Issue getting Bluetooth PAN to work without user GUI login
Hi everyone,
I'm a new Manjaro user, and I'm trying to set up a Raspberry Pi 4 for Remote Access via Bluetooth (And Wifi Hostspot, but that's another issue)
TLDR I want to be able to connect a bunch of serial lines and VNC/SSH in and use it to configure switches/routers remotely/wirelessly and want to be able to do it without having to log in to the GUI and everything that goes with it
I've set up PAN via Blueman and it works fine except I've found that when no user is signed into the GUI (SSH doesn't change anything), the PAN service doesn't work
The main access method currently is via Ethernet or my home WLAN (I want bluetooth as an option in case I need both of those for network testing/remote access). I have VNC set up via XDM/Light DM so closing/exiting will kill the GUI session and LDM is set to not create a GUI session on boot.
From what I can tell, the Class of the Controller is 0x00000000, and only has limited UUIDs until it's changed to 0x001e0000 and a lot more UUIDs appear
On reboot/logout it reverts to 0x0
The error that I mainly see is
Server error, bridge not initialized: (0x1116)
BNEP server cannot be added
Autostart is on
I added Autostart to /etc/bluetooth/main.conf and tried adding Class=0x001e0000 (and then 0x1e0000) but no change
I've spend days searching and not found anything that could help that has worked
My guess is that something runs on login/logout that changes the class value?
I can see some new units in systemctl list-units but nothing that I can start (Eg. Polkit and rtkit-daemon) changes anything
I feel like if I could work out what actually changes the class and replicate it on boot then that would solve the immediate issue (or even better, just enable whatever services are needed permanently outside of GUI log in)
Any ideas?
Thanks in advance
Details/Logs below
Device
System:    Host: dragonpi Kernel: 4.19.80-1-MANJARO-ARM aarch64 bits: 64 compiler: gcc v: 9.1.0 Console: tty 0
           Distro: Manjaro ARM
Machine:   Type: ARM Device System: Raspberry Pi 4 Model B Rev 1.1 details: BCM2835 rev: c03111 serial: <filter>
Argument "Raspberry Pi 4 Model B Rev 1.1" isn't numeric in sprintf at /usr/bin/inxi line 6997.
CPU:       Topology: Quad Core model: N/A variant: cortex-a72 bits: 64 type: MCP arch: ARMv8 rev: 3
           features: Use -f option to see features bogomips: 432
           Speed: 600 MHz min/max: 600/1500 MHz Core speeds (MHz): 1: 600 2: 600 3: 600 4: 600
Graphics:  Device-1: bcm2835-vc4 driver: vc4_drm v: N/A bus ID: N/A
           Device-2: bcm2835-hdmi driver: N/A bus ID: N/A
           Display: server: X.org 1.20.5 driver: none unloaded: modesetting tty: 120x24
Audio:     Device-1: bcm2835-audio driver: bcm2835_audio bus ID: N/A
           Sound Server: ALSA v: k4.19.80-1-MANJARO-ARM
Network:   Message: No ARM data found for this feature.
           IF-ID-1: eth0 state: down mac: <filter>
           IF-ID-2: wlan0 state: up mac: <filter>
Drives:    Local Storage: total: 119.08 GiB used: 4.68 GiB (3.9%)
           ID-1: /dev/mmcblk0 model: SN128 size: 119.08 GiB
Partition: ID-1: / size: 117.10 GiB used: 4.64 GiB (4.0%) fs: ext4 dev: /dev/mmcblk0p2
           ID-2: /boot size: 93.8 MiB used: 39.6 MiB (42.3%) fs: vfat dev: /dev/mmcblk0p1
Sensors:   Message: No sensors data was found. Is sensors configured?
Info:      Processes: 115 Uptime: 4h 35m Memory: 3.73 GiB used: 163.1 MiB (4.3%) Init: systemd Compilers: gcc: 9.1.0
           Shell: bash v: 5.0.11 inxi: 3.0.36
On Login BTMON shows
@ MGMT Command: Set Bondable (0x0009) plen 1        {0x0001} [hci0] 11.924504
        Bondable: Enabled (0x01)
@ MGMT Event: Command Complete (0x0001) plen 7                                                               {0x0001} [hci0] 11.924525
      Set Bondable (0x0009) plen 4
        Status: Success (0x00)
        Current settings: 0x00000ad1
          Powered
          Bondable
          Secure Simple Pairing
          BR/EDR
          Low Energy
          Secure Connections
@ MGMT Event: New Settings (0x0006) plen 4        {0x0002} [hci0] 11.924529
          Powered
          Bondable
          BR/EDR
          Low Energy
          Secure Connections
@ MGMT Command: Set IO Capability (0x0018) plen 1                                                            {0x0001} [hci0] 11.924695
        Capability: KeyboardDisplay (0x04)
@ MGMT Event: Command Complete (0x0001) plen 3                                                               {0x0001} [hci0] 11.924701
      Set IO Capability (0x0018) plen 0
@ MGMT Command: Add UUID (0x0010) plen 17        {0x0001} [hci0] 12.030189
        UUID: 00001116-0000-1000-8000-00805f9b34fb
        Service class: 0x02
< HCI Command: Write Class of Device (0x03|0x0024) plen 3                                                          #2 [hci0] 12.030253
        Class: 0x1e0000
          Major class: Miscellaneous
          Minor class: 0x00
          Networking (LAN, Ad hoc)
          Rendering (Printing, Speaker)
          Capturing (Scanner, Microphone)
          Object Transfer (v-Inbox, v-Folder)
> HCI Event: Command Complete (0x0e) plen 4        #3 [hci0] 12.030982
      Write Class of Device (0x03|0x0024) ncmd 1
@ MGMT Event: Class Of Device Changed (0x0007) plen 3                                                        {0x0002} [hci0] 12.031013
        Class: 0x1e0000
          Minor class: 0x00
@ MGMT Event: Class Of Device Changed (0x0007) plen 3                                                        {0x0001} [hci0] 12.031013
        Class: 0x1e0000
          Minor class: 0x00
< HCI Command: Write Extended Inquiry Response (0x03|0x0052) plen 241                                              #4 [hci0] 12.031044
        FEC: Not required (0x00)
        Name (complete): dragonpi
        TX power: 0 dBm
        Device ID: USB Implementer's Forum assigned (0x0002)
          Vendor: Linux Foundation (0x1d6b)
          Product: 0x0246
          Version: 5.3.3 (0x0533)
        16-bit Service UUIDs (complete): 15 entries
          Generic Access Profile (0x1800)
          Generic Attribute Profile (0x1801)
          A/V Remote Control (0x110e)
          A/V Remote Control Target (0x110c)
          Audio Sink (0x110b)
          Audio Source (0x110a)
          Headset AG (0x1112)
          Headset (0x1108)
          Message Notification Server (0x1133)
          Message Access Server (0x1132)
          Phonebook Access Server (0x112f)
          IrMC Sync (0x1104)
          OBEX File Transfer (0x1106)
          OBEX Object Push (0x1105)
          NAP (0x1116)
        128-bit Service UUIDs (complete): 1 entry
          Vendor specific (00005005-0000-1000-8000-0002ee000001)
> HCI Event: Command Complete (0x0e) plen 4        #5 [hci0] 12.032403
      Write Extended Inquiry Response (0x03|0x0052) ncmd 1
@ MGMT Event: Command Complete (0x0001) plen 6                                                               {0x0001} [hci0] 12.032440
      Add UUID (0x0010) plen 3
        Class: 0x1e0000
          Minor class: 0x00
On logout BTMON shows
@ MGMT Command: Set Bondable (0x0009) plen 1        {0x0001} [hci0] 72.183905
        Bondable: Disabled (0x00)
@ MGMT Event: Command Complete (0x0001) plen 7                                                               {0x0001} [hci0] 72.183944
        Current settings: 0x00000ac1
          Powered
          BR/EDR
          Low Energy
          Secure Connections
@ MGMT Event: New Settings (0x0006) plen 4        {0x0002} [hci0] 72.183948
          Powered
          BR/EDR
          Low Energy
          Secure Connections
@ MGMT Command: Remove UUID (0x0011) plen 16        {0x0001} [hci0] 72.184084
< HCI Command: Write Class of Device (0x03|0x0024) plen 3                                                          #6 [hci0] 72.184134
        Class: 0x1c0000
          Minor class: 0x00
> HCI Event: Command Complete (0x0e) plen 4        #7 [hci0] 72.185316
@ MGMT Event: Class Of Device Changed (0x0007) plen 3                                                        {0x0002} [hci0] 72.185363
        Class: 0x1c0000
          Minor class: 0x00
@ MGMT Event: Class Of Device Changed (0x0007) plen 3                                                        {0x0001} [hci0] 72.185363
        Class: 0x1c0000
          Minor class: 0x00
< HCI Command: Write Extended Inquiry Response (0x03|0x0052) plen 241                                              #8 [hci0] 72.185401
        TX power: 0 dBm
          Product: 0x0246
        16-bit Service UUIDs (complete): 14 entries
          Audio Sink (0x110b)
          Headset AG (0x1112)
          Headset (0x1108)
          IrMC Sync (0x1104)
> HCI Event: Command Complete (0x0e) plen 4        #9 [hci0] 72.186887
@ MGMT Event: Command Complete (0x0001) plen 6                                                               {0x0001} [hci0] 72.186920
      Remove UUID (0x0011) plen 3
        Class: 0x1c0000
          Minor class: 0x00
Result from BTMON when attempting to connect while logged out
Bluetooth monitor ver 5.51
= Note: Linux version 4.19.80-1-MANJARO-ARM (aarch64)                                                          0.204111
= Note: Bluetooth subsystem version 2.22        0.204121
= New Index: <Pi MAC> (Primary,UART,hci0)                                                      [hci0] 0.204129
= Open Index: <Pi MAC>        [hci0] 0.204132
= Index Info: <Pi MAC> (Broadcom Corporation)                                                  [hci0] 0.204137
@ MGMT Open: bluetoothd (privileged) version 1.14                                                     {0x0001} 0.204142
@ MGMT Open: btmon (privileged) version 1.14                                                          {0x0002} 0.204351
> HCI Event: Connect Request (0x04) plen 10                                                         #1 [hci0] 39.608238
        Address: <Phone MAC> (Samsung Electronics Co.,Ltd)
        Class: 0x5a020c
          Major class: Phone (cellular, cordless, payphone, modem)
          Minor class: Smart phone
          Telephony (Cordless telephony, Modem, Headset)
        Link type: ACL (0x01)
< HCI Command: Accept Connection Request (0x01|0x0009) plen 7                                       #2 [hci0] 39.608330
        Role: Master (0x00)
> HCI Event: Command Status (0x0f) plen 4                                                           #3 [hci0] 39.608824
      Accept Connection Request (0x01|0x0009) ncmd 1
> HCI Event: Role Change (0x12) plen 8                                                              #4 [hci0] 39.767902
        Role: Master (0x00)
> HCI Event: Connect Complete (0x03) plen 11                                                        #5 [hci0] 39.776776
        Handle: 11
        Encryption: Disabled (0x00)
< HCI Command: Read Remote Supported Features (0x01|0x001b) plen 2                                  #6 [hci0] 39.777032
        Handle: 11
> HCI Event: Max Slots Change (0x1b) plen 3                                                         #7 [hci0] 39.779140
        Handle: 11
        Max slots: 5
> HCI Event: Command Status (0x0f) plen 4                                                           #8 [hci0] 39.779947
      Read Remote Supported Features (0x01|0x001b) ncmd 1
> HCI Event: Read Remote Supported Features (0x0b) plen 11                                          #9 [hci0] 39.780068
        Handle: 11
        Features: 0xbf 0xfe 0xcf 0xfe 0xdb 0xff 0x7b 0x87
          3 slot packets
          5 slot packets
          Encryption
          Slot offset
          Timing accuracy
          Role switch
          Sniff mode
          Power control requests
          Channel quality driven data rate (CQDDR)
          SCO link
          HV2 packets
          HV3 packets
          u-law log synchronous data
          A-law log synchronous data
          CVSD synchronous data
          Paging parameter negotiation
          Power control
          Transparent synchronous data
          Flow control lag (most significant bit)
          Broadcast Encryption
          Enhanced Data Rate ACL 2 Mbps mode
          Enhanced Data Rate ACL 3 Mbps mode
          Enhanced inquiry scan
          Interlaced inquiry scan
          Interlaced page scan
          RSSI with inquiry results
          Extended SCO link (EV3 packets)
          EV4 packets
          EV5 packets
          AFH capable slave
          AFH classification slave
          LE Supported (Controller)
          3-slot Enhanced Data Rate ACL packets
          5-slot Enhanced Data Rate ACL packets
          Sniff subrating
          Pause encryption
          AFH capable master
          AFH classification master
          Enhanced Data Rate eSCO 2 Mbps mode
          Enhanced Data Rate eSCO 3 Mbps mode
          3-slot Enhanced Data Rate eSCO packets
          Simultaneous LE and BR/EDR (Controller)
          Encapsulated PDU
          Erroneous Data Reporting
          Non-flushable Packet Boundary Flag
          Link Supervision Timeout Changed Event
          Inquiry TX Power Level
          Enhanced Power Control
          Extended features
< HCI Command: Read Remote Extended Features (0x01|0x001c) plen 3                                  #10 [hci0] 39.780275
        Handle: 11
        Page: 1
> HCI Event: Command Status (0x0f) plen 4                                                          #11 [hci0] 39.780689
      Read Remote Extended Features (0x01|0x001c) ncmd 1
> HCI Event: Read Remote Extended Features (0x23) plen 13                                          #12 [hci0] 39.781930
        Handle: 11
        Page: 1/2
        Features: 0x0f 0x00 0x00 0x00 0x00 0x00 0x00 0x00
          Secure Simple Pairing (Host Support)
          LE Supported (Host)
          Simultaneous LE and BR/EDR (Host)
          Secure Connections (Host Support)
< HCI Command: Remote Name Request (0x01|0x0019) plen 10                                           #13 [hci0] 39.782100
        Page scan repetition mode: R2 (0x02)
        Page scan mode: Mandatory (0x00)
        Clock offset: 0x0000
< ACL Data TX: Handle 11 flags 0x00 dlen 10                                                        #14 [hci0] 39.782169
      L2CAP: Information Request (0x0a) ident 1 len 2
        Type: Extended features supported (0x0002)
> HCI Event: Command Status (0x0f) plen 4                                                          #15 [hci0] 39.782935
      Remote Name Request (0x01|0x0019) ncmd 1
> HCI Event: Remote Name Req Complete (0x07) plen 255                                              #16 [hci0] 39.790116
@ MGMT Event: Device Connected (0x000b) plen 26                                               {0x0002} [hci0] 39.790145
        BR/EDR Address: <Phone MAC> (Samsung Electronics Co.,Ltd)
        Flags: 0x00000000
        Data length: 13
        Name (complete): DissS8
        Class: 0x5a020c
@ MGMT Event: Device Connected (0x000b) plen 26                                               {0x0001} [hci0] 39.790145
        Flags: 0x00000000
        Data length: 13
        Class: 0x5a020c
> ACL Data RX: Handle 11 flags 0x02 dlen 10                                                        #17 [hci0] 39.790300
      L2CAP: Information Request (0x0a) ident 2 len 2
< ACL Data TX: Handle 11 flags 0x00 dlen 16                                                        #18 [hci0] 39.790328
      L2CAP: Information Response (0x0b) ident 2 len 8
        Result: Success (0x0000)
        Features: 0x000002b8
          Enhanced Retransmission Mode
          Streaming Mode
          FCS Option
          Fixed Channels
          Unicast Connectionless Data Reception
> HCI Event: Number of Completed Packets (0x13) plen 5                                             #19 [hci0] 39.792910
        Num handles: 1
        Handle: 11
        Count: 2
> ACL Data RX: Handle 11 flags 0x02 dlen 16                                                        #20 [hci0] 39.795319
      L2CAP: Information Response (0x0b) ident 1 len 8
        Features: 0x000000b8
          Streaming Mode
          FCS Option
          Fixed Channels
< ACL Data TX: Handle 11 flags 0x00 dlen 10                                                        #21 [hci0] 39.795354
        Type: Fixed channels supported (0x0003)
> ACL Data RX: Handle 11 flags 0x02 dlen 10                                                        #22 [hci0] 39.799045
      L2CAP: Information Request (0x0a) ident 3 len 2
< ACL Data TX: Handle 11 flags 0x00 dlen 20                                                        #23 [hci0] 39.799078
      L2CAP: Information Response (0x0b) ident 3 len 12
        Channels: 0x0000000000000086
          L2CAP Signaling (BR/EDR)
          Connectionless reception
          Security Manager (BR/EDR)
> ACL Data RX: Handle 11 flags 0x02 dlen 20                                                        #24 [hci0] 39.800347
      L2CAP: Information Response (0x0b) ident 2 len 12
        Channels: 0x0000000000000082
> HCI Event: Link Key Request (0x17) plen 6                                                        #25 [hci0] 39.801720
< HCI Command: Link Key Request Reply (0x01|0x000b) plen 22                                        #26 [hci0] 39.801749
        Link key: d8a3ff7393dcc7fb7fc4670abeb8bb66
> HCI Event: Number of Completed Packets (0x13) plen 5                                             #27 [hci0] 39.802205
        Num handles: 1
        Handle: 11
        Count: 2
> HCI Event: Command Complete (0x0e) plen 10                                                       #28 [hci0] 39.803372
      Link Key Request Reply (0x01|0x000b) ncmd 1
> HCI Event: Encryption Change (0x08) plen 4                                                       #29 [hci0] 39.841290
        Handle: 11
        Encryption: Enabled with AES-CCM (0x02)
< HCI Command: Read Encryption Key Size (0x05|0x0008) plen 2                                       #30 [hci0] 39.841372
        Handle: 11
> HCI Event: Command Complete (0x0e) plen 7                                                        #31 [hci0] 39.841780
      Read Encryption Key Size (0x05|0x0008) ncmd 1
        Handle: 11
        Key size: 16
> ACL Data RX: Handle 11 flags 0x02 dlen 12                                                        #32 [hci0] 39.845329
      L2CAP: Connection Request (0x02) ident 4 len 4
        PSM: 15 (0x000f)
        Source CID: 67
< ACL Data TX: Handle 11 flags 0x00 dlen 16                                                        #33 [hci0] 39.845456
      L2CAP: Connection Response (0x03) ident 4 len 8
        Destination CID: 64
        Source CID: 67
        Result: Connection pending (0x0001)
        Status: Authorization pending (0x0002)
< ACL Data TX: Handle 11 flags 0x00 dlen 16                                                        #34 [hci0] 39.846037
        Destination CID: 64
        Source CID: 67
        Result: Connection successful (0x0000)
        Status: No further information available (0x0000)
< ACL Data TX: Handle 11 flags 0x00 dlen 27                                                        #35 [hci0] 39.846103
      L2CAP: Configure Request (0x04) ident 3 len 19
        Destination CID: 67
        Flags: 0x0000
        Option: Maximum Transmission Unit (0x01) [mandatory]
          MTU: 1691
        Option: Retransmission and Flow Control (0x04) [mandatory]
          Mode: Basic (0x00)
          TX window size: 0
          Max transmit: 0
          Retransmission timeout: 0
          Monitor timeout: 0
          Maximum PDU size: 0
> HCI Event: Number of Completed Packets (0x13) plen 5                                             #36 [hci0] 39.849176
        Num handles: 1
        Handle: 11
        Count: 2
> ACL Data RX: Handle 11 flags 0x02 dlen 16                                                        #37 [hci0] 39.851599
      L2CAP: Configure Request (0x04) ident 5 len 8
        Destination CID: 64
        Flags: 0x0000
          MTU: 1691
< ACL Data TX: Handle 11 flags 0x00 dlen 18                                                        #38 [hci0] 39.851670
      L2CAP: Configure Response (0x05) ident 5 len 10
        Source CID: 67
        Flags: 0x0000
          MTU: 1691
> HCI Event: Number of Completed Packets (0x13) plen 5                                             #39 [hci0] 39.854186
        Num handles: 1
        Handle: 11
        Count: 2
> ACL Data RX: Handle 11 flags 0x02 dlen 14                                                        #40 [hci0] 39.855332
      L2CAP: Configure Response (0x05) ident 3 len 6
        Source CID: 64
        Flags: 0x0000
> ACL Data RX: Handle 11 flags 0x02 dlen 11                                                        #41 [hci0] 39.856564
      Channel: 64 len 7 [PSM 15 mode Basic (0x00)] {chan 0}
      BNEP: Control (0x01|0)
         Setup Conn Req (0x01)
           Dst: 0x1116(NAP)
           Src: 0x1115(PANU)
= bluetoothd: Server error, bridge not initialized: (0x1116)                                                  39.856903
= bluetoothd: BNEP server cannot be added        39.860037
> HCI Event: Max Slots Change (0x1b) plen 3                                                        #42 [hci0] 40.523053
        Handle: 11
        Max slots: 5
> HCI Event: Encryption Key Refresh Complete (0x30) plen 3                                         #43 [hci0] 40.533360
        Handle: 11
> HCI Event: Role Change (0x12) plen 8                                                             #44 [hci0] 40.533602
        Role: Slave (0x01)
> HCI Event: Link Supervision Timeout Changed (0x38) plen 4                                        #45 [hci0] 40.544318
        Handle: 11
        Timeout: 5000.000 msec (0x1f40)
> ACL Data RX: Handle 11 flags 0x02 dlen 11                                                        #46 [hci0] 59.858177
           Dst: 0x1116(NAP)
           Src: 0x1115(PANU)
> ACL Data RX: Handle 11 flags 0x02 dlen 11                                                        #47 [hci0] 79.864676
           Dst: 0x1116(NAP)
           Src: 0x1115(PANU)
> ACL Data RX: Handle 11 flags 0x02 dlen 11                                                        #48 [hci0] 99.867430
           Dst: 0x1116(NAP)
           Src: 0x1115(PANU)
> HCI Event: Disconnect Complete (0x05) plen 4                                                    #49 [hci0] 106.726259
        Handle: 11
        Reason: Remote User Terminated Connection (0x13)
@ MGMT Event: Device Disconnected (0x000c) plen 8                                            {0x0002} [hci0] 106.726317
        Reason: Connection terminated by remote host (0x03)
@ MGMT Event: Device Disconnected (0x000c) plen 8                                            {0x0001} [hci0] 106.726317
Systemctl list-units pre-login
UNIT        LOAD   ACTIVE SUB       DESCRIPTION
proc-sys-fs-binfmt_misc.automount                                                              loaded active waiting   Arbitrary Executable File Formats File System Automount Point
sys-devices-platform-scb-fd580000.genet-net-eth0.device                                        loaded active plugged   /sys/devices/platform/scb/fd580000.genet/net/eth0
sys-devices-platform-soc-fe201000.serial-tty-ttyAMA0-hci0.device                               loaded active plugged   /sys/devices/platform/soc/fe201000.serial/tty/ttyAMA0/hci0
sys-devices-platform-soc-fe201000.serial-tty-ttyAMA0.device                                    loaded active plugged   /sys/devices/platform/soc/fe201000.serial/tty/ttyAMA0
