Issue Booting into ISO
Hello i am a little new to linux but have some knowledge on it.
I am trying to boot into manjaro iso from my usb and i get the error Security boot failed.
If and can fix this then please reply.
Thanks
Robin / Ilikefivem
You have to disable Secure Boot in order to boot from the ISO and later into the installed system.
This can be done in the UEFI of your system.
This topic was automatically closed 24 hours after the last reply. New replies are no longer allowed.
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or :heart: or :+1: if you agree)
:innocent:
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
Solution
