Issue removing AMD PRO driver
Hello,
I did a stupid thing, I wanted to install the drivers "amd pro" to be able to encode with the encoder "amd vce" with handbreak, but manjaro is no longer usable, I have access but it bug. I install with the package "amdgpu-pro-installer.tar.gz" using the "PKGBUILD", but I do not know how to put back as before!
uninstall those drivers first, then reinstall drivers from mhwd
sudo mhwd -a pci free 0300
But that's what I do not know how to do, uninstall the amd pro driver.
post pacman -Qs amdgpu
it's ok for uninstall amd pro driver, but réinstall not work, driver already installed, and after reboot same bug probleme.
If you broke your setup by installing a third-party driver package then you might consider reinstalling Manjaro and chalking this up to experience.
really? There is no solution?
Do you know what changes you made and so can undo those changes?
Can you accurately share the steps you used to make the changes which might enable someone else to determine what went wrong?
If no to either of these then reinstalling is the best way forwards.
I simply installed this package:
aur.archlinux.org/packages/amdgpu-pro-libgl/
And what happened when you removed that package?
nothing special except that the screen resolution has changed.
And then did you run
yes!!
And then what?
no I did:
sudo mhwd -f -i pci video-linux
and
sudo mhwd -f -i pci vesa-linux
after reboot same probleme
are there some ancient instructions out there that actually suggest installing video-vesa to fix anything?
Not as far as I know. Everything for mhwd I've seen is as your provided command.
(Removing video-vesa on the other hand...)
why dont you post some actionable information.
along with
inxi -Fxxxza
mhwd -li
ls -laR /etc/X11 ; cat /etc/X11/xorg.conf.d/*.conf
sorry, I had not understood, I thought this command was to remove the driver and so eventually the driver and is still installed.
[jb@jb-pc ~]$ pacman -Qs amdgpu
local/amdgpu-core-meta 19.30_855429-1 (Radeon_Software_for_Linux)
    Config file /etc/ld.so.conf.d/20-amdgpu.conf
local/amdgpu-pro-core-meta 19.30_855429-1 (Radeon_Software_for_Linux)
    Config file /etc/ld.so.conf.d/10-amdgpu-pro.conf
local/amdgpu-pro-libgl 19.30_855429-1 (Radeon_Software_for_Linux)
    AMDGPU Pro OpenGL driver
local/mhwd-amdgpu 1.2.1-1
    MHWD module-ids for amdgpu
local/opencl-amdgpu-pro-comgr 19.30_855429-1 (Radeon_Software_for_Linux)
    Code object manager (COMGR)
local/roct-amdgpu-pro 19.30_855429-1 (Radeon_Software_for_Linux)
    development environment for hsakmt-roct
local/xf86-video-amdgpu 19.0.1-1 (xorg-drivers)
    X.org amdgpu video driver
[jb@jb-pc ~]$ inxi -Fxxxza
  Host: jb-pc Kernel: 5.2.11-1-MANJARO x86_64 bits: 64 compiler: gcc
  v: 9.1.0
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.2-x86_64
  root=UUID=1247948a-d670-4e2c-957d-f0e39f1f4fca rw quiet
  udev.log_priority=3
  Desktop: KDE Plasma 5.16.4 tk: Qt 5.13.0 wm: kwin_x11 dm: SDDM
  Distro: Manjaro Linux
  Type: Desktop Mobo: Micro-Star model: B450M PRO-VDH PLUS (MS-7A38)
  v: 7.0 serial: <filter> UEFI: American Megatrends v: 9.30
  date: 03/06/2019
  Topology: Quad Core model: AMD Ryzen 3 3200G with Radeon Vega Graphics
  bits: 64 type: MCP arch: Zen+ family: 17 (23) model-id: 18 (24)
  stepping: 1 microcode: 8108102 L2 cache: 2048 KiB
  bogomips: 28811
  Speed: 2662 MHz min/max: 1400/3600 MHz boost: enabled Core speeds (MHz):
  1: 2662 2: 2959 3: 2518 4: 2082
  Vulnerabilities: Type: l1tf status: Not affected
  Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional,
  STIBP: disabled, RSB filling
  Device-1: AMD Picasso vendor: Micro-Star MSI driver: amdgpu v: kernel
  bus ID: 38:00.0 chip ID: 1002:15d8
  Display: x11 server: X.Org 1.20.5 driver: vesa compositor: kwin_x11
  resolution: 1280x768~N/A
  OpenGL: renderer: N/A v: N/A direct render: N/A
  Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel
  v: kernel bus ID: 38:00.1 chip ID: 1002:15de
  Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI
  driver: snd_hda_intel v: kernel bus ID: 38:00.6 chip ID: 1022:15e3
  Sound Server: ALSA v: k5.2.11-1-MANJARO
  vendor: Micro-Star MSI driver: r8168 v: 8.047.02-NAPI port: f000
  bus ID: 1b:00.0 chip ID: 10ec:8168
  IF: enp27s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Local Storage: total: 2.53 TiB used: 24.16 GiB (0.9%)
  ID-1: /dev/nvme0n1 vendor: Kingston model: SKC2000M8250G
  size: 232.89 GiB block size: physical: 512 B logical: 512 B
  speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: S2681102 scheme: GPT
  ID-2: /dev/sda vendor: Seagate model: ST3500418AS size: 465.76 GiB
  block size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
  rotation: 7200 rpm serial: <filter> rev: CC44 scheme: MBR
  ID-3: /dev/sdb vendor: Western Digital model: WD10EARS-22Y5B1
  size: 931.51 GiB block size: physical: 4096 B logical: 512 B
  speed: 3.0 Gb/s serial: <filter> rev: 0A80 scheme: MBR
  ID-4: /dev/sdd type: USB vendor: Generic model: MassStorageClass
  size: 29.81 GiB block size: physical: 512 B logical: 512 B
  serial: <filter> rev: 1536 scheme: MBR
  ID-5: /dev/sde type: USB vendor: Western Digital model: WD10JPVX-60JC3T0
  rotation: 5400 rpm serial: <filter> rev: 0302 scheme: MBR
  ID-1: / raw size: 117.19 GiB size: 114.85 GiB (98.00%)
  used: 24.14 GiB (21.0%) fs: ext4 dev: /dev/nvme0n1p5
  System Temperatures: cpu: 50.6 C mobo: N/A gpu: amdgpu temp: 50 C
  Processes: 262 Uptime: 1h 09m Memory: 15.42 GiB used: 1.70 GiB (11.0%)
  Init: systemd v: 242 Compilers: gcc: 9.1.0 Shell: bash v: 5.0.9
  running in: konsole inxi: 3.0.36
[jb@jb-pc ~]$ mhwd -li
> Installed PCI configs:
           video-linux            2018.05.04                true            PCI
         network-r8168            2016.04.20                true            PCI
[jb@jb-pc ~]$ ls -laR /etc/X11 ; cat /etc/X11/xorg.conf.d/*.conf
/etc/X11:
total 32
drwxr-xr-x  5 root root 4096 12 mars   2019 .
drwxr-xr-x 94 root root 4096 11 sept. 20:20 ..
drwxr-xr-x  2 root root 4096 11 sept. 20:17 mhwd.d
drwxr-xr-x  3 root root 4096 12 mars   2019 xinit
drwxr-xr-x  2 root root 4096 11 sept. 20:17 xorg.conf.d
/etc/X11/mhwd.d:
total 16
drwxr-xr-x 2 root root 4096 11 sept. 20:17 .
drwxr-xr-x 5 root root 4096 12 mars   2019 ..
-rw-r--r-- 1 root root  545 11 sept. 20:17 vesa.conf
/etc/X11/xinit:
total 28
drwxr-xr-x 3 root root 4096 12 mars   2019 .
-rw-r--r-- 1 root root  739  4 mars   2019 xinitrc
drwxr-xr-x 2 root root 4096  6 sept. 21:58 xinitrc.d
-rw-r--r-- 1 root root   45  4 mars   2019 xserverrc
/etc/X11/xinit/xinitrc.d:
total 20
drwxr-xr-x 2 root root 4096  6 sept. 21:58 .
drwxr-xr-x 3 root root 4096 12 mars   2019 ..
-rwxr-xr-x 1 root root  318  9 nov.   2018 40-libcanberra-gtk-module.sh
-rwxr-xr-x 1 root root  203 18 août  10:43 50-systemd-user.sh
/etc/X11/xorg.conf.d:
total 16
-rw-r--r-- 1 root root  266 30 août  21:18 00-keyboard.conf
lrwxrwxrwx 1 root root   25 11 sept. 20:17 90-mhwd.conf -> /etc/X11/mhwd.d/vesa.conf
# Read and parsed by systemd-localed. It's probably wise not to edit this file
# manually too freely.
Section "InputClass"
        Identifier "system-keyboard"
        MatchIsKeyboard "on"
        Option "XkbLayout" "fr"
        Option "XkbModel" "pc105"
EndSection
## Generated by mhwd - Manjaro Hardware Detection
Section "Device"
    Identifier  "Device0"
    Driver      "vesa"
    BusID       "PCI:56:0:0"
        Option      "DRI"    "true"
EndSection
Section "DRI"
        Group  "video"
        Mode   0666
EndSection
Section "Extensions"
    Option "Composite" "Enable"
    Option "RENDER"    "Enable"
EndSection
    Identifier          "Keyboard Defaults"
    MatchIsKeyboard        "yes"
    Option              "XkbOptions" "terminate:ctrl_alt_bksp"
EndSection
I advance! I successfully uninstalled the AMD PRO driver! (for you it's nothing, but for me it's huge lol)
Everything works ALMOST as before, now the problem is that my screen is no longer recognized, and therefore the resolution is blocked