sys-devices-platform-soc-fe300000.mmcnr-mmc_host-mmc1-mmc1:0001-mmc1:0001:1-net-wlan0.device   loaded active plugged   /sys/devices/platform/soc/fe300000.mmcnr/mmc_host/mmc1/mmc1:0001/mmc1:0001:1/net/wlan0
sys-devices-platform-soc-fe340000.emmc2-mmc_host-mmc0-mmc0:aaaa-block-mmcblk0-mmcblk0p1.device loaded active plugged   /sys/devices/platform/soc/fe340000.emmc2/mmc_host/mmc0/mmc0:aaaa/block/mmcblk0/mmcblk0p1
sys-devices-platform-soc-fe340000.emmc2-mmc_host-mmc0-mmc0:aaaa-block-mmcblk0-mmcblk0p2.device loaded active plugged   /sys/devices/platform/soc/fe340000.emmc2/mmc_host/mmc0/mmc0:aaaa/block/mmcblk0/mmcblk0p2
sys-devices-platform-soc-fe340000.emmc2-mmc_host-mmc0-mmc0:aaaa-block-mmcblk0.device           loaded active plugged   /sys/devices/platform/soc/fe340000.emmc2/mmc_host/mmc0/mmc0:aaaa/block/mmcblk0
sys-devices-platform-soc-soc:audio-sound-card0.device                                          loaded active plugged   /sys/devices/platform/soc/soc:audio/sound/card0
sys-devices-virtual-block-ram0.device                                                          loaded active plugged   /sys/devices/virtual/block/ram0
sys-devices-virtual-block-ram1.device                                                          loaded active plugged   /sys/devices/virtual/block/ram1
sys-devices-virtual-block-ram10.device                                                         loaded active plugged   /sys/devices/virtual/block/ram10
sys-devices-virtual-block-ram11.device                                                         loaded active plugged   /sys/devices/virtual/block/ram11
sys-devices-virtual-block-ram12.device                                                         loaded active plugged   /sys/devices/virtual/block/ram12
sys-devices-virtual-block-ram13.device                                                         loaded active plugged   /sys/devices/virtual/block/ram13
sys-devices-virtual-block-ram14.device                                                         loaded active plugged   /sys/devices/virtual/block/ram14
sys-devices-virtual-block-ram15.device                                                         loaded active plugged   /sys/devices/virtual/block/ram15
sys-devices-virtual-block-ram2.device                                                          loaded active plugged   /sys/devices/virtual/block/ram2
sys-devices-virtual-block-ram3.device                                                          loaded active plugged   /sys/devices/virtual/block/ram3
sys-devices-virtual-block-ram4.device                                                          loaded active plugged   /sys/devices/virtual/block/ram4
sys-devices-virtual-block-ram5.device                                                          loaded active plugged   /sys/devices/virtual/block/ram5
sys-devices-virtual-block-ram6.device                                                          loaded active plugged   /sys/devices/virtual/block/ram6
sys-devices-virtual-block-ram7.device                                                          loaded active plugged   /sys/devices/virtual/block/ram7
sys-devices-virtual-block-ram8.device                                                          loaded active plugged   /sys/devices/virtual/block/ram8
sys-devices-virtual-block-ram9.device                                                          loaded active plugged   /sys/devices/virtual/block/ram9
sys-devices-virtual-misc-rfkill.device                                                         loaded active plugged   /sys/devices/virtual/misc/rfkill
sys-devices-virtual-tty-ttyprintk.device                                                       loaded active plugged   /sys/devices/virtual/tty/ttyprintk
sys-module-configfs.device        loaded active plugged   /sys/module/configfs
sys-module-fuse.device        loaded active plugged   /sys/module/fuse
sys-subsystem-bluetooth-devices-hci0.device                                                    loaded active plugged   /sys/subsystem/bluetooth/devices/hci0
sys-subsystem-net-devices-eth0.device                                                          loaded active plugged   /sys/subsystem/net/devices/eth0
sys-subsystem-net-devices-wlan0.device                                                         loaded active plugged   /sys/subsystem/net/devices/wlan0
-.mount        loaded active mounted   /
boot.mount        loaded active mounted   /boot
dev-mqueue.mount        loaded active mounted   POSIX Message Queue File System
run-user-1000.mount        loaded active mounted   /run/user/1000
sys-fs-fuse-connections.mount        loaded active mounted   FUSE Control File System
sys-kernel-config.mount        loaded active mounted   Kernel Configuration File System
sys-kernel-debug.mount        loaded active mounted   Kernel Debug File System
tmp.mount        loaded active mounted   Temporary Directory (/tmp)
systemd-ask-password-console.path                                                              loaded active waiting   Dispatch Password Requests to Console Directory Watch
systemd-ask-password-wall.path        loaded active waiting   Forward Password Requests to Wall Directory Watch
init.scope        loaded active running   System and Service Manager
session-c1.scope        loaded active running   Session c1 of user veitch
attach-bluetooth.service        loaded active running   Attach Bluetooth Adapter
bluetooth.service        loaded active running   Bluetooth service
dbus.service        loaded active running   D-Bus System Message Bus
haveged.service        loaded active running   Entropy Daemon based on the HAVEGE algorithm
kmod-static-nodes.service        loaded active exited    Create list of static device nodes for the current kernel
lightdm.service        loaded active running   Light Display Manager
lvm2-lvmetad.service        loaded active running   LVM2 metadata daemon
lvm2-monitor.service        loaded active exited    Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling
NetworkManager.service        loaded active running   Network Manager
nmb.service        loaded active running   Samba NMB Daemon
smb.service        loaded active running   Samba SMB Daemon
sshd.service        loaded active running   OpenSSH Daemon
systemd-journal-flush.service        loaded active exited    Flush Journal to Persistent Storage
systemd-journald.service        loaded active running   Journal Service
systemd-logind.service        loaded active running   Login Service
systemd-modules-load.service        loaded active exited    Load Kernel Modules
systemd-networkd-wait-online.service                                                           loaded active exited    Wait for Network to be Configured
systemd-networkd.service        loaded active running   Network Service
systemd-random-seed.service        loaded active exited    Load/Save Random Seed
systemd-remount-fs.service        loaded active exited    Remount Root and Kernel File Systems
systemd-sysctl.service        loaded active exited    Apply Kernel Variables
systemd-timesyncd.service        loaded active running   Network Time Synchronization
systemd-tmpfiles-setup-dev.service                                                             loaded active exited    Create Static Device Nodes in /dev
systemd-tmpfiles-setup.service        loaded active exited    Create Volatile Files and Directories
systemd-udev-trigger.service        loaded active exited    udev Coldplug all Devices
systemd-udevd.service        loaded active running   udev Kernel Device Manager
systemd-update-utmp.service        loaded active exited    Update UTMP about System Boot/Shutdown
systemd-user-sessions.service        loaded active exited    Permit User Sessions
tlp.service        loaded active exited    TLP system startup/shutdown
user-runtime-dir@1000.service        loaded active exited    User Runtime Directory /run/user/1000
user@1000.service        loaded active running   User Manager for UID 1000
wpa_supplicant.service        loaded active running   WPA supplicant
-.slice        loaded active active    Root Slice
system-getty.slice        loaded active active    system-getty.slice
system.slice        loaded active active    System Slice
user-1000.slice        loaded active active    User Slice of UID 1000
user.slice        loaded active active    User and Session Slice
dbus.socket        loaded active running   D-Bus System Message Bus Socket
dm-event.socket        loaded active listening Device-mapper event daemon FIFOs
lvm2-lvmetad.socket        loaded active running   LVM2 metadata daemon socket
lvm2-lvmpolld.socket        loaded active listening LVM2 poll daemon socket
systemd-coredump.socket        loaded active listening Process Core Dump Socket
systemd-initctl.socket        loaded active listening initctl Compatibility Named Pipe
systemd-journald-dev-log.socket        loaded active running   Journal Socket (/dev/log)
systemd-journald.socket        loaded active running   Journal Socket
systemd-networkd.socket        loaded active running   Network Service Netlink Socket
systemd-rfkill.socket        loaded active listening Load/Save RF Kill Switch Status /dev/rfkill Watch
systemd-udevd-control.socket        loaded active running   udev Control Socket
systemd-udevd-kernel.socket        loaded active running   udev Kernel Socket
xvnc.socket        loaded active listening XVNC Server
basic.target        loaded active active    Basic System
bluetooth.target        loaded active active    Bluetooth
cryptsetup.target        loaded active active    Local Encrypted Volumes
getty.target        loaded active active    Login Prompts
graphical.target        loaded active active    Graphical Interface
local-fs-pre.target        loaded active active    Local File Systems (Pre)
local-fs.target        loaded active active    Local File Systems
machines.target        loaded active active    Containers
multi-user.target        loaded active active    Multi-User System
network-online.target        loaded active active    Network is Online
network.target        loaded active active    Network
paths.target        loaded active active    Paths
remote-cryptsetup.target        loaded active active    Remote Encrypted Volumes
remote-fs.target        loaded active active    Remote File Systems
slices.target        loaded active active    Slices
sockets.target        loaded active active    Sockets
sound.target        loaded active active    Sound Card
swap.target        loaded active active    Swap
sysinit.target        loaded active active    System Initialization
time-set.target        loaded active active    System Time Set
time-sync.target        loaded active active    System Time Synchronized
timers.target        loaded active active    Timers
man-db.timer        loaded active waiting   Daily man-db regeneration
pamac-cleancache.timer        loaded active waiting   Monthly clean packages cache
pamac-mirrorlist.timer        loaded active waiting   Generate mirrorlist weekly
shadow.timer        loaded active waiting   Daily verification of password and group files
systemd-tmpfiles-clean.timer        loaded active waiting   Daily Cleanup of Temporary Directories
updatedb.timer        loaded active waiting   Daily locate database update
Systemctl list-units post-login
  sys-devices-virtual-net-pan1.device                                                            loaded active plugged   /sys/devices/virtual/net/pan1
  sys-subsystem-net-devices-pan1.device                                                          loaded active plugged   /sys/subsystem/net/devices/pan1
  run-user-1000-gvfs.mount        loaded active mounted   /run/user/1000/gvfs
  session-c3.scope        loaded active running   Session c3 of user veitch
  polkit.service        loaded active running   Authorization Manager
  rtkit-daemon.service        loaded active running   RealtimeKit Scheduling Policy Service
  udisks2.service        loaded active running   Disk Manager
  upower.service        loaded active running   Daemon for power management
● user@973.service        loaded failed failed    User Manager for UID 973
  xvnc@0-192.168.1.4:5900-192.168.1.41:58263.service                                             loaded active running   XVNC Per-Connection Daemon (192.168.1.41:58263)
  system-xvnc.slice        loaded active active    system-xvnc.slice
dmesg (Adding here due to post limit)
dmesg
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd083]
[    0.000000] Linux version 4.19.80-1-MANJARO-ARM (root@aarch64) (gcc version 9.1.0 (GCC)) #1 SMP PREEMPT Tue Oct 22 03:51:34 UTC 2019
[    0.000000] Machine model: Raspberry Pi 4 Model B Rev 1.1
[    0.000000] efi: Getting EFI parameters from FDT:
[    0.000000] efi: UEFI not found.
[    0.000000] cma: Reserved 256 MiB at 0x000000001e800000
[    0.000000] On node 0 totalpages: 1015808
[    0.000000]   DMA32 zone: 3840 pages used for memmap
[    0.000000]   DMA32 zone: 0 pages reserved
[    0.000000]   DMA32 zone: 245760 pages, LIFO batch:63
[    0.000000]   Normal zone: 12032 pages used for memmap
[    0.000000]   Normal zone: 770048 pages, LIFO batch:63
[    0.000000] random: get_random_bytes called from start_kernel+0xa0/0x46c with crng_init=0
[    0.000000] percpu: Embedded 22 pages/cpu s53208 r8192 d28712 u90112
[    0.000000] pcpu-alloc: s53208 r8192 d28712 u90112 alloc=22*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] ARM_SMCCC_ARCH_WORKAROUND_1 missing from firmware
[    0.000000] CPU features: enabling workaround for EL2 vector hardening
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 999936
[    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 cma=64M cma=256M  smsc95xx.macaddr=DC:A6:32:3D:14:3A vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  root=/dev/mmcblk0p2 rw rootwait console=ttyS0,115200 console=tty1 selinux=0 plymouth.enable=0 smsc95xx.turbo_mode=N dwc_otg.lpm_enable=0 kgdboc=ttyS0,115200 elevator=noop snd-bcm2835.enable_compat_alsa=0
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] software IO TLB: mapped [mem 0x37fff000-0x3bfff000] (64MB)
[    0.000000] Memory: 3641584K/4063232K available (8188K kernel code, 1024K rwdata, 2604K rodata, 960K init, 919K bss, 159504K reserved, 262144K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] ftrace: allocating 29217 entries in 115 pages
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[    0.000000]  Tasks RCU enabled.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[    0.000005] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[    0.000226] Console: colour dummy device 80x25
[    0.000597] console [tty1] enabled
[    0.000649] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=216000)
[    0.000687] pid_max: default: 32768 minimum: 301
[    0.000983] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.001048] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.024027] ASID allocator initialised with 32768 entries
[    0.032023] rcu: Hierarchical SRCU implementation.
[    0.040534] EFI services will not be available.
[    0.048076] smp: Bringing up secondary CPUs ...
[    0.080265] Detected PIPT I-cache on CPU1
[    0.080324] CPU1: Booted secondary processor 0x0000000001 [0x410fd083]
[    0.112345] Detected PIPT I-cache on CPU2
[    0.112387] CPU2: Booted secondary processor 0x0000000002 [0x410fd083]
[    0.144455] Detected PIPT I-cache on CPU3
[    0.144497] CPU3: Booted secondary processor 0x0000000003 [0x410fd083]
[    0.144635] smp: Brought up 1 node, 4 CPUs
[    0.144723] SMP: Total of 4 processors activated.
[    0.144746] CPU features: detected: 32-bit EL0 Support
[    0.145347] CPU: All CPU(s) started at EL2
[    0.145398] alternatives: patching kernel code
[    0.146863] devtmpfs: initialized
[    0.155094] Enabled cp15_barrier support
[    0.155144] Enabled setend support
[    0.155525] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.155569] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.162095] pinctrl core: initialized pinctrl subsystem
[    0.162807] DMI not present or invalid.
[    0.163218] NET: Registered protocol family 16
[    0.164470] cpuidle: using governor menu
[    0.164920] vdso: 2 pages (1 code @ (____ptrval____), 1 data @ (____ptrval____))
[    0.164953] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.167481] DMA: preallocated 1024 KiB pool for atomic allocations
[    0.167643] Serial: AMBA PL011 UART driver
[    0.171046] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[    0.202194] bcm2835-dma fe007000.dma: DMA legacy API manager at (____ptrval____), dmachans=0x1
[    0.204500] vgaarb: loaded
[    0.204866] SCSI subsystem initialized
[    0.205078] usbcore: registered new interface driver usbfs
[    0.205149] usbcore: registered new interface driver hub
[    0.205270] usbcore: registered new device driver usb
[    0.205377] pps_core: LinuxPPS API ver. 1 registered
[    0.205398] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.205435] PTP clock support registered
[    0.212660] raspberrypi-firmware soc:firmware: Attached to firmware from 2019-10-21 16:47, variant start
[    0.216678] raspberrypi-firmware soc:firmware: Firmware hash is 8c7c951122d2cae572e891f04ddf287078ff2f11
[    0.222066] clocksource: Switched to clocksource arch_sys_counter
[    0.297569] VFS: Disk quotas dquot_6.6.0
[    0.297677] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.297852] FS-Cache: Loaded
[    0.298107] CacheFiles: Loaded
[    0.298697] simple-framebuffer: probe of 0.framebuffer failed with error -12
[    0.307488] NET: Registered protocol family 2
[    0.308203] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes)
[    0.308272] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[    0.308485] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[    0.309026] TCP: Hash tables configured (established 32768 bind 32768)
[    0.309224] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[    0.309297] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[    0.309558] NET: Registered protocol family 1
[    0.310331] RPC: Registered named UNIX socket transport module.
[    0.310359] RPC: Registered udp transport module.
[    0.310379] RPC: Registered tcp transport module.
[    0.310398] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.310426] PCI: CLS 0 bytes, default 64
[    0.310628] Trying to unpack rootfs image as initramfs...
[    0.802357] Freeing initrd memory: 7228K
[    0.811923] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[    0.813909] Initialise system trusted keyrings
[    0.814250] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[    0.821505] FS-Cache: Netfs 'nfs' registered for caching
[    0.822273] NFS: Registering the id_resolver key type
[    0.822324] Key type id_resolver registered
[    0.822344] Key type id_legacy registered
[    0.822374] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.822585] fuse init (API version 7.27)
[    0.825439] Key type asymmetric registered
[    0.825468] Asymmetric key parser 'x509' registered
[    0.825538] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[    0.825747] io scheduler noop registered (default)
[    0.825770] io scheduler deadline registered
[    0.825950] io scheduler cfq registered
[    0.825973] io scheduler mq-deadline registered
[    0.825992] io scheduler kyber registered
[    0.826033] io scheduler bfq registered
[    0.859168] brcm-pcie fd500000.pcie: dmabounce: initialised - 32768 kB, threshold 0x00000000c0000000
[    0.859221] brcm-pcie fd500000.pcie: could not get clock
[    0.859309] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[    0.859365] brcm-pcie fd500000.pcie:   MEM 0x600000000..0x603ffffff -> 0xf8000000
[    0.910105] brcm-pcie fd500000.pcie: link up, 5.0 Gbps x1 (!SSC)
[    0.910433] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[    0.910464] pci_bus 0000:00: root bus resource [bus 00-01]
[    0.910490] pci_bus 0000:00: root bus resource [mem 0x600000000-0x603ffffff] (bus address [0xf8000000-0xfbffffff])
[    0.910557] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[    0.910718] pci 0000:00:00.0: PME# supported from D0 D3hot
[    0.913841] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    0.914026] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[    0.914143] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[    0.914332] pci 0000:01:00.0: PME# supported from D0 D3cold
[    0.917284] pci_bus 0000:01: busn_res: [bus 01] end is updated to 01
[    0.917336] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[    0.917371] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[    0.917417] pci 0000:00:00.0: PCI bridge to [bus 01]
[    0.917446] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
[    0.917527] pci 0000:00:00.0: enabling device (0000 -> 0002)
[    0.917565] pci 0000:01:00.0: enabling device (0000 -> 0002)
[    0.920769] iproc-rng200 fe104000.rng: hwrng registered
[    0.921078] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[    0.921737] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[    0.922029] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    0.931706] brd: module loaded
[    0.941604] loop: module loaded
[    0.942499] Loading iSCSI transport class v2.0-870.
[    0.944334] libphy: Fixed MDIO Bus: probed
[    0.944814] bcmgenet fd580000.genet: failed to get enet clock
[    0.944845] bcmgenet fd580000.genet: GENET 5.0 EPHY: 0x0000
[    0.944874] bcmgenet fd580000.genet: failed to get enet-wol clock
[    0.944903] bcmgenet fd580000.genet: failed to get enet-eee clock
[    0.944936] bcmgenet: Skipping UMAC reset
[    0.945172] unimac-mdio unimac-mdio.-19: DMA mask not set
[    0.954097] libphy: bcmgenet MII bus: probed
[    0.984734] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus at 0x(____ptrval____)
[    0.985678] usbcore: registered new interface driver r8152
[    0.985746] usbcore: registered new interface driver lan78xx
[    0.985821] usbcore: registered new interface driver smsc95xx
[    0.986203] xhci_hcd 0000:01:00.0: xHCI Host Controller
[    0.986253] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[    0.991540] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000001000000890
[    0.991732] genirq: irq_chip Brcm_MSI did not update eff. affinity mask of irq 41
[    0.992346] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[    0.992378] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.992403] usb usb1: Product: xHCI Host Controller
[    0.992424] usb usb1: Manufacturer: Linux 4.19.80-1-MANJARO-ARM xhci-hcd
[    0.992447] usb usb1: SerialNumber: 0000:01:00.0
[    0.993010] hub 1-0:1.0: USB hub found
[    0.993077] hub 1-0:1.0: 1 port detected
[    0.993494] xhci_hcd 0000:01:00.0: xHCI Host Controller
[    0.993527] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[    0.993570] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[    0.993868] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[    0.993897] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.993922] usb usb2: Product: xHCI Host Controller
[    0.993942] usb usb2: Manufacturer: Linux 4.19.80-1-MANJARO-ARM xhci-hcd
[    0.993964] usb usb2: SerialNumber: 0000:01:00.0
[    0.994511] hub 2-0:1.0: USB hub found
[    0.994576] hub 2-0:1.0: 4 ports detected
