I haven’t followed pinephone things since around the original pinephone launch so I might just be out of the loop.
Recieved PPP today and updated mirrors then system via pacman -Syyu
During the update I get a Y/N prompt asking if I want to replace kwayland
with kwin
. I select no as I thought it was trying to install the default plasma window manager. (couldn’t find any information so I had to go with my assumtion)
After, everything seems fine with the exception of the lock screen, when locked and attempting to wake I get a text message on screen that is too large to read but it says something along the lines of “broken lock-screen” and something about a virtual terminal (I can tell it’s instructions on how to recover, I just cant read it) .
Turning the screen off and on then presents me with (vanilla?) SDDM but I can not log in from here as there is no virtual keyboard for user input. A reboot is required to recover from here.
So my question is 1) Is this lock-screen behavior related to my window manager decision during the upgrade? or 2) A common bug everyone is dealing with.
Edit: As an aside, plasma mobile has come a long way!
The relevant logs, directly monitored with jounalctl -f via SSH
From locking to lock-screen crash:
Jul 28 16:12:21 manjaro-arm systemd-logind[3513]: Power key pressed short.
Jul 28 16:12:22 manjaro-arm kernel: panel-himax-hx8394 ff960000.mipi.0: disable
Jul 28 16:12:22 manjaro-arm kernel: dw-mipi-dsi-rockchip ff960000.mipi: disable
Jul 28 16:12:22 manjaro-arm kernel: dw-mipi-dsi-rockchip ff960000.mipi: post disable
Jul 28 16:12:22 manjaro-arm kernel: dw-mipi-dsi-rockchip ff960000.mipi: mode 0
Jul 28 16:12:22 manjaro-arm kernel: panel-himax-hx8394 ff960000.mipi.0: unprepare
Jul 28 16:12:22 manjaro-arm kwin_wayland_wrapper[3730]: not a valid new object id (2), message get_registry(n)
Jul 28 16:12:22 manjaro-arm kwin_wayland_wrapper[3730]: error in client communication (pid 3730)
Jul 28 16:12:22 manjaro-arm kwin_wayland_wrapper[4102]: wl_display@1: error 1: invalid arguments for wl_display@1.get_registry
Jul 28 16:12:22 manjaro-arm kscreenlocker_greet[4102]: qt.qpa.wayland: Creating a fake screen in order for Qt not to crash
Jul 28 16:12:22 manjaro-arm kscreenlocker_greet[4102]: The Wayland connection experienced a fatal error: Invalid argument
Jul 28 16:12:23 manjaro-arm kscreenlocker_greet[4105]: qt.qpa.wayland: Creating a fake screen in order for Qt not to crash
Jul 28 16:12:23 manjaro-arm kscreenlocker_greet[4105]: The Wayland connection broke. Did the Wayland compositor die?
Jul 28 16:12:23 manjaro-arm systemd-logind[3513]: Power key pressed short.
Jul 28 16:12:23 manjaro-arm kernel: dw-mipi-dsi-rockchip ff960000.mipi: mode set
Jul 28 16:12:23 manjaro-arm kernel: panel-himax-hx8394 ff960000.mipi.0: prepare
Jul 28 16:12:23 manjaro-arm kernel: dw-mipi-dsi-rockchip ff960000.mipi: pre enable
Jul 28 16:12:23 manjaro-arm kernel: dw-mipi-dsi-rockchip ff960000.mipi: dw_mipi_dsi_phy_init / dw_mipi_dsi_rockchip_config: 00006258 => set=ffff0000
Jul 28 16:12:23 manjaro-arm kernel: dw-mipi-dsi-rockchip ff960000.mipi: mode 0
Jul 28 16:12:23 manjaro-arm kernel: dw-mipi-dsi-rockchip ff960000.mipi: enable
Jul 28 16:12:23 manjaro-arm kernel: dw-mipi-dsi-rockchip ff960000.mipi: mode 1
Jul 28 16:12:23 manjaro-arm kernel: panel-himax-hx8394 ff960000.mipi.0: enable
Jul 28 16:12:23 manjaro-arm kscreenlocker_greet[4108]: qt.qpa.wayland: Creating a fake screen in order for Qt not to crash
Jul 28 16:12:23 manjaro-arm kscreenlocker_greet[4108]: The Wayland connection broke. Did the Wayland compositor die?
