Yes
31 August 2020 14:01
1
So my cpu freq is stuck at just under 400 MHz and I can’t seem to figure why. I searched around and read the arch wiki regarding cpu freq, made sure TLP was working alright, governor and all, but nothing. I can’t seem to find the exact reason this is happening, might have to do a clean install. One thing that did catch my attention is that fiddling with cpupower doesn’t seem to change anything for some reason.
Any chance you clever guys know a way I could troubleshoot the issue? Your help would be greatly appreciated.
I’m dumping every relevant command result I can think of in [this pastebin], if there is anything in particular you think might help get to the issue please let me know.
EDIT: won’t let me post the link to the bin for some reason, I’m pasting the dump as a comment to avoid causing unnecessary headaches.
EDIT2: not sure what it means but if I run systemctl status I get “State: degraded” at the top of the result.
EDIT3: thought this might help:
> sudo head /sys/devices/system/cpu/cpu0/cpufreq/*
> ==> /sys/devices/system/cpu/cpu0/cpufreq/affected_cpus <==
> 0
> ==> /sys/devices/system/cpu/cpu0/cpufreq/bios_limit <==
> 3000000
> ==> /sys/devices/system/cpu/cpu0/cpufreq/cpb <==
> 1
> ==> /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq <==
> 3000000
> ==> /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_max_freq <==
> 3000000
> ==> /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_min_freq <==
> 1400000
> ==> /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_transition_latency <==
> 0
> ==> /sys/devices/system/cpu/cpu0/cpufreq/freqdomain_cpus <==
> 0 1
> ==> /sys/devices/system/cpu/cpu0/cpufreq/related_cpus <==
> 0
> ==> /sys/devices/system/cpu/cpu0/cpufreq/scaling_available_frequencies <==
> 3000000 1700000 1400000
> ==> /sys/devices/system/cpu/cpu0/cpufreq/scaling_available_governors <==
> userspace ondemand performance schedutil
> ==> /sys/devices/system/cpu/cpu0/cpufreq/scaling_cur_freq <==
> 399254
> ==> /sys/devices/system/cpu/cpu0/cpufreq/scaling_driver <==
> acpi-cpufreq
> ==> /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor <==
> ondemand
> ==> /sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq <==
> 3000000
> ==> /sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq <==
> 1400000
> ==> /sys/devices/system/cpu/cpu0/cpufreq/scaling_setspeed <==
> <unsupported>
Yes
31 August 2020 14:03
2
> sudo lscpu
> Architecture: x86_64
> CPU op-mode(s): 32-bit, 64-bit
> Byte Order: Little Endian
> Address sizes: 48 bits physical, 48 bits virtual
> CPU(s): 12
> On-line CPU(s) list: 0-11
> Thread(s) per core: 2
> Core(s) per socket: 6
> Socket(s): 1
> NUMA node(s): 1
> Vendor ID: AuthenticAMD
> CPU family: 23
> Model: 96
> Model name: AMD Ryzen 5 4600H with Radeon Graphics
> Stepping: 1
> Frequency boost: enabled
> CPU MHz: 399.207
> CPU max MHz: 3000,0000
> CPU min MHz: 1400,0000
> BogoMIPS: 5991.47
> Virtualization: AMD-V
> L1d cache: 192 KiB
> L1i cache: 192 KiB
> L2 cache: 3 MiB
> L3 cache: 8 MiB
> NUMA node0 CPU(s): 0-11
> Vulnerability Itlb multihit: Not affected
> Vulnerability L1tf: Not affected
> Vulnerability Mds: Not affected
> Vulnerability Meltdown: Not affected
> Vulnerability Spec store bypass: Mitigation; Speculative Store Bypass disabled via prctl an
> d seccomp
> Vulnerability Spectre v1: Mitigation; usercopy/swapgs barriers and __user pointer sa
> nitization
> Vulnerability Spectre v2: Mitigation; Full AMD retpoline, IBPB conditional, IBRS_FW,
> STIBP conditional, RSB filling
> Vulnerability Srbds: Not affected
> Vulnerability Tsx async abort: Not affected
> Flags: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca c
> mov pat pse36 clflush mmx fxsr sse sse2 ht syscall nx mmxe
> xt fxsr_opt pdpe1gb rdtscp lm constant_tsc rep_good nopl n
> onstop_tsc cpuid extd_apicid aperfmperf pni pclmulqdq moni
> tor ssse3 fma cx16 sse4_1 sse4_2 movbe popcnt aes xsave av
> x f16c rdrand lahf_lm cmp_legacy svm extapic cr8_legacy ab
> m sse4a misalignsse 3dnowprefetch osvw ibs skinit wdt tce
> topoext perfctr_core perfctr_nb bpext perfctr_llc mwaitx c
> pb cat_l3 cdp_l3 hw_pstate ssbd mba ibrs ibpb stibp vmmcal
> l fsgsbase bmi1 avx2 smep bmi2 cqm rdt_a rdseed adx smap c
> lflushopt clwb sha_ni xsaveopt xsavec xgetbv1 xsaves cqm_l
> lc cqm_occup_llc cqm_mbm_total cqm_mbm_local clzero irperf
> xsaveerptr rdpru wbnoinvd arat npt lbrv svm_lock nrip_sav
> e tsc_scale vmcb_clean flushbyasid decodeassists pausefilt
> er pfthreshold avic v_vmsave_vmload vgif umip rdpid overfl
> ow_recov succor smca
> journalctl -n 25
> -- Logs begin at Mon 2020-08-24 19:57:19 WEST, end at Sun 2020-08-30 17:55:15 WEST. --
> ago 30 17:52:54 eric-laptop dbus-daemon[442]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.232' (uid=0 pid=7673 comm="sudo lscpu ")
> ago 30 17:52:54 eric-laptop audit[7673]: USER_ACCT pid=7673 uid=1000 auid=1000 ses=1 msg='op=PAM:accounting grantors=pam_permit,pam_time acct="eric" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
> ago 30 17:52:54 eric-laptop audit[7673]: CRED_REFR pid=7673 uid=0 auid=1000 ses=1 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
> ago 30 17:52:54 eric-laptop dbus-daemon[442]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
> ago 30 17:52:54 eric-laptop sudo[7673]: pam_systemd_home(sudo:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
> ago 30 17:52:54 eric-laptop kernel: audit: type=1101 audit(1598806374.928:126): pid=7673 uid=1000 auid=1000 ses=1 msg='op=PAM:accounting grantors=pam_permit,pam_time acct="eric" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
> ago 30 17:52:54 eric-laptop kernel: audit: type=1110 audit(1598806374.928:127): pid=7673 uid=0 auid=1000 ses=1 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
> ago 30 17:52:54 eric-laptop kernel: audit: type=1105 audit(1598806374.938:128): pid=7673 uid=0 auid=1000 ses=1 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
> ago 30 17:52:54 eric-laptop audit[7673]: USER_START pid=7673 uid=0 auid=1000 ses=1 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
> ago 30 17:52:54 eric-laptop sudo[7673]: eric : TTY=pts/2 ; PWD=/home/eric ; USER=root ; COMMAND=/usr/bin/lscpu
> ago 30 17:52:54 eric-laptop sudo[7673]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=0)
> ago 30 17:52:54 eric-laptop sudo[7673]: pam_unix(sudo:session): session closed for user root
> ago 30 17:52:54 eric-laptop audit[7673]: USER_END pid=7673 uid=0 auid=1000 ses=1 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
> ago 30 17:52:54 eric-laptop audit[7673]: CRED_DISP pid=7673 uid=0 auid=1000 ses=1 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
> ago 30 17:52:54 eric-laptop kernel: audit: type=1106 audit(1598806374.991:129): pid=7673 uid=0 auid=1000 ses=1 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
> ago 30 17:52:54 eric-laptop kernel: audit: type=1104 audit(1598806374.991:130): pid=7673 uid=0 auid=1000 ses=1 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
> ago 30 17:54:58 eric-laptop kernel: rtw_pci 0000:03:00.0: stop vif 72:2b:a2:f1:8e:02 on port 0
