Ok I’m looking into the difference between HSP/HFP mode and A2DP
in the mean time this is my output for
inxi -Fazy
thought I should include this retroactively.
Kernel: 5.4.67-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=b07503bd-bffa-4d45-aa99-af732d6bdd9e rw quiet
nvme_core.multipath=0 quiet apparmor=1 security=apparmor
resume=UUID=dcad0e08-24aa-413c-931c-95dc8ba5fb19 udev.log_priority=3
Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.1 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Desktop System: Gigabyte product: Z390 AORUS PRO WIFI v: N/A
serial: <filter>
Mobo: Gigabyte model: Z390 AORUS PRO WIFI-CF v: x.x serial: <filter>
UEFI: American Megatrends v: F8 date: 12/27/2018
Device-1: hid-0003:256F:C652.000B-battery
model: 3Dconnexion Universal Receiver serial: N/A charge: N/A status: N/A
Topology: 8-Core model: Intel Core i9-9900K bits: 64 type: MT MCP
arch: Kaby Lake family: 6 model-id: 9E (158) stepping: C (12) microcode: D6
L2 cache: 16.0 MiB
bogomips: 115232
Speed: 800 MHz min/max: 800/5000 MHz Core speeds (MHz): 1: 782 2: 800 3: 800
4: 800 5: 800 6: 800 7: 800 8: 802 9: 800 10: 800 11: 801 12: 800 13: 800
14: 800 15: 800 16: 800
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
Device-1: NVIDIA TU106 [GeForce RTX 2060 Rev. A] vendor: eVga.com.
driver: nvidia v: 418.113 alternate: nouveau,nvidia_drm bus ID: 01:00.0
chip ID: 10de:1f08
Display: x11 server: X.Org 1.20.9 compositor: kwin_x11 driver: nvidia
display ID: :0 screens: 1
Screen-1: 0 s-res: 5120x1440 s-dpi: 118 s-size: 1102x313mm (43.4x12.3")
s-diag: 1146mm (45.1")
Monitor-1: DP-0 res: 2560x1440 hz: 60 dpi: 118 size: 553x311mm (21.8x12.2")
diag: 634mm (25")
Monitor-2: DP-2 res: 2560x1440 dpi: 109 size: 597x336mm (23.5x13.2")
diag: 685mm (27")
OpenGL: renderer: GeForce RTX 2060/PCIe/SSE2 v: 4.6.0 NVIDIA 418.113
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Gigabyte driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_sof_pci bus ID: 00:1f.3
chip ID: 8086:a348
Device-2: NVIDIA TU106 High Definition Audio vendor: eVga.com.
driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 10de:10f9
Device-3: JBL Quantum 600 type: USB driver: hid-generic,snd-usb-audio,usbhid
bus ID: 1-10:14 chip ID: 0ecb:203c
Sound Server: ALSA v: k5.4.67-1-MANJARO
Device-1: Intel Wireless-AC 9560 [Jefferson Peak] driver: N/A
modules: iwlwifi bus ID: 00:14.3 chip ID: 8086:a370
Device-2: Intel Ethernet I219-V vendor: Gigabyte driver: e1000e v: 3.2.6-k
port: efa0 bus ID: 00:1f.6 chip ID: 8086:15bc
IF: eno2 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 1.84 TiB used: 69.15 GiB (3.7%)
ID-1: /dev/nvme0n1 model: PCIe SSD size: 953.87 GiB block size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: <filter>
rev: ECFM12.2 scheme: GPT
ID-2: /dev/nvme1n1 vendor: Samsung model: SSD 970 EVO Plus 250GB
size: 232.89 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 serial: <filter> rev: 2B2QEXM7 scheme: GPT
ID-3: /dev/sda vendor: Samsung model: SSD 860 EVO 1TB size: 931.51 GiB
block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter>
rev: 3B6Q scheme: GPT
ID-1: / raw size: 198.16 GiB size: 194.05 GiB (97.93%)
used: 69.15 GiB (35.6%) fs: ext4 dev: /dev/nvme1n1p2
ID-1: swap-1 type: partition size: 34.43 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme1n1p3
System Temperatures: cpu: 44.0 C mobo: N/A gpu: nvidia temp: 43 C
Processes: 286 Uptime: 22h 49m Memory: 31.30 GiB used: 2.97 GiB (9.5%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1435 lib: 361
flatpak: 0 Shell: Bash v: 5.0.18 running in: yakuake inxi: 3.1.05
and
pacmd list-cards
for this I don’t see anything for audio inputs other than the Cannon Lake inputs.
pacmd list-cards
3 card(s) available.
