Issues with Optimus Switch GDM - GDM defaults to "llvmpipe", videos still lag, need help diagnosing
Hello,
Another duel graphics issue. Specs are below, I tried optimus switch (gdm) and everything works fine except that .mp4 and .avi video files lag when played in the Video app, audio is fine.
Version: Kyria 19.0.2
Kernel: 5.4.23
GNOME: 3.34.4
GPU: (intel only) VGA intel uhd graphics 630 (disabled) Geforce MX250
GPU Driver: video-nvidia-440xx (2019.25.10)
EDIT: recent problem I have found is Gnome defaults to llvmpipe (LLVM 9.0.1, 256 bits) in Settings/Details/About/Graphics when it should be using IntelUHD 630.
(1)several (2) Ubuntu forums list this error for GDM, but the fixes are all relevant to Ubuntu only.
Initially I tried nvidia prime mode and booted to a black screen. Intel only mode booted to GDM, but all original issues persisted (unable to play .mp4 and .avi files, discord and chromium glitch out).
Through googling I was told to check the xorg.conf file. The author of optimus-switch suggests to fall back to Direct Rendering Infrastructure (1) instead of the default (3). This solved all the original problems, however the video files still lag.
/etc/X11/xorg.conf.d/20-intel.conf file:
   Section "Device"
        Identifier  "Intel Graphics"
        Driver      "intel"
        Option      "DRI" "1"             # DRI2 and DRI1 are alternatives if DRI3 performs performs poorly
        Option      "TearFree" "True"
        #Option      "AccelMethod"  "sna" # default
        #Option      "AccelMethod"  "uxa" # fallback
     EndSection
how else can I diagnose this issue and potentially get the videos to flow naturally, without lag? As well as Gnome recognizing the proper GPU? Thank you for any help.
