Issue with Wine
Hello
I’m using Manjaro with KDE Plasma. And I have an issue with a Windows program I usually launch with Wine. It won’t launch anymore. It did work before, though.
I tried every other program I run with Wine and they still work.
The program in question is the 64-bit version of the game boy emulator BGB: https://bgb.bircd.org/
here is what happens when I try to launch it from the terminal:
MESA-INTEL: warning: Haswell Vulkan support is incomplete
00e8:err:module:loader_init "winspool.drv" failed to initialize, aborting
00e8:err:module:loader_init Initializing dlls for L"Z:\\home\\guillaume\\Documents\\BGB\\bgb64.exe" failed, status c0000005
There seems to be an issue with “winspool.drv”? Can someone help me fix this?
Drink more coffee?
This is not a solution to your issue, and have I have not used this Windows Game Boy Emulator.
But why not just use one of the many native Linux emulators for this? (Which I have used, many years ago.)
Hi, could you please post your inxi -zv8 so we can see what hardware you are using? Highlight the pasted text and press the </> button at the top of the reply window, so it appears in a properly formatted box.
I have made a few searches related to these error messages and have found various results, including this one and also this.
These could be relevant to the issue; we’ll see when we know what hardware you are using.
Cheers! :smiley:
Also, I’d investigate the suggestion by @Molski.
I have a suspicion that the winspool.drv issue is a result of the top messages, but of course I could well be wrong.
Here is the output from inxi -zv8
  Kernel: 6.9.12-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.9-x86_64
    root=UUID=7a50f8a9-f8ba-479b-84df-7a12b77eaf4d rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.5.0
  Type: Desktop System: LENOVO product: 10AAS01N00 v: ThinkCentre M93p
    serial: <superuser required>
  Mobo: LENOVO model: SHARKBAY v: NOK serial: <superuser required>
    part-nu: LENOVO_MT_10AA uuid: <superuser required> UEFI: LENOVO v: FBKTE0AUS
    date: 12/23/2021
  System RAM: total: 8 GiB available: 7.65 GiB used: 1.74 GiB (22.7%)
  Array-1: capacity: 16 GiB slots: 2 modules: 2 EC: None
  Device-1: ChannelA-DIMM0 type: DDR3 detail: synchronous size: 4 GiB
    speed: 1600 MT/s volts: curr: 2 min: 1.35 max: 2 width (bits): data: 64
    total: 64 manufacturer: Samsung part-no: M471B5173QH0-YK0 serial: <filter>
  Device-2: ChannelB-DIMM0 type: DDR3 detail: synchronous size: 4 GiB
  Info: model: Intel Core i5-4570T bits: 64 type: MT MCP arch: Haswell
    gen: core 4 level: v3 note: check built: 2013-15 process: Intel 22nm
    family: 6 model-id: 0x3C (60) stepping: 3 microcode: 0x28
    L3: 4 MiB desc: 1x4 MiB
  Speed (MHz): avg: 798 high: 800 min/max: 800/3600 scaling:
    driver: intel_cpufreq governor: schedutil cores: 1: 798 2: 800 3: 798 4: 798
    bogomips: 23159
  Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
    bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
    dtherm dts epb erms est f16c flush_l1d fma fpu fsgsbase fxsr ht ibpb ibrs
    ida invpcid lahf_lm lm mca mce md_clear mmx monitor movbe msr mtrr
    nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
    pni popcnt pse pse36 pti pts rdrand rdtscp rep_good sdbg sep smep smx ss
    ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tsc tsc_adjust
    tsc_deadline_timer vme x2apic xsave xsaveopt xtopology xtpr
  Type: itlb_multihit status: KVM: VMX unsupported
    STIBP: conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
    affected
  Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
    vendor: Lenovo driver: i915 v: kernel arch: Gen-7.5 process: Intel 22nm
    built: 2013 ports: active: HDMI-A-1 empty: DP-1, DP-2, HDMI-A-2,
    HDMI-A-3, VGA-1 bus-ID: 00:02.0 chip-ID: 8086:0412 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.2
    compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: crocus gpu: i915 display-ID: :0 screens: 1
    s-diag: 582mm (22.93")
  Monitor-1: HDMI-A-1 mapped: HDMI-1 model: Philips PHL 226E9Q
    serial: <filter> built: 2020 res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2
    chroma: red: x: 0.659 y: 0.333 green: x: 0.322 y: 0.600 blue: x: 0.149
