Hi all,
I have just attempted an install of reaper using the terminal:
sudo pamac install reaper
The process, according to the terminal, all completed perfectly. This included 1.2 GB of downloaded dependencies. I assume that’s what they were, because I know that the reaper installer is only about 15 MB!
At the end, I got the message:
installation completed successfully.
But whenever I try to run the app, the taskbar icon appears for 1 second and then disappears.
If anyone has any suggestions as to why this is happening and how to fix it, I’d be most appreciative!
Cheers.
KDE Plasma Version: 5.27.5
KDE Frameworks Version: 5.106.0
Qt Version: 5.15.9
Kernel Version: 6.1.29-1-MANJARO (64-bit)
Graphics Platform: X11
Processors: 8 × Intel® Core™ i7-8565U CPU @ 1.80GHz
Memory: 7.5 GiB of RAM
Graphics Processor: Mesa Intel® UHD Graphics 620
Manufacturer: Dell Inc.
Product Name: Inspiron 7580
