I’ve got a Flashfire Cobra V6 and the hat instead of working as intended it reports as a single axis with each hat direction giving a different value, and axis value stays in that direction until I press a different direction. I’ve tested it in Windows and it works as intended so a factory defect is ruled out
lsusb -vd 11c0:5606 output:
Bus 001 Device 004: ID 11c0:5606 Betop USB Joystick
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 1.10
bDeviceClass 0
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x11c0 Betop
idProduct 0x5606
bcdDevice 1.22
iManufacturer 0
iProduct 2 USB Joystick
iSerial 0
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 0x0022
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 100mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 3 Human Interface Device
bInterfaceSubClass 0
bInterfaceProtocol 0
iInterface 0
HID Device Descriptor:
bLength 9
bDescriptorType 33
bcdHID 1.00
bCountryCode 0 Not supported
bNumDescriptors 1
bDescriptorType 34 Report
wDescriptorLength 232
Report Descriptors:
** UNAVAILABLE **
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0040 1x 64 bytes
bInterval 1
Device Status: 0x0000
(Bus Powered)
dmesg gives the following when it’s connected:
[ 802.839421] input: USB Joystick as /devices/pci0000:00/0000:00:0c.0/usb1/1-2/1-2:1.0/0003:11C0:5606.0003/input/input10
[ 802.839559] hid-generic 0003:11C0:5606.0003: input,hidraw1: USB HID v1.00 Joystick [USB Joystick] on usb-0000:00:0c.0-2/input0
