The program wickrme was running fine for awhile but now its all of a sudden broken. When i attempt to run it from terminal i get this output
Gtk-Message: 19:40:49.063: Failed to load module "xapp-gtk3-module"
Gtk-Message: 19:40:49.063: Failed to load module "canberra-gtk-module"
[0213/195444.413265:WARNING:resource_bundle_qt.cpp(116)] locale_file_path.empty() for locale
Qt WebEngine ICU data not found at /opt/qt512/resources. Trying parent directory...
Qt WebEngine ICU data not found at /opt/qt512. Trying application directory...
Installed Qt WebEngine locales directory not found at location /opt/qt512/translations/qtwebengine_locales. Trying application directory...
Qt WebEngine locales directory not found at location /snap/wickrme/474/usr/bin/qtwebengine_locales. Trying fallback directory... Translations MAY NOT not be correct.
Path override failed for key ui::DIR_LOCALES and path '/home/user/snap/wickrme/474/.QtWebEngineProcess'
Qt WebEngine resources not found at /opt/qt512/resources. Trying parent directory...
Qt WebEngine resources not found at /opt/qt512. Trying application directory...
[0213/195444.427471:WARNING:resource_bundle_qt.cpp(116)] locale_file_path.empty() for locale
Fontconfig warning: FcPattern object weight does not accept value [40 210)
Segmentation fault (core dumped)
