I can’t open any files from encfs folder mounted
for example when use vlc in firejail
i try terminal show message
$vlc ~/mount/encfs/new/test.mp4
Reading profile /etc/firejail/vlc.profile
Error: cannot access profile file: vlc.local
edit /etc/firejail/vlc.profile and comment #vlc.local
Error: cannot access profile file: globals.local
recomment #global.local
Reading profile /etc/firejail/disable-common.inc
Error: cannot access profile file: disable-common.local
However think ,should all be disabled.
While in elsewhere no problem with firejail profile
Can you help me fix this issue?
