I everyone, my level in english is not so hight but I will try explain me the best way.
I have been try to set up systemd , because I would like to use DoT on my DNS request. I have no problems with Ubuntu distro, I just set up /etc/systemd/system.conf.d/*.conf and work it.
However, with Manjaro I don’t know why don’t work. I have started systemd service and it is enabled but when I try test it with 1.1.1.1/help (Cloudflare test) I get this “No” in DoT requests.
When I edit the main file /etc/systemd/resolved.conf without “drop-ins” like above, and I do the same test (from Cloudflare) I get “Yes” in DoT requests but not always. I mean, I get “Yes” and in some cases “No” too.
Thanks you for your answer, I am not an experienced user on Linux. I feel Linux a litle confuse to find directories and software files locations, it feel messy.
I can’t follow your instructions until sunday so I will write in the future.
Alright, I have created a new file in /etc/systemd/resolved.conf.d/*.conf . “resolved.conf” was restored from default to work with “drop-ins”, also have been restarted “systemd-resolved” and “NetworkManager” services. However I get the same problem described on my first comment:
I don’t know what is happening, and worst of it, I don’t know if Dns Over Tls working or not. I have checked status from “systemd-resolved” and I have get this result:
Did you type manually the DNS server to use with your connection? since you are using systemd dns resolver,you need to point to a local DNS to be able to use DNS over TLS in systemd,the DNS is 127.0.0.53
EDIT: Actually nevermind,looks like it works without you setting the DNS 127.0.0.53 manually,but give it a try just in case.
Ok, I will try but I don’t know how to use Wireshark.
Some time ago I have been looking for information but I am not sure, first of all I need to set up port mirroring on my router, isn’t it? Anyway, thanks you.
I have done, but I get the same result doing Cloudflare test.
Do you get the same result every time refresh the website?
Global
Protocols: +LLMNR +mDNS +DNSOverTLS DNSSEC=no/unsupported
resolv.conf mode: foreign
DNS Servers: 1.1.1.1
Fallback DNS Servers: 1.1.1.1 9.9.9.10 8.8.8.8 2606:4700:4700::1111 2620:fe::10 2001:4860:4860::8888
I only have this in the /etc/systemd/resolved.conf.d/dns_servers.conf remember
Make sure also to activate the service (or restart if you have it).
sudo systemctl restart systemd-resolved.service
In case still not working,you can try forcing the system to only use DNS by the systemd-resolved be aware that if systemd-resolved is not working correctly you will not have internet
Create a file in /etc/NetworkManager/conf.d/dns.conf and in there type
[main]
dns=systemd-resolved
Then restart the network manager
sudo systemctl restart NetworkManager.service
Check that the system is using the DNS of systemd-resolved only,the file /etc/resolv.conf should contain
# Generated by NetworkManager
nameserver 127.0.0.53
options edns0 trust-ad
Try using the internet,if internet is not working the systemd-resolved is not working properly then (because of no DNS resolver),i don’t know what the cause because everything you have looks ok…