> ago 30 17:54:58 eric-laptop NetworkManager[444]: <info> [1598806498.1656] device (wlo1): set-hw-addr: set MAC address to 4E:FD:34:31:9A:4E (scanning)
> ago 30 17:54:58 eric-laptop kernel: rtw_pci 0000:03:00.0: start vif 4e:fd:34:31:9a:4e on port 0
> ago 30 17:54:58 eric-laptop NetworkManager[444]: <info> [1598806498.3592] device (wlo1): supplicant interface state: inactive -> interface_disabled
> ago 30 17:54:58 eric-laptop NetworkManager[444]: <info> [1598806498.4192] device (wlo1): supplicant interface state: interface_disabled -> inactive
> ago 30 17:55:02 eric-laptop wpa_supplicant[1025]: nl80211: send_and_recv->nl_recvmsgs failed: -33
> ago 30 17:55:06 eric-laptop wpa_supplicant[1025]: nl80211: send_and_recv->nl_recvmsgs failed: -33
> ago 30 17:55:10 eric-laptop wpa_supplicant[1025]: nl80211: send_and_recv->nl_recvmsgs failed: -33
> ago 30 17:55:15 eric-laptop wpa_supplicant[1025]: nl80211: send_and_recv->nl_recvmsgs failed: -33
> sudo tlp-stat -p
> --- TLP 1.3.1 --------------------------------------------
> +++ Processor
> CPU model = AMD Ryzen 5 4600H with Radeon Graphics
> /sys/devices/system/cpu/cpu0/cpufreq/scaling_driver = acpi-cpufreq
> /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor = ondemand
> /sys/devices/system/cpu/cpu0/cpufreq/scaling_available_governors = userspace ondemand performance schedutil
> /sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq = 1400000 [kHz]
> /sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq = 3000000 [kHz]
> /sys/devices/system/cpu/cpu0/cpufreq/scaling_available_frequencies = 3000000 1700000 1400000 [kHz]
> /sys/devices/system/cpu/cpu10/cpufreq/scaling_driver = acpi-cpufreq
> /sys/devices/system/cpu/cpu10/cpufreq/scaling_governor = ondemand
> /sys/devices/system/cpu/cpu10/cpufreq/scaling_available_governors = userspace ondemand performance schedutil
> /sys/devices/system/cpu/cpu10/cpufreq/scaling_min_freq = 1400000 [kHz]
> /sys/devices/system/cpu/cpu10/cpufreq/scaling_max_freq = 3000000 [kHz]
> /sys/devices/system/cpu/cpu10/cpufreq/scaling_available_frequencies = 3000000 1700000 1400000 [kHz]
> /sys/devices/system/cpu/cpu11/cpufreq/scaling_driver = acpi-cpufreq
> /sys/devices/system/cpu/cpu11/cpufreq/scaling_governor = ondemand
> /sys/devices/system/cpu/cpu11/cpufreq/scaling_available_governors = userspace ondemand performance schedutil
> /sys/devices/system/cpu/cpu11/cpufreq/scaling_min_freq = 1400000 [kHz]
> /sys/devices/system/cpu/cpu11/cpufreq/scaling_max_freq = 3000000 [kHz]
> /sys/devices/system/cpu/cpu11/cpufreq/scaling_available_frequencies = 3000000 1700000 1400000 [kHz]
> /sys/devices/system/cpu/cpu1/cpufreq/scaling_driver = acpi-cpufreq
> /sys/devices/system/cpu/cpu1/cpufreq/scaling_governor = ondemand
> /sys/devices/system/cpu/cpu1/cpufreq/scaling_available_governors = userspace ondemand performance schedutil
> /sys/devices/system/cpu/cpu1/cpufreq/scaling_min_freq = 1400000 [kHz]
> /sys/devices/system/cpu/cpu1/cpufreq/scaling_max_freq = 3000000 [kHz]
> /sys/devices/system/cpu/cpu1/cpufreq/scaling_available_frequencies = 3000000 1700000 1400000 [kHz]
> /sys/devices/system/cpu/cpu2/cpufreq/scaling_driver = acpi-cpufreq
> /sys/devices/system/cpu/cpu2/cpufreq/scaling_governor = ondemand
> /sys/devices/system/cpu/cpu2/cpufreq/scaling_available_governors = userspace ondemand performance schedutil
> /sys/devices/system/cpu/cpu2/cpufreq/scaling_min_freq = 1400000 [kHz]
> /sys/devices/system/cpu/cpu2/cpufreq/scaling_max_freq = 3000000 [kHz]
> /sys/devices/system/cpu/cpu2/cpufreq/scaling_available_frequencies = 3000000 1700000 1400000 [kHz]
> /sys/devices/system/cpu/cpu3/cpufreq/scaling_driver = acpi-cpufreq
> /sys/devices/system/cpu/cpu3/cpufreq/scaling_governor = ondemand
> /sys/devices/system/cpu/cpu3/cpufreq/scaling_available_governors = userspace ondemand performance schedutil
> /sys/devices/system/cpu/cpu3/cpufreq/scaling_min_freq = 1400000 [kHz]
> /sys/devices/system/cpu/cpu3/cpufreq/scaling_max_freq = 3000000 [kHz]
> /sys/devices/system/cpu/cpu3/cpufreq/scaling_available_frequencies = 3000000 1700000 1400000 [kHz]
> /sys/devices/system/cpu/cpu4/cpufreq/scaling_driver = acpi-cpufreq
> /sys/devices/system/cpu/cpu4/cpufreq/scaling_governor = ondemand
> /sys/devices/system/cpu/cpu4/cpufreq/scaling_available_governors = userspace ondemand performance schedutil
> /sys/devices/system/cpu/cpu4/cpufreq/scaling_min_freq = 1400000 [kHz]
> /sys/devices/system/cpu/cpu4/cpufreq/scaling_max_freq = 3000000 [kHz]
> /sys/devices/system/cpu/cpu4/cpufreq/scaling_available_frequencies = 3000000 1700000 1400000 [kHz]
> /sys/devices/system/cpu/cpu5/cpufreq/scaling_driver = acpi-cpufreq
> /sys/devices/system/cpu/cpu5/cpufreq/scaling_governor = ondemand
> /sys/devices/system/cpu/cpu5/cpufreq/scaling_available_governors = userspace ondemand performance schedutil
> /sys/devices/system/cpu/cpu5/cpufreq/scaling_min_freq = 1400000 [kHz]
> /sys/devices/system/cpu/cpu5/cpufreq/scaling_max_freq = 3000000 [kHz]
> /sys/devices/system/cpu/cpu5/cpufreq/scaling_available_frequencies = 3000000 1700000 1400000 [kHz]
> /sys/devices/system/cpu/cpu6/cpufreq/scaling_driver = acpi-cpufreq
> /sys/devices/system/cpu/cpu6/cpufreq/scaling_governor = ondemand
> /sys/devices/system/cpu/cpu6/cpufreq/scaling_available_governors = userspace ondemand performance schedutil
> /sys/devices/system/cpu/cpu6/cpufreq/scaling_min_freq = 1400000 [kHz]
> /sys/devices/system/cpu/cpu6/cpufreq/scaling_max_freq = 3000000 [kHz]
> /sys/devices/system/cpu/cpu6/cpufreq/scaling_available_frequencies = 3000000 1700000 1400000 [kHz]
> /sys/devices/system/cpu/cpu7/cpufreq/scaling_driver = acpi-cpufreq
> /sys/devices/system/cpu/cpu7/cpufreq/scaling_governor = ondemand
> /sys/devices/system/cpu/cpu7/cpufreq/scaling_available_governors = userspace ondemand performance schedutil
> /sys/devices/system/cpu/cpu7/cpufreq/scaling_min_freq = 1400000 [kHz]
> /sys/devices/system/cpu/cpu7/cpufreq/scaling_max_freq = 3000000 [kHz]
> /sys/devices/system/cpu/cpu7/cpufreq/scaling_available_frequencies = 3000000 1700000 1400000 [kHz]
> /sys/devices/system/cpu/cpu8/cpufreq/scaling_driver = acpi-cpufreq
> /sys/devices/system/cpu/cpu8/cpufreq/scaling_governor = ondemand
> /sys/devices/system/cpu/cpu8/cpufreq/scaling_available_governors = userspace ondemand performance schedutil
> /sys/devices/system/cpu/cpu8/cpufreq/scaling_min_freq = 1400000 [kHz]
> /sys/devices/system/cpu/cpu8/cpufreq/scaling_max_freq = 3000000 [kHz]
> /sys/devices/system/cpu/cpu8/cpufreq/scaling_available_frequencies = 3000000 1700000 1400000 [kHz]
> /sys/devices/system/cpu/cpu9/cpufreq/scaling_driver = acpi-cpufreq
> /sys/devices/system/cpu/cpu9/cpufreq/scaling_governor = ondemand
> /sys/devices/system/cpu/cpu9/cpufreq/scaling_available_governors = userspace ondemand performance schedutil
> /sys/devices/system/cpu/cpu9/cpufreq/scaling_min_freq = 1400000 [kHz]
> /sys/devices/system/cpu/cpu9/cpufreq/scaling_max_freq = 3000000 [kHz]
> /sys/devices/system/cpu/cpu9/cpufreq/scaling_available_frequencies = 3000000 1700000 1400000 [kHz]
> /sys/devices/system/cpu/cpufreq/boost = 1
> Intel EPB: unsupported CPU.
> /sys/module/workqueue/parameters/power_efficient = Y
> /proc/sys/kernel/nmi_watchdog = 0
> uname -a (have both 5.7 and 5.8, tried with both)
> Linux eric-laptop 5.7.17-2-MANJARO #1 SMP PREEMPT Sat Aug 22 14:58:17 UTC 2020 x86_64 GNU/Linux
> pacman -Qe
> accountsservice 0.6.55-2
> acpi 1.7-3
> acpid 2.0.32-2
> alsa-firmware 1.2.1-2
> alsa-plugins 1:1.2.2-2
> alsa-utils 1.2.3-2
> amd-ucode 20200817.r1695.7a30af1-1
> arandr 0.1.10-4
> autoconf 2.69-7
> automake 1.16.2-3
> autotiling 1.1-1
> avahi 0.8+15+ge8a3dd0-1
> b43-fwcutter 019-3
> bash 5.0.018-1
> binutils 2.35-1
> bison 3.6.4-1
> brave 1.12.105-1
> btrfs-progs 5.7-1
> bzip2 1.0.8-3
> clipit 1:1.4.3-2
> cmake 3.18.2-1
> coreutils 8.32-1
> cpupower 5.7-1
> crda 4.14-3
> cronie 1.5.5-1
> cryptsetup 2.3.3-1
> device-mapper 2.02.187-3
> dfc 3.1.1-3
> dhclient 4.4.2-2
> dhcpcd 9.1.4-2
> diffutils 3.7-3
> dmidecode 3.2-2
> dmraid 1.0.0.rc16.3-12
> dnsmasq 2.82-2
> dosfstools 4.1-3
> e2fsprogs 1.45.6-2
> ecryptfs-utils 111-4
> efibootmgr 17-1
> escrotum-git 0.2.1.r47.abcab0e-1
> exfat-utils 1.3.0-2
> f2fs-tools 1.13.0-2
> fakeroot 1.24-2
> featherpad 0.14.2-2
> feh 3.4.1-1
> file 5.39-1
> filesystem 2020.05-1
> findutils 4.7.0-2
> flex 2.6.4-3
> gawk 5.1.0-1
> gcc 10.2.0-1
> gcc-libs 10.2.0-1
> gcolor2 0.4-9
> gettext 0.20.2-1
> glibc 2.32-2
> gnome-keyring 1:3.36.0-1
> gotop 4.0.0-1
> gparted 1.1.0-1
> grep 3.4-1
> grub 2.04-11.1
> grub-theme-manjaro-dev 18.0-3
> gvfs 1.44.1-4
> gvfs-afc 1.44.1-4
> gvfs-gphoto2 1.44.1-4
> gvfs-mtp 1.44.1-4
> gvfs-smb 1.44.1-4
> gzip 1.10-3
> hardcode-fixer 1:r539.f812186-5
> htop 2.2.0-3
> i3-default-artwork 20190912-1
> inetutils 1.9.4-8
> inxi 3.1.05+2-1
> iproute2 5.8.0-1
> iputils 20190709-3
> jdk-openjdk 14.0.2.u12-1
> jdk8-openjdk 8.u262-1
> jfsutils 1.1.15-7
> kvantum-manjaro 0.13.5-1
> less 551-3
> lib32-flex 2.6.4-2
> lib32-libva-vdpau-driver 0.7.4-6
> lib32-mesa-demos 8.4.0-2
> lib32-mesa-vdpau 20.1.6-1
> lib32-vulkan-intel 20.1.6-1
> lib32-vulkan-radeon 20.1.6-1
> libtool 2.4.6+42+gb88cebd5-14
> libva-mesa-driver 20.1.6-1
> libva-vdpau-driver 0.7.4-4
> licenses 20200427-1
> lightdm-slick-greeter 1.3.2-1
> linux-latest 5.7-2
> linux58 5.8.3-2
> logrotate 3.17.0-1
> lvm2 2.02.187-3
> lxappearance 0.6.3-3
> lxinput 0.3.5-3
> m4 1.4.18-3
> maia-console 1.2-6
> make 4.3-3
> man-db 2.9.3-1
> man-pages 5.08-1
> manjaro-alsa 20200126-1
> manjaro-browser-settings 20200629-1
> manjaro-firmware 20160419-1
> manjaro-hotfixes 2018.08-6
> manjaro-i3-settings 20200804-1
> manjaro-ranger-settings 20190513-2
> manjaro-release 20.1-0
> manjaro-system 20200723-1
> manjaro-zsh-config 0.12-1
> markdown_previewer 0.r6.64ad4d7-1
> materia-gtk-theme 20200320-1
> mdadm 4.1-2
> memtest86+ 5.01-4
> mesa-demos 8.4.0-4
> mesa-vdpau 20.1.6-1
> mhwd 0.6.4-3
> mhwd-db 0.6.4-12
> mkinitcpio-openswap 0.1.0-3
> mlocate 0.26.git.20170220-3
> mobile-broadband-provider-info 20190618-2
> moc 1:2.5.2-3
> modemmanager 1.14.2-1
> morc_menu 1.0-2
> mousepad 0.4.2-3
> nano 5.1-1
> ncdu 1.15.1-1
> netbeans 12.0-1
> netctl 1.23-1
> network-manager-applet 1.18.0-1
> networkmanager 1.26.2-1
> networkmanager-openconnect 1.2.6-2
> networkmanager-openvpn 1.8.12-1
> networkmanager-pptp 1.2.9dev+10+gb41b0d0-2
> networkmanager-vpnc 1.2.7dev+20+gdca3aea-2
> nfs-utils 2.5.1-1
> noto-fonts-emoji 20200720-1
> nss-mdns 0.14.1-3
> ntfs-3g 2017.3.23-4
> ntp 4.2.8.p15-1
> openresolv 3.11.0-1
> openssh 8.3p1-3
> os-prober 1.77-1
> p7zip 16.02-6
> pacman 5.2.2-2
> pamac-gtk 9.5.8-1
> patch 2.7.6-8
> patchutils 0.3.4-4
> pavucontrol 1:4.0-2
> pciutils 3.7.0-1
> perl 5.32.0-1
> perl-file-mimeinfo 0.29-4
> phpmyadmin 5.0.2-1
> pkgconf 1.7.3-1
> polkit-gnome 0.105-5
> polybar 3.4.3-3
> powertop 2.13-1
> procps-ng 3.3.16-2
> psmisc 23.3-2
> pulseaudio 13.0-3
> qt5-styleplugins 5.0.0.20170311-23
> qt5ct 1.1-1
> ranger 1.9.3.4.gd8c363c9-1
> reiserfsprogs 3.6.27-3
> rsync 3.2.3-1
> s-nail 14.9.19-1
> sbxkb 0.7.6-4
> screenfetch 3.9.1-1
> sed 4.8-1
> shadow 4.8.1-3
> spectre-meltdown-checker 0.43-1
> speedtest-cli 2.1.2-2
> squashfs-tools 4.4-2
> sudo 1.9.2-1
> sysfsutils 2.1.0-11
> syslog-ng 3.28.1-3
> sysstat 12.4.0-1
> systemd 246.3-2
> systemd-fsck-silent 239-1
> systemd-sysvcompat 246.3-2
> tar 1.32-3
> terminus-font 4.48-3
> texinfo 6.7-3
> thunar 1.8.15-1
> timeshift 20.03.r8.gad3c01c-1
> tlp 1.3.1-2
> tlpui 1.3.1-1
> tree 1.8.0-2
> ttf-bitstream-vera 1.10-14
> ttf-ubuntu-font-family 0.83-6
> ufw 0.36-3
> upower 0.99.11-3
> usbutils 012-2
> util-linux 2.36-2
> vi 1:070224-4
> viewnior 1.7-3
> vim 8.2.1490-0.1
> w3m 0.5.3.git20200507-1
> wget 1.20.3-3
> which 2.21-5
> wmutils 1:1.4-1
> wpa_supplicant 2:2.9-7
> xautolock 2.2-6
> xdg-user-dirs 0.17-3
> xdg-utils 1.1.3+19+g9816ebb-1
> xdotool 3.20160805.1-3
> xf86-input-elographics 1.4.2-2
> xf86-input-evdev 2.10.6-2
> xf86-input-libinput 0.30.0-1
> xf86-input-void 1.4.1-5
> xf86-video-amdgpu 19.1.0-2
> xf86-video-ati 1:19.1.0-2
> xf86-video-intel 1:2.99.917+908+g7181c5a4-1
> xf86-video-nouveau 1.0.16-2
> xfce4-power-manager 1.6.6-1
> xfce4-terminal 0.8.9.2-1
> xfsprogs 5.7.0-3
> xorg-server 1.20.8-4
> xorg-twm 1.0.11-1
> xorg-xhost 1.0.8-2
> xorg-xinit 1.4.1-2
> xorg-xkill 1.0.5-2
> xorg-xprop 1.2.4-2
> xterm 358-1
> xz 5.2.5-1
> yay 10.0.4-1
> zathura 0.4.6-1
> zathura-pdf-poppler 0.3.0-1
> zensu 0.1-1
EDIT: formatting is nice
can you reports
inxi -Fxza --no-host
cpupower frequency-info
have you try others kernels ?
