Jazzy June (2017) Screenshots
screenshots
#41
hello,
interesting your conky…
what are the parameters for Announcements?
vlw fwi, Holmes :slight_smile:
#42
I use these lines
#43
Gnome-Unity style instead of my Plasma desktop :wink:
Cutomized the gtk3 theme a bit
#44
Mate Desktop: Icons: Arc, Theme: Blue Submarine, advance mate menu, compiz, conky, wallpaper can be found here
#45
I love that wallpaper! Any chance you might share the link? :grin:
#46
It looks similar to my Manjaro Mate on VB. :wink:
#47
Its a lot better on metal, smooth as silk!! :slight_smile:
What DE are you using as your daily driver?
#48
I’m using Manjaro Cinnamon (and Windows 10 - dual boot). :slight_smile:
#49
Can’t remember where did i get it from :laughing:.
So i will just post it here.
#50
Hey, thanks! I really appreciate it :slight_smile:
#51
It’s a mac wallpapper: https://www.tineye.com/search/8410776972d959db74c0d8b4c5335b97be8244f1/
I can’t believe no one knows how to do a reverse image lookup.
#52
How do you do that?
#53
https://images.google.com/imghp?hl=en&gws_rd=ssl
Drag and drop an image. I put it in a tools folder on my menu bar along with other look ups.:wink:
#54
Well, as kmartin pointed out you can use googles image lookup site.
Personally, I like to use https://www.tineye.com/, but there are many online reverse image lookup sites.
https://www.google.com/search?q=image+lookup&ie=utf-8&oe=utf-8#q=reverse+image+lookup
#55
My KDE Desktop
#56
OS: Manjaro
DE: Gnome 3.24.2
Theme: Pop-Eta
Icons: Paper
Cursor: Breeze
Shell Theme: Pop-Eta
Extensions: Alternatetab , Arc menu, Dash to panel, Easyscreencast, Manjaro update indicator, Openweather, Tilix dropdown, user themes
Software: Gnome text editor, gThumb, WPS Office, DeaDBeeF, Cheese, gnome videos, Opera web browser, Hexchat, gnome maps, Tilix, Htop
#57
#58
Am I the only one running Enlightenment?
Anyone interested, please use my PKGBUILD’s or binaries (x86_64 only):
:slight_smile: https://github.com/NuLogicSystems/PKGBUILD/
:slight_smile: http://www.nulogicsystems.com/public_files/nulogic/x86_64/
You’ll be glad you did…
EFL 1.19.1
Enlightenment 0.21.8
E Arc theme modified by okra
Arc gtk theme v2/3
Arc icon theme
In the system tray:
indicator-stickynotes
clipit
pamac-tray-appindicator
http://www.enlightenment.org/ss/e-593ca2b5237f30.02425735.jpg
#59
Can I add it as a repo in pacman.conf?
#60
Why yes, yes you can…
Just add this:
[nulogic] SigLevel = Never Server = http://nulogicsystems.com/public_files/nulogic/$arch
You might want to add it before extra, otherwise you’ll need to specify the nulogic repo when installing packages that have older upstream versions.
