Issues with AMD Vega 11
I have an oldish HP Prodesk G405 (4 cores, 16GB RAM) which has an AMD Radeon RX Vega 11 GPU built-in.
I could install Manjaro KDE without issues, but it seems graphics performance is quite low. Under Wayland it is borderline unusable with CPU load around 80% and using X it’s just not good. Moving windows feels choppy for example. CPU load is at 15-20% however.
The resolution is at 3840x1600 and the amdgpu driver is installed.
How do I improve performance here?
For some reason, after two restarts both, X and Wayland, work just fine… Idle CPU load is around 1%. Very strange. Let’s hope it remains that way.
Possibly gremlins.
PRoper system info would be something like
inxi -Farz
Without any information we can only guess …
( Besides inxi … maybe output from htop, or ps -aux , etc… )
Maybe initial disk indexing?
No, the Wayland process(es) was high up in htop. Anyway, it hasn’t occurred again.
It’s occurring again (didn’t use the machine in the meantime).
If I execute kquitapp6 plasmashell, I stop plasma and CPU usage is back to normal despite kwayland still running. Another kstart5 plasmashell however results in the same high CPU usage again.
Then I tried installing Gnome. High CPU does not occur in either Gnome mode (classic/not classic and X11/Wayland). I then logged out and back into Plasma, and it works… But after a restart I could not reproduce this behavior any more. :disappointed_relieved:
If CPU usage is high in Plasma, in the display settings, I can only select one resolution (the native one of 3840x1600) and it is set to 30Hz. If I manage to get a working session, I can select the resolutions and set the frequency up to 75Hz.
This is very strange. I can’t use the machine with this nondeterministic behavior. I will add the output of inxi -Farz soon.
inxi -Farz while not working:
  Kernel: 6.10.11-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.10-x86_64
    root=UUID=e654727c-f33a-4a49-9133-0fa90609d00a rw quiet splash
    resume=UUID=60d47ef3-f200-4b69-b747-0eecb6ad6880 udev.log_priority=3
  Desktop: KDE Plasma v: 6.1.5 tk: Qt v: N/A info: frameworks v: 6.5.0
  Type: Desktop System: HP product: HP ProDesk 405 G4 Desktop Mini v: SBKPF
    serial: <superuser required> Chassis: type: 3 serial: <superuser required>
  Mobo: HP model: 8626 v: KBC Version 07.D2.00 serial: <superuser required>
    part-nu: 6QS11EA#ABD uuid: <superuser required> UEFI-[Legacy]: HP
    v: R24 Ver. 02.23.00 date: 09/21/2023
  Info: model: AMD Ryzen 5 PRO 2400GE w/ Radeon Vega Graphics bits: 64
    type: MT MCP arch: Zen level: v3 note: check built: 2017-19 process: GF 14nm
    family: 0x17 (23) model-id: 0x11 (17) stepping: 0 microcode: 0x8101016
  Topology: cpus: 1x dies: 1 clusters: 1 cores: 4 threads: 8 tpc: 2
    smt: enabled cache: L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB
    desc: 4x512 KiB L3: 4 MiB desc: 1x4 MiB
  Speed (MHz): avg: 3185 min/max: 1600/3200 boost: enabled scaling:
    driver: acpi-cpufreq governor: schedutil cores: 1: 3185 2: 3185 3: 3185
    4: 3185 5: 3185 6: 3185 7: 3185 8: 3185 bogomips: 51123
  Type: retbleed mitigation: untrained return thunk; SMT vulnerable
  Device-1: Advanced Micro Devices [AMD/ATI] Raven Ridge [Radeon Vega Series
    / Radeon Mobile Series] vendor: Hewlett-Packard driver: N/A
    alternate: amdgpu arch: GCN-5 code: Vega process: GF 14nm built: 2017-20
    pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0a:00.0 chip-ID: 1002:15dd
    class-ID: 0300
  Device-2: Logitech C920 PRO HD Webcam driver: snd-usb-audio,uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-3.4:5
    chip-ID: 046d:08e5 class-ID: 0102 serial: <filter>
  Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.2
    compositor: kwin_wayland driver: X: loaded: modesetting unloaded: radeon
    alternate: fbdev,vesa gpu: N/A display-ID: 0
  Monitor-1: Unknown-1 res: 3072x1280 size: N/A modes: N/A
  API: EGL v: 1.5 platforms: device: 0 drv: swrast surfaceless: drv: swrast
    wayland: drv: swrast x11: drv: swrast inactive: gbm
  API: OpenGL v: 4.5 vendor: mesa v: 24.2.2-arch1.1 glx-v: 1.4
    direct-render: yes renderer: llvmpipe (LLVM 18.1.8 256 bits)
    device-ID: ffffffff:ffffffff memory: 14.23 GiB unified: yes
    display-ID: :1.0
  Device-1: Advanced Micro Devices [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP
    Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel pcie: gen: 3
    speed: 8 GT/s lanes: 16 bus-ID: 0a:00.1 chip-ID: 1002:15de class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] Family 17h/19h HD Audio
    speed: 8 GT/s lanes: 16 bus-ID: 0a:00.6 chip-ID: 1022:15e3 class-ID: 0403
  Device-3: Logitech C920 PRO HD Webcam driver: snd-usb-audio,uvcvideo
  API: ALSA v: k6.10.11-2-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.3 status: active with: 1: pipewire-pulse
    vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: 3300 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) driver: btusb
    v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1
    bus-ID: 2-3.3.3:6 chip-ID: 0a12:0001 class-ID: e001
  Local Storage: total: 476.94 GiB used: 13.65 GiB (2.9%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW512G8H
    lanes: 4 tech: SSD serial: <filter> fw-rev: HPS0 temp: 24.9 C scheme: MBR
  ID-1: / raw-size: 460.91 GiB size: 452.61 GiB (98.20%)
    used: 13.65 GiB (3.0%) fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-1: swap-1 type: partition size: 16.02 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p2 maj-min: 259:2
  System Temperatures: cpu: 73.1 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: pm: pacman pkgs: 1615 libs: 420 tools: gnome-software,pamac
    pm: flatpak pkgs: 0
    1: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    2: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    3: https://linorg.usp.br/manjaro/stable/$repo/$arch
  Memory: total: 16 GiB note: est. available: 14.57 GiB used: 2.86 GiB (19.7%)
  Processes: 273 Power: uptime: 2m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 5.81 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
    tool: systemctl
  Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.2.32 running-in: konsole inxi: 3.3.36
ps -aux while not working:
USER         PID %CPU %MEM    VSZ   RSS TTY      STAT START   TIME COMMAND
root           1  0.4  0.0  21200 12336 ?        Rs   20:42   0:01 /sbin/init splash
root           2  0.0  0.0      0     0 ?        S    20:42   0:00 [kthreadd]
root           3  0.0  0.0      0     0 ?        S    20:42   0:00 [pool_workqueue_release]
root           4  0.0  0.0      0     0 ?        I<   20:42   0:00 [kworker/R-rcu_gp]
root           5  0.0  0.0      0     0 ?        I<   20:42   0:00 [kworker/R-sync_wq]
root           6  0.0  0.0      0     0 ?        I<   20:42   0:00 [kworker/R-slub_flushwq]
root           7  0.0  0.0      0     0 ?        I<   20:42   0:00 [kworker/R-netns]
root           8  0.0  0.0      0     0 ?        I    20:42   0:00 [kworker/0:0-events]
root           9  0.0  0.0      0     0 ?        I    20:42   0:00 [kworker/0:1-events]
root          10  0.0  0.0      0     0 ?        I<   20:42   0:00 [kworker/0:0H-events_highpri]
root          11  0.0  0.0      0     0 ?        I    20:42   0:00 [kworker/u32:0-async]
root          12  0.0  0.0      0     0 ?        I    20:42   0:00 [kworker/u32:1-events_unbound]
root          13  0.0  0.0      0     0 ?        I<   20:42   0:00 [kworker/R-mm_percpu_wq]
root          14  0.0  0.0      0     0 ?        I    20:42   0:00 [rcu_tasks_kthread]
root          15  0.0  0.0      0     0 ?        I    20:42   0:00 [rcu_tasks_rude_kthread]
root          16  0.0  0.0      0     0 ?        I    20:42   0:00 [rcu_tasks_trace_kthread]
root          17  0.0  0.0      0     0 ?        S    20:42   0:00 [ksoftirqd/0]
root          18  0.0  0.0      0     0 ?        I    20:42   0:00 [rcu_preempt]
root          19  0.0  0.0      0     0 ?        S    20:42   0:00 [rcub/0]
root          20  0.0  0.0      0     0 ?        S    20:42   0:00 [rcu_exp_par_gp_kthread_worker/0]
root          21  0.0  0.0      0     0 ?        S    20:42   0:00 [rcu_exp_gp_kthread_worker]
root          22  0.0  0.0      0     0 ?        S    20:42   0:00 [migration/0]
root          23  0.0  0.0      0     0 ?        S    20:42   0:00 [idle_inject/0]
root          24  0.0  0.0      0     0 ?        S    20:42   0:00 [cpuhp/0]
root          25  0.0  0.0      0     0 ?        S    20:42   0:00 [cpuhp/2]
root          26  0.0  0.0      0     0 ?        S    20:42   0:00 [idle_inject/2]
root          27  0.0  0.0      0     0 ?        S    20:42   0:00 [migration/2]
root          28  0.0  0.0      0     0 ?        S    20:42   0:00 [ksoftirqd/2]
root          29  0.0  0.0      0     0 ?        I    20:42   0:00 [kworker/2:0-cgwb_release]
root          30  0.0  0.0      0     0 ?        I<   20:42   0:00 [kworker/2:0H-events_highpri]
root          31  0.0  0.0      0     0 ?        S    20:42   0:00 [cpuhp/4]
root          32  0.0  0.0      0     0 ?        S    20:42   0:00 [idle_inject/4]
root          33  0.0  0.0      0     0 ?        S    20:42   0:00 [migration/4]
root          34  0.0  0.0      0     0 ?        S    20:42   0:00 [ksoftirqd/4]
root          35  0.0  0.0      0     0 ?        I    20:42   0:00 [kworker/4:0-events]
root          36  0.0  0.0      0     0 ?        I<   20:42   0:00 [kworker/4:0H-events_highpri]
root          37  0.0  0.0      0     0 ?        S    20:42   0:00 [cpuhp/6]
root          38  0.0  0.0      0     0 ?        S    20:42   0:00 [idle_inject/6]
root          39  0.0  0.0      0     0 ?        S    20:42   0:00 [migration/6]
root          40  0.0  0.0      0     0 ?        S    20:42   0:00 [ksoftirqd/6]
root          41  0.0  0.0      0     0 ?        I    20:42   0:00 [kworker/6:0-cgroup_destroy]
root          42  0.0  0.0      0     0 ?        I<   20:42   0:00 [kworker/6:0H-events_highpri]
root          43  0.0  0.0      0     0 ?        S    20:42   0:00 [cpuhp/1]
root          44  0.0  0.0      0     0 ?        S    20:42   0:00 [idle_inject/1]
root          45  0.0  0.0      0     0 ?        S    20:42   0:00 [migration/1]
root          46  0.0  0.0      0     0 ?        S    20:42   0:00 [ksoftirqd/1]
root          47  0.0  0.0      0     0 ?        I    20:42   0:00 [kworker/1:0-cgroup_destroy]
root          48  0.0  0.0      0     0 ?        I<   20:42   0:00 [kworker/1:0H-events_highpri]
root          49  0.0  0.0      0     0 ?        S    20:42   0:00 [cpuhp/3]
root          50  0.0  0.0      0     0 ?        S    20:42   0:00 [idle_inject/3]
root          51  0.0  0.0      0     0 ?        S    20:42   0:00 [migration/3]
root          52  0.0  0.0      0     0 ?        S    20:42   0:00 [ksoftirqd/3]
root          53  0.0  0.0      0     0 ?        I    20:42   0:00 [kworker/3:0-events]
root          54  0.0  0.0      0     0 ?        I<   20:42   0:00 [kworker/3:0H-events_highpri]
root          55  0.0  0.0      0     0 ?        S    20:42   0:00 [cpuhp/5]
root          56  0.0  0.0      0     0 ?        S    20:42   0:00 [idle_inject/5]
root          57  0.0  0.0      0     0 ?        S    20:42   0:00 [migration/5]
root          58  0.0  0.0      0     0 ?        S    20:42   0:00 [ksoftirqd/5]
root          59  0.0  0.0      0     0 ?        I    20:42   0:00 [kworker/5:0-events]
root          60  0.0  0.0      0     0 ?        I<   20:42   0:00 [kworker/5:0H-events_highpri]
root          61  0.0  0.0      0     0 ?        S    20:42   0:00 [cpuhp/7]
root          62  0.0  0.0      0     0 ?        S    20:42   0:00 [idle_inject/7]
root          63  0.0  0.0      0     0 ?        S    20:42   0:00 [migration/7]
root          64  0.0  0.0      0     0 ?        S    20:42   0:00 [ksoftirqd/7]
root          65  0.0  0.0      0     0 ?        I    20:42   0:00 [kworker/7:0-events]
root          66  0.0  0.0      0     0 ?        I<   20:42   0:00 [kworker/7:0H-events_highpri]
root          67  0.0  0.0      0     0 ?        S    20:42   0:00 [kdevtmpfs]
root          68  0.0  0.0      0     0 ?        I<   20:42   0:00 [kworker/R-inet_frag_wq]
root          69  0.0  0.0      0     0 ?        S    20:42   0:00 [kauditd]
root          70  0.0  0.0      0     0 ?        S    20:42   0:00 [khungtaskd]
root          71  0.0  0.0      0     0 ?        I    20:42   0:00 [kworker/u32:2-async]
root          72  0.0  0.0      0     0 ?        S    20:42   0:00 [oom_reaper]
root          73  0.0  0.0      0     0 ?        I<   20:42   0:00 [kworker/R-writeback]
root          74  0.0  0.0      0     0 ?        S    20:42   0:00 [kcompactd0]
root          75  0.0  0.0      0     0 ?        SN   20:42   0:00 [ksmd]
root          76  0.0  0.0      0     0 ?        SN   20:42   0:00 [khugepaged]
root          77  0.0  0.0      0     0 ?        I<   20:42   0:00 [kworker/R-kintegrityd]
root          78  0.0  0.0      0     0 ?        I<   20:42   0:00 [kworker/R-kblockd]
root          79  0.0  0.0      0     0 ?        I<   20:42   0:00 [kworker/R-blkcg_punt_bio]
root          80  0.0  0.0      0     0 ?        I    20:42   0:00 [kworker/1:1-mm_percpu_wq]
root          81  0.0  0.0      0     0 ?        S    20:42   0:00 [irq/9-acpi]
root          82  0.0  0.0      0     0 ?        I    20:42   0:00 [kworker/6:1-events]
root          83  0.0  0.0      0     0 ?        I    20:42   0:00 [kworker/2:1-mm_percpu_wq]
root          84  0.0  0.0      0     0 ?        I<   20:42   0:00 [kworker/R-tpm_dev_wq]
root          85  0.0  0.0      0     0 ?        I<   20:42   0:00 [kworker/R-ata_sff]
root          86  0.0  0.0      0     0 ?        I<   20:42   0:00 [kworker/R-edac-poller]
root          87  0.0  0.0      0     0 ?        I<   20:42   0:00 [kworker/R-devfreq_wq]
root          88  0.0  0.0      0     0 ?        S    20:42   0:00 [watchdogd]
root          89  0.0  0.0      0     0 ?        I    20:42   0:00 [kworker/7:1-mm_percpu_wq]
root          90  0.0  0.0      0     0 ?        I<   20:42   0:00 [kworker/6:1H-kblockd]
root          91  0.0  0.0      0     0 ?        I    20:42   0:00 [kworker/4:1-pm]
root          92  0.0  0.0      0     0 ?        S    20:42   0:00 [irq/27-AMD-Vi]
root          93  0.0  0.0      0     0 ?        S    20:42   0:00 [kswapd0]
root          94  0.0  0.0      0     0 ?        I<   20:42   0:00 [kworker/R-kthrotld]
root          95  0.0  0.0      0     0 ?        I    20:42   0:00 [kworker/3:1-events]
root          96  0.0  0.0      0     0 ?        I    20:42   0:00 [kworker/5:1-cgroup_destroy]
root          97  0.0  0.0      0     0 ?        I<   20:42   0:00 [kworker/R-acpi_thermal_pm]
root          98  0.0  0.0      0     0 ?        I    20:42   0:00 [kworker/2:2-events]
root          99  0.0  0.0      0     0 ?        I    20:42   0:00 [kworker/2:3-cgroup_destroy]
root         100  0.0  0.0      0     0 ?        I    20:42   0:00 [kworker/2:4-events]
root         101  0.0  0.0      0     0 ?        I    20:42   0:00 [kworker/2:5]
root         102  0.0  0.0      0     0 ?        S    20:42   0:00 [hwrng]
root         103  0.0  0.0      0     0 ?        S    20:42   0:00 [scsi_eh_0]
root         104  0.0  0.0      0     0 ?        I<   20:42   0:00 [kworker/R-scsi_tmf_0]
root         105  0.0  0.0      0     0 ?        S    20:42   0:00 [scsi_eh_1]
root         106  0.0  0.0      0     0 ?        I<   20:42   0:00 [kworker/R-scsi_tmf_1]
root         107  0.0  0.0      0     0 ?        S    20:42   0:00 [scsi_eh_2]
root         108  0.0  0.0      0     0 ?        I<   20:42   0:00 [kworker/R-scsi_tmf_2]
root         109  0.0  0.0      0     0 ?        S    20:42   0:00 [scsi_eh_3]
root         110  0.0  0.0      0     0 ?        I<   20:42   0:00 [kworker/R-scsi_tmf_3]
root         111  0.0  0.0      0     0 ?        S    20:42   0:00 [scsi_eh_4]
root         112  0.0  0.0      0     0 ?        I<   20:42   0:00 [kworker/R-scsi_tmf_4]
root         113  0.0  0.0      0     0 ?        S    20:42   0:00 [scsi_eh_5]
root         114  0.0  0.0      0     0 ?        I<   20:42   0:00 [kworker/R-scsi_tmf_5]
root         115  0.0  0.0      0     0 ?        S    20:42   0:00 [scsi_eh_6]
root         116  0.0  0.0      0     0 ?        I<   20:42   0:00 [kworker/R-scsi_tmf_6]
root         117  0.0  0.0      0     0 ?        S    20:42   0:00 [scsi_eh_7]
root         118  0.0  0.0      0     0 ?        I<   20:42   0:00 [kworker/R-scsi_tmf_7]
root         119  0.0  0.0      0     0 ?        I    20:42   0:00 [kworker/u32:3-events_unbound]
root         120  0.0  0.0      0     0 ?        I    20:42   0:00 [kworker/u32:4-events_unbound]
root         121  0.0  0.0      0     0 ?        I    20:42   0:00 [kworker/u32:5-async]
root         122  3.5  0.0      0     0 ?        I    20:42   0:10 [kworker/u32:6-events_unbound]
root         123  0.0  0.0      0     0 ?        I    20:42   0:00 [kworker/u32:7-events_power_efficient]
root         124  3.3  0.0      0     0 ?        I    20:42   0:09 [kworker/u32:8-ext4-rsv-conversion]
root         125  0.0  0.0      0     0 ?        S    20:42   0:00 [scsi_eh_8]
root         126  0.0  0.0      0     0 ?        I<   20:42   0:00 [kworker/R-scsi_tmf_8]
root         127  0.0  0.0      0     0 ?        S    20:42   0:00 [scsi_eh_9]
root         128  0.0  0.0      0     0 ?        I<   20:42   0:00 [kworker/R-scsi_tmf_9]
root         129  3.1  0.0      0     0 ?        I    20:42   0:09 [kworker/u32:9-events_power_efficient]
root         130  0.0  0.0      0     0 ?        I    20:42   0:00 [kworker/u32:10-async]
root         131  0.0  0.0      0     0 ?        I    20:42   0:00 [kworker/u32:11-events_power_efficient]
root         132  0.0  0.0      0     0 ?        I    20:42   0:00 [kworker/u32:12-events_unbound]
root         133  0.0  0.0      0     0 ?        I<   20:42   0:00 [kworker/R-mld]
root         134  0.0  0.0      0     0 ?        I<   20:42   0:00 [kworker/2:1H-kblockd]
root         135  0.0  0.0      0     0 ?        I<   20:42   0:00 [kworker/R-ipv6_addrconf]
root         142  0.0  0.0      0     0 ?        I<   20:42   0:00 [kworker/R-kstrp]
root         146  0.0  0.0      0     0 ?        I<   20:42   0:00 [kworker/R-zswap-shrink]
root         147  0.0  0.0      0     0 ?        I<   20:42   0:00 [kworker/u33:0-hci0]
root         178  0.0  0.0      0     0 ?        I<   20:42   0:00 [kworker/4:1H-kblockd]
root         184  0.0  0.0      0     0 ?        I<   20:42   0:00 [kworker/1:1H-kblockd]
root         203  0.0  0.0      0     0 ?        I<   20:42   0:00 [kworker/7:1H-kblockd]
root         204  0.0  0.0      0     0 ?        I<   20:42   0:00 [kworker/0:1H-kblockd]
root         221  0.0  0.0      0     0 ?        I<   20:42   0:00 [kworker/3:1H-kblockd]
root         222  0.0  0.0      0     0 ?        I    20:42   0:00 [kworker/5:2-events]
root         223  0.0  0.0      0     0 ?        I<   20:42   0:00 [kworker/5:1H-kblockd]
root         224  0.0  0.0      0     0 ?        I<   20:42   0:00 [kworker/R-nvme-wq]
root         225  0.0  0.0      0     0 ?        I<   20:42   0:00 [kworker/R-nvme-reset-wq]
root         226  0.0  0.0      0     0 ?        I<   20:42   0:00 [kworker/R-nvme-delete-wq]
root         227  0.0  0.0      0     0 ?        I<   20:42   0:00 [kworker/R-nvme-auth-wq]
root         228  0.0  0.0      0     0 ?        I    20:42   0:00 [kworker/4:2-events]
root         229  0.0  0.0      0     0 ?        I    20:42   0:00 [kworker/4:3-events]
root         230  0.0  0.0      0     0 ?        I    20:42   0:00 [kworker/4:4-events]
root         231  0.0  0.0      0     0 ?        I    20:42   0:00 [kworker/3:2-events]
root         232  0.0  0.0      0     0 ?        I    20:42   0:00 [kworker/1:2-cgroup_destroy]
root         298  0.0  0.0      0     0 ?        S    20:43   0:00 [jbd2/nvme0n1p1-8]
root         299  0.0  0.0      0     0 ?        I<   20:43   0:00 [kworker/R-ext4-rsv-conversion]
root         315  0.0  0.0      0     0 ?        I    20:43   0:00 [kworker/0:2-cgroup_destroy]
root         317  0.0  0.0      0     0 ?        I    20:43   0:00 [kworker/3:3-events]
root         318  0.0  0.0      0     0 ?        I    20:43   0:00 [kworker/3:4-events]
root         319  0.0  0.0      0     0 ?        I    20:43   0:00 [kworker/3:5-events]
root         320  0.0  0.0      0     0 ?        I    20:43   0:00 [kworker/3:6-events]
root         321  0.0  0.0      0     0 ?        I    20:43   0:00 [kworker/3:7-events]
root         322  0.0  0.0      0     0 ?        I    20:43   0:00 [kworker/3:8-mm_percpu_wq]
root         357  0.1  0.1  48808 25444 ?        Ss   20:43   0:00 /usr/lib/systemd/systemd-journald
root         373  0.0  0.0  14288  5832 ?        Ss   20:43   0:00 /usr/lib/systemd/systemd-userdbd
root         379  0.0  0.0      0     0 ?        S    20:43   0:00 [psimon]
root         395  0.0  0.0      0     0 ?        I    20:43   0:00 [kworker/5:3-mm_percpu_wq]
root         401  0.0  0.0      0     0 ?        I    20:43   0:00 [kworker/5:4-events]
root         403  0.0  0.0      0     0 ?        I    20:43   0:00 [kworker/5:5-cgroup_destroy]
root         404  0.0  0.0      0     0 ?        I    20:43   0:00 [kworker/5:6-events]
root         405  0.0  0.0      0     0 ?        I    20:43   0:00 [kworker/0:3]
root         406  0.0  0.0      0     0 ?        I    20:43   0:00 [kworker/0:4-events]
root         409  0.0  0.0  35328 10264 ?        Ss   20:43   0:00 /usr/lib/systemd/systemd-udevd
root         414  0.0  0.0      0     0 ?        S    20:43   0:00 [psimon]
root         456  0.0  0.0      0     0 ?        I<   20:43   0:00 [kworker/R-ipmi-msghandler-remove-wq]
root         460  0.0  0.0      0     0 ?        S    20:43   0:00 [ccp-1-q2]
root         461  0.0  0.0      0     0 ?        S    20:43   0:00 [ccp-1-q3]
root         462  0.0  0.0      0     0 ?        S    20:43   0:00 [ccp-1-q4]
root         466  0.0  0.0      0     0 ?        I<   20:43   0:00 [kworker/R-cryptd]
root         478  0.0  0.0      0     0 ?        I    20:43   0:00 [kworker/6:2-mm_percpu_wq]
root         479  0.0  0.0      0     0 ?        I<   20:43   0:00 [kworker/u33:1-hci0]
root         480  0.0  0.0      0     0 ?        I<   20:43   0:00 [kworker/u33:2]
root         483  0.0  0.0      0     0 ?        I    20:43   0:00 [kworker/1:3-cgroup_destroy]
systemd+     513  0.0  0.0  89056  7348 ?        Ssl  20:43   0:00 /usr/lib/systemd/systemd-timesyncd
dbus         517  0.0  0.0   7460  3720 ?        Ss   20:43   0:00 /usr/bin/dbus-broker-launch --scope system --audit
dbus         518  0.0  0.0   6472  4480 ?        S    20:43   0:00 dbus-broker --log 4 --controller 9 --machine-id 628ef29548844a6198fb4fede17c9470 --max-bytes 536870912 --max-fds 4096 --max-matches 131072 --audit
root         519  0.0  0.1 412712 21788 ?        Ssl  20:43   0:00 /usr/bin/NetworkManager --no-daemon
root         521  0.0  0.0   9700  5236 ?        Ss   20:43   0:00 /usr/lib/bluetooth/bluetoothd
polkitd      522  0.1  0.0 308992 10224 ?        Ssl  20:43   0:00 /usr/lib/polkit-1/polkitd --no-debug --log-level=err
root         523  0.0  0.0  15208  7524 ?        Ss   20:43   0:00 /usr/lib/systemd/systemd-logind
root         532  0.0  0.0      0     0 ?        I    20:43   0:00 [kworker/7:2-cgroup_destroy]
root         576  0.0  0.0 389360 11520 ?        Ssl  20:43   0:00 /usr/bin/ModemManager
root         588  0.0  0.0  24144  9868 ?        Ss   20:43   0:00 /usr/bin/cupsd -l
root         591  0.0  0.0   7108  2972 ?        Ss   20:43   0:00 /usr/sbin/crond -n
root         598  0.0  0.1 153884 22904 ?        Ssl  20:43   0:00 /usr/bin/sddm
root         600  0.6  0.3 1433440 45936 tty2    Ssl+ 20:43   0:01 /usr/lib/Xorg -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_LsgWXY -noreset -displayfd 16
root         625  0.0  0.0      0     0 ?        S    20:43   0:00 [psimon]
root         702  0.0  0.2  77652 30908 ?        S    20:43   0:00 /usr/lib/sddm/sddm-helper --socket /tmp/sddm-auth-0c04d97b-6532-4582-92e2-7dd166052901 --id 1 --start /usr/lib/plasma-dbus-run-session-if-needed /usr/bin/startplasma-wayland --user sebastian
sebasti+     708  0.1  0.0  20140 11424 ?        Ss   20:43   0:00 /usr/lib/systemd/systemd --user
sebasti+     710  0.0  0.0  20452  3448 ?        S    20:43   0:00 (sd-pam)
sebasti+     724  0.0  0.7 1866216 121560 ?      Sl   20:43   0:00 /usr/bin/kwalletd6 --pam-login 12 13
sebasti+     725  0.0  0.2 217460 41240 tty1     Ssl+ 20:43   0:00 /usr/bin/startplasma-wayland
sebasti+     736  0.0  0.0   6936  3332 ?        Ss   20:43   0:00 /usr/bin/dbus-broker-launch --scope user
sebasti+     737  0.0  0.0   5732  3712 ?        S    20:43   0:00 dbus-broker --log 4 --controller 10 --machine-id 628ef29548844a6198fb4fede17c9470 --max-bytes 100000000000000 --max-fds 25000000000000 --max-matches 5000000000
sebasti+     745  0.0  0.1 147592 21480 ?        Ssl  20:43   0:00 /usr/bin/kwin_wayland_wrapper --xwayland
sebasti+     748  0.0  0.2 268672396 31908 ?     SNsl 20:43   0:00 /usr/lib/kf6/baloo_file
sebasti+     750  329  2.9 3152472 446200 ?      Sl   20:43  13:34 /usr/bin/kwin_wayland --wayland-fd 7 --socket wayland-0 --xwayland-fd 8 --xwayland-fd 9 --xwayland-display :1 --xwayland-xauthority /run/user/1000/xauth_ppXnXC --xwayland
root         755  0.0  0.0 467208 12244 ?        Ssl  20:43   0:00 /usr/lib/udisks2/udisksd
sebasti+     763  0.0  0.1 825220 16344 ?        Ssl  20:43   0:00 /usr/lib/xdg-desktop-portal
sebasti+     769  0.0  0.0 530796  7996 ?        Ssl  20:43   0:00 /usr/lib/xdg-document-portal
sebasti+     774  0.0  0.0 305992  7224 ?        Ssl  20:43   0:00 /usr/lib/xdg-permission-store
root         782  0.0  0.0   2560  1788 ?        Ss   20:43   0:00 fusermount3 -o rw,nosuid,nodev,fsname=portal,auto_unmount,subtype=portal -- /run/user/1000/doc
root         783  0.0  0.0 316616 11664 ?        Ssl  20:43   0:00 /usr/lib/upowerd
sebasti+     789  0.0  0.1 523236 28448 ?        Ssl  20:43   0:00 /usr/lib/xdg-desktop-portal-gtk
sebasti+     810  0.0  0.0 102864 14744 ?        S<sl 20:43   0:00 /usr/bin/pipewire
sebasti+     811  0.1  0.2 759504 33440 ?        S<sl 20:43   0:00 /usr/bin/wireplumber
rtkit        833  0.0  0.0  20516  2716 ?        SNsl 20:43   0:00 /usr/lib/rtkit-daemon
sebasti+     854  0.0  0.0 379444  6808 ?        Ssl  20:43   0:00 /usr/lib/at-spi-bus-launcher
sebasti+     856  0.0  0.2 1406836 36584 ?       S    20:43   0:00 /usr/bin/Xwayland :1 -auth /run/user/1000/xauth_ppXnXC -listenfd 172 -listenfd 173 -displayfd 164 -rootless -wm 167 -enable-ei-portal
sebasti+     862  0.0  0.0   6812  2924 ?        S    20:43   0:00 /usr/bin/dbus-broker-launch --config-file=/usr/share/defaults/at-spi2/accessibility.conf --scope user
sebasti+     863  0.0  0.0   4216  2368 ?        S    20:43   0:00 dbus-broker --log 4 --controller 9 --machine-id 628ef29548844a6198fb4fede17c9470 --max-bytes 100000000000000 --max-fds 6400000 --max-matches 5000000000
sebasti+     880  0.0  0.0 232496  6672 ?        Ssl  20:43   0:00 /usr/lib/at-spi2-registryd --use-gnome-session
sebasti+     881  0.0  0.0 322152 11652 ?        Ssl  20:43   0:00 /usr/lib/gvfsd
sebasti+     891  0.0  0.0 456360  8548 ?        Sl   20:43   0:00 /usr/lib/gvfsd-fuse /run/user/1000/gvfs -f
sebasti+     939  0.0  0.4 1761792 73288 ?       Ssl  20:43   0:00 /usr/bin/ksmserver
sebasti+     941  0.1  0.7 3213352 114540 ?      Ssl  20:43   0:00 /usr/bin/kded6
sebasti+    1004  0.0  0.0 103852 13096 ?        S<sl 20:43   0:00 /usr/bin/pipewire-pulse
sebasti+    1006 93.6  4.5 4202532 701912 ?      Ssl  20:43   3:50 /usr/bin/plasmashell --no-respawn
sebasti+    1035  0.0  0.4 2134988 69936 ?       Ssl  20:43   0:00 /usr/lib/kactivitymanagerd
sebasti+    1036  0.0  0.1 224360 27512 ?        Ssl  20:43   0:00 /usr/bin/gmenudbusmenuproxy
sebasti+    1037  0.0  0.5 2083128 81904 ?       Ssl  20:43   0:00 /usr/lib/polkit-kde-authentication-agent-1
sebasti+    1038  0.1  0.5 2080136 80764 ?       Ssl  20:43   0:00 /usr/lib/org_kde_powerdevil
sebasti+    1039  0.1  0.5 1863260 80756 ?       Ssl  20:43   0:00 /usr/lib/xdg-desktop-portal-kde
sebasti+    1040  0.0  0.1 222644 26292 ?        Ssl  20:43   0:00 /usr/bin/xembedsniproxy
sebasti+    1138  0.1  0.2 171684 32484 ?        Ssl  20:43   0:00 /usr/bin/ksystemstats
root        1149  0.0  0.0 307908  8556 ?        Ssl  20:43   0:00 /usr/lib/power-profiles-daemon
root        1165  0.0  0.0      0     0 ?        S<   20:43   0:00 [krfcommd]
sebasti+    1227  0.0  0.0 229188  5372 ?        Ssl  20:43   0:00 /usr/lib/dconf-service
sebasti+    1252  0.0  0.0   7812  4316 ?        S    20:43   0:00 /usr/bin/xsettingsd
sebasti+    1263  0.0  0.2 336392 43016 ?        Ssl  20:43   0:00 /usr/bin/msm_kde_notifier
sebasti+    1268  0.1  0.4 1163528 74872 ?       Ssl  20:43   0:00 /usr/lib/evolution-data-server/evolution-alarm-notify
sebasti+    1275  0.1  0.6 2061428 105680 ?      Ssl  20:43   0:00 /usr/bin/kdeconnectd
sebasti+    1297  0.0  0.0 309952  8536 ?        Ssl  20:43   0:00 /usr/lib/geoclue-2.0/demos/agent
sebasti+    1300  0.0  0.4 1762036 74856 ?       Ssl  20:43   0:00 /usr/bin/kaccess
sebasti+    1304  0.1  0.5 2094416 86060 ?       Ssl  20:43   0:00 /usr/bin/pamac-tray-plasma
sebasti+    1319  0.0  0.1 241032 30032 ?        Sl   20:43   0:00 /usr/lib/kf6/kioworker /usr/lib/qt6/plugins/kf6/kio/desktop.so desktop  local:/run/user/1000/plasmashellBcoZpu.1.kioworker.socket
sebasti+    1433  0.0  0.3 919080 49968 ?        Ssl  20:43   0:00 /usr/lib/evolution-source-registry
sebasti+    1450  0.0  0.1 544076 26008 ?        Ssl  20:43   0:00 /usr/lib/goa-daemon
sebasti+    1459  0.0  0.0 389384 10944 ?        Ssl  20:43   0:00 /usr/lib/goa-identity-service
sebasti+    1466  0.0  0.1 894812 28768 ?        Ssl  20:43   0:00 /usr/lib/evolution-calendar-factory
sebasti+    1476  0.0  0.2 820548 35620 ?        Ssl  20:43   0:00 /usr/lib/evolution-addressbook-factory
sebasti+    1514  2.3  0.8 2521212 134568 ?      Ssl  20:43   0:05 /usr/bin/konsole
sebasti+    1518  8.8  4.3 3786080 657320 ?      Ssl  20:43   0:20 /usr/lib/firefox/firefox
sebasti+    1550  0.5  0.0  13404 10904 pts/1    Ss   20:43   0:01 /bin/zsh
sebasti+    1565  0.0  0.0  10740  4168 pts/1    S    20:43   0:00 /bin/zsh
sebasti+    1586  0.0  0.0  11864  4908 pts/1    S    20:43   0:00 /bin/zsh
sebasti+    1588  0.0  0.0  11848  4756 pts/1    S    20:43   0:00 /bin/zsh
sebasti+    1594  0.0  0.0 138248  4504 pts/1    Sl   20:43   0:00 /usr/share/zsh-theme-powerlevel10k/gitstatus/usrbin/gitstatusd -G v1.5.4 -s -1 -u -1 -d -1 -c -1 -m -1 -v FATAL -t 16
sebasti+    1676  0.0  0.2 248620 33896 ?        Sl   20:44   0:00 /usr/lib/firefox/firefox -contentproc -parentBuildID 20240930133656 -prefsLen 31506 -prefMapSize 255726 -appDir /usr/lib/firefox/browser {f663c991-bac3-489a-9483-c2cdb33f736a} 1518 true 1 socket
sebasti+    1693  0.2  0.9 2512388 139392 ?      Sl   20:44   0:00 /usr/lib/firefox/firefox -contentproc -isForBrowser -prefsLen 31647 -prefMapSize 255726 -jsInitLen 234840 -parentBuildID 20240930133656 -greomni /usr/lib/firefox/omni.ja -appomni /usr/lib/firefox/browser/omni.ja -appDir /usr/lib/firefox/browser {8693f618-f7cb-4bfe-bc41-23a5c32dfeb6} 1518 true 2 tab
sebasti+    1763  1.9  1.9 2874924 292636 ?      Sl   20:44   0:04 /usr/lib/firefox/firefox -contentproc -isForBrowser -prefsLen 37693 -prefMapSize 255726 -jsInitLen 234840 -parentBuildID 20240930133656 -greomni /usr/lib/firefox/omni.ja -appomni /usr/lib/firefox/browser/omni.ja -appDir /usr/lib/firefox/browser {ca7e1429-25f2-4f01-b61a-99a6dfa372cc} 1518 true 3 tab
sebasti+    1782  3.5  1.7 2774260 270328 ?      Sl   20:44   0:08 /usr/lib/firefox/firefox -contentproc -isForBrowser -prefsLen 33614 -prefMapSize 255726 -jsInitLen 234840 -parentBuildID 20240930133656 -greomni /usr/lib/firefox/omni.ja -appomni /usr/lib/firefox/browser/omni.ja -appDir /usr/lib/firefox/browser {22ae3d7d-6acb-4014-a895-45bc2565e702} 1518 true 4 tab
sebasti+    1865  0.1  0.6 1868312 97308 ?       Sl   20:44   0:00 /usr/bin/plasma-browser-integration-host /usr/lib/mozilla/native-messaging-hosts/org.kde.plasma.browser_integration.json plasma-browser-integration@kde.org
sebasti+    1872  0.0  0.2 247540 31980 ?        Sl   20:44   0:00 /usr/lib/firefox/firefox -contentproc -parentBuildID 20240930133656 -sandboxingKind 0 -prefsLen 37800 -prefMapSize 255726 -appDir /usr/lib/firefox/browser {9f7327b3-a57a-4278-b5fb-a641d5748ab7} 1518 true 5 utility
sebasti+    1880  0.0  0.3 2444200 56092 ?       Sl   20:44   0:00 /usr/lib/firefox/firefox -contentproc -isForBrowser -prefsLen 33721 -prefMapSize 255726 -jsInitLen 234840 -parentBuildID 20240930133656 -greomni /usr/lib/firefox/omni.ja -appomni /usr/lib/firefox/browser/omni.ja -appDir /usr/lib/firefox/browser {42c9e4ef-5ea1-4c86-810d-743861646506} 1518 true 6 tab
sebasti+    1884  0.0  0.3 2444200 56816 ?       Sl   20:44   0:00 /usr/lib/firefox/firefox -contentproc -isForBrowser -prefsLen 33721 -prefMapSize 255726 -jsInitLen 234840 -parentBuildID 20240930133656 -greomni /usr/lib/firefox/omni.ja -appomni /usr/lib/firefox/browser/omni.ja -appDir /usr/lib/firefox/browser {0d410556-5d96-4dad-bb7a-e9a99fec086e} 1518 true 7 tab
sebasti+    1923  0.0  0.3 2444200 57504 ?       Sl   20:44   0:00 /usr/lib/firefox/firefox -contentproc -isForBrowser -prefsLen 33825 -prefMapSize 255726 -jsInitLen 234840 -parentBuildID 20240930133656 -greomni /usr/lib/firefox/omni.ja -appomni /usr/lib/firefox/browser/omni.ja -appDir /usr/lib/firefox/browser {99d53873-eef8-40bd-b025-bdf709acc46c} 1518 true 8 tab
root        2527  0.0  0.0  14832  6136 ?        S    20:45   0:00 systemd-userwork: waiting...
root        2529  0.0  0.0  14832  6140 ?        S    20:45   0:00 systemd-userwork: waiting...
root        2533  0.0  0.0  14832  6184 ?        S    20:45   0:00 systemd-userwork: waiting...
sebasti+    2632  0.0  0.1 268530548 29620 ?     S    20:46   0:00 /usr/lib/kf6/kioworker /usr/lib/qt6/plugins/kf6/kio/tags.so tags  local:/run/user/1000/plasmashelluOPPAZ.4.kioworker.socket
root        2704 25.0  0.0  18340  9180 pts/1    S+   20:47   0:00 sudo ps -aux
root        2706  0.0  0.0  18340  2708 pts/2    Ss   20:47   0:00 sudo ps -aux
root        2707  0.0  0.0  10360  6600 pts/2    R+   20:47   0:00 ps -aux
I’m beginning to think that this completely random behavior, and when it worked with Gnome it was just a coicidence.
Here is data I got after some reboots for a working session.
inxi -Farz when working:
    clocksource: hpet avail: acpi_pm
  Desktop: KDE Plasma v: 6.1.5 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
    serial: <filter> Chassis: type: 3 serial: <filter>
  Mobo: HP model: 8626 v: KBC Version 07.D2.00 serial: <filter>
    part-nu: 6QS11EA#ABD uuid: f32d2f13-ce4a-f1db-0f21-64dcbb3ce735
    UEFI-[Legacy]: HP v: R24 Ver. 02.23.00 date: 09/21/2023
  Info: model: AMD Ryzen 5 PRO 2400GE w/ Radeon Vega Graphics socket: AM4
    bits: 64 type: MT MCP arch: Zen level: v3 note: check built: 2017-19
    process: GF 14nm family: 0x17 (23) model-id: 0x11 (17) stepping: 0
  Speed (MHz): avg: 3200 min/max: 1600/3200 boost: enabled
    base/boost: 3200/3800 scaling: driver: acpi-cpufreq governor: schedutil
    volts: 1.4 V ext-clock: 100 MHz cores: 1: 3200 2: 3200 3: 3200 4: 3200
    5: 3200 6: 3200 7: 3200 8: 3200 bogomips: 51121
    / Radeon Mobile Series] vendor: Hewlett-Packard driver: amdgpu v: kernel
    arch: GCN-5 code: Vega process: GF 14nm built: 2017-20 pcie: gen: 3
    speed: 8 GT/s lanes: 16 ports: active: DP-2 empty: DP-1,DP-3,DP-4
    bus-ID: 0a:00.0 chip-ID: 1002:15dd class-ID: 0300 temp: 63.0 C
  Display: unspecified server: X.Org v: 24.1.2 with: Xwayland v: 24.1.2
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :1 screens: 1
  Screen-1: 0 s-res: 3840x1600 s-dpi: 96 s-size: 1016x423mm (40.00x16.65")
    s-diag: 1101mm (43.33") monitors: <missing: xrandr>
  Monitor-1: DP-2 model: Acer CB382CUR serial: <filter> built: 2022
    res: 3840x1600 dpi: 111 gamma: 1.2 size: 880x367mm (34.65x14.45")
    diag: 953mm (37.5") modes: max: 3840x1600 min: 720x400
    device: 1 drv: swrast gbm: drv: radeonsi surfaceless: drv: radeonsi x11:
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.2-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon Vega 11 Graphics
    (radeonsi raven LLVM 18.1.8 DRM 3.57 6.10.11-2-MANJARO)
    device-ID: 1002:15dd memory: 1000 MiB unified: no
  API: Vulkan v: 1.3.295 layers: N/A device: 0 type: integrated-gpu name: AMD
    Radeon Vega 11 Graphics (RADV RAVEN) driver: mesa radv v: 24.2.2-arch1.1
    device-ID: 1002:15dd surfaces: xcb,xlib
  Server-2: PipeWire v: 1.2.3 status: n/a (root, process) with:
    bus-ID: 2-3.3.3:9 chip-ID: 0a12:0001 class-ID: e001
  Local Storage: total: 476.94 GiB used: 13.66 GiB (2.9%)
    lanes: 4 tech: SSD serial: <filter> fw-rev: HPS0 temp: 37.9 C scheme: MBR
    used: 13.66 GiB (3.0%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p1
    maj-min: 259:1
  System Temperatures: cpu: 62.2 C mobo: N/A gpu: amdgpu temp: 62.0 C
    pm: flatpak pkgs: 0
  Memory: total: 16 GiB note: est. available: 14.57 GiB used: 1.55 GiB (10.6%)
  Processes: 279 Power: uptime: 1m states: freeze,mem,disk suspend: deep
    tool: systemctl
  Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Bash (sudo) v: 5.2.32
ps -aux when working:
root           1  2.2  0.0  21352 12492 ?        Ss   20:57   0:01 /sbin/init splash
root           2  0.0  0.0      0     0 ?        S    20:57   0:00 [kthreadd]
root           3  0.0  0.0      0     0 ?        S    20:57   0:00 [pool_workqueue_release]
root           4  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/R-rcu_gp]
root           5  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/R-sync_wq]
root           6  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/R-slub_flushwq]
root           7  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/R-netns]
root           8  0.0  0.0      0     0 ?        I    20:57   0:00 [kworker/0:0-rcu_gp]
root           9  0.0  0.0      0     0 ?        I    20:57   0:00 [kworker/0:1-events]
root          10  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/0:0H-events_highpri]
root          11  0.0  0.0      0     0 ?        I    20:57   0:00 [kworker/u32:0-async]
root          12  0.2  0.0      0     0 ?        I    20:57   0:00 [kworker/u32:1-events_unbound]
root          13  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/R-mm_percpu_wq]
root          14  0.0  0.0      0     0 ?        I    20:57   0:00 [rcu_tasks_kthread]
root          15  0.0  0.0      0     0 ?        I    20:57   0:00 [rcu_tasks_rude_kthread]
root          16  0.0  0.0      0     0 ?        I    20:57   0:00 [rcu_tasks_trace_kthread]
root          17  0.0  0.0      0     0 ?        S    20:57   0:00 [ksoftirqd/0]
root          18  0.0  0.0      0     0 ?        I    20:57   0:00 [rcu_preempt]
root          19  0.0  0.0      0     0 ?        S    20:57   0:00 [rcub/0]
root          20  0.0  0.0      0     0 ?        S    20:57   0:00 [rcu_exp_par_gp_kthread_worker/0]
root          21  0.0  0.0      0     0 ?        S    20:57   0:00 [rcu_exp_gp_kthread_worker]
root          22  0.0  0.0      0     0 ?        S    20:57   0:00 [migration/0]
root          23  0.0  0.0      0     0 ?        S    20:57   0:00 [idle_inject/0]
root          24  0.0  0.0      0     0 ?        S    20:57   0:00 [cpuhp/0]
root          25  0.0  0.0      0     0 ?        S    20:57   0:00 [cpuhp/2]
root          26  0.0  0.0      0     0 ?        S    20:57   0:00 [idle_inject/2]
root          27  0.2  0.0      0     0 ?        S    20:57   0:00 [migration/2]
root          28  0.0  0.0      0     0 ?        S    20:57   0:00 [ksoftirqd/2]
root          29  0.0  0.0      0     0 ?        I    20:57   0:00 [kworker/2:0-events]
root          30  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/2:0H-events_highpri]
root          31  0.0  0.0      0     0 ?        S    20:57   0:00 [cpuhp/4]
root          32  0.0  0.0      0     0 ?        S    20:57   0:00 [idle_inject/4]
root          33  0.2  0.0      0     0 ?        S    20:57   0:00 [migration/4]
root          34  0.0  0.0      0     0 ?        S    20:57   0:00 [ksoftirqd/4]
root          35  0.0  0.0      0     0 ?        I    20:57   0:00 [kworker/4:0-events]
root          36  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/4:0H-events_highpri]
root          37  0.0  0.0      0     0 ?        S    20:57   0:00 [cpuhp/6]
root          38  0.0  0.0      0     0 ?        S    20:57   0:00 [idle_inject/6]
root          39  0.2  0.0      0     0 ?        S    20:57   0:00 [migration/6]
root          40  0.0  0.0      0     0 ?        S    20:57   0:00 [ksoftirqd/6]
root          41  0.0  0.0      0     0 ?        I    20:57   0:00 [kworker/6:0-pm]
root          42  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/6:0H-events_highpri]
root          43  0.0  0.0      0     0 ?        S    20:57   0:00 [cpuhp/1]
root          44  0.0  0.0      0     0 ?        S    20:57   0:00 [idle_inject/1]
root          45  0.2  0.0      0     0 ?        S    20:57   0:00 [migration/1]
root          46  0.0  0.0      0     0 ?        S    20:57   0:00 [ksoftirqd/1]
root          47  0.0  0.0      0     0 ?        I    20:57   0:00 [kworker/1:0-pm]
root          48  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/1:0H-events_highpri]
root          49  0.0  0.0      0     0 ?        S    20:57   0:00 [cpuhp/3]
root          50  0.0  0.0      0     0 ?        S    20:57   0:00 [idle_inject/3]
root          51  0.2  0.0      0     0 ?        S    20:57   0:00 [migration/3]
root          52  0.0  0.0      0     0 ?        S    20:57   0:00 [ksoftirqd/3]
root          53  0.0  0.0      0     0 ?        I    20:57   0:00 [kworker/3:0-cgroup_destroy]
root          54  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/3:0H-events_highpri]
root          55  0.0  0.0      0     0 ?        S    20:57   0:00 [cpuhp/5]
root          56  0.0  0.0      0     0 ?        S    20:57   0:00 [idle_inject/5]
root          57  0.2  0.0      0     0 ?        S    20:57   0:00 [migration/5]
root          58  0.0  0.0      0     0 ?        S    20:57   0:00 [ksoftirqd/5]
root          59  0.0  0.0      0     0 ?        I    20:57   0:00 [kworker/5:0-events]
root          60  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/5:0H-events_highpri]
root          61  0.0  0.0      0     0 ?        S    20:57   0:00 [cpuhp/7]
root          62  0.0  0.0      0     0 ?        S    20:57   0:00 [idle_inject/7]
root          63  0.2  0.0      0     0 ?        S    20:57   0:00 [migration/7]
root          64  0.0  0.0      0     0 ?        S    20:57   0:00 [ksoftirqd/7]
root          65  0.0  0.0      0     0 ?        I    20:57   0:00 [kworker/7:0-events]
root          66  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/7:0H-events_highpri]
root          67  0.0  0.0      0     0 ?        S    20:57   0:00 [kdevtmpfs]
root          68  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/R-inet_frag_wq]
root          69  0.0  0.0      0     0 ?        S    20:57   0:00 [kauditd]
root          70  0.0  0.0      0     0 ?        S    20:57   0:00 [khungtaskd]
root          71  0.0  0.0      0     0 ?        I    20:57   0:00 [kworker/u32:2-events_unbound]
root          72  0.0  0.0      0     0 ?        S    20:57   0:00 [oom_reaper]
root          73  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/R-writeback]
root          74  0.0  0.0      0     0 ?        S    20:57   0:00 [kcompactd0]
root          75  0.0  0.0      0     0 ?        SN   20:57   0:00 [ksmd]
root          76  0.0  0.0      0     0 ?        SN   20:57   0:00 [khugepaged]
root          77  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/R-kintegrityd]
root          78  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/R-kblockd]
root          79  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/R-blkcg_punt_bio]
root          80  0.0  0.0      0     0 ?        I    20:57   0:00 [kworker/1:1-mm_percpu_wq]
root          81  0.0  0.0      0     0 ?        S    20:57   0:00 [irq/9-acpi]
root          82  0.0  0.0      0     0 ?        I    20:57   0:00 [kworker/4:1-events]
root          83  0.0  0.0      0     0 ?        I    20:57   0:00 [kworker/2:1-events]
root          84  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/R-tpm_dev_wq]
root          85  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/R-ata_sff]
root          86  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/R-edac-poller]
root          87  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/R-devfreq_wq]
root          88  0.0  0.0      0     0 ?        S    20:57   0:00 [watchdogd]
root          89  0.0  0.0      0     0 ?        I    20:57   0:00 [kworker/6:1-pm]
root          90  0.0  0.0      0     0 ?        I    20:57   0:00 [kworker/7:1-events]
root          91  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/6:1H-kblockd]
root          92  0.0  0.0      0     0 ?        S    20:57   0:00 [irq/27-AMD-Vi]
root          93  0.0  0.0      0     0 ?        S    20:57   0:00 [kswapd0]
root          94  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/R-kthrotld]
root          95  0.0  0.0      0     0 ?        I    20:57   0:00 [kworker/3:1-events]
root          96  0.0  0.0      0     0 ?        I    20:57   0:00 [kworker/5:1-events]
root          97  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/R-acpi_thermal_pm]
root          98  0.0  0.0      0     0 ?        I    20:57   0:00 [kworker/6:2-events]
root          99  0.0  0.0      0     0 ?        I    20:57   0:00 [kworker/6:3-events]
root         100  0.0  0.0      0     0 ?        I    20:57   0:00 [kworker/6:4-events]
root         101  0.0  0.0      0     0 ?        I    20:57   0:00 [kworker/6:5]
root         102  0.1  0.0      0     0 ?        S    20:57   0:00 [hwrng]
root         103  0.0  0.0      0     0 ?        S    20:57   0:00 [scsi_eh_0]
root         104  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/R-scsi_tmf_0]
root         105  0.0  0.0      0     0 ?        S    20:57   0:00 [scsi_eh_1]
root         106  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/R-scsi_tmf_1]
root         107  0.0  0.0      0     0 ?        S    20:57   0:00 [scsi_eh_2]
root         108  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/R-scsi_tmf_2]
root         109  0.0  0.0      0     0 ?        S    20:57   0:00 [scsi_eh_3]
root         110  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/R-scsi_tmf_3]
root         111  0.0  0.0      0     0 ?        S    20:57   0:00 [scsi_eh_4]
root         112  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/R-scsi_tmf_4]
root         113  0.0  0.0      0     0 ?        S    20:57   0:00 [scsi_eh_5]
root         114  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/R-scsi_tmf_5]
root         115  0.0  0.0      0     0 ?        S    20:57   0:00 [scsi_eh_6]
root         116  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/R-scsi_tmf_6]
root         117  0.0  0.0      0     0 ?        S    20:57   0:00 [scsi_eh_7]
root         118  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/R-scsi_tmf_7]
root         119  0.0  0.0      0     0 ?        I    20:57   0:00 [kworker/u32:3-events_unbound]
root         120  0.0  0.0      0     0 ?        I    20:57   0:00 [kworker/u32:4-async]
root         121  0.0  0.0      0     0 ?        I    20:57   0:00 [kworker/u32:5-async]
root         122  0.1  0.0      0     0 ?        I    20:57   0:00 [kworker/u32:6-events_unbound]
root         123  0.1  0.0      0     0 ?        I    20:57   0:00 [kworker/u32:7-gfx]
root         124  0.0  0.0      0     0 ?        I    20:57   0:00 [kworker/u32:8-writeback]
root         125  0.0  0.0      0     0 ?        S    20:57   0:00 [scsi_eh_8]
root         126  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/R-scsi_tmf_8]
root         127  0.0  0.0      0     0 ?        S    20:57   0:00 [scsi_eh_9]
root         128  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/R-scsi_tmf_9]
root         129  0.2  0.0      0     0 ?        I    20:57   0:00 [kworker/u32:9-events_unbound]
root         130  0.0  0.0      0     0 ?        I    20:57   0:00 [kworker/u32:10-async]
root         131  0.0  0.0      0     0 ?        I    20:57   0:00 [kworker/u32:11-events_power_efficient]
root         132  0.0  0.0      0     0 ?        I    20:57   0:00 [kworker/u32:12-events_unbound]
root         133  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/R-mld]
root         134  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/2:1H-kblockd]
root         135  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/R-ipv6_addrconf]
root         142  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/R-kstrp]
root         146  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/R-zswap-shrink]
root         147  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/u33:0-ttm]
root         184  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/1:1H-kblockd]
root         198  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/3:1H-kblockd]
root         200  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/5:1H-kblockd]
root         201  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/7:1H-kblockd]
root         202  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/0:1H-kblockd]
root         209  0.0  0.0      0     0 ?        I    20:57   0:00 [kworker/4:2-cgroup_destroy]
root         210  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/4:1H-kblockd]
root         215  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/R-nvme-wq]
root         217  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/R-nvme-reset-wq]
root         218  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/R-nvme-delete-wq]
root         219  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/R-nvme-auth-wq]
root         221  0.0  0.0      0     0 ?        I    20:57   0:00 [kworker/5:2]
root         222  0.0  0.0      0     0 ?        I    20:57   0:00 [kworker/0:2-events]
root         223  0.0  0.0      0     0 ?        I    20:57   0:00 [kworker/2:2-events]
root         224  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/R-amdgpu-reset-dev]
root         225  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/R-ttm]
root         226  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/R-amdgpu_dm_hpd_rx_offload_wq]
root         227  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/R-amdgpu_dm_hpd_rx_offload_wq]
root         228  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/R-amdgpu_dm_hpd_rx_offload_wq]
root         229  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/R-amdgpu_dm_hpd_rx_offload_wq]
root         230  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/R-dm_vblank_control_workqueue]
root         231  0.0  0.0      0     0 ?        S    20:57   0:00 [card1-crtc0]
root         232  0.0  0.0      0     0 ?        S    20:57   0:00 [card1-crtc1]
root         233  0.0  0.0      0     0 ?        S    20:57   0:00 [card1-crtc2]
root         234  0.0  0.0      0     0 ?        S    20:57   0:00 [card1-crtc3]
root         258  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/u33:1-ttm]
root         300  0.0  0.0      0     0 ?        S    20:57   0:00 [jbd2/nvme0n1p1-8]
root         301  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/R-ext4-rsv-conversion]
root         352  0.6  0.1  57004 27332 ?        Ss   20:57   0:00 /usr/lib/systemd/systemd-journald
root         370  0.0  0.0      0     0 ?        I    20:57   0:00 [kworker/7:2-events]
root         371  0.0  0.0  14288  5828 ?        Ss   20:57   0:00 /usr/lib/systemd/systemd-userdbd
root         375  0.0  0.0      0     0 ?        S    20:57   0:00 [psimon]
root         400  0.3  0.0  35328 10548 ?        Ss   20:57   0:00 /usr/lib/systemd/systemd-udevd
root         404  0.0  0.0      0     0 ?        S    20:57   0:00 [psimon]
root         456  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/R-ipmi-msghandler-remove-wq]
root         466  0.0  0.0      0     0 ?        S    20:57   0:00 [ccp-1-q2]
root         467  0.0  0.0      0     0 ?        S    20:57   0:00 [ccp-1-q3]
root         468  0.0  0.0      0     0 ?        S    20:57   0:00 [ccp-1-q4]
root         470  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/R-cryptd]
root         480  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/u33:2-ttm]
root         488  0.0  0.0      0     0 ?        I    20:57   0:00 [kworker/1:2-mm_percpu_wq]
root         505  0.0  0.0      0     0 ?        I    20:57   0:00 [kworker/3:2-events]
systemd+     519  0.0  0.0  89056  7348 ?        Ssl  20:57   0:00 /usr/lib/systemd/systemd-timesyncd
dbus         525  0.0  0.0   7460  4000 ?        Ss   20:57   0:00 /usr/bin/dbus-broker-launch --scope system --audit
dbus         526  0.3  0.0   6604  4304 ?        S    20:57   0:00 dbus-broker --log 4 --controller 9 --machine-id 628ef29548844a6198fb4fede17c9470 --max-bytes 536870912 --max-fds 4096 --max-matches 131072 --audit
root         527  0.4  0.1 412692 21972 ?        Ssl  20:57   0:00 /usr/bin/NetworkManager --no-daemon
root         529  0.1  0.0   9700  4848 ?        Ss   20:57   0:00 /usr/lib/bluetooth/bluetoothd
polkitd      530  1.0  0.0 382724 10364 ?        Ssl  20:57   0:00 /usr/lib/polkit-1/polkitd --no-debug --log-level=err
root         531  0.2  0.0  15244  7788 ?        Ss   20:57   0:00 /usr/lib/systemd/systemd-logind
root         582  0.1  0.0 389360 11932 ?        Ssl  20:57   0:00 /usr/bin/ModemManager
root         597  0.0  0.0  24144  9844 ?        Ss   20:57   0:00 /usr/bin/cupsd -l
root         600  0.0  0.0   7108  2900 ?        Ss   20:57   0:00 /usr/sbin/crond -n
cups         603  0.0  0.0  12748  5348 ?        S    20:57   0:00 /usr/lib/cups/notifier/dbus dbus://
root         606  0.0  0.1 153880 21060 ?        Ssl  20:57   0:00 /usr/bin/sddm
root         607  0.0  0.0      0     0 ?        I    20:57   0:00 [kworker/4:3]
root         609  0.6  0.6 1164596 103484 tty2   Ssl+ 20:57   0:00 /usr/lib/Xorg -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_qopGpg -noreset -displayfd 16
root         627  0.0  0.0      0     0 ?        S    20:57   0:00 [psimon]
root         674  0.0  0.0      0     0 ?        I    20:57   0:00 [kworker/1:3]
root         675  0.1  0.1  77652 20852 ?        S    20:57   0:00 /usr/lib/sddm/sddm-helper --socket /tmp/sddm-auth-f91ca645-d292-4c4a-af83-8e9bcc890dbd --id 1 --start /usr/lib/plasma-dbus-run-session-if-needed /usr/bin/startplasma-wayland --user sebastian
sebasti+     681  1.3  0.0  20136 11780 ?        Ss   20:57   0:00 /usr/lib/systemd/systemd --user
root         682  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/u33:3-ttm]
root         683  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/u33:4-ttm]
root         684  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/u33:5-ttm]
root         685  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/u33:6-ttm]
root         686  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/u33:7-ttm]
root         687  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/u33:8-ttm]
root         688  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/u33:9-ttm]
root         689  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/u33:10-ttm]
root         690  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/u33:11-ttm]
root         691  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/u33:12-ttm]
root         692  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/u33:13-ttm]
root         693  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/u33:14-ttm]
root         694  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/u33:15-ttm]
root         695  0.0  0.0      0     0 ?        I<   20:57   0:00 [kworker/u33:16]
sebasti+     697  0.0  0.0  20452  3480 ?        S    20:57   0:00 (sd-pam)
sebasti+     711  0.4  0.6 1436276 93216 ?       Sl   20:57   0:00 /usr/bin/kwalletd6 --pam-login 12 13
sebasti+     712  0.1  0.2 217460 33460 tty1     Ssl+ 20:57   0:00 /usr/bin/startplasma-wayland
sebasti+     724  0.0  0.0   6940  3264 ?        Ss   20:57   0:00 /usr/bin/dbus-broker-launch --scope user
sebasti+     725  0.4  0.0   5600  3220 ?        S    20:57   0:00 dbus-broker --log 4 --controller 10 --machine-id 628ef29548844a6198fb4fede17c9470 --max-bytes 100000000000000 --max-fds 25000000000000 --max-matches 5000000000
sebasti+     733  0.0  0.1 147592 15332 ?        Ssl  20:57   0:00 /usr/bin/kwin_wayland_wrapper --xwayland
sebasti+     736  0.5  0.1 268672532 27572 ?     SNsl 20:57   0:00 /usr/lib/kf6/baloo_file
sebasti+     738  6.2  1.4 2293864 217088 ?      Sl   20:57   0:02 /usr/bin/kwin_wayland --wayland-fd 7 --socket wayland-0 --xwayland-fd 8 --xwayland-fd 9 --xwayland-display :1 --xwayland-xauthority /run/user/1000/xauth_dORkdI --xwayland
root         744  0.2  0.0 467204 12400 ?        Ssl  20:57   0:00 /usr/lib/udisks2/udisksd
