For over an hour, I have been trying to update my system, and dependencies keep blocking it.
sudo pacman -Syu ✔
[sudo] password for [censored]:
core is up to date
extra is up to date
multilib is up to date
:: Replace sdl2 with extra/sdl2-compat? [Y/n] y
resolving dependencies...
:: installing icu (76.1-1) breaks dependency 'libicui18n.so=75-64' required by electron30
:: installing icu (76.1-1) breaks dependency 'libicuuc.so=75-64' required by electron30
:: installing flac (1.5.0-1) breaks dependency 'libFLAC.so=12-64' required by electron30
:: installing libxml2 (2.14.3-1) breaks dependency 'libxml2.so=2-64' required by electron30
:: installing icu (76.1-1) breaks dependency 'libicui18n.so=75-64' required by electron32
:: installing icu (76.1-1) breaks dependency 'libicuuc.so=75-64' required by electron32
:: installing flac (1.5.0-1) breaks dependency 'libFLAC.so=12-64' required by electron32
:: installing libxml2 (2.14.3-1) breaks dependency 'libxml2.so=2-64' required by electron32
Following this, I started searching online and followed a recommendation to delete electron30, as I could always reinstall it later. electron32 was an issue, though.
sudo pacman -R electron32
checking dependencies...
:: removing electron32 breaks dependency 'electron32' required by code
I then tried to update icu and again failed.
sudo pacman -S icu
:: installing icu (76.1-1) breaks dependency 'libicuuc.so=75-64' required by harfbuzz-icu
:: installing icu (76.1-1) breaks dependency 'libicuuc.so=75-64' required by raptor
After more searching online, several different resolved questions on forums pointed to the mirror list being the issue. After looking up what the mirror list was, I thought it didn’t sound right, but I tried optimizing them anyway, as I noticed that despite living in the US, it was trying to use the Netherlands. This got the same dependency issues. Finally, I thought, if electron has already passed version 32, then maybe I can bypass these issues by installing a later version.
sudo pacman -S electron 1 ✘
[sudo] password for [censered]:
:: installing libxml2 (2.14.3-1) breaks dependency 'libxml2.so=2-64' required by libarchive
:: installing flac (1.5.0-1) breaks dependency 'libFLAC.so=12-64' required by libsndfile
:: installing libxml2 (2.14.3-1) breaks dependency 'libxml2.so=2-64' required by openconnect
:: installing libxml2 (2.14.3-1) breaks dependency 'libxml2.so=2-64' required by sane
Does anyone have any ideas what I should try next? This is my first help forum post… ever, so I hope I did it right.
