Hi,
I have an issue with my new monitor : Odyssey G9 from samsung. This monitor is suppose to support a defintiion of 5120 x 1440, but i can only have a 1600x900, and i can’t change anything.
The monitor is connected to a display port.
I searched the internet but could not find anything.
Thanks in adavnce for your help.
Can your GPU give this resolution again?
I used Google Translator …
Yes, this screen works perfectly on my windows session…
I use the same monitor - no problem.
What is the output of
inxi -Gxxx
Mine is
$ inxi -Gxxx
Device-1: AMD Ellesmere [Radeon Pro WX 7100] driver: amdgpu v: kernel
arch: GCN-4 pcie: speed: 2.5 GT/s lanes: 16 ports: active: DP-4
empty: DP-1,DP-2,DP-3 bus-ID: 61:00.0 chip-ID: 1002:67c4 class-ID: 0300
temp: 74.0 C
Device-2: Logitech HD Webcam C525 type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 2-2.4:6 chip-ID: 046d:0826 class-ID: 0e02 serial: 56B848E0
Display: wayland server: X.org v: 1.21.1.7 with: Xwayland v: 22.1.8
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: 0
Monitor-1: DP-4 res: 5120x1440 size: N/A modes: N/A
API: OpenGL v: 4.6 Mesa 22.3.6 renderer: AMD Radeon Pro WX 7100 Graphics
(polaris10 LLVM 15.0.7 DRM 3.49 6.2.2-1-MANJARO) direct-render: Yes
You may also check your refresh rate.
Make sure you use the supplied cable or another high quality cable designed for the 240Hz refreshrate.
Hi,
This what i get :
Device-1: Intel Alder Lake-P Integrated Graphics vendor: Dell driver: i915
v: kernel arch: Gen-12.2 ports: active: eDP-1 empty: DP-1,DP-2,HDMI-A-1
bus-ID: 0000:00:02.0 chip-ID: 8086:46a6 class-ID: 0300
Device-2: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: Dell
driver: nvidia v: 525.89.02 arch: Ampere bus-ID: 0000:01:00.0
chip-ID: 10de:2520 class-ID: 0300
Device-3: Logitech Brio 500 type: USB
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo bus-ID: 1-2.2:12
chip-ID: 046d:0943 class-ID: 0300 serial: 2228LZ55T6R8
Device-4: Microdia Integrated_Webcam_FHD type: USB driver: uvcvideo
bus-ID: 1-6:4 chip-ID: 0c45:6739 class-ID: 0e02
Display: x11 server: X.org v: 1.21.1.7 with: Xwayland v: 22.1.8
compositor: gnome-shell v: 43.3 driver: X: loaded: modesetting,nvidia
alternate: fbdev,nouveau,nv,vesa dri: iris gpu: i915 display-ID: :1
screens: 1
Screen-1: 0 s-res: 8112x3070 s-size: <missing: xdpyinfo>
Monitor-1: DP-1-0.1 pos: right res: 3200x1800 hz: 60 dpi: 68
size: 1190x340mm (46.85x13.39") diag: 1238mm (48.73") modes: N/A
Monitor-2: eDP-1 pos: primary,left res: 4912x3070 hz: 60 dpi: 362
size: 345x215mm (13.58x8.46") diag: 407mm (16") modes: N/A
API: OpenGL v: 4.6 Mesa 22.3.5 renderer: Mesa Intel Graphics (ADL GT2)
direct-render: Yes