index: 0
driver: <module-alsa-card.c>
owner module: 6
properties:
alsa.card = "1"
alsa.card_name = "HDA NVidia"
alsa.long_card_name = "HDA NVidia at 0x55080000 irq 17"
device.bus_path = "pci-0000:01:00.1"
sysfs.path = "/devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1"
device.bus = "pci"
device.vendor.id = "10de"
device.vendor.name = "NVIDIA Corporation"
device.product.id = "10f9"
device.product.name = "TU106 High Definition Audio Controller"
device.string = "1"
device.description = "TU106 High Definition Audio Controller"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-pci"
profiles:
output:hdmi-stereo: Digital Stereo (HDMI) Output (priority 5900, available: unknown)
output:hdmi-stereo-extra1: Digital Stereo (HDMI 2) Output (priority 5700, available: unknown)
output:hdmi-stereo-extra2: Digital Stereo (HDMI 3) Output (priority 5700, available: no)
output:hdmi-surround-extra2: Digital Surround 5.1 (HDMI 3) Output (priority 600, available: no)
output:hdmi-surround71-extra2: Digital Surround 7.1 (HDMI 3) Output (priority 600, available: no)
off: Off (priority 0, available: unknown)
active profile: <output:hdmi-stereo-extra1>
sinks:
alsa_output.pci-0000_01_00.1.hdmi-stereo-extra1/#5: TU106 High Definition Audio Controller Digital Stereo (HDMI 2)
sources:
alsa_output.pci-0000_01_00.1.hdmi-stereo-extra1.monitor/#5: Monitor of TU106 High Definition Audio Controller Digital Stereo (HDMI 2)
ports:
hdmi-output-0: HDMI / DisplayPort (priority 5900, latency offset 0 usec, available: yes)
properties:
device.product.name = "DELL U2518D
hdmi-output-1: HDMI / DisplayPort 2 (priority 5800, latency offset 0 usec, available: yes)
properties:
hdmi-output-2: HDMI / DisplayPort 3 (priority 5700, latency offset 0 usec, available: no)
properties:
index: 2
owner module: 8
properties:
alsa.card = "0"
alsa.long_card_name = "HDA Intel PCH at 0x55430000 irq 157"
sysfs.path = "/devices/pci0000:00/0000:00:1f.3/sound/card0"
device.bus = "pci"
device.vendor.id = "8086"
device.product.id = "a348"
device.product.name = "Cannon Lake PCH cAVS"
device.string = "0"
device.description = "Built-in Audio"
profiles:
input:analog-stereo: Analog Stereo Input (priority 65, available: no)
output:analog-stereo: Analog Stereo Output (priority 6500, available: unknown)
output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (priority 6565, available: no)
output:analog-surround-21: Analog Surround 2.1 Output (priority 1300, available: unknown)
output:analog-surround-21+input:analog-stereo: Analog Surround 2.1 Output + Analog Stereo Input (priority 1365, available: no)
output:analog-surround-40: Analog Surround 4.0 Output (priority 1200, available: unknown)
output:analog-surround-40+input:analog-stereo: Analog Surround 4.0 Output + Analog Stereo Input (priority 1265, available: no)
output:analog-surround-41: Analog Surround 4.1 Output (priority 1300, available: unknown)
output:analog-surround-41+input:analog-stereo: Analog Surround 4.1 Output + Analog Stereo Input (priority 1365, available: no)
output:analog-surround-50: Analog Surround 5.0 Output (priority 1200, available: unknown)
output:analog-surround-50+input:analog-stereo: Analog Surround 5.0 Output + Analog Stereo Input (priority 1265, available: no)
output:analog-surround-51: Analog Surround 5.1 Output (priority 1300, available: unknown)
output:analog-surround-51+input:analog-stereo: Analog Surround 5.1 Output + Analog Stereo Input (priority 1365, available: no)
output:iec958-stereo: Digital Stereo (IEC958) Output (priority 5500, available: unknown)
output:iec958-stereo+input:analog-stereo: Digital Stereo (IEC958) Output + Analog Stereo Input (priority 5565, available: no)
active profile: <output:analog-stereo>
sinks:
alsa_output.pci-0000_00_1f.3.analog-stereo/#2: Built-in Audio Analog Stereo
sources:
alsa_output.pci-0000_00_1f.3.analog-stereo.monitor/#2: Monitor of Built-in Audio Analog Stereo
ports:
analog-input-front-mic: Front Microphone (priority 8500, latency offset 0 usec, available: no)
properties:
analog-input-rear-mic: Rear Microphone (priority 8200, latency offset 0 usec, available: no)
properties:
analog-input-linein: Line In (priority 8100, latency offset 0 usec, available: no)
properties:
analog-output-lineout: Line Out (priority 9000, latency offset 0 usec, available: yes)
properties:
analog-output-headphones: Headphones (priority 9900, latency offset 0 usec, available: no)
properties:
iec958-stereo-output: Digital Output (S/PDIF) (priority 0, latency offset 0 usec, available: unknown)
properties:
index: 4
owner module: 35
properties:
alsa.card = "2"
alsa.card_name = "Quantum 600"
alsa.long_card_name = "JBL Quantum 600 at usb-0000:00:14.0-10, full speed"
alsa.driver_name = "snd_usb_audio"
device.bus_path = "pci-0000:00:14.0-usb-0:10:1.0"
sysfs.path = "/devices/pci0000:00/0000:00:14.0/usb1/1-10/1-10:1.0/sound/card2"
udev.id = "usb-JBL_Quantum_600-00"
device.bus = "usb"
device.vendor.id = "0ecb"
device.vendor.name = "JBL"
device.product.id = "203c"
device.product.name = "Quantum 600"
device.serial = "JBL_Quantum_600"
device.string = "2"
device.description = "Quantum 600"
device.icon_name = "audio-card-usb"
profiles:
active profile: <output:iec958-stereo>
sinks:
alsa_output.usb-JBL_Quantum_600-00.iec958-stereo/#6: Quantum 600 Digital Stereo (IEC958)
sources:
alsa_output.usb-JBL_Quantum_600-00.iec958-stereo.monitor/#6: Monitor of Quantum 600 Digital Stereo (IEC958)
ports:
analog-output: Analog Output (priority 9900, latency offset 0 usec, available: unknown)
properties:
properties:
