Had a small update this morning for the keyring & 2 aur packages.
AUR went ok however the keyring gave me this error>
gpg: next trustdb check due at 2021-10-12
gpg: error reading key: No public key
Error while configuring manjaro-keyring
→ Disabled 2 keys.
==> Updating trust database…
Running post-transaction hooks…
Arming ConditionNeedsUpdate…
Any ideas? Just ignore it?
EDIT: Just checked the history. There is no mention of a keyring error. So maybe I can just ignore it. Time will tell.
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or or if you agree)
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
