Is There A Way To Upgrade to v21 from v20 Without Having to do a New Install?
Hello all, my first post. I’ve read that I should provide information, so lets get that done…
  Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  parameters: ro root=UUID=6578270b-76cf-44dc-9467-3e77810cebc1
  rootflags=subvol=/@ initrd=@\boot\initramfs-5.9-x86_64.img
  Desktop: Cinnamon 4.8.6 tk: GTK 3.24.27 wm: Muffin dm: LightDM 1.30.0
  Type: Desktop Mobo: ASUSTeK model: SABERTOOTH 990FX v: Rev 1.xx
  serial: <filter> UEFI: American Megatrends v: 1604 date: 10/16/2012
  RAM: total: 15.58 GiB used: 3.59 GiB (23.1%)
  Array-1: capacity: 32 GiB slots: 4 EC: Multi-bit ECC max-module-size: 8 GiB
  note: est.
  Device-1: DIMM0 size: 4 GiB speed: spec: 1333 MT/s actual: 667 MT/s
  type: DDR3 detail: synchronous bus-width: 64 bits total: 64 bits
  manufacturer: N/A part-no: Array1_ serial: N/A
  Device-2: DIMM1 size: 4 GiB speed: spec: 1333 MT/s actual: 667 MT/s
  Device-3: DIMM2 size: 4 GiB speed: spec: 1333 MT/s actual: 667 MT/s
  Device-4: DIMM3 size: 4 GiB speed: spec: 1333 MT/s actual: 667 MT/s
  Info: 8-Core model: AMD FX-8320 socket: AM3 (942) note: check bits: 64
  type: MCP arch: Bulldozer family: 15 (21) model-id: 2 stepping: N/A
  microcode: 6000852 cache: L1: 384 KiB L2: 2 MiB L3: 8 MiB bogomips: 56211
  Speed: 3833 MHz min/max: N/A base/boost: 3500/3500 volts: 1.4 V
  ext-clock: 200 MHz Core speeds (MHz): 1: 3833 2: 3467 3: 3644 4: 3579
  5: 3839 6: 3736 7: 3401 8: 3396
  Flags: 3dnowprefetch abm aes aperfmperf apic arat avx bmi1 clflush cmov
  cmp_legacy constant_tsc cpb cpuid cr8_legacy cx16 cx8 de decodeassists
  extapic extd_apicid f16c flushbyasid fma fma4 fpu fxsr fxsr_opt ht hw_pstate
  ibs lahf_lm lbrv lm lwp mca mce misalignsse mmx mmxext monitor msr mtrr
  nodeid_msr nonstop_tsc nopl npt nrip_save nx osvw pae pat pausefilter
  pclmulqdq pdpe1gb perfctr_core perfctr_nb pfthreshold pge pni popcnt pse
  pse36 rdtscp rep_good sep skinit ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 svm
  svm_lock syscall tbm tce topoext tsc tsc_scale vmcb_clean vme vmmcall wdt
  xop xsave
  Type: spectre_v2
  mitigation: Full AMD retpoline, STIBP: disabled, RSB filling
  Device-1: NVIDIA GM204 [GeForce GTX 970] driver: nvidia v: 460.56
  alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:13c2
  class-ID: 0300
  Display: server: X.Org 1.20.10 driver: loaded: nvidia display-ID: :0
  screens: 1
  Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x286mm (40.0x11.3")
  s-diag: 1055mm (41.6")
  Monitor-1: DVI-I-1 res: 1920x1080 hz: 60 dpi: 92
  size: 531x299mm (20.9x11.8") diag: 609mm (24")
  Monitor-2: DP-5 res: 1920x1080 hz: 60 dpi: 92 size: 531x299mm (20.9x11.8")
  diag: 609mm (24")
  OpenGL: renderer: GeForce GTX 970/PCIe/SSE2 v: 4.6.0 NVIDIA 460.56
  direct render: Yes
  Device-1: AMD SBx00 Azalia vendor: ASUSTeK driver: snd_hda_intel v: kernel
  bus-ID: 00:14.2 chip-ID: 1002:4383 class-ID: 0403
  Device-2: NVIDIA GM204 High Definition Audio driver: snd_hda_intel v: kernel
  bus-ID: 01:00.1 chip-ID: 10de:0fbb class-ID: 0403
  Sound Server-1: ALSA v: k5.9.16-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.23 running: no
  vendor: ASUSTeK P8P67 and other motherboards driver: r8169 v: kernel
  port: a000 bus-ID: 08:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp8s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-1: Broadcom BCM20702A0 Bluetooth 4.0 type: USB driver: btusb v: 0.8
  bus-ID: 9-5:3 chip-ID: 0a5c:21e8 class-ID: fe01 serial: <filter>
  Message: No LVM data was found.
  Local Storage: total: 5.69 TiB used: 1.74 TiB (30.6%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 250GB
  size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
  rotation: SSD serial: <filter> rev: 2B6Q scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000NM0033-9ZM173
  rotation: 7200 rpm serial: <filter> rev: 0001 scheme: MBR
  ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital model: WD10EZEX-00RKKA0
  rotation: 7200 rpm serial: <filter> rev: 0A80 scheme: MBR
  ID-4: /dev/sdd maj-min: 8:48 vendor: Hitachi model: HDS723020BLA642
  size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
  rotation: 7200 rpm serial: <filter> rev: A800 scheme: MBR
  ID-5: /dev/sde maj-min: 8:64 vendor: Western Digital model: WD10EZEX-00BN5A0
  rotation: 7200 rpm serial: <filter> rev: 1A01 scheme: GPT
  ID-6: /dev/sdf maj-min: 8:80 vendor: Seagate model: ST1000NM0033-9ZM173
  rotation: 7200 rpm serial: <filter> rev: SN03 scheme: GPT
  ID-1: / raw-size: 170.37 GiB size: 170.37 GiB (100.00%)
  used: 22.88 GiB (13.4%) fs: btrfs block-size: 4096 B dev: /dev/sda5
  maj-min: 8:5 label: N/A uuid: 6578270b-76cf-44dc-9467-3e77810cebc1
  ID-2: /boot/efi raw-size: 647 MiB size: 645.7 MiB (99.80%)
  used: 48.4 MiB (7.5%) fs: vfat block-size: 512 B dev: /dev/sda2 maj-min: 8:2
  label: N/A uuid: 86BD-A8C2
  ID-3: /home raw-size: 170.37 GiB size: 170.37 GiB (100.00%)
  ID-4: /mnt/Data raw-size: 369.99 GiB size: 363.18 GiB (98.16%)
  used: 261.39 GiB (72.0%) fs: ext4 block-size: 4096 B dev: /dev/sde7
  maj-min: 8:71 label: Data uuid: dc2fdf6d-4a89-4498-9462-59303f0bb79b
  ID-5: /mnt/Drive L raw-size: 294.92 GiB size: 294.92 GiB (100.00%)
  used: 195.66 GiB (66.3%) fs: ntfs block-size: 4096 B dev: /dev/sdc2
  maj-min: 8:34 label: Drive L uuid: E87E146C7E143632
  ID-6: /mnt/Drive-F raw-size: 370.85 GiB size: 370.85 GiB (100.00%)
  used: 175.75 GiB (47.4%) fs: ntfs block-size: 4096 B dev: /dev/sdf1
  maj-min: 8:81 label: Drive-F uuid: 01CFDB41B995E780
  ID-7: /mnt/Drive-Q raw-size: 468.01 GiB size: 468.01 GiB (100.00%)
  used: 371.28 GiB (79.3%) fs: ntfs block-size: 4096 B dev: /dev/sdd5
  maj-min: 8:53 label: Drive-Q uuid: 3258287658283B4D
  ID-8: /mnt/Drive-T In Dock raw-size: 469.6 GiB size: 469.6 GiB (100.00%)
  used: 353.48 GiB (75.3%) fs: ntfs block-size: 4096 B dev: /dev/sdb1
  maj-min: 8:17 label: Drive-T In Dock uuid: 62CEDCFECEDCCC03
  ID-9: /mnt/Drive-X raw-size: 97.66 GiB size: 97.66 GiB (100.00%)
  used: 26.95 GiB (27.6%) fs: ntfs block-size: 4096 B dev: /dev/sde4
  maj-min: 8:68 label: Drive-X uuid: 01D713BEB90BC7F0
  ID-10: /mnt/LM01 raw-size: 68.36 GiB size: 64.05 GiB (93.70%)
  used: 56.96 GiB (88.9%) fs: ext4 block-size: 4096 B dev: /dev/sde2
  maj-min: 8:66 label: LM01 uuid: fa9c9b02-a8b8-d401-b084-9b02a8b8d401
  ID-11: /mnt/Steam-Games raw-size: 48.83 GiB size: 47.81 GiB (97.92%)
  used: 16.2 GiB (33.9%) fs: ext4 block-size: 4096 B dev: /dev/sde6
  maj-min: 8:70 label: Steam-Games uuid: f981f428-f1c3-4947-8dc1-53ebf6049be8
  ID-12: /mnt/UbuntuMate raw-size: 461.92 GiB size: 453.66 GiB (98.21%)
  used: 299.65 GiB (66.1%) fs: ext4 block-size: 4096 B dev: /dev/sdb2
  maj-min: 8:18 label: UbuntuMate uuid: 8501b3c7-4655-4d65-9d7c-148156391811
  ID-13: /run/timeshift/backup raw-size: 170.37 GiB size: 170.37 GiB (100.00%)
  ID-1: swap-1 type: partition size: 3.43 GiB used: 0 KiB (0.0%) priority: -2
  dev: /dev/sda7 maj-min: 8:7 label: N/A
  uuid: b5289006-83c9-4fa5-818d-a789242ac1c8
  ID-1: /dev/sda1 maj-min: 8:1 size: 450 MiB fs: ntfs label: Recovery
  uuid: 8076D09476D08C72
  ID-2: /dev/sda3 maj-min: 8:3 size: 16 MiB fs: N/A label: N/A uuid: N/A
  ID-3: /dev/sda4 maj-min: 8:4 size: 58 GiB fs: ntfs label: System Drive
  uuid: 01D4BA0C4E9E2D30
  ID-4: /dev/sdc1 maj-min: 8:33 size: 294.92 GiB fs: ntfs label: Drive-K
  uuid: D870FBAA70FB8D8E
  ID-5: /dev/sdc3 maj-min: 8:35 size: 341.67 GiB fs: ntfs label: Drive M
  uuid: AC4224464224179A
  ID-6: /dev/sdd1 maj-min: 8:49 size: 465 GiB fs: ntfs label: Drive-N
  uuid: EC54624A5462179A
  ID-7: /dev/sdd2 maj-min: 8:50 size: 465 GiB fs: ntfs label: Drive-O
  uuid: 0848BE6A48BE5662
  ID-8: /dev/sdd3 maj-min: 8:51 size: 465 GiB fs: ntfs label: Drive-P
  uuid: 01CF8FC705774480
  ID-9: /dev/sdd4 maj-min: 8:52 size: 1 KiB fs: N/A label: N/A uuid: N/A
  ID-10: /dev/sde1 maj-min: 8:65 size: 283.18 GiB fs: ntfs label: Drive I
  uuid: 01D4A67F9B04AFA0
  ID-11: /dev/sde3 maj-min: 8:67 size: 62.12 GiB fs: ext4 label: Free
  uuid: 0c45d0eb-010d-4bac-8d77-f5b22a03c905
  ID-12: /dev/sde5 maj-min: 8:69 size: 1.38 GiB fs: swap label: N/A
  uuid: 0f58bfd2-801d-473d-80fb-479150d3cf4b
  ID-13: /dev/sdf2 maj-min: 8:82 size: 327.79 GiB fs: ntfs label: Drive-D
  uuid: 309AD13A9AD0FD72
  ID-14: /dev/sdf3 maj-min: 8:83 size: 232.88 GiB fs: ntfs label: Drive-G
  uuid: F22AA7552AA7161F
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  Device-1: 1-1:2 info: STMicro Fingerprint Reader type: <vendor specific>
  driver: N/A interfaces: 1 rev: 1.0 speed: 12 Mb/s power: 100mA
  chip-ID: 0483:2016 class-ID: 0000
  Device-2: 1-2:3 info: Microsoft Wireless Desktop Receiver 3.1
  type: Keyboard,HID driver: microsoft,usbhid interfaces: 2 rev: 2.0
  speed: 1.5 Mb/s power: 100mA chip-ID: 045e:00f9 class-ID: 0300
  Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 speed: 5 Gb/s
  Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 5 rev: 2.0
  Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  Hub-5: 5-0:1 info: Full speed (or root) Hub ports: 5 rev: 2.0
  Hub-6: 6-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 speed: 5 Gb/s
  Hub-7: 7-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
  Hub-8: 8-0:1 info: Full speed (or root) Hub ports: 5 rev: 1.1 speed: 12 Mb/s
  chip-ID: 1d6b:0001 class-ID: 0900
  Hub-9: 9-0:1 info: Full speed (or root) Hub ports: 5 rev: 1.1 speed: 12 Mb/s
  Device-1: 9-4:4 info: Kensington Expert Mouse Trackball type: Mouse
  driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
  power: 100mA chip-ID: 047d:1020 class-ID: 0301
  Device-2: 9-5:3 info: Broadcom BCM20702A0 Bluetooth 4.0 type: Bluetooth
  driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s chip-ID: 0a5c:21e8
