IVPN doesn't work
I purchased this VPN service today and i have a problem with connecting to it. I use the IVPN client from snap. When i try connecting i get the following message:
"Connection error: failed to set manual DNS: DNS error: failed to backup DNS configuration: rename /etc/resolv.conf /etc/-resolv.conf.ivpnsave: permission denied
Has anyone experience with this sort of problems or IVPN on manjaro in general?
Have you started/enabled the service?
systemctl status ivpn-service.service
But why should it be called ivpn.service?
So no it doesnt work.
Because that is what the script is called - it’s in the PKGBUILD:
PKGBUILD - aur.git - AUR Package Repositories
… and it isn’t called:
ivpn.service
it’s called:
is there another command i can try?
Im sry, i have the snap package, i thought it was from AUR but it wasnt.
I have no idea
and have exactly zero experience with snap packages and how they operate within a system.
ok anyways thank you very much
one suggestion (perhaps you can get your money back after you apparently already bought it …)
mullvad vpn
5 bucks a month
no need to buy a long subscription - use as needed on a monthly basis
price is always the same
Feature wise and price wise it looks superior.
And I know it works well.
The Arch wiki has a detailed description on how to set up and use it.
Please read documentation. If you still need help, contact IVPN support.
sounds great, thank you for the recommendation
i did and i will thank you.
