Good morning community.
I am experiencing an issue where when the system boots up and I get to the login screen, once entered the password, and this is correct, when I press enter it seems to go back to requesting the password and this happens endlessly.
The workaround to successfully log in is to open a tty2 by pressing CTRL+Alt+F2 and login in from there and then typing startx.
This successfully logs me in and I have do this every time.
Output below from:
inxi -Fza
Kernel: 5.15.25-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=103b50da-c9d2-43de-b51e-2fb207d9a556 rw quiet apparmor=1
Desktop: KDE Plasma 5.24.2 tk: Qt 5.15.2 wm: kwin_x11 vt: 2 dm: SDDM
Mobo: ASUSTeK model: ROG CROSSHAIR VIII HERO (WI-FI) v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 4004
date: 02/18/2022
Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3
family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
Topology: cpus: 1x cores: 12 tpc: 2 threads: 24 smt: enabled cache:
L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB desc: 12x512 KiB
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 4668 high: 4707 min/max: 2200/6255 boost: disabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 4668 2: 4648
3: 4660 4: 4697 5: 4686 6: 4676 7: 4667 8: 4639 9: 4670 10: 4688 11: 4673
12: 4677 13: 4674 14: 4670 15: 4674 16: 4674 17: 4707 18: 4674 19: 4655
20: 4640 21: 4679 22: 4617 23: 4687 24: 4641 bogomips: 224516
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional,
IBRS_FW, STIBP: always-on, RSB filling
Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: Gigabyte
driver: nvidia v: 510.54 alternate: nouveau,nvidia_drm pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 0a:00.0 chip-ID: 10de:1c82 class-ID: 0300
Device-2: CQG-5693-201019 Real QHD(2592x1944) type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 3-2.4:4 chip-ID: 2b16:6689
class-ID: 0102 serial: <filter>
Display: server: X.Org v: 1.21.1.3 compositor: kwin_x11 driver: X:
loaded: nvidia gpu: nvidia display-ID: :1 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 46 s-size: 1060x596mm (41.7x23.5")
s-diag: 1216mm (47.9")
Monitor-1: DP-1 res: 1920x1080 hz: 60 dpi: 26
size: 1872x1053mm (73.7x41.5") diag: 2148mm (84.6")
OpenGL: renderer: NVIDIA GeForce GTX 1050 Ti/PCIe/SSE2
v: 4.6.0 NVIDIA 510.54 direct render: Yes
Device-1: NVIDIA GP107GL High Definition Audio vendor: Gigabyte
bus-ID: 0a:00.1 chip-ID: 10de:0fb9 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
bus-ID: 0c:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: CQG-5693-201019 Real QHD(2592x1944) type: USB
Sound Server-1: ALSA v: k5.15.25-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.47 running: yes
Device-1: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 04:00.0
IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 05:00.0
IF: enp5s0 state: down mac: <filter>
Device-3: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 06:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp6s0 state: down mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-6:4 chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 4.59 TiB used: 361.26 GiB (7.7%)
model: SSD 980 PRO 500GB size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter>
rev: 5B2QGXA7 temp: 42.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM048-2E7172
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: SDM1
scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 870 QVO 1TB
type: SSD serial: <filter> rev: 2B6Q scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Western Digital
model: WD3200AVJS-63B6A0 size: 298.09 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s type: N/A serial: <filter> rev: 3A01
scheme: MBR
ID-5: /dev/sdd maj-min: 8:48 vendor: Seagate model: ST2000DM001-1CH164
type: HDD rpm: 7200 serial: <filter> rev: CC27 scheme: GPT
ID-6: /dev/sde maj-min: 8:64 vendor: Maxtor model: STM3160813AS
size: 149.05 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: MC1J scheme: GPT
ID-7: /dev/sdf maj-min: 8:80 type: USB vendor: SanDisk model: Ultra
size: 57.3 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 1.00 scheme: MBR
ID-1: / raw-size: 232.88 GiB size: 228.16 GiB (97.98%)
used: 11.42 GiB (5.0%) fs: ext4 dev: /dev/sda4 maj-min: 8:4
used: 34.8 MiB (36.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 46 C
Processes: 495 Uptime: 4m wakeups: 0 Memory: 31.32 GiB
used: 2.41 GiB (7.7%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1281 lib: 331 flatpak: 0
Shell: Zsh v: 5.8.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.13
Apologies for raising something that may have been raised before and if this has been raised in the incorrect section.
