Issues with passwordless ssh login after first attempt
Hello, I was trying to setup a passwordless ssh server on one of my old PCs and ran into a strange issue that I couldn’t figure out.
I setup the sshd_config following a guide, and then created the public/private key on my client machine, which is an ipad if that is important.
Then before attempting port forwarding I tested on my local network and was initially able to login on my client machine, but I tried opening emacs which got the terminal stuck so I just killed the app I was connecting with. After doing this I wasn’t able to connect again until hours later.
So I was wondering does this sound like a config issue on the server side, or does it sound like a issue with the app I’m using on the ipad not closing the connection properly?
Below I’ll post as much helpful information I know about:
sshd_config
Port <non-std-port>
LoginGraceTime 2m
PermitRootLogin no
MaxAuthTries 5
AuthorizedKeysFile .ssh/authorized_keys
PasswordAuthentication no
PermitEmptyPasswords no
ChallengeResponseAuthentication no
UsePAM yes
PrintMotd no # pam does that
ClientAliveInterval 720
Subsystem sftp /usr/lib/ssh/sftp-server
Protocol 2
AllowUsers <my-user>
journalctl -u sshd
These are the messages printed whether the login is successful or not.
<DATE> <USER> sshd[<#>]: pam_systemd_home(sshd:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
<DATE> <USER> sshd[<#>]: Accepted publickey for <USER> from <IP> port <PORT> ssh2: RSA SHA256:<SHA>
<DATE> <USER> sshd[<#>]: pam_unix(sshd:session): session opened for user <USER>(uid=<#1>) by (uid=<#2>)
<DATE> <USER> sshd[<#>]: pam_env(sshd:session): deprecated reading of user environment enabled
