Jelly July (2020) Screenshots
| Manjaro Plasma (Stable) | Theme: Arc | Icons: Papirus |
XFCE + Compiz today ! using a painting done by my buddy for the wallpaper !
Qogir Theme / Numix-circle icons / Simple Conky / Plank
Xfce, Plank
:balloon:
A post was split to a new topic: Can I remove wallpaper packages
My Jelly-icious July changes include removing all KDE panels and using Latte Dock which works so much better, imo, ie. a lot of cool configuration options, such as transparent taskbar, etc. It also allowed me to add a third pop-out media bar from the right.
I used this Latte Dock/Panel layout to start (note the recommended widgets to install first) and then a bit of tweaking on my own; mcOS Catalina for Latte - Dock and Panel
Wallpaper
Edit to add a switch-up, new WhiteSur theme released. The only issue I can't figure out is there is suppose to be a development version of latte dock (v1.0) that has floating panels and rounded corners on the bottom, pictures on WhiteSur KDE Store has it, but can't find this version of Latte Dock anywhere. Any info would be appreciated.
Figured out how to get the new round/floating features and taller media side panel of Latte Dock. The Latte Dock version in Stable is outdated. The newest version has these features, Latte Dock-git, is in AUR. Updated image to reflect.
A "try to find the icons" kind of setup. XFCE + Plank + All the Studio Ghibli Characters
Did someone say "Jelly"? Well, this one has some jelly too...
Not much has changed since my initial monthly screenshots post; it's just another wallpaper (source) as part of a daily rotation this time.
Man, just to see characters of two of my all time favorite anime movies. Kiki's delivery service and Princess Mononoke. Then music in Castle In The Sky is so pretty. Thanks for the memories. Now all I need to watch is My Neighbor Totoro. Which is on my todo list.
simple Gnome
Just slight changes to improve readability..
Tbh, imo every month you post the most gorgeous desktop for a while now.
I just collect macro wallpapers and apply pywal on them, no magic.
If you like this check r/unixporn on reddit. That's what 95% of people there do.
I mostly just post here when I find a good wallpaper to show. thx tho.
Plasma with ksmoothdock and one panel.
Nothing special
Still beta or alfa, buggier then in May :slight_smile:
Hello,
My old MacBook Pro is dead, so new laptop with ArchLinux I3.
Fred
| Manjaro Plasma | Theme: Arc | Icons: Zafiri |
Still cant keep away from tiling WM
Nice! Did you try calcurse I liked it till I tried to make caldav working, it is sad that after 8 years of development it does not work...
yes. I use it on my laptop and as for caldav :disappointed: i'll keep trying
I decided to switch to i3. Here is some first theming with polybar and pawal.
