Hello All
I beg your help for an outstanding problem I have with my new build PC tower.
I’ve 2 screens, the first one, a 22’ LG monitor selected as primary and a second one, a Samsung TV 46’ as secondary.
I don’t understand why, the 46’ has priority on boot and logging, also when this TV is switched off but stay in standby mode. If I want to use the 22’ monitor, I’ve to unplug the HDMI connection from the 46’ TV.
On the XFCE display management, the 22’ is selected as primary and mirror display is unselected.
In this new tower, I’ve also installed the last Debian as independant installation, they have their own ssd, no dual boot (selection by boot keyboard selection)
Debian has also trouble with the screens, It start with the 46’ TV, the 22’ stay in standby only. If I want to use my 22’ monitor with Debian I must unplug the cable from the TV.
At the first look, I think about a graphic card configuration (my old configuration didn’t got these issues), but I could be wrong, it’s an Sapphire Radeon RX6600 Pulse (Navi 23) running with kernel 5.15 LTS
Below some Informations they may help you
$ inxi -G
Device-1: AMD Navi 23 [Radeon RX 6600/6600 XT/6600M] driver: amdgpu
v: kernel
Display: x11 server: X.Org v: 21.1.3 driver: X: loaded: amdgpu
unloaded: modesetting,radeon gpu: amdgpu resolution: 1: 3840x2160~30Hz
2: 1680x1050~60Hz
OpenGL:
renderer: AMD DIMGREY_CAVEFISH (LLVM 13.0.1 DRM 3.42 5.15.41-1-MANJARO)
v: 4.6 Mesa 22.0.4
$ mhwd -li
Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
$ lspci | grep VGA
2d:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Navi 23 [Radeon RX 6600/6600 XT/6600M] (rev c7)
$ xrandr
Screen 0: minimum 320 x 200, current 5520 x 2160, maximum 16384 x 16384
DisplayPort-0 connected 3840x2160+1680+0 (normal left inverted right x axis y axis) 1872mm x 1053mm
3840x2160 30.00*+ 25.00 24.00 29.97 23.98
4096x2160 30.00 25.00 24.00 29.97 23.98
1920x1200 30.00
1920x1080 60.00 50.00 59.94 30.00 25.00 24.00 29.97 23.98
1600x1200 30.00
1680x1050 59.88
1600x900 60.00
1280x1024 75.02 60.02
1440x900 59.90
1366x768 59.79
1280x800 59.91
1152x864 75.00
1280x720 60.00 50.00 59.94
1024x768 75.03 70.07 60.00
832x624 74.55
800x600 72.19 75.00 60.32
720x576 50.00
720x480 60.00 59.94
640x480 75.00 72.81 66.67 60.00 59.94
720x400 70.08
DisplayPort-1 disconnected (normal left inverted right x axis y axis)
DisplayPort-2 disconnected (normal left inverted right x axis y axis)
HDMI-A-0 connected primary 1680x1050+0+552 (normal left inverted right x axis y axis) 473mm x 296mm
1680x1050 59.95*+ 59.88
1440x900 74.98 59.90
1280x960 60.00
1280x800 59.95
1152x864 75.00
1024x768 75.03 60.00
832x624 74.55
800x600 75.00 60.32 56.25
720x576 50.00
720x480 60.00 59.94
640x480 75.00 60.00 59.94
720x400 70.08
I think to have given all informations, if not, ask for more. Some questions I have, can the drivers could be not optimized for this CG, grub/bios options?
Screens connection are HDMI/HDMI for the 22’ and HDMI/Displayport for the 46’
Many thank for your help