sebasti+     747  0.4  0.0 694144 14376 ?        Ssl  20:57   0:00 /usr/lib/xdg-desktop-portal
sebasti+     757  0.0  0.0 530796  6036 ?        Ssl  20:57   0:00 /usr/lib/xdg-document-portal
sebasti+     762  0.0  0.0 305992  5504 ?        Ssl  20:57   0:00 /usr/lib/xdg-permission-store
root         769  0.0  0.0   2560  1792 ?        Ss   20:57   0:00 fusermount3 -o rw,nosuid,nodev,fsname=portal,auto_unmount,subtype=portal -- /run/user/1000/doc
sebasti+     775  0.3  0.1 523240 24028 ?        Ssl  20:57   0:00 /usr/lib/xdg-desktop-portal-gtk
root         776  0.2  0.0 316604  9400 ?        Ssl  20:57   0:00 /usr/lib/upowerd
sebasti+     804  0.2  0.0 101892 11864 ?        S<sl 20:57   0:00 /usr/bin/pipewire
sebasti+     805  0.9  0.1 759504 29412 ?        S<sl 20:57   0:00 /usr/bin/wireplumber
rtkit        818  0.0  0.0  20516  2712 ?        SNsl 20:57   0:00 /usr/lib/rtkit-daemon
sebasti+     838  0.0  0.0 379444  6512 ?        Ssl  20:57   0:00 /usr/lib/at-spi-bus-launcher
sebasti+     840  0.3  0.5 929404 91304 ?        Sl   20:57   0:00 /usr/bin/Xwayland :1 -auth /run/user/1000/xauth_dORkdI -listenfd 185 -listenfd 186 -displayfd 177 -rootless -wm 180 -enable-ei-portal
sebasti+     847  0.0  0.0   6812  3264 ?        S    20:57   0:00 /usr/bin/dbus-broker-launch --config-file=/usr/share/defaults/at-spi2/accessibility.conf --scope user
sebasti+     848  0.0  0.0   4216  2284 ?        S    20:57   0:00 dbus-broker --log 4 --controller 9 --machine-id 628ef29548844a6198fb4fede17c9470 --max-bytes 100000000000000 --max-fds 6400000 --max-matches 5000000000
sebasti+     849  0.0  0.0 232496  6800 ?        Ssl  20:57   0:00 /usr/lib/at-spi2-registryd --use-gnome-session
sebasti+     850  0.0  0.0 322152  9720 ?        Ssl  20:57   0:00 /usr/lib/gvfsd
sebasti+     860  0.0  0.0 456360  6272 ?        Sl   20:57   0:00 /usr/lib/gvfsd-fuse /run/user/1000/gvfs -f
sebasti+     910  0.5  0.6 1157264 95964 ?       Ssl  20:57   0:00 /usr/bin/ksmserver
sebasti+     912  1.1  0.8 2363052 124424 ?      Ssl  20:57   0:00 /usr/bin/kded6
sebasti+     952  0.0  0.0 103628 11224 ?        S<sl 20:57   0:00 /usr/bin/pipewire-pulse
sebasti+     980 14.8  2.7 4427580 412844 ?      Ssl  20:57   0:06 /usr/bin/plasmashell --no-respawn
sebasti+    1009  0.3  0.5 1410252 82052 ?       Ssl  20:57   0:00 /usr/lib/kactivitymanagerd
sebasti+    1010  0.1  0.1 224344 23764 ?        Ssl  20:57   0:00 /usr/bin/gmenudbusmenuproxy
sebasti+    1011  0.4  0.6 1366452 94776 ?       Ssl  20:57   0:00 /usr/lib/polkit-kde-authentication-agent-1
sebasti+    1012  1.6  0.6 1437324 93532 ?       Ssl  20:57   0:00 /usr/lib/org_kde_powerdevil
sebasti+    1013  0.6  0.6 1433312 93424 ?       Ssl  20:57   0:00 /usr/lib/xdg-desktop-portal-kde
sebasti+    1014  0.0  0.1 222632 22360 ?        Ssl  20:57   0:00 /usr/bin/xembedsniproxy
sebasti+    1050  0.5  0.1 171776 28948 ?        Ssl  20:57   0:00 /usr/bin/ksystemstats
root        1108  0.1  0.0 307912  6124 ?        Ssl  20:57   0:00 /usr/lib/power-profiles-daemon
root        1119  0.0  0.0      0     0 ?        S<   20:57   0:00 [krfcommd]
sebasti+    1168  0.0  0.0 229188  5368 ?        Ssl  20:57   0:00 /usr/lib/dconf-service
sebasti+    1182  0.0  0.0   7952  4204 ?        S    20:57   0:00 /usr/bin/xsettingsd
sebasti+    1186  0.0  0.1 241032 23880 ?        Sl   20:57   0:00 /usr/lib/kf6/kioworker /usr/lib/qt6/plugins/kf6/kio/desktop.so desktop  local:/run/user/1000/plasmashellfRhSXA.1.kioworker.socket
sebasti+    1245  0.3  0.2 336416 37220 ?        Ssl  20:57   0:00 /usr/bin/msm_kde_notifier
sebasti+    1252  1.0  0.5 1163104 85404 ?       Ssl  20:57   0:00 /usr/lib/evolution-data-server/evolution-alarm-notify
sebasti+    1257  0.8  0.6 1631388 105952 ?      Ssl  20:57   0:00 /usr/bin/kdeconnectd
sebasti+    1277  0.0  0.0 383684  6548 ?        Ssl  20:57   0:00 /usr/lib/geoclue-2.0/demos/agent
sebasti+    1279  0.5  0.6 1157436 97928 ?       Ssl  20:57   0:00 /usr/bin/kaccess
sebasti+    1289  0.6  0.6 1443280 96420 ?       Ssl  20:57   0:00 /usr/bin/pamac-tray-plasma
sebasti+    1349  0.4  0.3 919080 60344 ?        Ssl  20:57   0:00 /usr/lib/evolution-source-registry
sebasti+    1403  0.1  0.1 544076 22108 ?        Ssl  20:57   0:00 /usr/lib/goa-daemon
sebasti+    1429  0.0  0.0 389384  9652 ?        Ssl  20:57   0:00 /usr/lib/goa-identity-service
sebasti+    1436  0.2  0.1 894812 24972 ?        Ssl  20:57   0:00 /usr/lib/evolution-calendar-factory
sebasti+    1438  0.0  0.1 268530548 23580 ?     S    20:57   0:00 /usr/lib/kf6/kioworker /usr/lib/qt6/plugins/kf6/kio/tags.so tags  local:/run/user/1000/plasmashellchuzpS.2.kioworker.socket
sebasti+    1450  0.1  0.1 820544 26988 ?        Ssl  20:57   0:00 /usr/lib/evolution-addressbook-factory
sebasti+    1561  2.4  1.0 1658172 156024 ?      Ssl  20:58   0:00 /usr/bin/konsole
sebasti+    1598  1.0  0.0  12684 10244 pts/1    Ss   20:58   0:00 /bin/zsh
sebasti+    1610  0.0  0.0  10748  4028 pts/1    S    20:58   0:00 /bin/zsh
sebasti+    1620  0.0  0.0  11880  5124 pts/1    S    20:58   0:00 /bin/zsh
sebasti+    1621  0.0  0.0  11864  4820 pts/1    S    20:58   0:00 /bin/zsh
sebasti+    1623  0.0  0.0 138248  4400 pts/1    Sl   20:58   0:00 /usr/share/zsh-theme-powerlevel10k/gitstatus/usrbin/gitstatusd -G v1.5.4 -s -1 -u -1 -d -1 -c -1 -m -1 -v FATAL -t 16
root        1646  0.0  0.0  18344  9088 pts/1    S+   20:58   0:00 sudo -s
root        1650  0.0  0.0  18344  2552 pts/2    Ss   20:58   0:00 sudo -s
root        1651  0.0  0.0   8280  6460 pts/2    S    20:58   0:00 /bin/bash
root        1834  0.1  0.0  14832  6140 ?        S    20:58   0:00 systemd-userwork: waiting...
root        1836  0.1  0.0  14832  6140 ?        S    20:58   0:00 systemd-userwork: waiting...
root        1841  0.0  0.0  14832  6200 ?        S    20:58   0:00 systemd-userwork: waiting...
root        1876  0.0  0.0  10360  6652 pts/2    R+   20:58   0:00 ps -aux
And additionally the output for journalctl -b
When working:
https://file.io/CGVoj3l4OWJu
When not working:
https://file.io/DeVXSMgrSY3B
When ‘not working’ amdgpu is not loaded.
I dont know why this may be.
Maybe tell us about mhwd;
mhwd -li
And I may suggest setting early kms;
https://wiki.archlinux.org/title/Kernel_mode_setting#Early_KMS_start
mhwd -li when not working
> Installed PCI configs:
           video-linux            2024.05.06                true            PCI
Please sse the arch wiki - for an overview of how to configure your APU
AMDGPU - ArchWiki
Vulkan - ArchWiki
I added amgpu to the MODULES array in mkinitcpio.conf and regenerated the initramfs. No Change.
I looked at those pages, but I don’t see how I’d have to configure the APU. It’s neither Southern Islands nor Sea Islands architecture. The mesa package is installed, and I don’t think I’d need Vulkan support.
What did you have in mind?
I tried reinstalling mesa. Then I switched to testing. No change.
Googling “Vega 11 linux” returns several users having issues, but none are like mine (usually freezes).
After 10 reboots or so I’ve managed to get a working session again. Will stay here now with hibernation etc.
Nothing specifically… Just suggesting some homework.
Since the system memory is shared with system ram it may be a RAM issue.
Especially when you describe it comes and goes.
Boot a live ISO and run memtest+ - to verify if it is memory or not.
I’ll do that. I’d find it more plausible if it was an issue during driver initialization where some kind if timeout is reached most of the time. Or somewhere else.
Just a suggestion but have you updated your system and tried the 6.11 kernel.
I switched to testing and it’s now 6.10.13
Will install linux611 now.
No change in behavior using kernel 6.11.2. memtest+ found no errors.
When I booted GParted live in order to run memtest, I got an interesting message on screen:
amdgpu: Failed to get gpu_info firmware "amdgpu/raven_gpu_info.bin"
amdgpu: Fatal error during GPU init
Might be translatable to Arch based distros.
I think we should now focus on finding specific error messages. journalctl -b is already available a few posts up. Where else could I look? Thanks guys!
