How could I know why did it freeze? Are there any logs? I don’t want to power on because maybe the logs will be overwritten…
I closed the lid of my laptop and I noticed after some time that it didn’t suspend, and the fan was loud and the PC was hot. So I shutdown it manually via button. Is there a way to access logs to understand why did it happened ? I don’t want to power on because maybe the logs will be overwritten…
I had this problem with different kernels and different distros (ubuntu, archlinux, and now manjaro)
I have a Huawei Matebook D14 2020
The problem has happened again. Here’s some logs:
# journalctl -o short-precise -k -b all
Feb 12 16:52:55.318745 Manjaro kernel: uvcvideo: Failed to query (GET_CUR) UVC control 8 on unit 1: -32 (exp. 1).
Feb 12 16:52:55.325405 Manjaro kernel: uvcvideo: Failed to query (GET_DEF) UVC control 8 on unit 1: -32 (exp. 1).
Feb 12 16:52:55.772078 Manjaro kernel: uvcvideo: Failed to query (GET_CUR) UVC control 8 on unit 1: -32 (exp. 1).
Feb 12 16:52:55.772351 Manjaro kernel: uvcvideo: Failed to query (GET_CUR) UVC control 8 on unit 1: -32 (exp. 1).
Feb 12 16:52:55.775413 Manjaro kernel: uvcvideo: Failed to query (GET_CUR) UVC control 8 on unit 1: -32 (exp. 1).
Feb 12 16:52:55.778746 Manjaro kernel: uvcvideo: Failed to query (GET_CUR) UVC control 8 on unit 1: -32 (exp. 1).
Feb 12 16:52:55.782070 Manjaro kernel: uvcvideo: Failed to query (GET_CUR) UVC control 8 on unit 1: -32 (exp. 1).
Feb 12 16:52:55.785405 Manjaro kernel: uvcvideo: Failed to query (GET_CUR) UVC control 8 on unit 1: -32 (exp. 1).
Feb 12 16:52:55.788738 Manjaro kernel: uvcvideo: Failed to query (GET_DEF) UVC control 8 on unit 1: -32 (exp. 1).
Feb 12 16:52:55.788925 Manjaro kernel: uvcvideo: Failed to query (GET_DEF) UVC control 8 on unit 1: -32 (exp. 1).
Feb 12 16:52:55.792073 Manjaro kernel: uvcvideo: Failed to query (GET_DEF) UVC control 8 on unit 1: -32 (exp. 1).
Feb 12 16:52:55.795413 Manjaro kernel: uvcvideo: Failed to query (GET_DEF) UVC control 8 on unit 1: -32 (exp. 1).
Feb 12 16:52:55.798746 Manjaro kernel: uvcvideo: Failed to query (GET_DEF) UVC control 8 on unit 1: -32 (exp. 1).
Feb 12 16:52:55.802094 Manjaro kernel: uvcvideo: Failed to query (GET_DEF) UVC control 8 on unit 1: -32 (exp. 1).
Feb 12 16:52:55.805414 Manjaro kernel: uvcvideo: Failed to query (GET_CUR) UVC control 8 on unit 1: -32 (exp. 1).
Feb 12 16:52:55.808729 Manjaro kernel: uvcvideo: Failed to query (GET_CUR) UVC control 8 on unit 1: -32 (exp. 1).
Feb 12 16:52:55.808878 Manjaro kernel: uvcvideo: Failed to query (GET_CUR) UVC control 8 on unit 1: -32 (exp. 1).
Feb 12 16:52:55.812078 Manjaro kernel: uvcvideo: Failed to query (GET_CUR) UVC control 8 on unit 1: -32 (exp. 1).
Feb 12 16:52:55.815415 Manjaro kernel: uvcvideo: Failed to query (GET_CUR) UVC control 8 on unit 1: -32 (exp. 1).
Feb 12 16:52:55.818703 Manjaro kernel: uvcvideo: Failed to query (GET_CUR) UVC control 8 on unit 1: -32 (exp. 1).
Feb 12 16:52:55.822036 Manjaro kernel: uvcvideo: Failed to query (GET_CUR) UVC control 8 on unit 1: -32 (exp. 1).
Feb 12 16:54:40.448711 Manjaro kernel: usb 1-2: USB disconnect, device number 5
Feb 12 16:54:49.675373 Manjaro kernel: audit: type=1130 audit(1613145289.670:202): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Feb 12 16:54:49.678742 Manjaro kernel: wlp2s0: deauthenticating from c8:54:4b:e0:0a:ba by local choice (Reason: 3=DEAUTH_LEAVING)
Feb 12 16:54:49.705386 Manjaro kernel: rtw_8822ce 0000:02:00.0: sta c8:54:4b:e0:0a:ba with macid 0 left
Feb 12 16:54:49.955384 Manjaro kernel: rtw_8822ce 0000:02:00.0: stop vif 8c:c8:4b:c6:c9:ff on port 0
Feb 12 16:54:50.262054 Manjaro kernel: PM: suspend entry (deep)
