Hi,
I’m using a 2560x1080 monitor and I’m only able to use this resolution if I let the computer turn on before turning on the monitor. If the monitor is on while the pc boots, it sets the resolution at 1080p and the native resolution is not listed in the settings.
It’s a minor inconvenience to have to be careful about how I boot the computer, but I still would like to fix this.
Is there some way I could try to manually redetect the available resolutions without rebooting? or some other way I could try to fix this?
This used to work fine when I had an actual GPU in this computer. But recently, this gpu died and I’ve been using the integrated graphics from my intel cpu instead.
I’ll add here the two different outputs of xrandr: booting with the monitor on (and getting at most 1920x1080), and then booting with the monitor off (and getting 2560x1080).
This is xrandr after booting with the monitor on:
[bruno@Listuq ~]$ xrandr
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 32767 x 32767
DP1 disconnected (normal left inverted right x axis y axis)
DP2 disconnected (normal left inverted right x axis y axis)
HDMI1 disconnected (normal left inverted right x axis y axis)
HDMI2 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 580mm x 240mm
1920x1080 60.00 50.00 59.94* 30.00 29.97
1920x1080i 60.00 50.00 59.94
1680x1050 59.88
1600x900 60.00
1280x1024 75.02 60.02
1152x864 75.00
1280x720 60.00 50.00 59.94
1024x768 75.03 60.00
800x600 75.00 60.32
720x576 50.00
720x480 60.00 59.94
640x480 75.00 60.00 59.94
720x400 70.08
VGA1 disconnected (normal left inverted right x axis y axis)
VIRTUAL1 disconnected (normal left inverted right x axis y axis)
And this is xrandr after booting with the monitor off:
Screen 0: minimum 8 x 8, current 2560 x 1080, maximum 32767 x 32767
HDMI2 connected primary 2560x1080+0+0 (normal left inverted right x axis y axis) 580mm x 240mm
2560x1080 60.00*+
1920x1080 60.00 50.00 59.94 30.00 29.97
1680x1050 59.88
1600x900 60.00
1152x864 75.00
800x600 75.00 60.32
720x576 50.00
720x480 60.00 59.94
720x400 70.08
I’ve tried reconnecting the HDMI cable in with the monitor on/off, but it didn’ t change which resolutions were listed in the settings.
And here’s some information about the system:
[bruno@Listuq ~]$ inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.12.9-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.12-x86_64
root=UUID=04dc1621-8580-4deb-a48a-d3a224a2ce22 rw radeon.si_support=1
amdgpu.si_support=0 quiet udev.log_priority=3
Desktop: KDE Plasma 5.21.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: Gigabyte product: N/A v: N/A serial: <filter> Chassis:
type: 3 serial: <filter>
Mobo: Gigabyte model: H77-D3H v: x.x serial: <filter>
UEFI: American Megatrends v: F11 date: 08/21/2012
RAM: total: 19.44 GiB used: 2.71 GiB (14.0%)
Info: Quad Core model: Intel Core i7-3770K bits: 64 type: MT MCP
arch: Ivy Bridge family: 6 model-id: 3A (58) stepping: 9 microcode: 21
cache: L2: 8 MiB bogomips: 55888
Speed: 1597 MHz min/max: 1600/3900 MHz Core speeds (MHz): 1: 1597 2: 1596
3: 1597 4: 1597 5: 1597 6: 1597 7: 1597 8: 1597
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept
erms est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs ida
lahf_lm lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae pat
pbe pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts rdrand
rdtscp rep_good sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall
tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid xsave xsaveopt
xtopology xtpr
Type: l1tf
Type: srbds status: Vulnerable: No microcode
Device-1: Intel Xeon E3-1200 v2/3rd Gen Core processor Graphics
vendor: Gigabyte driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:0162
class-ID: 0300
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
loaded: intel unloaded: modesetting alternate: fbdev,vesa display-ID: :0
screens: 1
Screen-1: 0 s-res: 2560x1080 s-dpi: 120 s-size: 540x228mm (21.3x9.0")
s-diag: 586mm (23.1")
Monitor-1: HDMI2 res: 2560x1080 hz: 60 dpi: 112 size: 580x240mm (22.8x9.4")
diag: 628mm (24.7")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2)
v: 4.2 Mesa 21.1.2 compat-v: 3.0 direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20
class-ID: 0403
Sound Server-1: ALSA v: k5.12.9-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.30 running: yes
Device-1: Qualcomm Atheros AR9485 Wireless Network Adapter driver: ath9k
v: kernel port: f040 bus-ID: 02:00.0 chip-ID: 168c:0032 class-ID: 0280
IF: wlp2s0 state: down mac: <filter>
Device-2: Qualcomm Atheros AR8161 Gigabit Ethernet vendor: Gigabyte
driver: alx v: kernel port: e000 bus-ID: 05:00.0 chip-ID: 1969:1091
class-ID: 0200
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Permissions: Unable to run lvs. Root privileges required.
Local Storage: total: 987.41 GiB used: 573.39 GiB (58.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SV300S37A60G
size: 55.9 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
rotation: SSD serial: <filter> rev: BBF0 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD10EZEX-21WN4A0
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
rotation: 7200 rpm serial: <filter> rev: 1A01 scheme: GPT
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GH24NS95 rev: RN00
dev-links: cdrom
Features: speed: 12 multisession: yes audio: yes dvd: yes
ID-1: / raw-size: 55.4 GiB size: 54.28 GiB (97.98%) used: 38.11 GiB (70.2%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 04dc1621-8580-4deb-a48a-d3a224a2ce22
used: 280 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 61F1-286F
ID-3: /home raw-size: 931.51 GiB size: 915.89 GiB (98.32%)
used: 535.29 GiB (58.4%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: Bolota
uuid: 50d87f83-f49e-4c86-981a-e905c01f6566
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
Device-1: 1-1.5:3 info: Holtek Mechanical Keyboard type: Keyboard,HID
power: 100mA chip-ID: 04d9:1836 class-ID: 0300
Device-2: 1-1.6:4 info: [Maxxter] USB GAMING MOUSE type: Mouse,Keyboard
power: 100mA chip-ID: 18f8:0fc0 class-ID: 0301
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
Hub-5: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-6: 3-3:2 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Hub-7: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
Hub-8: 4-3:2 info: Genesys Logic Hub ports: 4 rev: 3.1 speed: 5 Gb/s
chip-ID: 05e3:0612 class-ID: 0900
Hub-9: 5-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-10: 6-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 29.8 C mobo: 27.8 C
Processes: 235 Uptime: 30m wakeups: 0 Init: systemd v: 248 tool: systemctl
Compilers: gcc: 11.1.0 clang: 12.0.0 Packages: pacman: 1749 lib: 456
Shell: Bash v: 5.1.8 running-in: yakuake inxi: 3.3.04
Thanks
