Issues installing
Just want to start off saying that this is my first experience with Linux and I am not very savvy with it. That said I’ve been trying to install Manjaro with the Plasma DE for a while now and keep running into the same issues. I’m pretty sure it’s a corrupt image causing the error but I thought I’d post here incase I’m being stupid.
I’ve disabled secure boot and am in UEFI mode in the bios. I’ve booted from the USB, liked the OS and tried the installer which came up with the unpackfs error.
I’ve tried following a tutorial for manual partitioning and that didn’t help. I’ve tried to install a dozen times with the same errors:
Command 'unsquashfs' returned non-zero exit status 1.
None
Traceback:
File "/usr/lib/calamares/modules/unpackfs/main.py", line 498, in run
    return unpackop.run()
File "/usr/lib/calamares/modules/unpackfs/main.py", line 317, in run
entry.do_count() # Fill in the entry.total
File "/usr/lib/calamares/modules/unpackfs/main.py", line 89, in do_count
libcalamares.utils.host_env_process_output(["unsquashfs", "-l", self.source], cb_count)
File "<string>", line 3, in <module>
System info:
Motherboard - MSI z97 g45 gaming
CPU - Intel 4790k
GPU GTX 980 Nvidia
check this:
Disable Secure Boot;
Enable AHCI - its under SATA/RAID options;
Disable Optane Memory and Rapid Storage Technology (RST) - you may not have these options;
Disable Fast Boot - you may not have this option;
Disable fast startup from windows;
use ventoy to flash the iso;
redownload the iso again from Manjaro Downloads
provide also system info:
inxi -Faz
use formatting, click this icon in editor: </>
Thanks. The fresh ISO install did it.