( 5.7 or 5.8 series )
Yes
31 August 2020 14:50
5
Yes, I’ve tried both but no difference
> System: Kernel: 5.8.3-2-MANJARO x86_64 bits: 64 compiler: N/A
> parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64 root=UUID=c9b98775-8f09-4cc4-9493-cd91a7523513 rw quiet
> udev.log_priority=3
> Desktop: i3 4.18.2 info: polybar dm: LightDM 1.30.0 Distro: Manjaro Linux
> Machine: Type: Laptop System: HP product: HP Pavilion Gaming Laptop 15-ec1xxx v: N/A serial: <filter> Chassis: type: 10
> serial: <filter>
> Mobo: HP model: 87B1 v: 31.17 serial: <filter> UEFI: AMI v: F.02 date: 05/14/2020
> Battery: ID-1: BAT0 charge: 51.4 Wh condition: 51.4/51.4 Wh (100%) volts: 13.1/11.6 model: Hewlett-Packard Primary
> type: Li-ion serial: N/A status: Full cycles: 462
> CPU: Topology: 6-Core model: AMD Ryzen 5 4600H with Radeon Graphics socket: FP6 bits: 64 type: MT MCP arch: Zen
> family: 17 (23) model-id: 60 (96) stepping: 1 microcode: 8600103 L1 cache: 384 KiB L2 cache: 3072 KiB
> L3 cache: 8192 KiB
> flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 71898
> Speed: 399 MHz min/max: 1400/3000 MHz base/boost: 3000/4000 boost: enabled volts: 1.2 V ext-clock: 100 MHz
> Core speeds (MHz): 1: 399 2: 399 3: 399 4: 400 5: 399 6: 399 7: 399 8: 399 9: 399 10: 399 11: 399 12: 400
> Vulnerabilities: Type: itlb_multihit status: Not affected
> Type: l1tf status: Not affected
> Type: mds status: Not affected
> Type: meltdown status: Not affected
> Type: spec_store_bypass mitigation: Speculative Store Bypass disabled via prctl and seccomp
> Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user pointer sanitization
> Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
> Type: srbds status: Not affected
> Type: tsx_async_abort status: Not affected
> Graphics: Device-1: NVIDIA TU117M vendor: Hewlett-Packard driver: nouveau v: kernel bus ID: 01:00.0 chip ID: 10de:1f99
> Device-2: Advanced Micro Devices [AMD/ATI] Renoir vendor: Hewlett-Packard driver: amdgpu v: kernel bus ID: 05:00.0
> chip ID: 1002:1636
> Device-3: IMC Networks HP TrueVision HD Camera type: USB driver: uvcvideo bus ID: 3-3:3 chip ID: 13d3:56c9
> serial: <filter>
> Display: server: X.Org 1.20.8 compositor: compton driver: amdgpu,ati,modesetting,nouveau alternate: fbdev,nv,vesa
> display ID: :0 screens: 1
> Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.0x11.2") s-diag: 582mm (22.9")
> Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 142 size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
> OpenGL: renderer: AMD RENOIR (DRM 3.38.0 5.8.3-2-MANJARO LLVM 10.0.1) v: 4.6 Mesa 20.1.6 direct render: Yes
> Audio: Device-1: NVIDIA vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 10de:10fa
> Device-2: Advanced Micro Devices [AMD] Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Hewlett-Packard
> driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x bus ID: 05:00.5 chip ID: 1022:15e2
> Device-3: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
> bus ID: 05:00.6 chip ID: 1022:15e3
> Sound Server: ALSA v: k5.8.3-2-MANJARO
> Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Hewlett-Packard driver: r8169 v: kernel
> port: e000 bus ID: 02:00.0 chip ID: 10ec:8168
> IF: eno1 state: down mac: <filter>
> Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter vendor: Hewlett-Packard driver: rtw_8822ce
> v: N/A modules: rtw88_8822ce port: d000 bus ID: 03:00.0 chip ID: 10ec:c822
> IF: wlo1 state: down mac: <filter>
