Sphor
15 May 2022 19:58
1
I have an old system I thought of giving a second life to by making it a family computer linked to the TV;
In the past, I used to stream movies, look at pictures, and other similar things on the TV by linking my laptop to it through an HDMI cable;
the laptop sent all the information needed through the HDMI cable, after which the TV split the sound to the sound system & used the video feed for the screen, so it worked as I had expected.
Upon connecting the old PC, however, using the same HDMI cable, I expected everything to work like with the laptop, but it seems that no sound is passed through the HDMI at all.
Edit: I forgot to mention that the HDMI output option does not show in the settings menu, and it shows as “unavailable/unplugged” in Pulse Audio Volume Control.
I tried connecting a jack, and it showed up, but I believe the TV might have the jack entry broken as I couldn’t make it work with any device, be it phone or PC.
P.S. both devices run the latest Stable Manjaro Gnome as of 15/05/2022.
I think the issue might be that the HDMI from the laptop was connected to the Motherboard, whereas the HDMI from the PC is connected to the graphics card? But I am unsure if that would be at all relevant.
Here’s some technical information about the system
inxi --full --verbosity=7 --filter --no-host
Kernel: 5.15.38-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
Desktop: GNOME v: 42.1 tk: GTK v: 3.24.33 wm: gnome-shell dm: GDM v: 42.0
Type: Desktop Mobo: MSI model: G41M-P26 (MS-7592) v: 5.0
serial: <superuser required> BIOS: American Megatrends v: 26.8
date: 08/26/2011
RAM: total: 3.83 GiB used: 2.01 GiB (52.4%)
RAM Report:
Info: quad core model: Intel Core2 Quad Q8300 bits: 64 type: MCP
smt: <unsupported> arch: Core Yorkfield rev: A cache: L1: 256 KiB L2: 4 MiB
Speed (MHz): avg: 2079 high: 2319 min/max: 2003/2499 cores: 1: 2000
2: 2319 3: 2000 4: 2000 bogomips: 20010
Flags: acpi aperfmperf apic arch_perfmon bts clflush cmov constant_tsc
cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts est fpu fxsr ht lahf_lm lm mca
mce mmx monitor msr mtrr nopl nx pae pat pbe pdcm pebs pge pni pse pse36
pti rep_good sep sse sse2 sse4_1 ssse3 syscall tm tm2 tsc vme xsave xtpr
Device-1: NVIDIA G94 [GeForce GT 130] vendor: PC Partner / Sapphire
driver: nouveau v: kernel pcie: speed: 2.5 GT/s lanes: 16 ports:
active: HDMI-A-1 empty: DVI-I-1,VGA-1 bus-ID: 01:00.0 chip-ID: 10de:0626
class-ID: 0300
Display: wayland server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.1
compositor: gnome-shell driver: gpu: nouveau display-ID: 0
Monitor-1: HDMI-A-1 model: Samsung res: 1360x768 dpi: 216
size: 160x90mm (6.3x3.54") diag: 184mm (7.2") modes: max: 1360x768
min: 640x480
OpenGL: renderer: NV94 v: 3.3 Mesa 22.0.3 direct render: Yes
Device-1: Intel NM10/ICH7 Family High Definition Audio
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:27d8 class-ID: 0403
Sound Server-1: ALSA v: k5.15.38-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.51 running: yes
Device-1: Qualcomm Atheros AR8132 Fast Ethernet vendor: Micro-Star MSI
driver: atl1c v: kernel pcie: speed: 2.5 GT/s lanes: 1 port: ec00
bus-ID: 03:00.0 chip-ID: 1969:1062 class-ID: 0200
IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 1.13 TiB used: 11.04 GiB (1.0%)
ID-1: /dev/sda vendor: Crucial model: CT240BX500SSD1 size: 223.57 GiB
speed: <unknown> type: SSD serial: <filter> rev: 054 scheme: MBR
ID-2: /dev/sdb vendor: Western Digital model: WD10EAVS-00D7B1
size: 931.51 GiB speed: <unknown> type: N/A serial: <filter> rev: 1A01
scheme: MBR
ID-1: / size: 210.7 GiB used: 11.04 GiB (5.2%) fs: ext4 dev: /dev/sda1
label: N/A uuid: 64457fcf-b385-48e7-87cd-cea556b21c91
ID-1: swap-1 type: partition size: 8.43 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda2 label: swap uuid: 75b76db1-1a21-4b1d-b672-b5b589d5925b
ID-1: /dev/sdb1 size: 287 MiB fs: ext4 label: N/A
uuid: d8290915-1993-4b80-b1f7-9aebd415e521
Hub-1: 1-0:1 info: Full speed or root hub ports: 8 rev: 2.0 speed: 480 Mb/s
Device-1: 1-8:4 info: Realtek Mass Storage Device (Multicard Reader)
type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.0
speed: 480 Mb/s power: 500mA chip-ID: 0bda:0151 class-ID: 0806
serial: <filter>
Hub-2: 2-0:1 info: Full speed or root hub ports: 2 rev: 1.1
speed: 12 Mb/s chip-ID: 1d6b:0001 class-ID: 0900
Device-1: 2-1:2 info: MosArt 2.4G Keyboard Mouse type: Keyboard,Mouse
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 062a:5918 class-ID: 0301
Hub-3: 3-0:1 info: Full speed or root hub ports: 2 rev: 1.1
Device-1: 3-2:2 info: Maxxter Telink Wireless Receiver
type: Mouse,Keyboard driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 12 Mb/s power: 50mA chip-ID: 248a:8367 class-ID: 0301
Hub-4: 4-0:1 info: Full speed or root hub ports: 2 rev: 1.1
Hub-5: 5-0:1 info: Full speed or root hub ports: 2 rev: 1.1
System Temperatures: cpu: 45.0 C mobo: N/A gpu: nouveau temp: 60.0 C
Fan Speeds (RPM): N/A gpu: nouveau fan: 1892
Processes: 222 Uptime: 4h 30m wakeups: 1 Init: systemd v: 250 Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1185 Shell: Zsh v: 5.8.1
running-in: gnome-terminal inxi: 3.3.15
i would try running pulse or pipewire not both, so lets try uninstalling pulse by installing pipewire with this package: manjaro-pipewire
- it will give you dependency issues, so remove those first, install manjaro-pipewire
, reboot and check
Sphor
15 May 2022 20:36
3
Is this better?
I am unsure what to look for, as both pulse & pipewire’s versions are still shown, even though like you said, the terminal did bring up dependendcy issues, to which I answered Y to all questions.
HDMI still does not show up as an output option in the settings.
Also, this is the new inxi output
inxi --full --verbosity=7 --filter --no-host  ✔
date: 08/26/2011
RAM: total: 3.83 GiB used: 2.13 GiB (55.5%)
RAM Report:
Speed (MHz): avg: 2000 high: 2002 min/max: 2003/2499 cores: 1: 2000
2: 2000 3: 2002 4: 2000 bogomips: 20005
class-ID: 0300
min: 640x480
Sound Server-3: PulseAudio v: 15.0 running: no
Local Storage: total: 1.13 TiB used: 11.1 GiB (1.0%)
scheme: MBR
ID-1: / size: 210.7 GiB used: 11.1 GiB (5.3%) fs: ext4 dev: /dev/sda1
serial: <filter>
System Temperatures: cpu: 48.0 C mobo: N/A gpu: nouveau temp: 61.0 C
Fan Speeds (RPM): N/A gpu: nouveau fan: 1870
Processes: 291 Uptime: 2m wakeups: 0 Init: systemd v: 250 Compilers:
so if it doesnt work with pipewire, try pulse, instal this package: manjaro-pulse
- it will remove pipewire, then reboot
Sphor
15 May 2022 21:42
5
Tried this way too, and unfortunately this isn’t working either.