Jul 28 16:12:33 manjaro-arm eg25-manager[3506]: Rescheduling upload since Location interface is not available, in 30s
From crash screen to SDDM (Sorry if overkill)
Jul 28 16:12:40 manjaro-arm upowerd[3761]: energy_full (12.620448) is greater than energy_full_design (0.000000)
Jul 28 16:12:40 manjaro-arm upowerd[3761]: Setting /sys/devices/platform/ff3c0000.i2c/i2c-0/0-001c/rk818-charger/power_supply/rk818-usb state empty as unknown and very low
Jul 28 16:13:03 manjaro-arm eg25-manager[3506]: Rescheduling upload since Location interface is not available, in 30s
Jul 28 16:13:10 manjaro-arm upowerd[3761]: energy_full (12.620448) is greater than energy_full_design (0.000000)
Jul 28 16:13:10 manjaro-arm upowerd[3761]: Setting /sys/devices/platform/ff3c0000.i2c/i2c-0/0-001c/rk818-charger/power_supply/rk818-usb state empty as unknown and very low
Jul 28 16:13:13 manjaro-arm eg25-manager[3506]: Modem is up for 120 seconds and fully ready
Jul 28 16:13:13 manjaro-arm eg25-manager[3506]: dropping systemd sleep block inhibitor
Jul 28 16:13:16 manjaro-arm systemd-networkd-wait-online[4003]: Timeout occurred while waiting for network connectivity.
Jul 28 16:13:16 manjaro-arm systemd[1]: systemd-networkd-wait-online.service: Main process exited, code=exited, status=1/FAILURE
Jul 28 16:13:16 manjaro-arm systemd[1]: systemd-networkd-wait-online.service: Failed with result 'exit-code'.
Jul 28 16:13:16 manjaro-arm systemd[1]: Failed to start Wait for Network to be Configured.
Jul 28 16:13:16 manjaro-arm systemd[1]: Reached target Network is Online.
Jul 28 16:13:33 manjaro-arm eg25-manager[3506]: Rescheduling upload since Location interface is not available, in 30s
Jul 28 16:13:40 manjaro-arm upowerd[3761]: energy_full (12.620448) is greater than energy_full_design (0.000000)
Jul 28 16:13:40 manjaro-arm upowerd[3761]: Setting /sys/devices/platform/ff3c0000.i2c/i2c-0/0-001c/rk818-charger/power_supply/rk818-usb state empty as unknown and very low
Jul 28 16:14:03 manjaro-arm eg25-manager[3506]: Rescheduling upload since Location interface is not available, in 30s
Jul 28 16:14:10 manjaro-arm upowerd[3761]: energy_full (12.620448) is greater than energy_full_design (0.000000)
Jul 28 16:14:10 manjaro-arm upowerd[3761]: Setting /sys/devices/platform/ff3c0000.i2c/i2c-0/0-001c/rk818-charger/power_supply/rk818-usb state empty as unknown and very low
Jul 28 16:14:13 manjaro-arm kernel: panel-himax-hx8394 ff960000.mipi.0: disable
Jul 28 16:14:14 manjaro-arm kernel: dw-mipi-dsi-rockchip ff960000.mipi: disable
Jul 28 16:14:14 manjaro-arm kernel: dw-mipi-dsi-rockchip ff960000.mipi: post disable
Jul 28 16:14:14 manjaro-arm kernel: dw-mipi-dsi-rockchip ff960000.mipi: mode 0
Jul 28 16:14:14 manjaro-arm kernel: panel-himax-hx8394 ff960000.mipi.0: unprepare
Jul 28 16:14:20 manjaro-arm kernel: rk818-bat: new offset:c=0x860, i=0x843, p=0x1d
Jul 28 16:14:33 manjaro-arm eg25-manager[3506]: Rescheduling upload since Location interface is not available, in 30s
Jul 28 16:14:40 manjaro-arm upowerd[3761]: energy_full (12.325932) is greater than energy_full_design (0.000000)
Jul 28 16:14:40 manjaro-arm upowerd[3761]: Setting /sys/devices/platform/ff3c0000.i2c/i2c-0/0-001c/rk818-charger/power_supply/rk818-usb state empty as unknown and very low
Jul 28 16:15:03 manjaro-arm eg25-manager[3506]: Rescheduling upload since Location interface is not available, in 30s
Jul 28 16:15:10 manjaro-arm upowerd[3761]: energy_full (12.317184) is greater than energy_full_design (0.000000)
Jul 28 16:15:10 manjaro-arm upowerd[3761]: Setting /sys/devices/platform/ff3c0000.i2c/i2c-0/0-001c/rk818-charger/power_supply/rk818-usb state empty as unknown and very low
Jul 28 16:15:33 manjaro-arm eg25-manager[3506]: Rescheduling upload since Location interface is not available, in 30s
Jul 28 16:15:40 manjaro-arm upowerd[3761]: energy_full (12.311352) is greater than energy_full_design (0.000000)
Jul 28 16:15:40 manjaro-arm upowerd[3761]: Setting /sys/devices/platform/ff3c0000.i2c/i2c-0/0-001c/rk818-charger/power_supply/rk818-usb state empty as unknown and very low
Jul 28 16:15:43 manjaro-arm dbus-daemon[3505]: [system] Activating service name='org.kde.powerdevil.backlighthelper' requested by ':1.38' (uid=1000 pid=3847 comm="/usr/lib/org_kde_powerdevil") (using servicehelper)
Jul 28 16:15:44 manjaro-arm dbus-daemon[3505]: [system] Successfully activated service 'org.kde.powerdevil.backlighthelper'
Jul 28 16:16:03 manjaro-arm eg25-manager[3506]: Rescheduling upload since Location interface is not available, in 30s
Jul 28 16:16:10 manjaro-arm upowerd[3761]: energy_full (12.311352) is greater than energy_full_design (0.000000)
Jul 28 16:16:10 manjaro-arm upowerd[3761]: Setting /sys/devices/platform/ff3c0000.i2c/i2c-0/0-001c/rk818-charger/power_supply/rk818-usb state empty as unknown and very low
Jul 28 16:16:15 manjaro-arm PackageKit[4002]: uid 1000 is trying to obtain org.freedesktop.packagekit.system-sources-refresh auth (only_trusted:0)
Jul 28 16:16:15 manjaro-arm PackageKit[4002]: uid 1000 obtained auth for org.freedesktop.packagekit.system-sources-refresh
Jul 28 16:16:15 manjaro-arm PackageKit[4002]: refresh-cache transaction /3_cbbbebda from uid 1000 finished with success after 13ms
Jul 28 16:16:19 manjaro-arm PackageKit[4002]: get-updates transaction /4_edaaabda from uid 1000 finished with success after 3302ms
Jul 28 16:16:27 manjaro-arm kernel: dw-mipi-dsi-rockchip ff960000.mipi: mode set
Jul 28 16:16:27 manjaro-arm kernel: panel-himax-hx8394 ff960000.mipi.0: prepare
Jul 28 16:16:27 manjaro-arm dbus-daemon[3505]: [system] Activating service name='org.kde.powerdevil.backlighthelper' requested by ':1.38' (uid=1000 pid=3847 comm="/usr/lib/org_kde_powerdevil") (using servicehelper)
Jul 28 16:16:28 manjaro-arm kernel: dw-mipi-dsi-rockchip ff960000.mipi: pre enable
Jul 28 16:16:28 manjaro-arm kernel: dw-mipi-dsi-rockchip ff960000.mipi: dw_mipi_dsi_phy_init / dw_mipi_dsi_rockchip_config: 00006258 => set=ffff0000
Jul 28 16:16:28 manjaro-arm kernel: dw-mipi-dsi-rockchip ff960000.mipi: mode 0
Jul 28 16:16:28 manjaro-arm kernel: dw-mipi-dsi-rockchip ff960000.mipi: enable
Jul 28 16:16:28 manjaro-arm kernel: dw-mipi-dsi-rockchip ff960000.mipi: mode 1
Jul 28 16:16:28 manjaro-arm kernel: panel-himax-hx8394 ff960000.mipi.0: enable
Jul 28 16:16:28 manjaro-arm dbus-daemon[3505]: [system] Successfully activated service 'org.kde.powerdevil.backlighthelper'
Jul 28 16:16:33 manjaro-arm eg25-manager[3506]: Rescheduling upload since Location interface is not available, in 30s
Jul 28 16:16:40 manjaro-arm upowerd[3761]: energy_full (12.308436) is greater than energy_full_design (0.000000)
Jul 28 16:16:40 manjaro-arm upowerd[3761]: Setting /sys/devices/platform/ff3c0000.i2c/i2c-0/0-001c/rk818-charger/power_supply/rk818-usb state empty as unknown and very low
Jul 28 16:16:44 manjaro-arm systemd-logind[3513]: Power key pressed short.
Jul 28 16:16:44 manjaro-arm kernel: panel-himax-hx8394 ff960000.mipi.0: disable
Jul 28 16:16:44 manjaro-arm kernel: dw-mipi-dsi-rockchip ff960000.mipi: disable
Jul 28 16:16:44 manjaro-arm kernel: dw-mipi-dsi-rockchip ff960000.mipi: post disable
Jul 28 16:16:44 manjaro-arm kernel: dw-mipi-dsi-rockchip ff960000.mipi: mode 0
Jul 28 16:16:44 manjaro-arm kernel: panel-himax-hx8394 ff960000.mipi.0: unprepare
Jul 28 16:16:44 manjaro-arm systemd[3664]: plasma-kwin_wayland.service: Main process exited, code=killed, status=10/USR1
Jul 28 16:16:44 manjaro-arm systemd[3664]: Stopped target plasma-workspace-wayland.target.
Jul 28 16:16:44 manjaro-arm systemd[3664]: Stopped target KDE Plasma Workspace.
Jul 28 16:16:44 manjaro-arm systemd[3664]: Stopped target Startup of XDG autostart applications.
Jul 28 16:16:44 manjaro-arm systemd[3664]: Stopping Geoclue Demo agent...
Jul 28 16:16:44 manjaro-arm systemd[3664]: Stopping Calindori Reminder Client...
Jul 28 16:16:44 manjaro-arm systemd[3664]: Stopping Discover...
Jul 28 16:16:44 manjaro-arm systemd[3664]: Stopping KDE Connect...
Jul 28 16:16:44 manjaro-arm systemd[3664]: Stopping Modem Daemon Service...
Jul 28 16:16:44 manjaro-arm systemd[3664]: Stopping Spacebar background service...
Jul 28 16:16:44 manjaro-arm xembedsniproxy[3848]: The X11 connection broke (error 1). Did the X11 server die?
Jul 28 16:16:44 manjaro-arm ksmserver[3794]: The X11 connection broke (error 1). Did the X11 server die?
Jul 28 16:16:44 manjaro-arm systemd[3664]: Stopping Telephony Daemon Service...
Jul 28 16:16:44 manjaro-arm systemd[3664]: Stopping Baloo File Indexer Daemon...
Jul 28 16:16:44 manjaro-arm systemd[3664]: Stopping Proxies GTK DBus menus to a Plasma readable format...
Jul 28 16:16:44 manjaro-arm systemd[3664]: Stopping KActivityManager Activity manager Service...
Jul 28 16:16:44 manjaro-arm systemd[3664]: Stopping KDE PolicyKit Authentication Agent...
Jul 28 16:16:44 manjaro-arm systemd[3664]: Stopping Powerdevil...
