Java issue. Launch diff version?
Program fails to launch with default jvm being 1.8. How to force to launch with other versions? Got other versions installed and no this is not minecraft.
You can use the archlinux-java command line utility to change the default Java environment.
As @pobrn mentioned, archlinux-java is your friend and it is documented here Java - ArchWiki
