helllo dear Experts,
suddenly i r un into issues - the system (Manjaro 18xy ) does not boot any more .
see more infos for fully insights
You really should update your system more regularly.
https://forum.manjaro.org/search?q=libidn2.so
You can resolve this by running:
sudo pacman-mirrors -f3
sudo pacman -Syyuu
You may need to use a chroot to let you run those on the installed system.