Jul 28 16:16:44 manjaro-arm systemd[3664]: Stopping Handle legacy xembed system tray icons...
Jul 28 16:16:44 manjaro-arm systemd[3664]: plasma-xembedsniproxy.service: Main process exited, code=exited, status=1/FAILURE
Jul 28 16:16:44 manjaro-arm systemd[3664]: plasma-xembedsniproxy.service: Failed with result 'exit-code'.
Jul 28 16:16:44 manjaro-arm systemd[3664]: Stopped Handle legacy xembed system tray icons.
Jul 28 16:16:44 manjaro-arm kded5[3796]: Service ":1.36" unregistered
Jul 28 16:16:44 manjaro-arm polkitd[3512]: Unregistered Authentication Agent for unix-session:c1 (system bus name :1.41, object path /org/kde/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8) (disconnected from bus)
Jul 28 16:16:44 manjaro-arm systemd[3664]: Stopped KDE Connect.
Jul 28 16:16:44 manjaro-arm systemd[3664]: plasma-ksmserver.service: Main process exited, code=exited, status=1/FAILURE
Jul 28 16:16:44 manjaro-arm systemd[3664]: plasma-ksmserver.service: Failed with result 'exit-code'.
Jul 28 16:16:44 manjaro-arm systemd[3664]: Stopped KDE Session Management Server.
Jul 28 16:16:44 manjaro-arm plasmashell[3818]: The Wayland connection broke. Did the Wayland compositor die?
Jul 28 16:16:44 manjaro-arm kded5[3796]: The Wayland connection broke. Did the Wayland compositor die?
Jul 28 16:16:44 manjaro-arm systemd[3664]: Stopped Baloo File Indexer Daemon.
Jul 28 16:16:44 manjaro-arm kwalletd5[3685]: The Wayland connection broke. Did the Wayland compositor die?
Jul 28 16:16:44 manjaro-arm systemd[3664]: Stopped Proxies GTK DBus menus to a Plasma readable format.
Jul 28 16:16:44 manjaro-arm systemd[3664]: Stopped KDE PolicyKit Authentication Agent.
Jul 28 16:16:44 manjaro-arm systemd[3664]: Stopped Modem Daemon Service.
Jul 28 16:16:44 manjaro-arm systemd[3664]: Stopped Spacebar background service.
Jul 28 16:16:44 manjaro-arm qmlkonsole[4045]: The Wayland connection broke. Did the Wayland compositor die?
Jul 28 16:16:44 manjaro-arm systemd[3664]: Stopped Telephony Daemon Service.
Jul 28 16:16:44 manjaro-arm systemd[3664]: Stopped KActivityManager Activity manager Service.
Jul 28 16:16:44 manjaro-arm systemd[3664]: Stopped Geoclue Demo agent.
Jul 28 16:16:44 manjaro-arm kernel: dw-mipi-dsi-rockchip ff960000.mipi: mode set
Jul 28 16:16:44 manjaro-arm kernel: panel-himax-hx8394 ff960000.mipi.0: prepare
Jul 28 16:16:44 manjaro-arm systemd[3664]: Stopped Calindori Reminder Client.
Jul 28 16:16:44 manjaro-arm systemd[3664]: Stopped Powerdevil.
Jul 28 16:16:44 manjaro-arm systemd[3664]: plasma-powerdevil.service: Consumed 1.305s CPU time.
Jul 28 16:16:44 manjaro-arm systemd[3664]: Stopped Discover.
Jul 28 16:16:44 manjaro-arm systemd[3664]: Stopped target Current graphical user session.
Jul 28 16:16:44 manjaro-arm systemd[3664]: Stopped target KDE Plasma Workspace Core.
Jul 28 16:16:44 manjaro-arm systemd[3664]: Stopping KDE Plasma Workspace...
Jul 28 16:16:44 manjaro-arm systemd[3664]: Stopped target Session services which should run early before the graphical session is brought up.