[    0.995723] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    1.021364] dwc_otg fe980000.usb: base=(____ptrval____)
[    1.224365] Core Release: 2.80a
[    1.224389] Setting default values for core params
[    1.224428] Finished setting default values for core params
[    1.326083] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[    1.426924] Using Buffer DMA mode
[    1.426946] Periodic Transfer Interrupt Enhancement - disabled
[    1.426965] Multiprocessor Interrupt Enhancement - disabled
[    1.426986] OTG VER PARAM: 0, OTG VER FLAG: 0
[    1.427008] Dedicated Tx FIFOs mode
[    1.427486] WARN::dwc_otg_hcd_init:1043: FIQ DMA bounce buffers: virt = ffffff800b12c000 dma = 0x00000000de934000 len=9024
[    1.427537] FIQ FSM acceleration enabled for :
               Non-periodic Split Transactions
               Periodic Split Transactions
               High-Speed Isochronous Endpoints
               Interrupt/Control Split Transaction hack enabled
[    1.427586] dwc_otg: Microframe scheduler enabled
[    1.427727] WARN::hcd_init_fiq:496: MPHI regs_base at ffffff8009055200
[    1.427817] dwc_otg fe980000.usb: DWC OTG Controller
[    1.427852] dwc_otg fe980000.usb: new USB bus registered, assigned bus number 3
[    1.427900] dwc_otg fe980000.usb: irq 22, io mem 0x00000000
[    1.427964] Init: Port Power? op_state=1
[    1.427982] Init: Power Port (0)
[    1.428227] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[    1.428257] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.428282] usb usb3: Product: DWC OTG Controller
[    1.428303] usb usb3: Manufacturer: Linux 4.19.80-1-MANJARO-ARM dwc_otg_hcd
[    1.428325] usb usb3: SerialNumber: fe980000.usb
[    1.428845] hub 3-0:1.0: USB hub found
[    1.428906] hub 3-0:1.0: 1 port detected
[    1.429577] dwc_otg: FIQ enabled
[    1.429586] dwc_otg: NAK holdoff enabled
[    1.429594] dwc_otg: FIQ split-transaction FSM enabled
[    1.429606] Module dwc_common_port init
[    1.429826] usbcore: registered new interface driver uas
[    1.429956] usbcore: registered new interface driver usb-storage
[    1.430198] mousedev: PS/2 mouse device common for all mice
[    1.431222] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[    1.431444] bcm2835-cpufreq: min=600000 max=1500000
[    1.432123] sdhci: Secure Digital Host Controller Interface driver
[    1.432145] sdhci: Copyright(c) Pierre Ossman
[    1.432559] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
[    1.432965] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.437017] ledtrig-cpu: registered to indicate activity on CPUs
[    1.437094] hidraw: raw HID events driver (C) Jiri Kosina
[    1.437164] usbcore: registered new interface driver usbhid
[    1.437173] usbhid: USB HID core driver
[    1.437295] Initializing XFRM netlink socket
[    1.437313] NET: Registered protocol family 17
[    1.437377] Key type dns_resolver registered
[    1.437781] registered taskstats version 1
[    1.437794] Loading compiled-in X.509 certificates
[    1.440856] uart-pl011 fe201000.serial: cts_event_workaround enabled
[    1.440937] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 19, base_baud = 0) is a PL011 rev2
[    1.442979] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[    1.443255] brcmstb_thermal fd5d2200.thermal: registered AVS TMON of-sensor driver
[    1.443544] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[    1.443555] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[    1.469513] sdhci-iproc fe340000.emmc2: Linked as a consumer to regulator.1
[    1.475960] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.20
[    1.475993] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    1.476017] usb 1-1: Product: USB2.0 Hub
[    1.477514] hub 1-1:1.0: USB hub found
[    1.477784] hub 1-1:1.0: 4 ports detected
[    1.489925] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[    1.491553] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    1.493172] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    1.496066] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[    1.497681] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    1.501484] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
[    1.503917] of_cfs_init
[    1.504028] of_cfs_init: OK
[    1.507623] Freeing unused kernel memory: 960K
[    1.507841] Run /init as init process
[    1.542689] random: fast init done
[    1.559659] mmc1: new high speed SDIO card at address 0001
[    1.604373] mmc0: new ultra high speed DDR50 SDXC card at address aaaa
[    1.609720] mmcblk0: mmc0:aaaa SN128 119 GiB
[    1.619118]  mmcblk0: p1 p2
[    2.011491] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    2.405310] systemd[1]: System time before build time, advancing clock.
[    2.513301] NET: Registered protocol family 10
[    2.513912] Segment Routing with IPv6
[    2.542190] systemd[1]: systemd 243.78-1-arch running in system mode. (+PAM +AUDIT -SELINUX -IMA -APPARMOR +SMACK -SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[    2.542903] systemd[1]: Detected architecture arm64.
[    2.554261] systemd[1]: Set hostname to <dragonpi>.
[    3.023961] systemd[1]: Configuration file /usr/lib/systemd/system/attach-bluetooth.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[    3.073712] random: systemd: uninitialized urandom read (16 bytes read)
[    3.073815] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[    3.073832] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[    3.075551] systemd[1]: Created slice system-getty.slice.
[    3.075882] random: systemd: uninitialized urandom read (16 bytes read)
[    3.076387] systemd[1]: Created slice User and Session Slice.
[    3.076571] random: systemd: uninitialized urandom read (16 bytes read)
[    3.076712] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    3.076990] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    3.629005] systemd-journald[163]: Received client request to flush runtime journal.
[    3.645747] systemd-journald[163]: File /var/log/journal/f23f6b9f8bae4974aec93685c2b25498/system.journal corrupted or uncleanly shut down, renaming and replacing.
[    3.852396] random: crng init done
[    3.852420] random: 7 urandom warning(s) missed due to ratelimiting
[    3.903099] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x0000ffff
[    3.903335] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00000fff
[    3.903539] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x0000ffff
[    3.903756] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x0000ffff
[    3.908617] vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[    3.925591] vchiq: vchiq_init_state: slot_zero = 00000000d4491332, is_master = 0
[    4.048324] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[    4.080897] bcm2835_audio soc:audio: card created with 8 channels
[    4.135204] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[    4.137664] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[    4.137689] [vc_sm_connected_init]: start
[    4.138772] [vc_sm_connected_init]: installed successfully
[    4.152486] media: Linux media interface: v0.10
[    4.175637] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
[    4.188027] videodev: Linux video capture interface: v2.00
[    4.282568] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    4.283576] [drm] No displays found. Consider forcing hotplug if HDMI is attached
[    4.283634] vc4-drm soc:gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
[    4.283961] [drm] Initialized vc4 0.0.0 20140616 for soc:gpu on minor 1
[    4.283978] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    4.283986] [drm] No driver support for vblank timestamp query.
[    4.283994] [drm] Setting vblank_disable_immediate to false because get_vblank_timestamp == NULL
[    4.298947] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[    4.311792] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[    4.316980] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[    4.322129] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[    4.322165] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[    4.325090] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[    4.325124] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[    4.326872] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    4.327822] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[    4.327855] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[    4.341254] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[    4.341285] cfg80211: failed to load regulatory.db
[    4.371515] brcmfmac: F1 signature read @0x18000000=0x15264345
[    4.375640] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[    4.376084] usbcore: registered new interface driver brcmfmac
[    4.498828] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[    4.573480] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[    4.587900] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Feb 27 2018 03:15:32 version 7.45.154 (r684107 CY) FWID 01-4fbe0b04
[    5.013849] uart-pl011 fe201000.serial: no DMA platform data
[    6.272507] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[    6.272703] bcmgenet: Skipping UMAC reset
[    6.342633] bcmgenet fd580000.genet: configuring instance for external RGMII (no delay)
[    6.343465] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[    6.359775] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[    6.386408] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[    6.386448] brcmfmac: power management disabled
[    6.914800] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[    6.915035] brcmfmac: power management disabled
[    7.162426] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[    7.358317] bcmgenet fd580000.genet eth0: Link is Down
[   10.279714] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   10.279960] brcmfmac: power management disabled
[   10.299431] Bluetooth: Core ver 2.22
[   10.299505] NET: Registered protocol family 31
[   10.299515] Bluetooth: HCI device and connection manager initialized
[   10.299532] Bluetooth: HCI socket layer initialized
[   10.299545] Bluetooth: L2CAP socket layer initialized
[   10.299569] Bluetooth: SCO socket layer initialized
[   10.311383] Bluetooth: HCI UART driver ver 2.3
[   10.311404] Bluetooth: HCI UART protocol H4 registered
[   10.311457] Bluetooth: HCI UART protocol Three-wire (H5) registered
[   10.311581] Bluetooth: HCI UART protocol Broadcom registered
[   10.404866] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   10.404905] Bluetooth: BNEP filters: protocol multicast
[   10.404941] Bluetooth: BNEP socket layer initialized
[   10.417764] NET: Registered protocol family 38
[   10.437347] cryptd: max_cpu_qlen set to 1000
[   15.506016] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[   17.028031] brcmfmac: power management disabled
systemctl status bluetooth.service
● bluetooth.service - Bluetooth service
   Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; vendor preset: disabled)
   Active: active (running) since Tue 2019-10-29 12:46:33 AEDT; 4h 58min ago
     Docs: man:bluetoothd(8)
 Main PID: 338 (bluetoothd)
    Tasks: 1 (limit: 4267)
   Memory: 2.3M
   CGroup: /system.slice/bluetooth.service
           └─338 /usr/lib/bluetooth/bluetoothd
Oct 29 12:46:33 dragonpi systemd[1]: Starting Bluetooth service...
Oct 29 12:46:33 dragonpi bluetoothd[338]: Bluetooth daemon 5.51
Oct 29 12:46:33 dragonpi systemd[1]: Started Bluetooth service.
Oct 29 12:46:33 dragonpi bluetoothd[338]: Starting SDP server
Oct 29 12:46:33 dragonpi bluetoothd[338]: Bluetooth management interface 1.14 initialized
Oct 29 17:38:51 dragonpi bluetoothd[338]: Server error, bridge not initialized: (0x1116)
Oct 29 17:38:51 dragonpi bluetoothd[338]: BNEP server cannot be added
Quick update - looks like sometimes the class desn't revert completely during logout and shows as class 0x001c0000
I didn't see this in prior testing. After reboot it's always 0x0
Notice that UUID: NAP (00001116-0000-1000-8000-00805f9b34fb) is missing in either class mode
bluetoothctl > show Pre GUI login
Controller DC:A6:32:3D:14:3E (public)
        Alias: dragonpi
        Class: 0x00000000
        Powered: yes
        Discoverable: no
        DiscoverableTimeout: 0x000000b4
        Pairable: yes
        UUID: Generic Attribute Profile (00001801-0000-1000-8000-00805f9b34fb)
        UUID: Generic Access Profile    (00001800-0000-1000-8000-00805f9b34fb)
        UUID: PnP Information           (00001200-0000-1000-8000-00805f9b34fb)
        UUID: A/V Remote Control Target (0000110c-0000-1000-8000-00805f9b34fb)
        UUID: A/V Remote Control        (0000110e-0000-1000-8000-00805f9b34fb)
        Modalias: usb:v1D6Bp0246d0533
        Discovering: no
Advertising Features:
        ActiveInstances: 0x00
        SupportedInstances: 0x05
        SupportedIncludes: tx-power
        SupportedIncludes: appearance
        SupportedIncludes: local-name
bluetoothctl > during GUI login
[CHG] Controller DC:A6:32:3D:14:3E Class: 0x00040000
[CHG] Controller DC:A6:32:3D:14:3E UUIDs: 0000110a-0000-1000-8000-00805f9b34fb
[CHG] Controller DC:A6:32:3D:14:3E UUIDs: 00001801-0000-1000-8000-00805f9b34fb
[CHG] Controller DC:A6:32:3D:14:3E UUIDs: 00001800-0000-1000-8000-00805f9b34fb
[CHG] Controller DC:A6:32:3D:14:3E UUIDs: 00001200-0000-1000-8000-00805f9b34fb
[CHG] Controller DC:A6:32:3D:14:3E UUIDs: 0000110c-0000-1000-8000-00805f9b34fb
[CHG] Controller DC:A6:32:3D:14:3E UUIDs: 0000110e-0000-1000-8000-00805f9b34fb
[CHG] Controller DC:A6:32:3D:14:3E UUIDs: 0000110b-0000-1000-8000-00805f9b34fb
[CHG] Controller DC:A6:32:3D:14:3E Class: 0x000c0000
[CHG] Controller DC:A6:32:3D:14:3E UUIDs: 00001112-0000-1000-8000-00805f9b34fb
[CHG] Controller DC:A6:32:3D:14:3E UUIDs: 00001108-0000-1000-8000-00805f9b34fb
[CHG] Controller DC:A6:32:3D:14:3E UUIDs: 00001133-0000-1000-8000-00805f9b34fb
[CHG] Controller DC:A6:32:3D:14:3E UUIDs: 00001105-0000-1000-8000-00805f9b34fb
[CHG] Controller DC:A6:32:3D:14:3E UUIDs: 00001132-0000-1000-8000-00805f9b34fb
[CHG] Controller DC:A6:32:3D:14:3E UUIDs: 00001104-0000-1000-8000-00805f9b34fb
[CHG] Controller DC:A6:32:3D:14:3E UUIDs: 00005005-0000-1000-8000-0002ee000001
[CHG] Controller DC:A6:32:3D:14:3E UUIDs: 0000112f-0000-1000-8000-00805f9b34fb
[CHG] Controller DC:A6:32:3D:14:3E UUIDs: 00001106-0000-1000-8000-00805f9b34fb
[CHG] Controller DC:A6:32:3D:14:3E Class: 0x001c0000
[CHG] Controller DC:A6:32:3D:14:3E Class: 0x001e0000
[CHG] Controller DC:A6:32:3D:14:3E UUIDs: 00001116-0000-1000-8000-00805f9b34fb
bluetoothctl > show Post GUI login
        Alias: dragonpi
        Class: 0x001e0000
        Powered: yes
        Discoverable: no
        Pairable: yes
        UUID: Message Notification Se.. (00001133-0000-1000-8000-00805f9b34fb)
        UUID: OBEX Object Push          (00001105-0000-1000-8000-00805f9b34fb)
        UUID: Message Access Server     (00001132-0000-1000-8000-00805f9b34fb)
        UUID: IrMC Sync                 (00001104-0000-1000-8000-00805f9b34fb)
        UUID: Vendor specific           (00005005-0000-1000-8000-0002ee000001)
        UUID: Headset AG                (00001112-0000-1000-8000-00805f9b34fb)
        UUID: Phonebook Access Server   (0000112f-0000-1000-8000-00805f9b34fb)
        UUID: Audio Sink                (0000110b-0000-1000-8000-00805f9b34fb)
        UUID: Headset                   (00001108-0000-1000-8000-00805f9b34fb)
        UUID: Audio Source              (0000110a-0000-1000-8000-00805f9b34fb)
        UUID: OBEX File Transfer        (00001106-0000-1000-8000-00805f9b34fb)
        Discovering: no
bluetoothctl > during GUI logout
bluetoothctl > show post GUI logout
        Alias: dragonpi
        Class: 0x001c0000
        Powered: yes
        Discoverable: no
        Pairable: yes
        Discovering: no
