I recently found that I cannot use <M-]>
keymap in NeoVim.
In insert mode, when I type <M-]>
, it will be mapped to ]
in normal mode, so it seems that Alt
has been mapped to Esc
in konsole. How can I disable this mapping?
keymap in NeoVim.
Depending on what is actually causing the descrepency between the current settings and your desire …
Check your profie settings.
Settings > Edit Current Profile > Keyboad Tab
