hi all
when I type in terminal:
$ npm
bash: npm: command not found
it worked yesterday.
I just reinstalled npm and nodejs in an attempt to fix the problem, still same issue.
what is going on?
hi all
$ npm
what is going on?
ok for some reason, yesterday i had updated npm with:
sudo npm install -g npm
and now
$ npm
does not work
but
$ sudo npm
does work
how do i revert this, because now i have to sudo everything i install through npm
ok shit so now what?
Use a node version manager e.g. nvm (github)
