Hi,
During the upgrade, I noticed these errors
(16/21) Updating 32-bit fontconfig cache…
Fontconfig error: failed reading config file: /etc/fonts/conf.d: (errno 21)
Fontconfig error: failed reading config file: /usr/share/fontconfig/conf.avail: (errno 21)
(20/21) Updating the info directory file…
error: command failed to execute correctly
The system has been rebooted and seems to work fine.
Best
the good use is
pacman -Syyu
can you report inxi -Fza
Only after changing branches. In all other cases it causes an unnecessary load on the servers.
Do you even use 32-Bit programms ?
Hi, follows the result of inxi -Fza
Kernel: 6.1.62-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=32c155f6-fb9a-4cdc-b688-17a45dab07c3 rw quiet
resume=UUID=ce29f740-037c-4510-afea-5d8284c797a7 DEEPIN_GFXMODE=
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm
v: 4.18.0 vt: 1 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: Hewlett-Packard product: HP ENVY m6 Notebook PC
v: 087D120022305B10000620100 serial: <superuser required> Chassis: type: 10
Mobo: Hewlett-Packard model: 18A6 v: 74.80 serial: <superuser required>
UEFI: Insyde v: F.35 date: 09/23/2013
Info: model: AMD A10-4600M APU with Radeon HD Graphics bits: 64 type: MT MCP
arch: Piledriver level: v2 built: 2012-13 process: GF 32nm family: 0x15 (21)
model-id: 0x10 (16) stepping: 1 microcode: 0x6001119
Topology: cpus: 1x cores: 4 smt: enabled cache: L1: 192 KiB
desc: d-4x16 KiB; i-2x64 KiB L2: 4 MiB desc: 2x2 MiB
Speed (MHz): avg: 1657 high: 2264 min/max: 1400/2300 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1565 2: 2264
3: 1400 4: 1400 bogomips: 18369
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
Type: spectre_v2 mitigation: Retpolines, STIBP: disabled, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: AMD Trinity [Radeon HD 7660G] vendor: Hewlett-Packard
driver: radeon v: kernel alternate: amdgpu arch: TeraScale-3
code: Northern Islands process: TSMC 32nm built: 2010-13 ports:
active: LVDS-1 empty: HDMI-A-1,VGA-1 bus-ID: 00:01.0 chip-ID: 1002:9900
class-ID: 0300
Device-2: Suyin HP Truevision HD driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-1:2 chip-ID: 064e:c336
Display: x11 server: X.Org v: 21.1.9 with: Xwayland v: 23.2.2 compositors:
1: xfwm v: 4.18.0 2: marco driver: X: loaded: radeon unloaded: modesetting
alternate: fbdev,vesa dri: r600 gpu: radeon display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31")
Monitor-1: LVDS-1 mapped: LVDS model: ChiMei InnoLux 0x15ab built: 2013
res: 1366x768 hz: 60 dpi: 101 gamma: 1.2 size: 344x193mm (13.54x7.6")
diag: 394mm (15.5") ratio: 16:9 modes: max: 1366x768 min: 640x480
API: EGL v: 1.5 hw: drv: amd r600 platforms: device: 0 drv: r600 device: 1
drv: swrast gbm: drv: kms_swrast surfaceless: drv: r600 x11: drv: r600
inactive: wayland
API: OpenGL v: 4.5 vendor: mesa v: 23.1.9-manjaro1.1 glx-v: 1.4
direct-render: yes renderer: AMD ARUBA (DRM 2.50.0 / 6.1.62-1-MANJARO LLVM
16.0.6) device-ID: 1002:9900 memory: 500 MiB unified: no
Device-1: AMD Trinity HDMI Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:01.1 chip-ID: 1002:9902
class-ID: 0403
Device-2: AMD FCH Azalia vendor: Hewlett-Packard driver: snd_hda_intel
v: kernel bus-ID: 00:14.2 chip-ID: 1022:780d class-ID: 0403
API: ALSA v: k6.1.62-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 0.3.85 status: off with: pipewire-media-session
status: off tools: pw-cli
Server-4: PulseAudio v: 16.1 status: active with: 1: pulseaudio-alsa
type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl,pavucontrol
vendor: Hewlett-Packard driver: r8168 v: 8.052.01-NAPI modules: r8169 pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 01:00.2
Device-2: Qualcomm Atheros AR9485 Wireless Network Adapter
vendor: Hewlett-Packard AR9485/HB125 802.11bgn 1x1 Wi-Fi driver: ath9k
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0
chip-ID: 168c:0032 class-ID: 0280
Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) driver: btusb
v: 0.8 type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1:2
chip-ID: 0a12:0001 class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 2.0
lmp-v: 3 status: discoverable: yes pairing: yes class-ID: 7c010c
Local Storage: total: 894.25 GiB used: 756.88 GiB (84.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Dogfish Technology model: SSD 960GB
size: 894.25 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 2A0 scheme: MBR
ID-1: / raw-size: 104.67 GiB size: 102.46 GiB (97.90%)
used: 95.62 GiB (93.3%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 571 MiB size: 569.9 MiB (99.80%)
used: 272 KiB (0.0%) fs: vfat dev: /dev/sda1 maj-min: 8:1
System Temperatures: cpu: 55.1 C mobo: N/A gpu: radeon temp: 50.0 C
Fan Speeds (rpm): N/A
Processes: 251 Uptime: 3m wakeups: 0 Memory: total: 8 GiB note: est.
available: 7.23 GiB used: 2.56 GiB (35.4%) Init: systemd v: 254
Packages: 3207 pm: pacman pkgs: 3200 libs: 596 tools: octopi,pamac,yay
pm: flatpak pkgs: 7 Shell: Bash v: 5.2.15 running-in: xfce4-terminal
inxi: 3.3.31
I think I never used 32 bit program, do you know a method to check it?
Don’t fix it if it ain’t broke
2 posts were split to a new topic: File system timestamps in future
