64/340.108/README/ at DuckDuckGo
I get no result.
If I search it like this:
KMS site:https://download.nvidia.com/XFree86/Linux-x86_64/ at DuckDuckGo
The earliest version is 390 which documented KMS and therefore nvidia_drm.
So my conclusion: Below v390 has no nvidia_drm (KMS).
Hello, have a am buying
I had the module prior to 19.Dec.2020. It was working. I accidentally deleted my /usr
directory and after I reinstalled everything, the module was gone.
Since than I had one post about it, but it wasn’t solved. This is my second post about it in hopes that I resolve the issue and find the module. There must be someone on this forum that uses the nvidia-340 with this module.In the meantime I’ll keep looking if I missed something.
