Hello everyone
I wanna install compton but when I simply type compton
in terminal, it says:
[ 11/26/2020 22:25:38.213 session_init WARN ] This compositor has been renamed to "picom", the "compton" binary will not be installed in the future.
[ 11/26/2020 22:25:38.218 session_init FATAL ERROR ] Another composite manager is already running
What should I do?
Specs:
System: Kernel: 5.8.18-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0 Desktop: KDE Plasma 5.20.3 tk: Qt 5.15.1
wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Laptop System: HP product: HP Pavilion Gaming Laptop 15-ec1xxx v: N/A serial: <superuser/root required>
Chassis: type: 10 serial: <superuser/root required>
Mobo: HP model: 87B1 v: 31.17 serial: <superuser/root required> UEFI: AMI v: F.02 date: 05/14/2020
Battery: ID-1: BAT0 charge: 15.9 Wh condition: 49.2/49.2 Wh (100%) volts: 11.0/11.6 model: Hewlett-Packard Primary
type: Li-ion serial: N/A status: Discharging cycles: 442
CPU: Info: 6-Core model: AMD Ryzen 5 4600H with Radeon Graphics bits: 64 type: MT MCP arch: Zen rev: 1
L2 cache: 3072 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 71895
Speed: 1397 MHz min/max: 1400/3000 MHz boost: enabled Core speeds (MHz): 1: 1397 2: 1398 3: 1397 4: 1397 5: 1397
6: 1397 7: 1397 8: 1391 9: 1398 10: 1397 11: 1400 12: 1397
Graphics: Device-1: NVIDIA TU117M vendor: Hewlett-Packard driver: N/A bus ID: 01:00.0 chip ID: 10de:1f99
Device-2: Advanced Micro Devices [AMD/ATI] Renoir vendor: Hewlett-Packard driver: amdgpu v: kernel bus ID: 05:00.0
chip ID: 1002:1636
Device-3: Luxvisions Innotech Limited HP TrueVision HD Camera type: USB driver: uvcvideo bus ID: 3-3:3
chip ID: 30c9:0013 serial: 0001
Display: x11 server: X.Org 1.20.9 compositor: kwin_x11 driver: amdgpu resolution: 1920x1080~60Hz s-dpi: 96
OpenGL: renderer: AMD RENOIR (DRM 3.38.0 5.8.18-1-MANJARO LLVM 11.0.0) v: 4.6 Mesa 20.2.2 direct render: Yes
Audio: Device-1: Advanced Micro Devices [AMD] Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Hewlett-Packard
driver: snd_rn_pci_acp3x v: kernel bus ID: 05:00.5 chip ID: 1022:15e2
Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
bus ID: 05:00.6 chip ID: 1022:15e3
Sound Server: ALSA v: k5.8.18-1-MANJARO
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Hewlett-Packard driver: r8169 v: kernel
port: e000 bus ID: 02:00.0 chip ID: 10ec:8168
IF: eno1 state: down mac: b0:5c:da:42:34:3f
Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter vendor: Hewlett-Packard driver: rtw_8822ce
v: N/A port: d000 bus ID: 03:00.0 chip ID: 10ec:c822
IF: wlo1 state: up mac: 70:66:55:bb:04:b7
Drives: Local Storage: total: 476.94 GiB used: 135.51 GiB (28.4%)
ID-1: /dev/nvme0n1 vendor: Toshiba model: KBG40ZNV512G KIOXIA size: 476.94 GiB speed: 31.6 Gb/s lanes: 4
serial: 306PEEC9PBV1 rev: HP00AE00 scheme: GPT
Partition: ID-1: / size: 459.50 GiB used: 135.51 GiB (29.5%) fs: ext4 dev: /dev/nvme0n1p2
Swap: ID-1: swap-1 type: partition size: 8.80 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p3
Sensors: System Temperatures: cpu: 42.5 C mobo: N/A gpu: amdgpu temp: 41.0 C
Info: Processes: 314 Uptime: 3m Memory: 7.21 GiB used: 1.61 GiB (22.3%) Init: systemd v: 246 Compilers: gcc: 10.2.0
Packages: pacman: 1615 Shell: Bash v: 5.0.18 running in: konsole inxi: 3.1.08