Jul 28 16:16:44 manjaro-arm systemd[3664]: plasma-kded.service: Main process exited, code=exited, status=1/FAILURE
Jul 28 16:16:44 manjaro-arm systemd[3664]: plasma-kded.service: Failed with result 'exit-code'.
Jul 28 16:16:44 manjaro-arm systemd[3664]: Stopped KDE Daemon.
Jul 28 16:16:44 manjaro-arm systemd[3664]: plasma-kded.service: Consumed 1.530s CPU time.
Jul 28 16:16:44 manjaro-arm systemd[3664]: plasma-kwin_wayland.service: Failed with result 'signal'.
Jul 28 16:16:44 manjaro-arm systemd[3664]: Stopped KDE Window Manager.
Jul 28 16:16:44 manjaro-arm systemd[3664]: plasma-kwin_wayland.service: Consumed 17.269s CPU time.
Jul 28 16:16:45 manjaro-arm sddm-helper[3658]: [PAM] Closing session
Jul 28 16:16:45 manjaro-arm sddm-helper[3658]: pam_unix(sddm-autologin:session): session closed for user phoner
Jul 28 16:16:45 manjaro-arm systemd[3664]: app-org.kde.mobile.qmlkonsole-091e242af05a4f51aa1b27d87d4387f3.scope: Consumed 2.582s CPU time.
Jul 28 16:16:45 manjaro-arm systemd[3664]: plasma-plasmashell.service: Main process exited, code=exited, status=1/FAILURE
Jul 28 16:16:45 manjaro-arm systemd[3664]: plasma-plasmashell.service: Failed with result 'exit-code'.
Jul 28 16:16:45 manjaro-arm systemd[3664]: Stopped KDE Plasma Workspace.
Jul 28 16:16:45 manjaro-arm systemd[3664]: plasma-plasmashell.service: Consumed 10.947s CPU time.
Jul 28 16:16:45 manjaro-arm kernel: dw-mipi-dsi-rockchip ff960000.mipi: pre enable
Jul 28 16:16:45 manjaro-arm kernel: dw-mipi-dsi-rockchip ff960000.mipi: dw_mipi_dsi_phy_init / dw_mipi_dsi_rockchip_config: 00006258 => set=ffff0000
Jul 28 16:16:45 manjaro-arm kernel: dw-mipi-dsi-rockchip ff960000.mipi: mode 0
Jul 28 16:16:45 manjaro-arm kernel: dw-mipi-dsi-rockchip ff960000.mipi: enable
Jul 28 16:16:45 manjaro-arm kernel: dw-mipi-dsi-rockchip ff960000.mipi: mode 1
Jul 28 16:16:45 manjaro-arm kernel: panel-himax-hx8394 ff960000.mipi.0: enable
Jul 28 16:16:45 manjaro-arm systemd-logind[3513]: Power key pressed short.
Jul 28 16:16:45 manjaro-arm sddm-helper[3658]: pam_kwallet5(sddm-autologin:session): pam_kwallet5: pam_sm_close_session
Jul 28 16:16:45 manjaro-arm sddm-helper[3658]: pam_kwallet5(sddm-autologin:setcred): pam_kwallet5: pam_sm_setcred
Jul 28 16:16:45 manjaro-arm sddm-helper[3658]: [PAM] Ended.
Jul 28 16:16:45 manjaro-arm sddm[3611]: Auth: sddm-helper exited successfully
Jul 28 16:16:45 manjaro-arm sddm[3611]: Display server stopping...
Jul 28 16:16:45 manjaro-arm systemd[1]: session-c1.scope: Deactivated successfully.
Jul 28 16:16:45 manjaro-arm systemd[1]: session-c1.scope: Consumed 2.157s CPU time.
Jul 28 16:16:45 manjaro-arm systemd-logind[3513]: Session c1 logged out. Waiting for processes to exit.
Jul 28 16:16:45 manjaro-arm systemd-logind[3513]: Removed session c1.
Jul 28 16:16:45 manjaro-arm sddm[3611]: Display server stopped.
Jul 28 16:16:45 manjaro-arm sddm[3611]: Running display stop script "/usr/share/sddm/scripts/Xstop"
Jul 28 16:16:45 manjaro-arm sddm[3611]: Removing display ":0" ...
Jul 28 16:16:45 manjaro-arm sddm[3611]: Adding new display on vt 1 ...
Jul 28 16:16:45 manjaro-arm sddm[3611]: Loading theme configuration from ""
Jul 28 16:16:45 manjaro-arm sddm[3611]: Display server starting...
Jul 28 16:16:45 manjaro-arm sddm[3611]: Adding cookie to "/var/run/sddm/{07ac1f40-dba2-48e8-9c76-69071c9b2b8e}"
Jul 28 16:16:45 manjaro-arm sddm[3611]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt1 -auth /var/run/sddm/{07ac1f40-dba2-48e8-9c76-69071c9b2b8e} -noreset -displayfd 18
Jul 28 16:16:46 manjaro-arm sddm[3611]: Setting default cursor
Jul 28 16:16:46 manjaro-arm sddm[3611]: Running display setup script "/usr/share/sddm/scripts/Xsetup"
Jul 28 16:16:46 manjaro-arm sddm[3611]: Display server started.
Jul 28 16:16:46 manjaro-arm sddm[3611]: Socket server starting...
Jul 28 16:16:46 manjaro-arm sddm[3611]: Socket server started.
Jul 28 16:16:46 manjaro-arm sddm[3611]: The configured theme "matcha-dynamic-sddm" doesn't exist, using the embedded theme instead
Jul 28 16:16:46 manjaro-arm sddm[3611]: Loading theme configuration from ""
Jul 28 16:16:46 manjaro-arm sddm[3611]: Greeter starting...
Jul 28 16:16:46 manjaro-arm sddm-helper[4189]: [PAM] Starting...
Jul 28 16:16:46 manjaro-arm sddm-helper[4189]: [PAM] Authenticating...
Jul 28 16:16:46 manjaro-arm sddm-helper[4189]: [PAM] returning.
Jul 28 16:16:46 manjaro-arm sddm-helper[4189]: pam_unix(sddm-greeter:session): session opened for user sddm(uid=969) by (uid=0)
Jul 28 16:16:46 manjaro-arm systemd[1]: Created slice User Slice of UID 969.
Jul 28 16:16:46 manjaro-arm systemd[1]: Starting User Runtime Directory /run/user/969...
Jul 28 16:16:46 manjaro-arm systemd-logind[3513]: New session c3 of user sddm.
Jul 28 16:16:46 manjaro-arm systemd[1]: Finished User Runtime Directory /run/user/969.
Jul 28 16:16:46 manjaro-arm systemd[1]: Starting User Manager for UID 969...
Jul 28 16:16:46 manjaro-arm systemd[4194]: pam_systemd_home(systemd-user:account): Not a user managed by systemd-homed: No home for user sddm known
Jul 28 16:16:46 manjaro-arm systemd[4194]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[sddm] ruser=[<unknown>] rhost=[<unknown>]
Jul 28 16:16:46 manjaro-arm systemd[4194]: pam_unix(systemd-user:session): session opened for user sddm(uid=969) by (uid=0)
Jul 28 16:16:46 manjaro-arm systemd[4194]: pam_env(systemd-user:session): deprecated reading of user environment enabled
Jul 28 16:16:47 manjaro-arm systemd-xdg-autostart-generator[4203]: Configuration file /etc/xdg/autostart/org.kde.kclockd-autostart.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Jul 28 16:16:47 manjaro-arm systemd[4194]: Queued start job for default target Main User Target.
Jul 28 16:16:47 manjaro-arm systemd[4194]: Created slice User Application Slice.
Jul 28 16:16:47 manjaro-arm systemd[4194]: Reached target Paths.
Jul 28 16:16:47 manjaro-arm systemd[4194]: Reached target Timers.
Jul 28 16:16:47 manjaro-arm systemd[4194]: Starting D-Bus User Message Bus Socket...
