I tried removing the nonfree driver but it kept saying script failed and it would not remove.
Issue: manjaro Stuck during boot
Did you tried chrooting into your main system first, right?
Anyway I’m calling @tids since he’s the one whos expert on this…
Ok, while we waiting for @tids to come to the rescue, let’s troubleshooting this!!!
Can you show whats the output of …
mhwd -li -d --pci
[manjaro@manjaro-gnome ~]$ sudo manjaro-chroot -a
==> Mounting (ManjaroLinux) [/dev/sda2]
–> mount: [/mnt]
–> mount: [/mnt/boot/efi]
–> mount: [/mnt/home]
[manjaro-gnome /]# mhwd -li -d --pci
ATTACHED: PCI
VERSION: 2017.03.12
INFO: Closed source catalyst drivers for linux.
PRIORITY: 5
FREEDRIVER: false
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300
VENDORIDS: 1002
Weird…It doesn’t show any free drivers available for this…
Maybe this is a kernel issues…Can you try installing another kernel (preferably4.9 and **4.11) to see what happen?
I don’t mind reinstalling the os buy I don’t want to update and install all the software again. If I replace the partition and install using the option in the installer would it remove all the installed software?
Or maybe copied all files in /var/cache/pacman/pkg/
to your other hard drive and after reinstalling it, copied back to your main partition… That way, you don’t need to download all the packages when updating
As for that you need to copy config files (Don’t know which one is the one, cause I’m not gnome user…) in your /home/<your_username>/
See this also :
https://wiki.manjaro.org/index.php?title=Partitioning_Overview_and_Existing_Partition_Tables#Where_Using_an_Existing_Linux_Partition_Table
I just reinstalled. If I get another issue I’m definitely switching to a different os as I’ve had too many issues with manjaro. Thank you for your help and time.
Just dont try to use catalyst in 2017. Its deprecated, slow and needs an completely own graphicsstack to work. It’s only good for fallback reasons (and advanced OpenCL users) in Manjaro.