    y: 0.055 white: x: 0.314 y: 0.329 size: 477x268mm (18.78x10.55")
    diag: 547mm (21.5") ratio: 16:9 modes: 1920x1080, 1920x1080i, 1680x1050,
    1280x1024, 1440x900, 1280x960, 1280x720, 1024x768, 832x624, 800x600,
    720x576, 720x480, 640x480, 720x400
  API: EGL v: 1.5 hw: drv: intel crocus platforms: device: 0 drv: crocus
    device: 1 drv: swrast gbm: drv: crocus surfaceless: drv: crocus x11:
    drv: crocus inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.1.6-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 4600 (HSW
    GT2) device-ID: 8086:0412 memory: 1.46 GiB unified: yes
  API: Vulkan v: 1.3.279 layers: 4 device: 0 type: integrated-gpu name: Intel
    HD Graphics 4600 (HSW GT2) driver: mesa intel v: 24.1.6-arch1.1
    device-ID: 8086:0412 surfaces: xcb,xlib
  Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
    vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 00:03.0
    chip-ID: 8086:0c0c class-ID: 0403
  Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Lenovo
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
    class-ID: 0403
  API: ALSA v: k6.9.12-3-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.2 status: active with: 1: pipewire-pulse
  Device-1: Intel Ethernet I217-LM vendor: Lenovo driver: e1000e v: kernel
    port: f080 bus-ID: 00:19.0 chip-ID: 8086:153a class-ID: 0200
  Local Storage: total: 447.13 GiB used: 52.18 GiB (11.7%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37480G
    size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: K1B3 scheme: GPT
  ID-1: / raw-size: 446.83 GiB size: 438.75 GiB (98.19%)
    used: 52.18 GiB (11.9%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
    uuid: 7a50f8a9-f8ba-479b-84df-7a12b77eaf4d
    used: 296 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: E07B-3FA3
  Hub-1: 1-0:1 info: full speed or root hub ports: 3 rev: 2.0
  Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:8000
  Hub-3: 2-0:1 info: full speed or root hub ports: 3 rev: 2.0
  Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:8008
  Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 15 rev: 2.0
  Device-1: 3-9:2 info: China Resource Semico COUGAR Gaming Keyboard
    type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
    speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 500mA
    chip-ID: 1a2c:437c class-ID: 0301
  Device-2: 3-10:3 info: Holtek E-Signal LUOM G10 Mechanical Gaming Mouse
    type: mouse,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
    chip-ID: 04d9:a09f class-ID: 0300
  Hub-6: 4-0:1 info: super-speed hub ports: 6 rev: 3.0
  System Temperatures: cpu: 48.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: pm: pacman pkgs: 1432 libs: 449 tools: pamac pm: flatpak pkgs: 0
    1: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    2: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    3: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    4: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    5: https://mirror.funami.tech/manjaro/stable/$repo/$arch
    6: http://free.nchc.org.tw/manjaro/stable/$repo/$arch
    7: https://mirror.dc.uz/manjaro/stable/$repo/$arch
    8: https://mirror.albony.xyz/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 196
  1: cpu: 18.2% command: chrome pid: 5104 mem: 240.0 MiB (3.0%)
  2: cpu: 9.8% command: konsole pid: 5130 mem: 229.7 MiB (2.9%)
  3: cpu: 9.7% command: chrome pid: 4846 mem: 424.0 MiB (5.4%)
  4: cpu: 8.3% command: chrome pid: 4899 mem: 236.4 MiB (3.0%)
  5: cpu: 3.9% command: zsh pid: 5144 mem: 11.6 MiB (0.1%)
  Memory top: 5 of 196
  1: mem: 424.0 MiB (5.4%) command: chrome pid: 4846 cpu: 9.7%
  2: mem: 389.3 MiB (4.9%) command: plasmashell pid: 769 cpu: 0.2%
  3: mem: 352.3 MiB (4.4%) command: soffice.bin pid: 4753 cpu: 0.7%
  4: mem: 270.8 MiB (3.4%) command: kwin_x11 pid: 747 cpu: 2.1%
  5: mem: 240.9 MiB (3.0%) command: dolphin pid: 3612 cpu: 0.3%
  Processes: 196 Power: uptime: 1h 46m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 3.05 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
    tool: systemctl
  Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.2.32 running-in: konsole inxi: 3.3.35
Hey, I have no idea why but it seems like the issue fixed itself magically. The program works now.