  Hub-10: 10-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1
  speed: 12 Mb/s chip-ID: 1d6b:0001 class-ID: 0900
  Hub-11: 11-0:1 info: Full speed (or root) Hub ports: 4 rev: 1.1
  System Temperatures: cpu: 23.2 C mobo: N/A gpu: nvidia temp: 44 C
  Fan Speeds (RPM): N/A gpu: nvidia fan: 27%
  Processes: 302 Uptime: 3h 51m wakeups: 14 Init: systemd v: 247
  tool: systemctl Compilers: gcc: 10.2.0 Packages: pacman: 1232 lib: 313
  flatpak: 0 Shell: Bash (sudo) v: 5.1.0 running-in: gnome-terminal
  inxi: 3.3.03
Right then, on to my question. I’ve just installed Manjaro Cinnamon 20.2-201208 yesterday to a BTRFS ssd, and got it all set up. Now I see that 21-210320 is was just made available today, and I’d very much like to upgrade.
Is there a way to do that from my existing setup in 20.2, without having to do a wipe and a new installation again in order to run 21-210320 ? I have searched the forum, but did not really find anything that would apply.
Edited Update: BTW, I did try doing a sudo pacman -Syyuu but that did not result in pulling in any upgraded system files.
TIA !
You don’t need reinstalling Manjaro, just update – you’ll always have fresh system. v21 is only ISO refreshing, it isn’t same as new release of Debian, Ubuntu or other point release distro. Anyway if you want to know current codename and release you can use lsb_release -a.
Just run ‘sudo pacman -Syyu’ from terminal & u will b upgraded to the latest version, v21 in this case.
If there is no update available then u r probably on the latest version.
Well, well, I learn something new every day, and that’s a good thing! Thanks, and the result of that command is:
|LSB Version:|n/a|
|Distributor ID:|ManjaroLinux|
|Description:|Manjaro Linux|
|Release:|21.0|
|Codename:|Ornara|
I don’t know how, or when that happened, but the only thing I can think of is when I grabbed all the updates yesterday right after the fresh install.
Excellent, I’m loving this Distro much more than Arch proper, which I ran for the last 3 years.
I appreciate you taking the time to educate me on this, Thanks!!
Manjaro 21 iso is out now…you could have used that to avoid massive updates.
Yes, as I added at the end of my OP, I did the -Syyuu command, but got nothing, so it had to have happened yesterday right after the install, when I grabbed all the update packages.
Nice to know that Manjaro is a true rolling distro!!! :slight_smile:
The Cinnamon flavor of 21 was not available yesterday at 1AM, so I used the latest stable version that was there. IMHBCO, the cinnamon flavor was just made available within the last few hours, right??
AFAIK, the updates were already available since last week. The latest packages were packaged into the iso very recently.
Community isos are made available a little while after official flavours are released
What I meant was that I could not find an install iso for v21 in the cinnamon flavor yesterday. It was only in the available downloads just a while ago, because I’ve been checking since I learned of the v21 release.
In any event, I’m on 21 now, and happy about it!
Thanks to all for the input!
