Pacman error: failed retrieving file 'core.db' from mirrors.piconets.webwerks.in
Hi i have a problem please help me
sudo pacman -Syu
 core.db failed to download
error: failed retrieving file 'core.db' from mirrors.piconets.webwerks.in : SSL certificate problem: certificate has expired
error: failed to synchronize all databases (download library error)
Hello,
Have you searched the forum?
You have to update mirrors first:
sudo pacman-mirrors -f5
and then run
sudo pacman -Syyu
or all at once
sudo pacman-mirrors -f5 && sudo pacman -Syyu
You might find this useful.
Welcome to the forum!
Try refreshing your mirror list, like so… :arrow_down:
sudo pacman-mirrors -f 5 && sudo pacman -Syyu
hi i tried updating mirror but same problem
::INFO => Mirror status: https://repo.manjaro.org/status.json
::INFO Using custom mirror file
::INFO Querying mirrors - This may take some time
::WARNING No mirrors in selection
::INFO The mirrors has not changed
is the same as the first time. This might help
hello but problem is not solved
Try sudo pacman-mirrors --continent && sudo pacman -Syyu.
You seem to have limited your mirrorlist to a faulty mirror.
thank you so much mirror is updated.