> IF-ID-1: enp5s0f4u1u4 state: unknown speed: N/A duplex: N/A mac: <filter>
> Drives: Local Storage: total: 476.94 GiB used: 16.93 GiB (3.5%)
> SMART Message: Required tool smartctl not installed. Check --recommends
> ID-1: /dev/nvme0n1 vendor: Toshiba model: KBG40ZNV512G KIOXIA size: 476.94 GiB block size: physical: 512 B
> logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: HP00AE00 scheme: GPT
> Partition: ID-1: / raw size: 100.57 GiB size: 98.49 GiB (97.93%) used: 13.10 GiB (13.3%) fs: ext4 block size: 4096 B
> dev: /dev/nvme0n1p4
> ID-2: /home raw size: 129.61 GiB size: 126.58 GiB (97.66%) used: 3.82 GiB (3.0%) fs: ext4 block size: 4096 B
> dev: /dev/nvme0n1p5
> Swap: Kernel: swappiness: 60 (default) cache pressure: 100 (default)
> ID-1: swap-1 type: partition size: 8.80 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p3
> Sensors: System Temperatures: cpu: 46.6 C mobo: N/A
> Fan Speeds (RPM): N/A
> GPU: device: amdgpu temp: 46 C device: nouveau temp: 40 C
> Info: Processes: 258 Uptime: 56m Memory: 7.21 GiB used: 1.63 GiB (22.6%) Init: systemd v: 246 Compilers: gcc: 10.2.0
> Packages: pacman: 806 lib: 219 Shell: Bash (sudo) v: 5.0.18 running in: xfce4-terminal inxi: 3.1.05
> analyzing CPU 0:
> driver: acpi-cpufreq
> CPUs which run at the same hardware frequency: 0
> CPUs which need to have their frequency coordinated by software: 0
> maximum transition latency: Cannot determine or is not supported.
> hardware limits: 1.40 GHz - 3.00 GHz
> available frequency steps: 3.00 GHz, 1.70 GHz, 1.40 GHz
> available cpufreq governors: userspace ondemand performance schedutil
> current policy: frequency should be within 1.40 GHz and 3.00 GHz.
> The governor "ondemand" may decide which speed to use
> within this range.
> current CPU frequency: Unable to call hardware
> current CPU frequency: 399 MHz (asserted by call to kernel)
> boost state support:
> Supported: yes
> Active: no
sudo cpupower frequency-info
> analyzing CPU 0:
> within this range.
> current CPU frequency: 1.70 GHz (asserted by call to hardware)
> Supported: yes
> Active: yes
> Boost States: 0
> Total States: 3
> Pstate-P0: 3000MHz
> Pstate-P1: 1700MHz
> Pstate-P2: 1400MHz
moson
31 August 2020 16:02
6
Sounds a bit like this:
https://bbs.archlinux.org/viewtopic.php?id=248477
Check if there is a BIOS update available for your NB.
Yes
31 August 2020 16:37
7
Not really… Wouldn’t that be solved by changing kernel anyways?
moson
31 August 2020 17:07
8
Don’t know. Didn’t read it all. Still worth a try with a firmware update.
may be stay on 5.7 series
Yes
31 August 2020 17:40
10
Tried already, doesn’t change a thing
moson
31 August 2020 18:22
11
Is it a fresh installation or did you get this problem recently after an update?
Yes
31 August 2020 18:27
12
I got it recently after fidlling around with who knows what. I found out after a reboot after 3 days without one… wasn’t after an update or anything. Oh and when booting from a live install I get the same problem. BIOS says CPUs are fine.
moson
31 August 2020 18:34
13
You “fiddled around” in the bios as well? Try bios defaults. Still I’d recommend to upgrade firmware.
Yes
31 August 2020 19:01
14
Definately not and already tried resetting the BIOS, will try to upgrade it as soon as I get to a windows machine. HP just loves linux users that much.
stephane:
Just an fyi, “a
” applies “xxx
”. And “z
” applies “--no-host
So inxi -Fza
is fine.