Someone from the Telegram Manjaro Group said that some machines are uncapable of providing audio data through HDMI, but given that the TV’s AUX intake may be broken (it’s not working with the phone, so I believe might be unusable)
Would you have any other suggestions I may try?
provide output from:
find /etc/udev/rules.d/
Sphor
15 May 2022 21:48
7
brahma:
I saw a post on Reddit which mentioned this, but the folder was empty, although I didn’t try it from Terminal, so let me try now
Yup, still empty
find /etc/udev/rules.d/  ✔
/etc/udev/rules.d/
and do you have open or close sourced drivers installed?
also you could create a .rules file in the file and put this inside it:
# Remove NVIDIA USB xHCI Host Controller devices, if present
ACTION=="add", SUBSYSTEM=="pci", ATTR{vendor}=="0x10de", ATTR{class}=="0x0c0330", ATTR{remove}="1"
# Remove NVIDIA USB Type-C UCSI devices, if present
ACTION=="add", SUBSYSTEM=="pci", ATTR{vendor}=="0x10de", ATTR{class}=="0x0c8000", ATTR{remove}="1"
# Remove NVIDIA Audio devices, if present
#ACTION=="add", SUBSYSTEM=="pci", ATTR{vendor}=="0x10de", ATTR{class}=="0x040300", ATTR{remove}="1"
# Enable runtime PM for NVIDIA VGA/3D controller devices on driver bind
ACTION=="bind", SUBSYSTEM=="pci", ATTR{vendor}=="0x10de", ATTR{class}=="0x030000", TEST=="power/control", ATTR{power/control}="auto"
ACTION=="bind", SUBSYSTEM=="pci", ATTR{vendor}=="0x10de", ATTR{class}=="0x030200", TEST=="power/control", ATTR{power/control}="auto"
# Disable runtime PM for NVIDIA VGA/3D controller devices on driver unbind
ACTION=="unbind", SUBSYSTEM=="pci", ATTR{vendor}=="0x10de", ATTR{class}=="0x030000", TEST=="power/control", ATTR{power/control}="on"
ACTION=="unbind", SUBSYSTEM=="pci", ATTR{vendor}=="0x10de", ATTR{class}=="0x030200", TEST=="power/control", ATTR{power/control}="on"
edit: i dont know if its neccesary but run this after:
sudo mkinitcpio -P
reboot
Sphor
15 May 2022 22:02
9
I am unsure,
From the Manjaro toolbox, it says this, so I think it’s the open source drivers
ATTACHED: PCI
VERSION: 2018.05.04
INFO: Standard open source drivers.
PRIORITY: 2
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300 0380 0302
VENDORIDS: 1002 8086 10de
I will try to put the file there and see how things go, thank you!
create the file with:
sudo nano /etc/udev/rules.d/90-hdmi.rules
put the info inside it, save it ctrl+x
, check if its created and the text is inside, run:
sudo mkinitcpio -P
reboot
post also output from: mhwd -l && mhwd -li
Sphor
15 May 2022 22:21
11
unfortunately it seems that it hasn’t worked , though thank you for trying!
by the way, mkinitcpio was a backup tool I would guess
Here’s the command you suggested:
mhwd -l && mhwd -li  ✔
> 0000:01:00.0 (0300:10de:0626) Display controller nVidia Corporation:
NAME VERSION FREEDRIVER TYPE
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
> Installed PCI configs:
there are no proprietary drivers available for your system … i was thinking that the close source drivers create maybe their own rules, but they are not available for your system… so i dont know what else to do…
Sphor
15 May 2022 22:27
13
Thank you for trying! hopefully someone else will come with an idea
Sphor:
On the website it says:
Requires DVI-to-HDMI dongle and SPDIF audio cable from motherboard to graphics card.
GeForce GT 130 (OEM Product)
So this card have no audio support through HDMI. It must have HDMI 1.0
support where only Video is possible. HDMI 1.1
has DVD-Audio added. Have look here: HDMI - Wikipedia
Sphor
16 May 2022 21:52
15
Thank you so much for explaining it to me;
I had no clue where to even begin looking.
knowing there was no way to get it working through HDMI alone, I looked for other ways to make it work through the options the TV gave.
For some reason, the Motherboard’s VGA did not work, but the graphic card’s did.
Something quite peculiar about this TV is that it has a dedicated PC [VGA+AudioJack] input group, which doesn’t work independently of one another, making me think that the Jack was broken.
End of story is that now it’s sorted, although through ways not-HDMI related, hopefully your insight about how HDMIs work might help others on the forum understand too,
Thank you and @brahma for helping!
system
Closed
19 May 2022 11:53
16
