The files you mention are regenerated by a depmod (regenerate some cache according to modules) command which is issued after installing the kernel. There is nothing to be worried in your output.
You should add one, at the top: Learn to ask Google first.
No, seriously. That’s how you learn. By asking questions. And when you’ve learnt how to Google, it’s easy to put any worry to rest AND in the process you learn Linux. So, do that and the rest will follow.
Why do you want to use the VLC so badly? The thing has become a monster over the years. For example, it refused to quit completely for me. I had to kill it every time via task manager. For a little over 2 years I use only mpv. The does without grumbling. mpv for video and Audacious for audio. I look at VLC again and again at greater intervals, only to find that it’s still the same overrated mess. Just food for thought …
Not really, it’s just the one I’m used to. But, I’m open to anything. As long as the system does’nt freeze on me. VLC does that. I wanted to know why. I use Clementine now as an audio player. Works pretty good. Gives a system average load less than one…and in my book…that is a purring kitten
I remember a non-VLC player with tabs. Vaguely. But that is a long time ago…
