Due to some bugs in the old one (which have been fixed quite a while ago), I’m waiting for an actualization. I managed to download and run a josm-tested.jar, but I’m interested to learn about the delay.
While I’m not sure, I think it just became outdated because the package maintainer doesn’t have time anymore. But, as I said, I’m in no way sure.
Nevertheless, I see multiple packages, both in the AUR as well as thee community repository when searching for josm:
$ pamac search josm
josm-tested 18543-1 AUR
An editor for OpenStreetMap written in Java
josm-svn 16176-1 AUR
josm-stable 22.09-1 AUR
An editor for OpenStreetMap written in Java. Stable releases
josm-javaws tested-2 AUR
An editor for OpenStreetMap written in Java, Java Web Start version (auto updates on startup)
josm 18463-1 community
And on looking deeper:
$ pamac info josm
Version : 18463-1
Description : An editor for OpenStreetMap written in Java
URL : https://josm.openstreetmap.de/
Licences : GPL
Repository : community
Installed Size : 16.5 MB
Groups : --
Depends On : desktop-file-utils hicolor-icon-theme java-runtime>=11 libxtst ttf-font
Optional Dependencies : --
Provides : --
Replaces : --
Conflicts With : --
Packager : Jaroslav Lichtblau <svetlemodry@archlinux.org>
Build Date : Mon 13 Jun 2022 17:22:28
Validated By : MD5 Sum SHA-256 Sum Signature
$ pamac info josm-stable
Version : 22.09-1
Description : An editor for OpenStreetMap written in Java. Stable releases
Licences : GPL
Repository : AUR
Groups : --
Depends On : hicolor-icon-theme java-runtime>=11 ttf-font sh
Make Dependencies : subversion
Check Dependencies : --
Provides : josm
Replaces : --
Conflicts With : josm
Packager : Unknown
Maintainer : RubenKelevra
First Submitted : Tue 23 Aug 2022 11:51:59
Last Modified : Tue 04 Oct 2022 12:03:02
Votes : 1
Build Date : Unknown
Validated By : Unknown
It would seem the one in the AUR is newer:
vs
So, you could always try the AUR version:
pamac build josm-stable
Hope it helps!
P.S.: I don’t know if we need to ping someone from @Manjaro-Team or even @jarodlau (I hope I’m right about that.) Perhaps one of the @moderators will know.
The josm package is inherited from Arch Linux. It was flagged out of date as you can see here Arch Linux - josm 18463-1 (any)
Once is there with the new version, it will be in unstable first, then testing, then stable, but you could grab it from Arch repository too, if is not heavy dependent on other packages (i didn’t check).
Thank you. As I wrote, I’m using a workaround actually.
I hope, that there will be an actualization in ARCH soon. Is there a possibility to nudge the process or is this already done by “Flagged out-of-date” (which has been done already in July 2022).