Jul 28 16:16:47 manjaro-arm systemd[4194]: Listening on PipeWire Multimedia System Socket.
Jul 28 16:16:47 manjaro-arm systemd[4194]: Listening on Sound System.
Jul 28 16:16:47 manjaro-arm systemd[4194]: Listening on D-Bus User Message Bus Socket.
Jul 28 16:16:47 manjaro-arm systemd[4194]: Reached target Sockets.
Jul 28 16:16:47 manjaro-arm systemd[4194]: Reached target Basic System.
Jul 28 16:16:47 manjaro-arm systemd[1]: Started User Manager for UID 969.
Jul 28 16:16:47 manjaro-arm systemd[4194]: Starting Update XDG user dir configuration...
Jul 28 16:16:47 manjaro-arm systemd[1]: Started Session c3 of User sddm.
Jul 28 16:16:47 manjaro-arm systemd[4194]: Finished Update XDG user dir configuration.
Jul 28 16:16:47 manjaro-arm systemd[4194]: Reached target Main User Target.
Jul 28 16:16:47 manjaro-arm systemd[4194]: Startup finished in 593ms.
Jul 28 16:16:47 manjaro-arm sddm[3611]: Greeter session started successfully
Jul 28 16:16:47 manjaro-arm sddm-greeter[4207]: High-DPI autoscaling not Enabled
Jul 28 16:16:47 manjaro-arm sddm-greeter[4207]: Reading from "/usr/share/wayland-sessions/plasma-mobile.desktop"
Jul 28 16:16:47 manjaro-arm sddm-greeter[4207]: Reading from "/usr/share/wayland-sessions/plasmawayland.desktop"
Jul 28 16:16:47 manjaro-arm sddm-greeter[4207]: Reading from "/usr/share/xsessions/plasma.desktop"
Jul 28 16:16:47 manjaro-arm sddm-greeter[4207]: Loading theme configuration from "qrc:/theme/theme.conf"
Jul 28 16:16:47 manjaro-arm systemd[4194]: Created slice User Core Session Slice.
Jul 28 16:16:47 manjaro-arm systemd[4194]: Starting D-Bus User Message Bus...
Jul 28 16:16:47 manjaro-arm systemd[4194]: Started D-Bus User Message Bus.
Jul 28 16:16:47 manjaro-arm sddm-greeter[4207]: Connected to the daemon.
Jul 28 16:16:47 manjaro-arm sddm-greeter[4207]: QFont::fromString: Invalid description '(empty)'
Jul 28 16:16:47 manjaro-arm sddm[3611]: Message received from greeter: Connect
Jul 28 16:16:47 manjaro-arm sddm-greeter[4207]: Loading qrc:/theme/Main.qml...
Jul 28 16:16:48 manjaro-arm sddm-greeter[4207]: file:///usr/lib/qt/qml/SddmComponents/LayoutBox.qml:35:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Jul 28 16:16:48 manjaro-arm sddm-greeter[4207]: qrc:/theme/Main.qml:41:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Jul 28 16:16:48 manjaro-arm sddm-greeter[4207]: Adding view for "DSI-1" QRect(0,0 720x1440)
Jul 28 16:16:48 manjaro-arm sddm-greeter[4207]: Message received from daemon: Capabilities
Jul 28 16:16:48 manjaro-arm sddm-greeter[4207]: Message received from daemon: HostName
Runlevel-zero:
Recieved PPP today
Not quite sure when the last factory image was build for PPP, but i recommend using the Beta12 build.
Your PPP might be on the unstable branch and there are a couple of known issues with kwin that will make the phone unusable, even the PP. There is work put into it to fix things, but not there yet.
In case you want to use the PPP more often, you can flash Phosh
and keep Plamo on a SD card instead.
Thanks for the suggestions, and yes that does look like the issue I was seeing. I’ve also found that I may have been waking the screen before the routine to turn the screen off was complete which is also why I could repeat the issue so readily.
Having some patience has improved the situation considerably.
