so, microphone shows as “disconnected” (or another english equivalent) even though it’s connected and I can’t record or test any audio with it. Built-in mic works fine, but all my external mics won’t work
Edit: mic only works with that dongle that “forks” headphone signal and microphone into one (sorry I don’t know the name for that). If I only plug the external microphone into the 3.5mm jack without a headphone plugged in it doesn’t work. Isn’t there a way to use onboard audio to play stuff and then use the mic to record?
Edit2: I installed pavucontrol and I think it recognizes the microphone as a headphone, thus explaining why it shows “speakers” as “disconnected” when I try to use the mic. The answer is the software is recognizing an input device as an output device. Is there a way to change that, I mean, reverse it?
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=e5e15574-5804-4e04-aff5-1f17b25486b5 rw quiet apparmor=1
security=apparmor resume=UUID=0fdeb131-dde4-464b-91ca-8a7bea6b72d8
udev.log_priority=3
Desktop: KDE Plasma 5.20.5 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Laptop System: LENOVO product: 80JE v: Lenovo G40-80 serial: <filter>
Chassis: type: 10 v: Lenovo G40-80 serial: <filter>
Mobo: LENOVO model: Lancer 4A1 v: SDK0E50515 STD serial: <filter>
UEFI: LENOVO v: B0CN79WW date: 05/07/2015
ID-1: BAT0 charge: 28.3 Wh condition: 29.3/32.6 Wh (90%) volts: 16.3/14.8
model: Lenovo IdeaPad type: Unknown serial: <filter> status: Charging
RAM: total: 7.69 GiB used: 2.11 GiB (27.4%)
Info: Dual Core model: Intel Core i5-5200U bits: 64 type: MT MCP
arch: Broadwell family: 6 model-id: 3D (61) stepping: 4 microcode: 2F
L2 cache: 3 MiB bogomips: 17567
Speed: 1333 MHz min/max: 500/2700 MHz Core speeds (MHz): 1: 1333 2: 1335
3: 1333 4: 1342
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon avx
avx2 bmi1 bmi2 bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de
ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority flush_l1d
fma fpu fsgsbase fxsr ht ibpb ibrs ida intel_pt invpcid invpcid_single
lahf_lm lm mca mce md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx
pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36
pti pts rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2
tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt xtopology xtpr
Type: l1tf
Device-1: Intel HD Graphics 5500 vendor: Lenovo driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:1616
Device-2: AMD Sun LE [Radeon HD 8550M / R5 M230] vendor: Lenovo
driver: radeon v: kernel alternate: amdgpu bus ID: 04:00.0
chip ID: 1002:666f
Device-3: Acer Lenovo EasyCamera type: USB driver: uvcvideo bus ID: 1-6:4
chip ID: 5986:0652 serial: <filter>
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
loaded: ati,intel,radeon unloaded: modesetting alternate: fbdev,vesa
display ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 112 size: 310x170mm (12.2x6.7")
diag: 354mm (13.9")
OpenGL: renderer: Mesa Intel HD Graphics 5500 (BDW GT2) v: 4.6 Mesa 20.3.3
direct render: Yes
Device-1: Intel Broadwell-U Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus ID: 00:03.0 chip ID: 8086:160c
Device-2: Intel Wildcat Point-LP High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:9ca0
Sound Server: ALSA v: k5.9.16-1-MANJARO
vendor: Lenovo driver: r8169 v: kernel port: 4000 bus ID: 02:00.0
chip ID: 10ec:8168
Device-2: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
vendor: Lenovo driver: ath9k v: kernel port: 4000 bus ID: 03:00.0
chip ID: 168c:0036
Device-3: Qualcomm Atheros AR3012 Bluetooth 4.0 type: USB driver: btusb
bus ID: 1-7:6 chip ID: 0cf3:3004
Local Storage: total: 1.13 TiB used: 142.47 GiB (12.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Hikvision model: HS-SSD-C100 240G
size: 223.57 GiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: E1.3
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD10JPCX-24UE4T0
size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: 1A01
ID-1: / raw size: 214.47 GiB size: 210.11 GiB (97.96%)
used: 85.04 GiB (40.5%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: e5e15574-5804-4e04-aff5-1f17b25486b5
ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%)
used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 5374-C4D5
ID-3: /media/HD raw size: 931.51 GiB size: 915.89 GiB (98.32%)
used: 57.43 GiB (6.3%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: HD
uuid: bd614be2-63d9-42aa-b5d3-b0876fc354e6
Kernel: swappiness: 10 (default 60) cache pressure: 50 (default 100)
dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: 0fdeb131-dde4-464b-91ca-8a7bea6b72d8
Message: No Unmounted partitions found.
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 11 rev: 2.0
speed: 480 Mb/s chip ID: 1d6b:0002
Device-1: 1-3:2 info: Pixart Imaging Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
chip ID: 093a:2510
Device-2: 1-4:3 info: Realtek RTS5129 Card Reader Controller
interfaces: 1 rev: 2.0 speed: 480 Mb/s chip ID: 0bda:0129 serial: <filter>
Device-3: 1-6:4 info: Acer Lenovo EasyCamera type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s chip ID: 5986:0652 serial: <filter>
Device-4: 1-7:6 info: Qualcomm Atheros AR3012 Bluetooth 4.0 type: Bluetooth
driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s chip ID: 0cf3:3004
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
chip ID: 1d6b:0003
System Temperatures: cpu: 51.0 C mobo: N/A gpu: radeon temp: 44.0 C
Processes: 193 Uptime: 8m wakeups: 1 Init: systemd v: 247 Compilers:
gcc: 10.2.0 Packages: pacman: 1372 lib: 387 flatpak: 0 Shell: Bash v: 5.1.0
running in: konsole inxi: 3.2.02
