I am setting up my thinkpad P14s gen 2 with manjaro i3. When setting up libinput and libinput-gestures, I’m facing some issues with 3-4 finger swipes and pinches.
3 finger swipe
I’m using the following config for moving between workspaces:
gesture swipe right 3 _internal ws_down
gesture swipe left 3 _internal ws_up
This works, except everytime I swipe it also pastes the clipboard. Clearly, it is also executing 3 finger tap before executing the swipe gesture mapping.
How do I fix this behavior? Is there a way to do this without removing the existing 3 tap gesture? If not, where can I remove the 3 finger tap for middle click behavior?
4 finger pinch
I’m also trying to use 4 finger pinch for quitting application:
gesture pinch in 4 xdotool key alt+shift+q
But all my 3-4 finger pinches get registered as swipes (see output of libinput-gestures -d
below).
libinput-gestures: SWIPE down 4 [-17.700000000000003, 19.91]
libinput-gestures: SWIPE right 4 [47.419999999999995, -43.04]
libinput-gestures: SWIPE left 4 [-53.17, 51.010000000000005]
ibinput-gestures: SWIPE left 3 [-50.06999999999999, 44.769999999999996]
libinput-gestures: SWIPE up 3 [27.04, -41.26]
How do I fix the issue?
Appreciate the help.
