Issue after newest Update booting
Okay so yesterday I installed the newest updates. But when I rebooted the only thing I see is the Boot screen of Manjaro and after 1-2 seconds just my UEFI logo where it then stucks. When I press the power button again. The Manjaro Boot logo appears again and the Notebook shuts it self down. I used a live usb stick to get into chroot and changed my grub config so that there is no quiet attribute. When I restarted I see some text for a second (it is way to fast to see something) and then just a blinking cursor where it keeps stucking again (I assume that the blinking cursor is the part where I just got displayed the UEFI logo).
I was able to restore my system using a live usb stick and Timeshift but now idk what to do with the update.
I fixed it using After update Manjaro won't boot to Gnome Login - #3 by kaiWizardly
  1. I’ve marked this answer as the solution to your question as it is by far the best answer you’ll get.
    Issue after newest Update booting - #2 by itzyanick
    However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or :heart: or :+1: if you agree)
  2. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
    Solution
  3. Please, please, please read this
:scream:
