Issue creating a kvm image
I am trying to create a aarch64 image in my Manjaro workstation.
I have found the following repo:
and I am trying to adjust it to Manjaro.
I am now still using an ArchLinux image but the problem I am having it is not regarding the image.
Consider the following steps:
Showing path and id:
downloading images:
creating raw image file:
partitioning the file:
creating the filesystems:
mounting:
copying distro:
trying to append to fstab file:
what is the reason I am getting permission denied if I am using sudo and file has ‘rw’ permission to owner?
sudo command can’t handle >> redirection, you should use other method, with tee for example:
echo "test" | sudo tee -a /mnt/kvm/root/fstab
And you are right @Tomek !
Thanks!
